initramfs-bbb-console
I used am335x-debian-11.7-iot-armhf-2023-09-02-4gb.img.xz image flashed sdcards and the booted with on console but stuck at (initramfs) prompt, I feel it is not switching to rootfs and at end init script is not getting triggered.
Logs:
U-Boot 2018.09-00002-g0b54a51eee (Sep 10 2018 - 19:41:39 -0500), Build: jenkins-github_Bootloader-Builder-65
CPU  : AM335X-GP rev 2.1
I2C:   ready
DRAM:  512 MiB
No match for driver 'omap_hsmmc'
Some drivers were not found
RTC 32KCLK Source: External.
MMC:   OMAP SD/MMC: 0, OMAP SD/MMC: 1
Loading Environment from EXT4... ** File not found /boot/uboot.env **
** Unable to read "/boot/uboot.env" from mmc0:1 **
Board: BeagleBone Black
<ethaddr> not set. Validating first E-fuse MAC
BeagleBone Black:
Model: Element14 BeagleBone Black Industrial:
BeagleBone: cape eeprom: i2c_probe: 0x54:
BeagleBone: cape eeprom: i2c_probe: 0x55:
BeagleBone: cape eeprom: i2c_probe: 0x56:
BeagleBone: cape eeprom: i2c_probe: 0x57:
Net:   eth0: MII MODE
cpsw, usb_ether
Press SPACE to abort autoboot in 2 seconds
board_name=[A335BNLT] ...
board_rev=[EIA0] ...
switch to partitions #0, OK
mmc0 is current device
SD/MMC found on device 0
Scanning mmc 0:1...
Checking for: /uEnv.txt ...
Checking for: /boot.scr ...
Checking for: /boot/boot.scr ...
Checking for: /boot/uEnv.txt ...
2041 bytes read in 11 ms (180.7 KiB/s)
Checking if uname_r is set in /boot/uEnv.txt...
Running uname_boot ...
loading /boot/vmlinuz-4.14.71-ti-r80 ...
10416640 bytes read in 670 ms (14.8 MiB/s)
debug: [enable_uboot_overlays=1] ...
debug: [enable_uboot_cape_universal=1] ...
debug: [uboot_base_dtb_univ=am335x-boneblack-uboot-univ.dtb] ...
uboot_overlays: [uboot_base_dtb=am335x-boneblack-uboot-univ.dtb] ...
uboot_overlays: Switching too: dtb=am335x-boneblack-uboot-univ.dtb ...
loading /boot/dtbs/4.14.71-ti-r80/am335x-boneblack-uboot-univ.dtb ...
161723 bytes read in 34 ms (4.5 MiB/s)
uboot_overlays: [fdt_buffer=0x60000] ...
uboot_overlays: unable to find [mmc 0:1 /lib/firmware/BB-BONE-eMMC1-01-00A0.dtbo]...
uboot_overlays: unable to find [mmc 0:1 /lib/firmware/BB-HDMI-TDA998x-00A0.dtbo]...
uboot_overlays: unable to find [mmc 0:1 /lib/firmware/BB-ADC-00A0.dtbo]...
uboot_overlays: unable to find [mmc 0:1 /lib/firmware/AM335X-PRU-RPROC-4-14-TI-00A0.dtbo]...
loading /boot/initrd.img-4.14.71-ti-r80 ...
4530240 bytes read in 298 ms (14.5 MiB/s)
debug: [console=ttyO0,115200n8 bone_capemgr.uboot_capemgr_enabled=1 root=/dev/mmcblk0p1 ro rootfstype=ext4 rootwait init=/opt/scripts/tools/eMMC/init.
debug: [bootz 0x82000000 0x88080000:452040 0x88000000] ...
## Flattened Device Tree blob at 88000000
   Loading Ramdisk to 8fbad000, end 8ffff040 ... OK
   Loading Device Tree to 8fb82000, end 8fbac7ba ... OK
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 4.14.71-ti-r80 (root@b2-am57xx-beagle-x15-2gb) (gcc version 6.3.0 20170516 (Debian 6.3.0-18+deb9u1)) #1 SMP PREEMPT Fri 8
[    0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c5387d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] OF: fdt: Machine model: TI AM335x BeagleBone Black
[    0.000000] Memory policy: Data cache writeback
[    0.000000] efi: Getting EFI parameters from FDT:
[    0.000000] efi: UEFI not found.
[    0.000000] cma: Reserved 48 MiB at 0x9c800000
[    0.000000] CPU: All CPU(s) started in SVC mode.
