I seem to be mixed up. I thought I was booting, and of course after booting a version of Yocto, a beagleboard.org image that the .org produced.
Anyway, here is some ideas in case people know about what I have come across…
[tio 20:58:22] tio v1.32
[tio 20:58:22] Press ctrl-t q to quit
[tio 20:58:22] Connected
U-Boot SPL 2021.01-gc21ddbdf (Nov 28 2022 - 15:42:44 +0000)
Model: BeagleBoard.org BeagleBone AI-64 R5
EEPROM not available at 0x50, trying to read at 0x51
Board: BBONEAI-64-B0- rev B0
SYSFW ABI: 3.1 (firmware rev 0x0015 '21.9.1--v2021.09a (Terrific Lla')
Trying to boot from MMC1
init_env from device 17 not supported!
Starting ATF on ARM64 core...
NOTICE: BL31: v2.5(release):0588523
NOTICE: BL31: Built : 17:13:47, Feb 16 2023
U-Boot SPL 2021.01-gea96725b (Feb 16 2023 - 17:13:47 +0000)
Model: Texas Instruments K3 J721E SoC
ti_i2c_eeprom_am6_parse_record: Ignoring record id 17
U-Boot 2021.01-gea96725b (Feb 16 2023 - 17:13:47 +0000)
SoC: J721E SR1.1 GP
DRAM: 4 GiB
Flash: 0 Bytes
MMC: sdhci@4f80000: 0, sdhci@4fb0000: 1
Loading Environment from FAT... *** Warning - bad CRC, using default environment
In: serial@2800000
Out: serial@2800000
Err: serial@2800000
am65_cpsw_nuss ethernet@46000000: K3 CPSW: nuss_ver: 0x6BA00101 cpsw_ver: 0x6BA80100 ale_ver: 0x00293904 Ports:1 mdio_freq:1000000
Net: eth0: ethernet@46000000port@1
Press SPACE to abort autoboot in 2 seconds
board_name=[BBONEAI-64-B0-] ...
name_fdt=[k3-j721e-beagleboneai64.dtb] ...
i2c_write: error waiting for data ACK (status=0x116)
pca953x gpio@22: Error reading output register
switch to partitions #0, OK
mmc1 is current device
Scanning mmc 1:1...
Found /extlinux/extlinux.conf
Retrieving file: /extlinux/extlinux.conf
705 bytes read in 9 ms (76.2 KiB/s)
BeagleBone AI-64 microSD (extlinux.conf) Options
1: BeagleBone AI-64 microSD Recovery
2: BeagleBone AI-64 copy microSD to eMMC
3: BeagleBone AI-64 microSD (default)
Enter choice: 3
Retrieving file: /initrd.img
9584911 bytes read in 414 ms (22.1 MiB/s)
Retrieving file: /Image
29485568 bytes read in 1253 ms (22.4 MiB/s)
append: root=/dev/mmcblk1p2 ro rootfstype=ext4 rootwait net.ifnames=0 quiet
Retrieving file: /k3-j721e-beagleboneai64.dtb
226922 bytes read in 19 ms (11.4 MiB/s)
## Flattened Device Tree blob at 88000000
Loading Ramdisk to 8f6db000, end 8ffff10f ... OK
Loading Device Tree to 000000008f6a0000, end 000000008f6da669 ... OK
Starting kernel ...
[ 0.660406] debugfs: Directory '31010000.pat' with parent 'regmap' already present!
[ 0.660606] debugfs: Directory '31011000.pat' with parent 'regmap' already present!
[ 0.660765] debugfs: Directory '31012000.pat' with parent 'regmap' already present!
[ 0.660889] debugfs: Directory '31013000.pat' with parent 'regmap' already present!
[ 0.661034] debugfs: Directory '31014000.pat' with parent 'regmap' already present!
[ 1.189833] am65-cpsw-nuss c000000.ethernet: /bus@100000/ethernet@c000000/ethernet-ports/port@1 error retrieving port phy: -19
[ 2.305653] usb usb1-port1: Cannot enable. Maybe the USB cable is bad?
