Hi Robert,
I tried to use the u-boot patch you mentionned but I still can’t see the eMMC cape.
I’m using the current ubuntu image : bone-ubuntu-14.04-console-armhf-2014-07-06-2gb
Here is my dmesg result. Do you see where the problem come from ?
Best regards,
Julien
dmesg
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Linux version 3.8.13-bone59 (root@imx6q-wandboard-2gb-0) (gcc version 4.8.2 (Ubuntu/Linaro 4.8.2-19ubuntu1) ) #1 SMP Sat Jul 5 02:59:43 UTC 2014
[ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=50c5387d
[ 0.000000] Machine: Generic AM33XX (Flattened Device Tree), model: TI AM335x BeagleBone
[ 0.000000] Memory policy: ECC disabled, Data cache writeback
[ 0.000000] On node 0 totalpages: 130816
[ 0.000000] free_area_init_node: node 0, pgdat c08a8e80, node_mem_map c0924000
[ 0.000000] Normal zone: 1024 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 129792 pages, LIFO batch:31
[ 0.000000] AM335X ES2.1 (l2cache sgx neon )
[ 0.000000] PERCPU: Embedded 9 pages/cpu @c0d34000 s14080 r8192 d14592 u36864
[ 0.000000] pcpu-alloc: s14080 r8192 d14592 u36864 alloc=9*4096
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 129792
[ 0.000000] Kernel command line: console=ttyO0,115200n8 root=/dev/mmcblk0p2 ro rootfstype=ext4 rootwait fixrtc quiet
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] __ex_table already sorted, skipping sort
[ 0.000000] allocated 1048576 bytes of page_cgroup
[ 0.000000] please try ‘cgroup_disable=memory’ option if you don’t want memory cgroups
[ 0.000000] Memory: 511MB = 511MB total
[ 0.000000] Memory: 505024k/505024k available, 19264k reserved, 0K highmem
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] vmalloc : 0xe0800000 - 0xff000000 ( 488 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xe0000000 ( 512 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf800000 - 0xbfe00000 ( 6 MB)
[ 0.000000] .text : 0xc0008000 - 0xc07e3b78 (8047 kB)
[ 0.000000] .init : 0xc07e4000 - 0xc0823700 ( 254 kB)
[ 0.000000] .data : 0xc0824000 - 0xc08abe40 ( 544 kB)
[ 0.000000] .bss : 0xc08abe40 - 0xc0923580 ( 478 kB)
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=1.
[ 0.000000] NR_IRQS:0 nr_irqs:0 0
[ 0.000000] Total of 128 interrupts on 1 active controller
[ 0.000000] OMAP clockevent source: GPTIMER1 at 26000000 Hz
[ 0.000000] sched_clock: 32 bits at 26MHz, resolution 38ns, wraps every 165191ms
[ 0.000000] OMAP clocksource: GPTIMER2 at 26000000 Hz
[ 0.000000] Console: colour dummy device 80x30
[ 0.000215] Calibrating delay loop… 1077.49 BogoMIPS (lpj=1051648)
[ 0.029198] pid_max: default: 32768 minimum: 301
[ 0.029321] Security Framework initialized
[ 0.029373] Mount-cache hash table entries: 512
[ 0.034711] Initializing cgroup subsys cpuacct
[ 0.034734] Initializing cgroup subsys memory
[ 0.034770] Initializing cgroup subsys blkio
[ 0.034852] CPU: Testing write buffer coherency: ok
[ 0.035239] CPU0: thread -1, cpu 0, socket -1, mpidr 0
[ 0.035287] Setting up static identity map for 0x804c96f8 - 0x804c9744
[ 0.036115] Brought up 1 CPUs
[ 0.036128] SMP: Total of 1 processors activated (1077.49 BogoMIPS).