[    0.000000] AM335X ES2.1 (sgx neon)
[    0.000000] random: get_random_bytes called from start_kernel+0xac/0x458 with crng_init=0
[    0.000000] percpu: Embedded 18 pages/cpu @df8e9000 s41548 r8192 d23988 u73728
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 129412
[    0.000000] Kernel command line: console=ttyO0,115200n8 bone_capemgr.uboot_capemgr_enabled=1 root=/dev/mmcblk0p1 ro rootfstype=ext4 rootwait init=h
[    0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[    0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[    0.000000] Memory: 440828K/522240K available (13312K kernel code, 1169K rwdata, 4364K rodata, 1024K init, 361K bss, 32260K reserved, 49152K cma-r)
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
[    0.000000]     vmalloc : 0xe0000000 - 0xff800000   ( 504 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xdfe00000   ( 510 MB)
[    0.000000]     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
[    0.000000]     modules : 0xbf000000 - 0xbfe00000   (  14 MB)
[    0.000000]       .text : 0xc0008000 - 0xc0e00000   (14304 kB)
[    0.000000]       .init : 0xc1400000 - 0xc1500000   (1024 kB)
[    0.000000]       .data : 0xc1500000 - 0xc1624498   (1170 kB)
[    0.000000]        .bss : 0xc162eb2c - 0xc1689000   ( 362 kB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[    0.000000] ftrace: allocating 42734 entries in 126 pages
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000]  RCU restricting CPUs from NR_CPUS=2 to nr_cpu_ids=1.
[    0.000000]  Tasks RCU enabled.
[    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=1
[    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[    0.000000] IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts
[    0.000000] OMAP clockevent source: timer2 at 24000000 Hz
[    0.000024] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
[    0.000053] clocksource: timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[    0.000067] OMAP clocksource: timer1 at 24000000 Hz
[    0.002064] timer_probe: no matching timers found
[    0.002407] Console: colour dummy device 80x30
[    0.002441] WARNING: Your 'console=ttyO0' has been replaced by 'ttyS0'
[    0.002449] This ensures that you still see kernel messages. Please
[    0.002456] update your kernel commandline.
[    0.002489] Calibrating delay loop... 995.32 BogoMIPS (lpj=1990656)
[    0.021158] pid_max: default: 32768 minimum: 301
[    0.021430] Security Framework initialized
[    0.021453] Yama: becoming mindful.
[    0.021494] AppArmor: AppArmor disabled by boot time parameter
[    0.021575] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.021592] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.022618] CPU: Testing write buffer coherency: ok
[    0.023136] CPU0: thread -1, cpu 0, socket -1, mpidr 0
[    0.037245] Setting up static identity map for 0x80100000 - 0x80100060
[    0.045154] Hierarchical SRCU implementation.
[    0.056275] EFI services will not be available.
[    0.061162] smp: Bringing up secondary CPUs ...
[    0.061183] smp: Brought up 1 node, 1 CPU
[    0.061195] SMP: Total of 1 processors activated (995.32 BogoMIPS).
[    0.061207] CPU: All CPU(s) started in SVC mode.
[    0.062787] devtmpfs: initialized
[    0.097472] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[    0.097950] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.097983] futex hash table entries: 256 (order: 2, 16384 bytes)
[    0.101905] xor: measuring software checksum speed
[    0.141174]    arm4regs  :  1200.000 MB/sec
[    0.181131]    8regs     :  1075.000 MB/sec
[    0.221130]    32regs    :   988.000 MB/sec
[    0.261129]    neon      :  1624.000 MB/sec
[    0.261140] xor: using function: neon (1624.000 MB/sec)
[    0.261160] pinctrl core: initialized pinctrl subsystem
[    0.262411] NET: Registered protocol family 16
[    0.265427] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.354688] omap_hwmod: debugss: _wait_target_disable failed
[    0.395419] cpuidle: using governor menu
[    0.401586] OMAP GPIO hardware version 0.1
[    0.429792] No ATAGs?
[    0.429813] hw-breakpoint: debug architecture 0x4 unsupported.
[    0.431248] omap4_sram_init:Unable to allocate sram needed to handle errata I688
[    0.431272] omap4_sram_init:Unable to get sram pool needed to handle errata I688
[    0.525209] raid6: neonx2   gen()  1882 MB/s
[    0.593162] raid6: neonx2   xor()  1497 MB/s
[    0.593174] raid6: using algorithm neonx2 gen() 1882 MB/s
[    0.593184] raid6: .... xor() 1497 MB/s, rmw enabled
[    0.593193] raid6: using neon recovery algorithm
[    0.601362] edma 49000000.edma: TI EDMA DMA engine driver
[    0.608469] SCSI subsystem initialized
[    0.609631] usbcore: registered new interface driver usbfs
[    0.609695] usbcore: registered new interface driver hub
[    0.609809] usbcore: registered new device driver usb
[    0.610856] omap_i2c 44e0b000.i2c: could not find pctldev for node /ocp/l4_wkup@44c00000/scm@210000/pinmux@800/pinmux_i2c0_pins, deferring probe
[    0.611845] omap_i2c 4802a000.i2c: bus 1 rev0.11 at 100 kHz
[    0.613285] omap_i2c 4819c000.i2c: bus 2 rev0.11 at 100 kHz
[    0.613806] media: Linux media interface: v0.10
[    0.613880] Linux video capture interface: v2.00
[    0.614059] pps_core: LinuxPPS API ver. 1 registered
[    0.614073] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.614100] PTP clock support registered
[    0.614712] omap-mailbox 480c8000.mailbox: omap mailbox rev 0x400
[    0.617536] Advanced Linux Sound Architecture Driver Initialized.