[ 3.109725] debugfs: Directory 'pd:27' with parent 'pm_genpd' already present!
[ 3.116975] debugfs: Directory 'pd:26' with parent 'pm_genpd' already present!
[ 3.125504] debugfs: Directory 'pd:242' with parent 'pm_genpd' already present!
[ 3.132824] debugfs: Directory 'pd:241' with parent 'pm_genpd' already present!
[ 3.140162] debugfs: Directory 'pd:240' with parent 'pm_genpd' already present!
[ 3.147478] debugfs: Directory 'pd:239' with parent 'pm_genpd' already present!
[ 3.277672] usb usb1-port1: Cannot enable. Maybe the USB cable is bad?
[ 4.225225] mmc1: Got data interrupt 0x00000002 even though no data operation was in progress.
[ 4.233832] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
[ 4.240255] mmc1: sdhci: Sys addr: 0x00000008 | Version: 0x00001004
[ 4.246678] mmc1: sdhci: Blk size: 0x00007200 | Blk cnt: 0x00000007
[ 4.253101] mmc1: sdhci: Argument: 0x00000000 | Trn mode: 0x00000033
[ 4.259524] mmc1: sdhci: Present: 0x01f70000 | Host ctl: 0x0000001f
[ 4.265945] mmc1: sdhci: Power: 0x0000000f | Blk gap: 0x00000080
[ 4.272367] mmc1: sdhci: Wake-up: 0x00000000 | Clock: 0x00000207
[ 4.278789] mmc1: sdhci: Timeout: 0x00000000 | Int stat: 0x00000000
[ 4.285211] mmc1: sdhci: Int enab: 0x03ff008b | Sig enab: 0x03ff008b
[ 4.291632] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[ 4.298054] mmc1: sdhci: Caps: 0x3fe8c801 | Caps_1: 0x18002407
[ 4.304476] mmc1: sdhci: Cmd: 0x00000c1a | Max curr: 0x00000000
[ 4.310897] mmc1: sdhci: Resp[0]: 0x00000b00 | Resp[1]: 0x00e7177f
[ 4.317319] mmc1: sdhci: Resp[2]: 0x325b5900 | Resp[3]: 0x00000900
[ 4.323740] mmc1: sdhci: Host ctl2: 0x0000000c
[ 4.328168] mmc1: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x0000000894f4320c
[ 4.335283] mmc1: sdhci: ============================================
[ 4.344587] mmc1: Got data interrupt 0x00000002 even though no data operation was in progress.
[ 4.353190] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
[ 4.359611] mmc1: sdhci: Sys addr: 0x00000008 | Version: 0x00001004
[ 4.366033] mmc1: sdhci: Blk size: 0x00007200 | Blk cnt: 0x00000007
[ 4.372455] mmc1: sdhci: Argument: 0x00000000 | Trn mode: 0x00000033
[ 4.378877] mmc1: sdhci: Present: 0x01f70000 | Host ctl: 0x0000001e
[ 4.385298] mmc1: sdhci: Power: 0x0000000f | Blk gap: 0x00000080
[ 4.391720] mmc1: sdhci: Wake-up: 0x00000000 | Clock: 0x00000207
[ 4.398141] mmc1: sdhci: Timeout: 0x00000000 | Int stat: 0x00000000
[ 4.404563] mmc1: sdhci: Int enab: 0x03ff008b | Sig enab: 0x03ff008b
[ 4.410985] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[ 4.417406] mmc1: sdhci: Caps: 0x3fe8c801 | Caps_1: 0x18002407
[ 4.423828] mmc1: sdhci: Cmd: 0x00000c1a | Max curr: 0x00000000
[ 4.430250] mmc1: sdhci: Resp[0]: 0x00000b00 | Resp[1]: 0x00e7177f
[ 4.436671] mmc1: sdhci: Resp[2]: 0x325b5900 | Resp[3]: 0x00000900
[ 4.443092] mmc1: sdhci: Host ctl2: 0x0000000c
[ 4.447521] mmc1: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x0000000894f4320c
[ 4.454637] mmc1: sdhci: ============================================
[ 4.461201] usb usb1-port1: Cannot enable. Maybe the USB cable is bad?