[ 0.036778] devtmpfs: initialized
[ 0.044759] omap_hwmod: wd_timer2: _wait_target_disable failed
[ 0.095846] pinctrl core: initialized pinctrl subsystem
[ 0.095971] rstctl core: initialized rstctl subsystem
[ 0.096236] regulator-dummy: no parameters
[ 0.096530] NET: Registered protocol family 16
[ 0.097013] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.102145] pinctrl-single 44e10800.pinmux: 142 pins at pa f9e10800 size 568
[ 0.102639] platform 49000000.edma: alias fck already exists
[ 0.102655] platform 49000000.edma: alias fck already exists
[ 0.102667] platform 49000000.edma: alias fck already exists
[ 0.103203] gpiochip_add: registered GPIOs 0 to 31 on device: gpio
[ 0.103290] OMAP GPIO hardware version 0.1
[ 0.104080] gpiochip_add: registered GPIOs 32 to 63 on device: gpio
[ 0.104693] gpiochip_add: registered GPIOs 64 to 95 on device: gpio
[ 0.105318] gpiochip_add: registered GPIOs 96 to 127 on device: gpio
[ 0.105587] of_get_named_gpio_flags exited with status 52
[ 0.105602] gpio-rctrl rstctl.4: loaded OK
[ 0.108379] hw-breakpoint: debug architecture 0x4 unsupported.
[ 0.109533] cpsw.0: No hwaddr in dt. Using d0:ff:50:eb:f4:c7 from efuse
[ 0.109551] cpsw.1: No hwaddr in dt. Using d0:ff:50:eb:f4:c9 from efuse
[ 0.116814] bio: create slab at 0
[ 0.122525] edma-dma-engine edma-dma-engine.0: TI EDMA DMA engine driver
[ 0.122657] of_get_named_gpio_flags: can’t parse gpios property
[ 0.122767] vmmcsd_fixed: 3300 mV
[ 0.124153] SCSI subsystem initialized
[ 0.124363] usbcore: registered new interface driver usbfs
[ 0.124418] usbcore: registered new interface driver hub
[ 0.124591] usbcore: registered new device driver usb
[ 0.125698] omap_i2c 44e0b000.i2c: bus 0 rev0.11 at 400 kHz
[ 0.126525] input: tps65217_pwr_but as /devices/ocp.3/44e0b000.i2c/i2c-0/0-0024/input/input0
[ 0.127990] DCDC1: at 1500 mV
[ 0.128743] vdd_mpu: 925 <–> 1325 mV at 1325 mV
[ 0.129508] vdd_core: 925 <–> 1150 mV at 1125 mV
[ 0.130238] LDO1: at 1800 mV
[ 0.130990] LDO2: at 3300 mV
[ 0.132348] LDO3: 1800 mV
[ 0.133116] LDO4: at 3300 mV
[ 0.133767] tps65217 0-0024: TPS65217 ID 0xe version 1.2
[ 0.134165] omap_i2c 44e0b000.i2c: unable to select pin group
[ 0.134578] omap_i2c 4819c000.i2c: bus 1 rev0.11 at 100 kHz
[ 0.135834] omap_i2c 4819c000.i2c: unable to select pin group
[ 0.135960] media: Linux media interface: v0.10
[ 0.136020] Linux video capture interface: v2.00
[ 0.136087] pps_core: LinuxPPS API ver. 1 registered
[ 0.136452] Advanced Linux Sound Architecture Driver Initialized.
[ 0.137038] NetLabel: Initializing
[ 0.137049] NetLabel: domain hash size = 128
[ 0.137054] NetLabel: protocols = UNLABELED CIPSOv4
[ 0.137113] NetLabel: unlabeled traffic allowed by default
[ 0.137280] Switching to clocksource gp_timer
[ 0.165101] NET: Registered protocol family 2
[ 0.165676] TCP established hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.165751] TCP bind hash table entries: 4096 (order: 4, 81920 bytes)
[ 0.165834] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.165893] TCP: reno registered
[ 0.165906] UDP hash table entries: 256 (order: 1, 12288 bytes)
[ 0.165929] UDP-Lite hash table entries: 256 (order: 1, 12288 bytes)
[ 0.166146] NET: Registered protocol family 1
[ 0.166502] RPC: Registered named UNIX socket transport module.