[    0.618257] NetLabel: Initializing
[    0.618275] NetLabel:  domain hash size = 128
[    0.618285] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
[    0.618375] NetLabel:  unlabeled traffic allowed by default
[    0.621574] clocksource: Switched to clocksource timer1
[    0.785303] VFS: Disk quotas dquot_6.6.0
[    0.785445] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    0.798455] NET: Registered protocol family 2
[    0.799401] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
[    0.799453] TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
[    0.799514] TCP: Hash tables configured (established 4096 bind 4096)
[    0.799636] UDP hash table entries: 256 (order: 1, 8192 bytes)
[    0.799661] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[    0.799880] NET: Registered protocol family 1
[    0.808847] RPC: Registered named UNIX socket transport module.
[    0.808869] RPC: Registered udp transport module.
[    0.808877] RPC: Registered tcp transport module.
[    0.808885] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.810004] Unpacking initramfs...
[    1.017641] random: fast init done
[    1.057400] Freeing initrd memory: 4428K
[    1.058140] hw perfevents: no interrupt-affinity property for /pmu, guessing.
[    1.058356] hw perfevents: enabled with armv7_cortex_a8 PMU driver, 5 counters available
[    1.060633] audit: initializing netlink subsys (disabled)
[    1.062118] audit: type=2000 audit(1.060:1): state=initialized audit_enabled=0 res=1
[    1.062272] workingset: timestamp_bits=14 max_order=17 bucket_order=3
[    1.068221] zbud: loaded
[    1.075882] NFS: Registering the id_resolver key type
[    1.075940] Key type id_resolver registered
[    1.075951] Key type id_legacy registered
[    1.075973] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    1.076350] fuse init (API version 7.26)
[    1.076985] SGI XFS with ACLs, security attributes, realtime, no debug enabled
[    1.096184] Key type asymmetric registered
[    1.096214] Asymmetric key parser 'x509' registered
[    1.096345] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[    1.100691] io scheduler noop registered
[    1.100711] io scheduler deadline registered
[    1.101109] io scheduler cfq registered (default)
[    1.101126] io scheduler mq-deadline registered
[    1.103963] pinctrl-single 44e10800.pinmux: 142 pins at pa f9e10800 size 568
[    1.116149] gpio-of-helper ocp:cape-universal: ready
[    1.127705] wkup_m3_ipc 44e11324.wkup_m3_ipc: could not get rproc handle
[    1.130414] Serial: 8250/16550 driver, 6 ports, IRQ sharing disabled
[    1.134221] 44e09000.serial: ttyS0 at MMIO 0x44e09000 (irq = 30, base_baud = 3000000) is a 8250
[    1.985914] console [ttyS0] enabled
[    1.990626] 48022000.serial: ttyS1 at MMIO 0x48022000 (irq = 31, base_baud = 3000000) is a 8250
[    2.000537] 48024000.serial: ttyS2 at MMIO 0x48024000 (irq = 32, base_baud = 3000000) is a 8250
[    2.010507] 481a6000.serial: ttyS3 at MMIO 0x481a6000 (irq = 33, base_baud = 3000000) is a 8250
[    2.020330] 481a8000.serial: ttyS4 at MMIO 0x481a8000 (irq = 34, base_baud = 3000000) is a 8250
[    2.030283] 481aa000.serial: ttyS5 at MMIO 0x481aa000 (irq = 35, base_baud = 3000000) is a 8250
[    2.042846] omap_rng 48310000.rng: Random Number Generator ver. 20
[    2.050636] [drm] Initialized vgem 1.0.0 20120112 for virtual device on minor 0
[    2.058228] usbcore: registered new interface driver udl
[    2.072423] at24 2-0054: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[    2.079750] at24 2-0055: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[    2.086943] at24 2-0056: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[    2.094122] at24 2-0057: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[    2.101733] eqep 48300180.eqep: ver. 1.0
[    2.105896] eqep 48300180.eqep: count_mode:0
[    2.110236] eqep 48300180.eqep: invert_qa:1
[    2.114468] eqep 48300180.eqep: invert_qb:1
[    2.118693] eqep 48300180.eqep: invert_qi:0
[    2.122929] eqep 48300180.eqep: invert_qs:0
[    2.127156] eqep 48300180.eqep: swap_inputs:0
[    2.131556] eqep 48300180.eqep: QDECCTL:0x0180
[    2.136042] eqep 48300180.eqep: QPOSINIT:0x00000000
[    2.140963] eqep 48300180.eqep: QPOSMAX:0xffffffff