[ 4.615617] blk_update_request: I/O error, dev mmcblk1, sector 0 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[ 4.628483] blk_update_request: I/O error, dev mmcblk1, sector 1 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[ 4.641419] blk_update_request: I/O error, dev mmcblk1, sector 2 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[ 4.654351] blk_update_request: I/O error, dev mmcblk1, sector 3 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[ 4.667312] blk_update_request: I/O error, dev mmcblk1, sector 4 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[ 4.680237] blk_update_request: I/O error, dev mmcblk1, sector 5 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[ 4.693112] blk_update_request: I/O error, dev mmcblk1, sector 6 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[ 4.705963] blk_update_request: I/O error, dev mmcblk1, sector 7 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[ 4.716153] Buffer I/O error on dev mmcblk1, logical block 0, async page read
[ 4.724173] mmc1: Got data interrupt 0x00000002 even though no data operation was in progress.
[ 4.732779] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
[ 4.739206] mmc1: sdhci: Sys addr: 0x00000008 | Version: 0x00001004
[ 4.745629] mmc1: sdhci: Blk size: 0x00007200 | Blk cnt: 0x00000007
[ 4.752051] mmc1: sdhci: Argument: 0x00000000 | Trn mode: 0x00000033
[ 4.758473] mmc1: sdhci: Present: 0x01f70000 | Host ctl: 0x0000001f
[ 4.764894] mmc1: sdhci: Power: 0x0000000f | Blk gap: 0x00000080
[ 4.771316] mmc1: sdhci: Wake-up: 0x00000000 | Clock: 0x00000207
[ 4.777737] mmc1: sdhci: Timeout: 0x00000000 | Int stat: 0x00000001
[ 4.784160] mmc1: sdhci: Int enab: 0x03ff008b | Sig enab: 0x03ff008b
[ 4.790581] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000001
[ 4.797005] mmc1: sdhci: Caps: 0x3fe8c801 | Caps_1: 0x18002407
[ 4.803426] mmc1: sdhci: Cmd: 0x00000c1a | Max curr: 0x00000000
[ 4.809848] mmc1: sdhci: Resp[0]: 0x00000b00 | Resp[1]: 0x47606cc0
[ 4.816270] mmc1: sdhci: Resp[2]: 0x53443332 | Resp[3]: 0x00000900
[ 4.822691] mmc1: sdhci: Host ctl2: 0x0000000c
[ 4.827120] mmc1: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x0000000894f4320c
[ 4.834236] mmc1: sdhci: ============================================
[ 4.843411] mmc1: Got data interrupt 0x00000002 even though no data operation was in progress.
[ 4.852013] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
[ 4.858435] mmc1: sdhci: Sys addr: 0x00000008 | Version: 0x00001004
[ 4.864858] mmc1: sdhci: Blk size: 0x00007200 | Blk cnt: 0x00000007
[ 4.871280] mmc1: sdhci: Argument: 0x00000000 | Trn mode: 0x00000033
[ 4.877701] mmc1: sdhci: Present: 0x01f70000 | Host ctl: 0x0000001e
[ 4.884123] mmc1: sdhci: Power: 0x0000000f | Blk gap: 0x00000080
[ 4.890545] mmc1: sdhci: Wake-up: 0x00000000 | Clock: 0x00000207
[ 4.896968] mmc1: sdhci: Timeout: 0x00000000 | Int stat: 0x00000000
[ 4.903390] mmc1: sdhci: Int enab: 0x03ff008b | Sig enab: 0x03ff008b
[ 4.909811] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[ 4.916233] mmc1: sdhci: Caps: 0x3fe8c801 | Caps_1: 0x18002407
[ 4.922654] mmc1: sdhci: Cmd: 0x00000c1a | Max curr: 0x00000000
[ 4.929076] mmc1: sdhci: Resp[0]: 0x00000b00 | Resp[1]: 0x47606cc0
[ 4.935499] mmc1: sdhci: Resp[2]: 0x53443332 | Resp[3]: 0x00000900
[ 4.941921] mmc1: sdhci: Host ctl2: 0x0000000c
[ 4.946350] mmc1: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x0000000894f4320c
[ 4.953465] mmc1: sdhci: ============================================
[ 4.964257] blk_update_request: I/O error, dev mmcblk1, sector 0 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[ 4.976941] blk_update_request: I/O error, dev mmcblk1, sector 1 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[ 4.999281] Buffer I/O error on dev mmcblk1, logical block 0, async page read
[ 5.007364] mmc1: Got data interrupt 0x00000002 even though no data operation was in progress.