[ 0.166512] RPC: Registered udp transport module.
[ 0.166519] RPC: Registered tcp transport module.
[ 0.166525] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.166820] Trying to unpack rootfs image as initramfs…
[ 0.355994] Freeing initrd memory: 3224K
[ 0.356307] hw perfevents: enabled with ARMv7 Cortex-A8 PMU driver, 5 counters available
[ 0.356533] CPU PMU: attempt to register multiple PMU devices!
[ 0.356558] arm-pmu: probe of arm-pmu failed with error -28
[ 0.356852] omap2_mbox_probe: platform not supported
[ 0.497111] VFS: Disk quotas dquot_6.5.2
[ 0.497241] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.497883] NFS: Registering the id_resolver key type
[ 0.497947] Key type id_resolver registered
[ 0.497956] Key type id_legacy registered
[ 0.498203] fuse init (API version 7.20)
[ 0.498554] Btrfs loaded
[ 0.498712] msgmni has been set to 992
[ 0.500141] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[ 0.500156] io scheduler noop registered
[ 0.500164] io scheduler deadline registered
[ 0.500184] io scheduler cfq registered (default)
[ 0.501217] tps65217-bl tps65217-bl: no platform data provided
[ 0.501239] tps65217-bl: probe of tps65217-bl failed with error -22
[ 0.501694] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.502893] omap_uart 44e09000.serial: did not get pins for uart0 error: -19
[ 0.503148] 44e09000.serial: ttyO0 at MMIO 0x44e09000 (irq = 72) is a OMAP UART0
[ 0.514015] console [ttyO0] enabled
[ 0.514616] [drm] Initialized drm 1.1.0 20060810
[ 0.521183] brd: module loaded
[ 0.524583] loop: module loaded
[ 0.524656] at24 0-0050: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 0.524695] at24 1-0054: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 0.524727] at24 1-0055: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 0.524760] at24 1-0056: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 0.524792] at24 1-0057: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 0.555322] bone-capemgr bone_capemgr.9: bone: scan failed (1 time)
[ 1.088517] bone-capemgr bone_capemgr.9: bone: scan failed (2 time)
[ 1.621719] bone-capemgr bone_capemgr.9: bone: scan failed (3 time)
[ 2.154926] bone-capemgr bone_capemgr.9: bone: scan failed (4 time)
[ 2.688125] bone-capemgr bone_capemgr.9: bone: scan failed (5 time)
[ 3.221328] bone-capemgr bone_capemgr.9: bone: scan failed (6 time)
[ 3.754531] bone-capemgr bone_capemgr.9: bone: scan failed (7 time)
[ 4.287736] bone-capemgr bone_capemgr.9: bone: scan failed (8 time)
[ 4.820938] bone-capemgr bone_capemgr.9: bone: scan failed (9 time)
[ 5.354141] bone-capemgr bone_capemgr.9: bone: scan failed (10 time)
[ 5.856100] bone-capemgr bone_capemgr.9: Failed to scan baseboard eeprom
[ 5.862586] bone-capemgr: probe of bone_capemgr.9 failed with error -110
[ 5.864156] OneNAND driver initializing
[ 5.864903] usbcore: registered new interface driver cdc_ether
[ 5.864948] usbcore: registered new interface driver rndis_host
[ 5.865039] usbcore: registered new interface driver cdc_ncm
[ 5.865454] usbcore: registered new interface driver cdc_acm
[ 5.865464] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 5.865471] Initializing USB Mass Storage driver…
[ 5.865540] usbcore: registered new interface driver usb-storage
[ 5.865547] USB Mass Storage support registered.