[    2.145799] eqep 48300180.eqep: QPOSCNT:0x00000000
[    2.150636] eqep 48300180.eqep: omit_interrupt:0
[    2.155296] eqep 48300180.eqep: QEINT:0x0800
[    2.159607] eqep 48300180.eqep: QUPRD:0x05f5e100
[    2.164267] eqep 48300180.eqep: QEPCTL:0x009e write
[    2.169188] eqep 48300180.eqep: QEPCTL:0x009e read
[    2.174040] eqep 48300180.eqep: irq:130, clk_rate:100000000
[    2.179901] eqep 48302180.eqep: ver. 1.0
[    2.184005] eqep 48302180.eqep: count_mode:0
[    2.188336] eqep 48302180.eqep: invert_qa:1
[    2.192564] eqep 48302180.eqep: invert_qb:1
[    2.196790] eqep 48302180.eqep: invert_qi:0
[    2.201015] eqep 48302180.eqep: invert_qs:0
[    2.205240] eqep 48302180.eqep: swap_inputs:0
[    2.209641] eqep 48302180.eqep: QDECCTL:0x0180
[    2.214127] eqep 48302180.eqep: QPOSINIT:0x00000000
[    2.219048] eqep 48302180.eqep: QPOSMAX:0xffffffff
[    2.223882] eqep 48302180.eqep: QPOSCNT:0x00000000
[    2.228719] eqep 48302180.eqep: omit_interrupt:0
[    2.233379] eqep 48302180.eqep: QEINT:0x0800
[    2.237691] eqep 48302180.eqep: QUPRD:0x05f5e100
[    2.242351] eqep 48302180.eqep: QEPCTL:0x009e write
[    2.247274] eqep 48302180.eqep: QEPCTL:0x009e read
[    2.252123] eqep 48302180.eqep: irq:132, clk_rate:100000000
[    2.257950] eqep 48304180.eqep: ver. 1.0
[    2.262053] eqep 48304180.eqep: count_mode:0
[    2.266382] eqep 48304180.eqep: invert_qa:1
[    2.270611] eqep 48304180.eqep: invert_qb:1
[    2.274838] eqep 48304180.eqep: invert_qi:0
[    2.279063] eqep 48304180.eqep: invert_qs:0
[    2.283288] eqep 48304180.eqep: swap_inputs:0
[    2.287686] eqep 48304180.eqep: QDECCTL:0x0180
[    2.292173] eqep 48304180.eqep: QPOSINIT:0x00000000
[    2.297095] eqep 48304180.eqep: QPOSMAX:0xffffffff
[    2.301930] eqep 48304180.eqep: QPOSCNT:0x00000000
[    2.306765] eqep 48304180.eqep: omit_interrupt:0
[    2.311426] eqep 48304180.eqep: QEINT:0x0800
[    2.315737] eqep 48304180.eqep: QUPRD:0x05f5e100
[    2.320396] eqep 48304180.eqep: QEPCTL:0x009e write
[    2.325317] eqep 48304180.eqep: QEPCTL:0x009e read
[    2.330164] eqep 48304180.eqep: irq:134, clk_rate:100000000
[    2.411312] libphy: Fixed MDIO Bus: probed
[    2.416448] CAN device driver interface
[    2.421869] c_can_platform 481cc000.can: c_can_platform device registered (regs=fa1cc000, irq=41)
[    2.431935] c_can_platform 481d0000.can: c_can_platform device registered (regs=fa1d0000, irq=42)
[    2.497687] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6, bus freq 1000000
[    2.505442] davinci_mdio 4a101000.mdio: detected phy mask fffffffe
[    2.512655] MDIO: davinci_mdio: dt: updated phy_id[0] from phy_mask[fffffffe]
[    2.534698] libphy: 4a101000.mdio: probed
[    2.539045] davinci_mdio 4a101000.mdio: phy[0]: device 4a101000.mdio:00, driver SMSC LAN8710/LAN8720
[    2.549758] cpsw 4a100000.ethernet: Detected MACID = 00:35:ff:90:27:1e
[    2.556549] cpsw 4a100000.ethernet: initialized cpsw ale version 1.4
[    2.562988] cpsw 4a100000.ethernet: ALE Table size 1024
[    2.568317] cpsw 4a100000.ethernet: cpts: overflow check period 1250 (jiffies)
[    2.579537] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    2.586228] ehci-platform: EHCI generic platform driver
[    2.591980] ehci-omap: OMAP-EHCI Host Controller driver
[    2.598387] usbcore: registered new interface driver usb-storage
[    2.607826] am335x-phy-driver 47401300.usb-phy: 47401300.usb-phy supply vcc not found, using dummy regulator
[    2.621177] am335x-phy-driver 47401b00.usb-phy: 47401b00.usb-phy supply vcc not found, using dummy regulator
[    2.635811] musb-hdrc musb-hdrc.1: MUSB HDRC host driver
[    2.641253] musb-hdrc musb-hdrc.1: new USB bus registered, assigned bus number 1
[    2.649055] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    2.655929] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.663211] usb usb1: Product: MUSB HDRC host driver
[    2.668221] usb usb1: Manufacturer: Linux 4.14.71-ti-r80 musb-hcd
[    2.674365] usb usb1: SerialNumber: musb-hdrc.1
[    2.679969] hub 1-0:1.0: USB hub found
[    2.683962] hub 1-0:1.0: 1 port detected
[    2.700463] omap_rtc 44e3e000.rtc: registered as rtc0
[    2.707282] i2c /dev entries driver
[    2.712191] Driver for 1-wire Dallas network protocol.