[ 5.015968] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
[ 5.022394] mmc1: sdhci: Sys addr: 0x00000008 | Version: 0x00001004
[ 5.028818] mmc1: sdhci: Blk size: 0x00007200 | Blk cnt: 0x00000007
[ 5.035242] mmc1: sdhci: Argument: 0x00000000 | Trn mode: 0x00000033
[ 5.041666] mmc1: sdhci: Present: 0x01f70000 | Host ctl: 0x0000001f
[ 5.048091] mmc1: sdhci: Power: 0x0000000f | Blk gap: 0x00000080
[ 5.054517] mmc1: sdhci: Wake-up: 0x00000000 | Clock: 0x00000207
[ 5.060941] mmc1: sdhci: Timeout: 0x00000000 | Int stat: 0x00000000
[ 5.067367] mmc1: sdhci: Int enab: 0x03ff008b | Sig enab: 0x03ff008b
[ 5.073791] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[ 5.080215] mmc1: sdhci: Caps: 0x3fe8c801 | Caps_1: 0x18002407
[ 5.086640] mmc1: sdhci: Cmd: 0x00000c1a | Max curr: 0x00000000
[ 5.093065] mmc1: sdhci: Resp[0]: 0x00000b00 | Resp[1]: 0x47606cc0
[ 5.099490] mmc1: sdhci: Resp[2]: 0x53443332 | Resp[3]: 0x00000900
[ 5.105913] mmc1: sdhci: Host ctl2: 0x0000000c
[ 5.110344] mmc1: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x0000000894f4320c
[ 5.117464] mmc1: sdhci: ============================================
[ 5.213809] mmc1: Got data interrupt 0x00000002 even though no data operation was in progress.
[ 5.222420] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
[ 5.228844] mmc1: sdhci: Sys addr: 0x00000008 | Version: 0x00001004
[ 5.235266] mmc1: sdhci: Blk size: 0x00007200 | Blk cnt: 0x00000007
[ 5.241688] mmc1: sdhci: Argument: 0x00000000 | Trn mode: 0x00000033
[ 5.248110] mmc1: sdhci: Present: 0x01f70000 | Host ctl: 0x0000001e
[ 5.254531] mmc1: sdhci: Power: 0x0000000f | Blk gap: 0x00000080
[ 5.260953] mmc1: sdhci: Wake-up: 0x00000000 | Clock: 0x00000207
[ 5.267375] mmc1: sdhci: Timeout: 0x00000000 | Int stat: 0x00000000
[ 5.273797] mmc1: sdhci: Int enab: 0x03ff008b | Sig enab: 0x03ff008b
[ 5.280218] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[ 5.286640] mmc1: sdhci: Caps: 0x3fe8c801 | Caps_1: 0x18002407
[ 5.293062] mmc1: sdhci: Cmd: 0x00000c1a | Max curr: 0x00000000
[ 5.299483] mmc1: sdhci: Resp[0]: 0x00000b00 | Resp[1]: 0x47606cc0
[ 5.305904] mmc1: sdhci: Resp[2]: 0x53443332 | Resp[3]: 0x00000900
[ 5.312326] mmc1: sdhci: Host ctl2: 0x0000000c
[ 5.316755] mmc1: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x0000000894f4320c
[ 5.323871] mmc1: sdhci: ============================================
[ 5.349622] Buffer I/O error on dev mmcblk1, logical block 0, async page read
[ 5.604222] mmc1: Got data interrupt 0x00000002 even though no data operation was in progress.