[ 5.865639] musb-hdrc: version 6.0, ?dma?, otg (peripheral+host)
[ 5.865903] musb-hdrc musb-hdrc.0.auto: pdev->id = 0
[ 5.865918] musb-hdrc musb-hdrc.0.auto: drivers/usb/musb/musb_dsps.c:468 dsps_musb_init: OK
[ 5.865940] musb-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, bulk combine, bulk split, HB-ISO Rx, HB-ISO Tx, SoftConn)
[ 5.865950] musb-hdrc: MHDRC RTL version 2.0
[ 5.865957] musb-hdrc: setup fifo_mode 4
[ 5.865971] musb-hdrc: 28/31 max ep, 16384/16384 memory
[ 5.866049] musb-hdrc musb-hdrc.0.auto: *** mode=3
[ 5.866058] musb-hdrc musb-hdrc.0.auto: *** power=250
[ 5.866458] musb-hdrc musb-hdrc.1.auto: pdev->id = 1
[ 5.866472] musb-hdrc musb-hdrc.1.auto: drivers/usb/musb/musb_dsps.c:468 dsps_musb_init: OK
[ 5.866492] musb-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, bulk combine, bulk split, HB-ISO Rx, HB-ISO Tx, SoftConn)
[ 5.866500] musb-hdrc: MHDRC RTL version 2.0
[ 5.866506] musb-hdrc: setup fifo_mode 4
[ 5.866516] musb-hdrc: 28/31 max ep, 16384/16384 memory
[ 5.866581] musb-hdrc musb-hdrc.1.auto: *** mode=1
[ 5.866591] musb-hdrc musb-hdrc.1.auto: *** power=250
[ 5.866600] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[ 5.866797] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 1
[ 5.866819] musb-hdrc musb-hdrc.1.auto: supports USB remote wakeup
[ 5.866879] usb usb1: default language 0x0409
[ 5.866907] usb usb1: udev 1, busnum 1, minor = 0
[ 5.866918] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 5.866928] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 5.866937] usb usb1: Product: MUSB HDRC host driver
[ 5.866945] usb usb1: Manufacturer: Linux 3.8.13-bone59 musb-hcd
[ 5.866954] usb usb1: SerialNumber: musb-hdrc.1.auto
[ 5.867344] usb usb1: usb_probe_device
[ 5.867358] usb usb1: configuration #1 chosen from 1 choice
[ 5.867395] usb usb1: adding 1-0:1.0 (config #1, interface 0)
[ 5.867495] hub 1-0:1.0: usb_probe_interface
[ 5.867506] hub 1-0:1.0: usb_probe_interface - got id
[ 5.867520] hub 1-0:1.0: USB hub found
[ 5.867540] hub 1-0:1.0: 1 port detected
[ 5.867549] hub 1-0:1.0: standalone hub
[ 5.867557] hub 1-0:1.0: individual port power switching
[ 5.867566] hub 1-0:1.0: no over-current protection
[ 5.867574] hub 1-0:1.0: Single TT
[ 5.867583] hub 1-0:1.0: TT requires at most 8 FS bit times (666 ns)
[ 5.867591] hub 1-0:1.0: power on to power good time: 10ms
[ 5.867612] hub 1-0:1.0: local power source is good
[ 5.867663] hub 1-0:1.0: enabling power on all ports
[ 5.868267] mousedev: PS/2 mouse device common for all mice
[ 5.869562] omap_rtc 44e3e000.rtc: rtc core: registered 44e3e000.rtc as rtc0
[ 5.869723] i2c /dev entries driver
[ 5.870669] pps_ldisc: PPS line discipline registered
[ 5.870743] Driver for 1-wire Dallas network protocol.