[    2.721117] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[    2.728809] softdog: initialized. soft_noboot=0 soft_margin=60 sec soft_panic=0 (nowayout=0)
[    2.739172] cpuidle: enable-method property 'ti,am3352' found operations
[    2.747036] sdhci: Secure Digital Host Controller Interface driver
[    2.753331] sdhci: Copyright(c) Pierre Ossman
[    2.758958] omap_hsmmc 48060000.mmc: Got CD GPIO
[    2.804132] sdhci-pltfm: SDHCI platform and OF driver helper
[    2.818386] ledtrig-cpu: registered to indicate activity on CPUs
[    2.825150] omap-aes 53500000.aes: OMAP AES hw accel rev: 3.2
[    2.831287] omap-aes 53500000.aes: will run requests pump with realtime priority
[    2.841443] omap-sham 53100000.sham: hw accel on OMAP rev 4.3
[    2.851826] hidraw: raw HID events driver (C) Jiri Kosina
[    2.858668] usbcore: registered new interface driver usbhid
[    2.864598] usbhid: USB HID core driver
[    2.869078] remoteproc remoteproc0: wkup_m3 is available
[    2.876465] mmc0: host does not support reading read-only switch, assuming write-enable
[    2.890208] wireguard: WireGuard 0.0.20180925 loaded. See www.wireguard.com for information.
[    2.890214] wireguard: Copyright (C) 2015-2018 Jason A. Donenfeld <Jason@zx2c4.com>. All Rights Reserved.
[    2.891050] NET: Registered protocol family 10
[    2.910911] Segment Routing with IPv6
[    2.911005] mip6: Mobile IPv6
[    2.911021] NET: Registered protocol family 17
[    2.911037] can: controller area network core (rev 20170425 abi 9)
[    2.911123] NET: Registered protocol family 29
[    2.911263] Key type dns_resolver registered
[    2.911269] mpls_gso: MPLS GSO support
[    2.911505] omap_voltage_late_init: Voltage driver support not added
[    2.912099] PM: Cannot get wkup_m3_ipc handle
[    2.912294] ThumbEE CPU extension supported.
[    2.912318] Registering SWP/SWPB emulation handler
[    2.913407] registered taskstats version 1
[    2.913532] zswap: loaded using pool lzo/zbud
[    2.920618] Btrfs loaded, crc32c=crc32c-generic
[    2.920716] ima: No TPM chip found, activating TPM-bypass! (rc=-19)
[    2.920738] ima: Allocated hash algorithm: sha256
[    3.005711] mmc0: new high speed SDHC card at address 21fb
[    3.012403] mmcblk0: mmc0:21fb APPSD 15.0 GiB
[    3.018593]  mmcblk0: p1
[    3.039760] input: tps65217_pwr_but as /devices/platform/ocp/44e0b000.i2c/i2c-0/0-0024/tps65217-pwrbutton/input/input0
[    3.051208] tps65217 0-0024: TPS65217 ID 0xe version 1.2
[    3.057111] at24 0-0050: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[    3.064191] omap_i2c 44e0b000.i2c: bus 0 rev0.11 at 400 kHz
[    3.071545] remoteproc remoteproc0: powering up wkup_m3
[    3.081205] remoteproc remoteproc0: Booting fw image am335x-pm-firmware.elf, size 217168
[    3.091441] PM: Cannot get wkup_m3_ipc handle
[    3.096225] remoteproc remoteproc0: remote processor wkup_m3 is now up
[    3.096245] wkup_m3_ipc 44e11324.wkup_m3_ipc: CM3 Firmware Version = 0x193
[    3.111385] omap_rtc 44e3e000.rtc: setting system clock to 2000-01-01 00:00:00 UTC (946684800)
[    3.120314] of_cfs_init
[    3.123010] of_cfs_init: OK
[    3.127334] ALSA device list:
[    3.130433]   No soundcards found.
[    3.138538] Freeing unused kernel memory: 1024K
Loading, please wait...
starting version 232
[    3.597367] random: systemd-udevd: uninitialized urandom read (16 bytes read)
[    3.614824] random: systemd-udevd: uninitialized urandom read (16 bytes read)
[    3.625895] random: udevadm: uninitialized urandom read (16 bytes read)
Begin: Loading essential drivers ... done.
Begin: Running /scripts/init-premount ... done.
Begin: Mounting root file system ... Begin: Running /scripts/local-top ... done.
Begin: Running /scripts/local-premount ... Scanning for Btrfs filesystems
done.
Warning: fsck not present, so skipping root file system
[   32.138975] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
done.
Begin: Running /scripts/local-bottom ... done.
Begin: Running /scripts/init-bottom ... done.
[   32.303671] EXT4-fs error (device mmcblk0p1): ext4_lookup:1586: inode #2: comm mount: deleted inode referenced: 655362
mount: mounting /run on /root/run failed: Structure needs cleaning
[   32.462162] EXT4-fs error (device mmcblk0p1): ext4_lookup:1586: inode #400456: comm run-init: deleted inode referenced: 525501
run-init: /opt/scripts/tools/eMMC/init-eMMC-flasher-v3.sh: Structure needs cleaning
Target filesystem doesn't have requested /o[   32.487673] EXT4-fs error (device mmcblk0p1): ext4_lookup:1586: inode #2: comm run-init: deleted inode 5
pt/scripts/tools/eMMC/init-eMMC-flasher-v3.sh.
run-init: /sbin/init: Structure needs cleaning
run-init: /etc/init: Permission denied
[   32.559218] EXT4-fs error (device mmcblk0p1): ext4_lookup:1586: inode #2: comm run-init: deleted inode referenced: 786433
run-init: /bin/init: Structure needs cleaning[   32.577544] EXT4-fs error (device mmcblk0p1): ext4_lookup:1586: inode #2: comm run-init: deleted inod3
run-init: /bin/sh: Structure needs cleaning
run-init: : No such file or directory
No init found. Try passing init= bootarg.