[ 5.612828] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
[ 5.619252] mmc1: sdhci: Sys addr: 0x00000008 | Version: 0x00001004
[ 5.625674] mmc1: sdhci: Blk size: 0x00007200 | Blk cnt: 0x00000007
[ 5.632097] mmc1: sdhci: Argument: 0x00000000 | Trn mode: 0x00000033
[ 5.638519] mmc1: sdhci: Present: 0x01f70000 | Host ctl: 0x0000001f
[ 5.644941] mmc1: sdhci: Power: 0x0000000f | Blk gap: 0x00000080
[ 5.651363] mmc1: sdhci: Wake-up: 0x00000000 | Clock: 0x00000207
[ 5.657785] mmc1: sdhci: Timeout: 0x00000000 | Int stat: 0x00000001
[ 5.664207] mmc1: sdhci: Int enab: 0x03ff008b | Sig enab: 0x03ff008b
[ 5.670629] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000001
[ 5.677051] mmc1: sdhci: Caps: 0x3fe8c801 | Caps_1: 0x18002407
[ 5.683474] mmc1: sdhci: Cmd: 0x00000c1a | Max curr: 0x00000000
[ 5.689895] mmc1: sdhci: Resp[0]: 0x00000b00 | Resp[1]: 0x47606cc0
[ 5.696317] mmc1: sdhci: Resp[2]: 0x53443332 | Resp[3]: 0x00000900
[ 5.702739] mmc1: sdhci: Host ctl2: 0x0000000c
[ 5.707167] mmc1: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x0000000894f4320c
[ 5.714282] mmc1: sdhci: ============================================
[ 5.720928] usb usb1-port1: Cannot enable. Maybe the USB cable is bad?
[ 5.727949] usb usb1-port1: unable to enumerate USB device
[ 5.736125] mmc1: Got data interrupt 0x00000002 even though no data operation was in progress.
[ 5.744728] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
[ 5.744731] mmc1: sdhci: Sys addr: 0x00000008 | Version: 0x00001004
[ 5.744733] mmc1: sdhci: Blk size: 0x00007200 | Blk cnt: 0x00000007
[ 5.744735] mmc1: sdhci: Argument: 0x00000000 | Trn mode: 0x00000033
[ 5.744737] mmc1: sdhci: Present: 0x01f70000 | Host ctl: 0x0000001e
[ 5.744740] mmc1: sdhci: Power: 0x0000000f | Blk gap: 0x00000080
[ 5.744742] mmc1: sdhci: Wake-up: 0x00000000 | Clock: 0x00000207
[ 5.744744] mmc1: sdhci: Timeout: 0x00000000 | Int stat: 0x00000001
[ 5.744746] mmc1: sdhci: Int enab: 0x03ff008b | Sig enab: 0x03ff008b
[ 5.744748] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000001
[ 5.744750] mmc1: sdhci: Caps: 0x3fe8c801 | Caps_1: 0x18002407
[ 5.744752] mmc1: sdhci: Cmd: 0x00000c1a | Max curr: 0x00000000
[ 5.744754] mmc1: sdhci: Resp[0]: 0x00000b00 | Resp[1]: 0x47606cc0
[ 5.744756] mmc1: sdhci: Resp[2]: 0x53443332 | Resp[3]: 0x00000900
[ 5.744758] mmc1: sdhci: Host ctl2: 0x0000000c
[ 5.744760] mmc1: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x0000000894f4320c
[ 5.744762] mmc1: sdhci: ============================================
[ 5.790550] mmc1: Got data interrupt 0x00000002 even though no data operation was in progress.