[ 5.871838] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[ 5.872198] device-mapper: ioctl: 4.23.1-ioctl (2012-12-18) initialised: dm-devel@redhat.com
[ 5.872230] cpuidle: using governor ladder
[ 5.872238] cpuidle: using governor menu
[ 5.872460] of_get_named_gpio_flags exited with status 6
[ 5.872470] of_get_named_gpio_flags: can’t parse gpios property
[ 5.872477] of_get_named_gpio_flags: can’t parse gpios property
[ 5.872496] omap_hsmmc mmc.5: of_parse_phandle_with_args of ‘reset’ failed
[ 5.879163] omap_hsmmc mmc.5: Failed to get rstctl; not using any
[ 5.879448] edma-dma-engine edma-dma-engine.0: allocated channel for 0:25
[ 5.879490] edma-dma-engine edma-dma-engine.0: allocated channel for 0:24
[ 5.879711] mmc.5 supply vmmc_aux not found, using dummy regulator
[ 5.879993] omap_hsmmc mmc.5: pins are not configured from the driver
[ 5.907184] pinctrl-single 44e10800.pinmux: pin 44e10854 already requested by 44e10800.pinmux; cannot claim for gpio-leds.8
[ 5.917977] pinctrl-single 44e10800.pinmux: pin-21 (gpio-leds.8) status -22
[ 5.924686] pinctrl-single 44e10800.pinmux: could not request pin 21 on device pinctrl-single
[ 5.932923] leds-gpio gpio-leds.8: pins are not configured from the driver
[ 5.932944] of_get_named_gpio_flags exited with status 53
[ 5.932954] of_get_named_gpio_flags exited with status 54
[ 5.932963] of_get_named_gpio_flags exited with status 55
[ 5.932972] of_get_named_gpio_flags exited with status 56
[ 5.932983] of_get_named_gpio_flags exited with status 53
[ 5.933144] of_get_named_gpio_flags exited with status 54
[ 5.933288] of_get_named_gpio_flags exited with status 55
[ 5.933377] of_get_named_gpio_flags exited with status 56
[ 5.933662] ledtrig-cpu: registered to indicate activity on CPUs
[ 5.933888] edma-dma-engine edma-dma-engine.0: allocated channel for 0:36
[ 5.933933] omap-sham 53100000.sham: hw accel on OMAP rev 4.3
[ 5.935133] omap-aes 53500000.aes: OMAP AES hw accel rev: 3.2
[ 5.935204] edma-dma-engine edma-dma-engine.0: allocated channel for 0:5
[ 5.935240] edma-dma-engine edma-dma-engine.0: allocated channel for 0:6
[ 5.937750] usbcore: registered new interface driver usbhid
[ 5.937763] usbhid: USB HID core driver
[ 5.938628] ashmem: initialized
[ 5.938815] logger: created 256K log ‘log_main’
[ 5.938986] logger: created 256K log ‘log_events’
[ 5.939140] logger: created 256K log ‘log_radio’
[ 5.939295] logger: created 256K log ‘log_system’
[ 5.941057] TCP: cubic registered
[ 5.941134] NET: Registered protocol family 10
[ 5.941827] NET: Registered protocol family 17
[ 5.942179] Key type dns_resolver registered
[ 5.942329] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[ 5.942351] ThumbEE CPU extension supported.
[ 5.942379] Registering SWP/SWPB emulation handler
[ 5.942942] registered taskstats version 1
[ 5.967490] hub 1-0:1.0: state 7 ports 1 chg 0000 evt 0000
[ 5.967537] hub 1-0:1.0: hub_suspend
[ 5.967560] usb usb1: bus auto-suspend, wakeup 1
[ 5.990222] mmc0: host does not support reading read-only switch. assuming write-enable.
[ 5.990861] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6
[ 5.990872] davinci_mdio 4a101000.mdio: detected phy mask fffffffe
[ 5.992108] mmc0: new high speed SDHC card at address 1234
[ 5.994910] mmcblk0: mmc0:1234 SA16G 14.6 GiB
[ 5.996619] mmcblk0: p1 p2
[ 5.998967] libphy: 4a101000.mdio: probed
[ 5.998991] davinci_mdio 4a101000.mdio: phy[0]: device 4a101000.mdio:00, driver SMSC LAN8710/LAN8720
[ 5.999145] Detected MACID = d0:ff:50:eb:f4:c7
[ 5.999245] cpsw 4a100000.ethernet: NAPI disabled
[ 6.000192] omap_rtc 44e3e000.rtc: setting system clock to 2000-01-01 00:00:00 UTC (946684800)
[ 6.006328] ALSA device list:
[ 6.006350] No soundcards found.