BusyBox v1.22.1 (Debian 1:1.22.0-19+b3) built-in shell (ash)
Enter 'help' for a list of built-in commands.
(initramfs) help
Built-in commands:
        . : [ [[ alias bg break cd chdir command continue echo eval exec
        exit export false fg getopts hash help history jobs kill let
        local printf pwd read readonly return set shift source test times
        trap true type ulimit umask unalias unset wait
(initramfs) boot
sh: boot: not found
(initramfs) [  113.437615] random: crng init done
[  113.441059] random: 7 urandom warning(s) missed due to ratelimiting
[  332.765576] EXT4-fs (mmcblk0p1): error count since last fsck: 64
[  332.771623] EXT4-fs (mmcblk0p1): initial error at time 946685093: ext4_mb_generate_buddy:757
[  332.780103] EXT4-fs (mmcblk0p1): last error at time 946684829: ext4_lookup:1586: inode 2
at development laptop:
oem@bhagwabhartiya:~/Desktop$ cd /media/oem/rootfs/
oem@bhagwabhartiya:/media/oem/rootfs$ ls
ls: cannot access 'media': Structure needs cleaning
ls: cannot access 'sbin': Structure needs cleaning
ls: cannot access 'bin': Structure needs cleaning
ls: cannot access 'home': Structure needs cleaning
ls: cannot access 'root': Structure needs cleaning
ls: cannot access 'usr': Structure needs cleaning
ls: cannot access 'lib': Structure needs cleaning
ls: cannot access 'run': Structure needs cleaning
bbb-uEnv.txt  bin  boot  dev  etc  home  ID.txt  lib  lost+found  media  mnt  nfs-uEnv.txt  opt  proc  root  run  sbin  srv  sys  tmp  usr  var
oem@bhagwabhartiya:/media/oem/rootfs$ cd boot/
oem@bhagwabhartiya:/media/oem/rootfs/boot$ ls
config-4.14.71-ti-r80  dtbs  initrd.img-4.14.71-ti-r80  SOC.sh  System.map-4.14.71-ti-r80  uboot  uEnv.txt  vmlinuz-4.14.71-ti-r80
seems filesystem has been corrupted ?
KIndly suggest what more i should act to boot it properly ?
Thanks.
ankur
It’s still booting from eMMC:
Just erase the eMMC…
Kindly share its steps to erase eMMC and in case if i require to re-flash then re-flashing eMMC file and step to re-flash also… or is it possible to boot from sdcard keeping emmc as it is …like via some jumper setting or something elike else ?
regd.
ankur
debian@BeagleBone:~$ lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS
mmcblk1 179:0 0 3.6G 0 disk
mmcblk1boot0 179:256 0 4M 1 disk
mmcblk1boot1 179:512 0 4M 1 disk
mmcblk0 179:768 0 7.5G 0 disk
└─mmcblk0p1 179:769 0 7.5G 0 part /
this list what your memory devices are.
mmcblk1 being the emmc
to erase this,
sudo dd if=/dev/zero of=/dev/mmcblk1 bs=1M count=4
sync
now reboot
hi,
thx for your reply.
The steps you provided is at at bbb linux prompt which comns after booting, my problem is, i m at initramfs prompt, i.e. not able to boot board hence not have the linux prompt …
thx.
ankur
@Ankur ,
Try to research blkdiscard.
Or: blkdiscard(8) - Linux manual page
P.S. Sorry, I just understood the dilemma. It boots but not from mini-USB to USB 2.0 for networking. Got it. I do not want you to remove your entire system by accident. Can you flash something else to the board in kernel 5.10.x? If not, and if you want to keep your data, time to read and find examples for testing.
I have had this exact, same issue where I could not boot into a board because of buildroot builds, i.e. either my u-boot was outdated and/or the kernel was mismatched with the u-boot build.
Are you using a buildroot set up?
Hi @silver2row
No, I am not using any buildroot setup , instead I just downloaded the xz image from Latest Software Images - BeagleBoard , flashed into sdcard, setup the minicom at my ubuntu laptop, connected the console cable and started…but its stuck at initramfs prompt…then robert told, its taking from emmc , please erase it…then it will start normally…but here…my problem is how to erase as my booting is completed…?
earlier it didnt given that much issues…but now …i dont know why so much issues i m facing…
seems image is not appropriately selected…but again which exact image should be used…none specifically told…i m trying from my own…if u know some proven image…kindly let me know and if somewhere my steps are wrong…kindly correct the steps too…
all fight till yet is to get a test bed//from where i can try my other skill-up…
regd.
ankur
On the BBB, there is a S2 Button/Boot Button. Same button.
That button while held when applying power will boot to the micro SD Card.
P.S. 4.14.x is older…yes. EOL probably. I can check debian archives but I am almost 100% sure that 4.14.x is EOL forever. Outside of humor here, say you did something like update/upgrade, that may have changed some elementary processes and programs which I think beagleboard.org use to make sure their images are in the communities best interest. Outside of that guess, use the button that is alone, S2/Boot button. One in the same.