[ 5.802763] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
[ 5.802765] mmc1: sdhci: Sys addr: 0x00000008 | Version: 0x00001004
[ 5.802767] mmc1: sdhci: Blk size: 0x00007200 | Blk cnt: 0x00000007
[ 5.802770] mmc1: sdhci: Argument: 0x00000000 | Trn mode: 0x00000033
[ 5.802772] mmc1: sdhci: Present: 0x01f70000 | Host ctl: 0x0000001f
[ 5.802774] mmc1: sdhci: Power: 0x0000000f | Blk gap: 0x00000080
[ 5.802777] mmc1: sdhci: Wake-up: 0x00000000 | Clock: 0x00000207
[ 5.815619] mmc1: sdhci: Timeout: 0x00000000 | Int stat: 0x00000000
[ 5.815622] mmc1: sdhci: Int enab: 0x03ff008b | Sig enab: 0x03ff008b
[ 5.815624] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[ 5.815627] mmc1: sdhci: Caps: 0x3fe8c801 | Caps_1: 0x18002407
[ 5.828468] mmc1: sdhci: Cmd: 0x00000c1a | Max curr: 0x00000000
[ 5.828471] mmc1: sdhci: Resp[0]: 0x00000b00 | Resp[1]: 0x47606cc0
[ 5.828473] mmc1: sdhci: Resp[2]: 0x53443332 | Resp[3]: 0x00000900
[ 5.828476] mmc1: sdhci: Host ctl2: 0x0000000c
[ 5.839325] mmc1: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x0000000894f4320c
[ 5.839326] mmc1: sdhci: ============================================
[ 5.842003] mmc1: Got data interrupt 0x00000002 even though no data operation was in progress.
[ 5.852874] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
[ 5.852876] mmc1: sdhci: Sys addr: 0x00000008 | Version: 0x00001004
[ 5.852878] mmc1: sdhci: Blk size: 0x00007200 | Blk cnt: 0x00000007
[ 5.852880] mmc1: sdhci: Argument: 0x00000000 | Trn mode: 0x00000033
[ 5.852882] mmc1: sdhci: Present: 0x01f70000 | Host ctl: 0x0000001e
[ 5.852885] mmc1: sdhci: Power: 0x0000000f | Blk gap: 0x00000080
[ 5.867896] mmc1: sdhci: Wake-up: 0x00000000 | Clock: 0x00000207
[ 5.867899] mmc1: sdhci: Timeout: 0x00000000 | Int stat: 0x00000001
[ 5.880742] mmc1: sdhci: Int enab: 0x03ff008b | Sig enab: 0x03ff008b
[ 5.880744] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000001
[ 5.880747] mmc1: sdhci: Caps: 0x3fe8c801 | Caps_1: 0x18002407
[ 5.893589] mmc1: sdhci: Cmd: 0x00000c1a | Max curr: 0x00000000
[ 5.893591] mmc1: sdhci: Resp[0]: 0x00000b00 | Resp[1]: 0x47606cc0
[ 5.893594] mmc1: sdhci: Resp[2]: 0x53443332 | Resp[3]: 0x00000900
[ 5.906434] mmc1: sdhci: Host ctl2: 0x0000000c
[ 5.906436] mmc1: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x0000000894f4320c
[ 5.906438] mmc1: sdhci: ============================================
[ 5.925174] Buffer I/O error on dev mmcblk1, logical block 7572464, async page read
[ 6.201756] mmc1: Got data interrupt 0x00000002 even though no data operation was in progress.