[ 6.007026] Freeing init memory: 252K
[ 6.086805] systemd-udevd[96]: starting version 204
[ 7.716228] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 8.397593] init: plymouth-upstart-bridge main process (151) terminated with status 1
[ 8.397673] init: plymouth-upstart-bridge main process ended, respawning
[ 8.489076] init: plymouth-upstart-bridge main process (161) terminated with status 1
[ 8.489159] init: plymouth-upstart-bridge main process ended, respawning
[ 8.554676] init: plymouth-upstart-bridge main process (164) terminated with status 1
[ 8.554749] init: plymouth-upstart-bridge main process ended, respawning
[ 8.557001] init: ureadahead main process (154) terminated with status 5
[ 10.730381] EXT4-fs (mmcblk0p2): re-mounted. Opts: errors=remount-ro
[ 13.119106] systemd-udevd[296]: starting version 204
[ 15.911971] init: avahi-cups-reload main process (385) terminated with status 1
[ 16.073022] net eth0: initializing cpsw version 1.12 (0)
[ 16.076064] net eth0: phy found : id is : 0x7c0f1
[ 16.076095] libphy: PHY 4a101000.mdio:01 not found
[ 16.080789] net eth0: phy 4a101000.mdio:01 not found on slave 1
[ 16.114642] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 17.683245] init: udev-fallback-graphics main process (465) terminated with status 1
[ 27.169984] init: plymouth-upstart-bridge main process ended, respawning
[ 60.649487] gadget: using random self ethernet address
[ 60.656050] usb0: MAC e6:f7:2c:27:dc:2e
[ 60.656092] usb0: HOST MAC d0:ff:50:eb:f4:c9
[ 60.671243] gadget: Mass Storage Function, version: 2009/09/11
[ 60.671290] gadget: Number of LUNs=1
[ 60.671345] lun0: LUN: removable file: /dev/mmcblk0p1
[ 60.671539] gadget: Multifunction Composite Gadget
[ 60.671602] gadget: g_multi ready
[ 60.671680] musb-hdrc musb-hdrc.0.auto: MUSB HDRC host driver
[ 60.672632] musb-hdrc musb-hdrc.0.auto: new USB bus registered, assigned bus number 2
[ 60.674002] musb-hdrc musb-hdrc.0.auto: supports USB remote wakeup
[ 60.674171] usb usb2: default language 0x0409
[ 60.674263] usb usb2: udev 1, busnum 2, minor = 128
[ 60.674299] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 60.674334] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 60.674365] usb usb2: Product: MUSB HDRC host driver
[ 60.674397] usb usb2: Manufacturer: Linux 3.8.13-bone59 musb-hcd
[ 60.674427] usb usb2: SerialNumber: musb-hdrc.0.auto
[ 60.677140] usb usb2: usb_probe_device
[ 60.677188] usb usb2: configuration #1 chosen from 1 choice
[ 60.677302] usb usb2: adding 2-0:1.0 (config #1, interface 0)
[ 60.677669] hub 2-0:1.0: usb_probe_interface
[ 60.677704] hub 2-0:1.0: usb_probe_interface - got id
[ 60.677753] hub 2-0:1.0: USB hub found
[ 60.677814] hub 2-0:1.0: 1 port detected
[ 60.677844] hub 2-0:1.0: standalone hub
[ 60.677871] hub 2-0:1.0: individual port power switching
[ 60.677900] hub 2-0:1.0: no over-current protection
[ 60.677927] hub 2-0:1.0: Single TT
[ 60.677958] hub 2-0:1.0: TT requires at most 8 FS bit times (666 ns)
[ 60.677987] hub 2-0:1.0: power on to power good time: 10ms
[ 60.678051] hub 2-0:1.0: local power source is good
[ 60.678222] hub 2-0:1.0: enabling power on all ports
[ 60.778161] hub 2-0:1.0: state 7 ports 1 chg 0000 evt 0000
[ 60.778217] hub 2-0:1.0: hub_suspend
[ 60.778244] usb usb2: bus auto-suspend, wakeup 1
[ 63.683164] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
ubuntu@arm:/$