So, there is a Power button and a Reset button that are both near each other. Neither of those buttons will need to be in play here. Use the S2 button. On the silkscreen, it is labeled S2.
So, again…
  1. Hold the S2 button while applying power via the mini-USB to USB 2.0 cable and do not let go until you see two LEDs light up.
  2. You should boot into the micro SD Card now.
Are you trying to save data on the eMMC or the micro SD Card?
Hi @silver2row,
With button pressed logs are :
I2C: ready
DRAM: 512 MiB
No match for driver ‘omap_hsmmc’
Loading Environment from EXT4… ** File not found /boot/uboot.env **
** Unable to read “/boot/uboot.env” from mmc0:1 **
BeagleBone Black:
Net: eth0: MII MODE
cpsw, usb_ether
board_name=[A335BNLT] …
board_rev=[EIA0] …
Scanning mmc 0:1…
Checking for: /uEnv.txt …
Checking for: /boot.scr …
Checking for: /boot/boot.scr …
Checking for: /boot/uEnv.txt …
Checking if uname_r is set in /boot/uEnv.txt…
Running uname_boot …
loading /boot/vmlinuz-4.14.71-ti-r80 …
10416640 bytes read in 669 ms (14.8 MiB/s)
debug: [enable_uboot_overlays=1] …
debug: [enable_uboot_cape_universal=1] …
debug: [uboot_base_dtb_univ=am335x-boneblack-uboot-univ.dtb] …
uboot_overlays: [uboot_base_dtb=am335x-boneblack-uboot-univ.dtb] …
uboot_overlays: Switching too: dtb=am335x-boneblack-uboot-univ.dtb …
loading /boot/dtbs/4.14.71-ti-r80/am335x-boneblack-uboot-univ.dtb …
uboot_overlays: [fdt_buffer=0x60000] …
uboot_overlays: unable to find [mmc 0:1 /lib/firmware/BB-BONE-eMMC1-01-00A0.dtbo]…
uboot_overlays: unable to find [mmc 0:1 /lib/firmware/BB-HDMI-TDA998x-00A0.dtbo]…
uboot_overlays: unable to find [mmc 0:1 /lib/firmware/BB-ADC-00A0.dtbo]…
uboot_overlays: unable to find [mmc 0:1 /lib/firmware/AM335X-PRU-RPROC-4-14-TI-00A0.dtbo]…
loading /boot/initrd.img-4.14.71-ti-r80 …
debug: [bootz 0x82000000 0x88080000:452040 0x88000000] …
Loading Ramdisk to 8fbad000, end 8ffff040 … OK
Loading Device Tree to 8fb82000, end 8fbac7ba … OK
Starting kernel …
[ 0.000066] OMAP clocksource: timer1 at 24000000 Hz
[ 0.002075] timer_probe: no matching timers found
[ 0.002414] Console: colour dummy device 80x30
[ 0.002448] WARNING: Your ‘console=ttyO0’ has been replaced by ‘ttyS0’
[ 0.002457] This ensures that you still see kernel messages. Please
[ 0.002464] update your kernel commandline.
[ 0.002496] Calibrating delay loop… 995.32 BogoMIPS (lpj=1990656)
[ 0.021137] pid_max: default: 32768 minimum: 301
[ 0.021411] Security Framework initialized
[ 0.021431] Yama: becoming mindful.
[ 0.021473] AppArmor: AppArmor disabled by boot time parameter
[ 0.021558] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.021572] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.022595] CPU: Testing write buffer coherency: ok
[ 0.023122] CPU0: thread -1, cpu 0, socket -1, mpidr 0
[ 0.037222] Setting up static identity map for 0x80100000 - 0x80100060
[ 0.045134] Hierarchical SRCU implementation.
[ 0.056274] EFI services will not be available.
[ 0.061141] smp: Bringing up secondary CPUs …
[ 0.061163] smp: Brought up 1 node, 1 CPU
[ 0.061176] SMP: Total of 1 processors activated (995.32 BogoMIPS).
[ 0.061187] CPU: All CPU(s) started in SVC mode.
[ 0.062777] devtmpfs: initialized
[ 0.097449] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[ 0.097933] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.097964] futex hash table entries: 256 (order: 2, 16384 bytes)
[ 0.101911] xor: measuring software checksum speed
[ 0.141159] arm4regs : 1200.000 MB/sec
[ 0.181111] 8regs : 1075.000 MB/sec
[ 0.221111] 32regs : 988.000 MB/sec
[ 0.261109] neon : 1620.000 MB/sec
[ 0.261120] xor: using function: neon (1620.000 MB/sec)
[ 0.261142] pinctrl core: initialized pinctrl subsystem
[ 0.262399] NET: Registered protocol family 16
[ 0.265425] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.354845] omap_hwmod: debugss: _wait_target_disable failed
[ 0.395568] cpuidle: using governor menu
[ 0.401737] OMAP GPIO hardware version 0.1
[ 0.430137] No ATAGs?
[ 0.430157] hw-breakpoint: debug architecture 0x4 unsupported.