[ 6.210362] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
[ 6.216785] mmc1: sdhci: Sys addr: 0x00000008 | Version: 0x00001004
[ 6.223207] mmc1: sdhci: Blk size: 0x00007200 | Blk cnt: 0x00000007
[ 6.229629] mmc1: sdhci: Argument: 0x00000000 | Trn mode: 0x00000033
[ 6.236051] mmc1: sdhci: Present: 0x01f70000 | Host ctl: 0x0000001f
[ 6.242473] mmc1: sdhci: Power: 0x0000000f | Blk gap: 0x00000080
[ 6.248895] mmc1: sdhci: Wake-up: 0x00000000 | Clock: 0x00000207
[ 6.255316] mmc1: sdhci: Timeout: 0x00000000 | Int stat: 0x00000000
[ 6.261738] mmc1: sdhci: Int enab: 0x03ff008b | Sig enab: 0x03ff008b
[ 6.268160] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[ 6.274582] mmc1: sdhci: Caps: 0x3fe8c801 | Caps_1: 0x18002407
[ 6.281003] mmc1: sdhci: Cmd: 0x00000c1a | Max curr: 0x00000000
[ 6.287426] mmc1: sdhci: Resp[0]: 0x00000b00 | Resp[1]: 0x47606cc0
[ 6.293847] mmc1: sdhci: Resp[2]: 0x53443332 | Resp[3]: 0x00000900
[ 6.300268] mmc1: sdhci: Host ctl2: 0x0000000c
[ 6.304698] mmc1: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x0000000894f4320c
[ 6.311813] mmc1: sdhci: ============================================
[ 6.320937] mmc1: Got data interrupt 0x00000002 even though no data operation was in progress.
[ 6.329527] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
[ 6.335949] mmc1: sdhci: Sys addr: 0x00000008 | Version: 0x00001004
[ 6.342371] mmc1: sdhci: Blk size: 0x00007200 | Blk cnt: 0x00000007
[ 6.348793] mmc1: sdhci: Argument: 0x00000000 | Trn mode: 0x00000033
[ 6.355215] mmc1: sdhci: Present: 0x01f70000 | Host ctl: 0x0000001e
[ 6.361637] mmc1: sdhci: Power: 0x0000000f | Blk gap: 0x00000080
[ 6.368059] mmc1: sdhci: Wake-up: 0x00000000 | Clock: 0x00000207
[ 6.374480] mmc1: sdhci: Timeout: 0x00000000 | Int stat: 0x00000000
[ 6.380902] mmc1: sdhci: Int enab: 0x03ff008b | Sig enab: 0x03ff008b
[ 6.387324] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[ 6.393746] mmc1: sdhci: Caps: 0x3fe8c801 | Caps_1: 0x18002407
[ 6.400168] mmc1: sdhci: Cmd: 0x00000c1a | Max curr: 0x00000000
[ 6.406590] mmc1: sdhci: Resp[0]: 0x00000b00 | Resp[1]: 0x47606cc0
[ 6.413011] mmc1: sdhci: Resp[2]: 0x53443332 | Resp[3]: 0x00000900
[ 6.419433] mmc1: sdhci: Host ctl2: 0x0000000c
[ 6.423861] mmc1: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x0000000894f4320c
[ 6.430976] mmc1: sdhci: ============================================
[ 6.455139] mmc1: Got data interrupt 0x00000002 even though no data operation was in progress.
[ 6.463731] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
[ 6.470153] mmc1: sdhci: Sys addr: 0x00000008 | Version: 0x00001004
[ 6.476574] mmc1: sdhci: Blk size: 0x00007200 | Blk cnt: 0x00000007
[ 6.482996] mmc1: sdhci: Argument: 0x00000000 | Trn mode: 0x00000033
[ 6.489417] mmc1: sdhci: Present: 0x01f70000 | Host ctl: 0x0000001f
[ 6.495840] mmc1: sdhci: Power: 0x0000000f | Blk gap: 0x00000080
[ 6.502262] mmc1: sdhci: Wake-up: 0x00000000 | Clock: 0x00000207
[ 6.508683] mmc1: sdhci: Timeout: 0x00000000 | Int stat: 0x00000000
[ 6.515105] mmc1: sdhci: Int enab: 0x03ff008b | Sig enab: 0x03ff008b
[ 6.521526] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[ 6.527948] mmc1: sdhci: Caps: 0x3fe8c801 | Caps_1: 0x18002407
[ 6.534369] mmc1: sdhci: Cmd: 0x00000c1a | Max curr: 0x00000000
[ 6.540790] mmc1: sdhci: Resp[0]: 0x00000b00 | Resp[1]: 0x47606cc0
[ 6.547212] mmc1: sdhci: Resp[2]: 0x53443332 | Resp[3]: 0x00000900
[ 6.553633] mmc1: sdhci: Host ctl2: 0x0000000c
[ 6.558062] mmc1: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x0000000894f4320c
[ 6.565178] mmc1: sdhci: ============================================
[ 6.574106] mmc1: Got data interrupt 0x00000002 even though no data operation was in progress.
[ 6.582697] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
[ 6.589118] mmc1: sdhci: Sys addr: 0x00000008 | Version: 0x00001004
[ 6.595540] mmc1: sdhci: Blk size: 0x00007200 | Blk cnt: 0x00000007
[ 6.601961] mmc1: sdhci: Argument: 0x00000000 | Trn mode: 0x00000033
[ 6.608383] mmc1: sdhci: Present: 0x01f70000 | Host ctl: 0x0000001e
[ 6.614804] mmc1: sdhci: Power: 0x0000000f | Blk gap: 0x00000080
[ 6.621226] mmc1: sdhci: Wake-up: 0x00000000 | Clock: 0x00000207
[ 6.627647] mmc1: sdhci: Timeout: 0x00000000 | Int stat: 0x00000000
[ 6.634068] mmc1: sdhci: Int enab: 0x03ff008b | Sig enab: 0x03ff008b
[ 6.640490] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[ 6.646913] mmc1: sdhci: Caps: 0x3fe8c801 | Caps_1: 0x18002407
[ 6.653334] mmc1: sdhci: Cmd: 0x00000c1a | Max curr: 0x00000000
[ 6.659756] mmc1: sdhci: Resp[0]: 0x00000b00 | Resp[1]: 0x47606cc0
[ 6.666177] mmc1: sdhci: Resp[2]: 0x53443332 | Resp[3]: 0x00000900
[ 6.672599] mmc1: sdhci: Host ctl2: 0x0000000c
[ 6.677028] mmc1: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x0000000894f4320c
[ 6.684143] mmc1: sdhci: ============================================
[ 6.708051] Buffer I/O error on dev mmcblk1, logical block 7572464, async page read
Gave up waiting for root file system device. Common problems:
- Boot args (cat /proc/cmdline)
- Check rootdelay= (did the system wait long enough?)
- Missing modules (cat /proc/modules; ls /dev)
ALERT! /dev/mmcblk1p2 does not exist. Dropping to a shell!
(initramfs) ls
drwxr-xr-x 13 0 0 0 .
drwxr-xr-x 13 0 0 0 ..
drwxr-xr-x 3 0 0 0 var
drwxr-xr-x 2 0 0 0 tmp
dr-xr-xr-x 170 0 0 0 proc
dr-xr-xr-x 12 0 0 0 sys
drwxr-xr-x 5 0 0 0 usr
drwxr-xr-x 5 0 0 0 scripts
lrwxrwxrwx 1 0 0 8 sbin -> usr/sbin
drwxr-xr-x 5 0 0 100 run
lrwxrwxrwx 1 0 0 7 lib -> usr/lib
-rwxr-xr-x 1 0 0 6556 init
drwxr-xr-x 5 0 0 0 etc
drwxr-xr-x 3 0 0 0 conf
lrwxrwxrwx 1 0 0 7 bin -> usr/bin
-rw-r--r-- 1 0 0 4096 .random-seed
drwx------ 2 0 0 0 root
drwxr-xr-x 13 0 0 4040 dev
(initramfs)
For some reason, I do not have a /dev/mmcblk1p2
file supposedly and I am booting from SD Card.
P.S. If you see my current issue, please do contact me. I am all ears. Oh!
Update
Okay, okay, okay. How can I enter via sh
a couple of commands into the file cmdline
Like this or…
sh "echo rootdelay=15 /proc/cmdline"