[ 0.431573] omap4_sram_init:Unable to allocate sram needed to handle errata I688
[ 0.431599] omap4_sram_init:Unable to get sram pool needed to handle errata I688
[ 0.525185] raid6: neonx2 gen() 1882 MB/s
[ 0.593145] raid6: neonx2 xor() 1497 MB/s
[ 0.593157] raid6: using algorithm neonx2 gen() 1882 MB/s
[ 0.593166] raid6: … xor() 1497 MB/s, rmw enabled
[ 0.593176] raid6: using neon recovery algorithm
[ 0.601383] edma 49000000.edma: TI EDMA DMA engine driver
[ 0.608519] SCSI subsystem initialized
[ 0.609617] usbcore: registered new interface driver usbfs
[ 0.609684] usbcore: registered new interface driver hub
[ 0.609800] usbcore: registered new device driver usb
[ 0.610849] omap_i2c 44e0b000.i2c: could not find pctldev for node /ocp/l4_wkup@44c00000/scm@210000/pinmux@800/pinmux_i2c0_pins, deferring probe
[ 0.611846] omap_i2c 4802a000.i2c: bus 1 rev0.11 at 100 kHz
[ 0.613287] omap_i2c 4819c000.i2c: bus 2 rev0.11 at 100 kHz
[ 0.613817] media: Linux media interface: v0.10
[ 0.613897] Linux video capture interface: v2.00
[ 0.614082] pps_core: LinuxPPS API ver. 1 registered
[ 0.614095] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 0.614125] PTP clock support registered
[ 0.614742] omap-mailbox 480c8000.mailbox: omap mailbox rev 0x400
[ 0.617523] Advanced Linux Sound Architecture Driver Initialized.
[ 0.618247] NetLabel: Initializing
[ 0.618265] NetLabel: domain hash size = 128
[ 0.618275] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[ 0.618365] NetLabel: unlabeled traffic allowed by default
[ 0.621559] clocksource: Switched to clocksource timer1
[ 0.785754] VFS: Disk quotas dquot_6.6.0
[ 0.785900] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.798827] NET: Registered protocol family 2
[ 0.799777] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.799831] TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.799892] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.800016] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 0.800042] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 0.800256] NET: Registered protocol family 1
[ 0.809217] RPC: Registered named UNIX socket transport module.
[ 0.809240] RPC: Registered udp transport module.
[ 0.809248] RPC: Registered tcp transport module.
[ 0.809256] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.810234] Unpacking initramfs…
[ 1.017631] random: fast init done
[ 1.058206] Freeing initrd memory: 4428K
[ 1.058767] hw perfevents: no interrupt-affinity property for /pmu, guessing.
[ 1.058989] hw perfevents: enabled with armv7_cortex_a8 PMU driver, 5 counters available
[ 1.061288] audit: initializing netlink subsys (disabled)
[ 1.062736] audit: type=2000 audit(1.064:1): state=initialized audit_enabled=0 res=1
[ 1.062884] workingset: timestamp_bits=14 max_order=17 bucket_order=3
[ 1.068722] zbud: loaded
[ 1.076491] NFS: Registering the id_resolver key type
[ 1.076556] Key type id_resolver registered
[ 1.076566] Key type id_legacy registered
[ 1.076589] nfs4filelayout_init: NFSv4 File Layout Driver Registering…
[ 1.076937] fuse init (API version 7.26)
[ 1.077653] SGI XFS with ACLs, security attributes, realtime, no debug enabled
[ 1.088659] Key type asymmetric registered
[ 1.088688] Asymmetric key parser ‘x509’ registered
[ 1.088819] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[ 1.093155] io scheduler noop registered
[ 1.093175] io scheduler deadline registered
[ 1.093832] io scheduler cfq registered (default)
[ 1.093849] io scheduler mq-deadline registered
[ 1.096531] pinctrl-single 44e10800.pinmux: 142 pins at pa f9e10800 size 568
[ 1.108908] gpio-of-helper ocp:cape-universal: ready
[ 1.120402] wkup_m3_ipc 44e11324.wkup_m3_ipc: could not get rproc handle
[ 1.123163] Serial: 8250/16550 driver, 6 ports, IRQ sharing disabled
[ 1.126968] 44e09000.serial: ttyS0 at MMIO 0x44e09000 (irq = 30, base_baud = 3000000) is a 8250
[ 1.978720] console [ttyS0] enabled
[ 1.983427] 48022000.serial: ttyS1 at MMIO 0x48022000 (irq = 31, base_baud = 3000000) is a 8250
[ 1.993357] 48024000.serial: ttyS2 at MMIO 0x48024000 (irq = 32, base_baud = 3000000) is a 8250
[ 2.003243] 481a6000.serial: ttyS3 at MMIO 0x481a6000 (irq = 33, base_baud = 3000000) is a 8250
[ 2.013089] 481a8000.serial: ttyS4 at MMIO 0x481a8000 (irq = 34, base_baud = 3000000) is a 8250
[ 2.022942] 481aa000.serial: ttyS5 at MMIO 0x481aa000 (irq = 35, base_baud = 3000000) is a 8250
[ 2.035492] omap_rng 48310000.rng: Random Number Generator ver. 20
[ 2.043240] [drm] Initialized vgem 1.0.0 20120112 for virtual device on minor 0
[ 2.050847] usbcore: registered new interface driver udl
[ 2.065067] at24 2-0054: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 2.072397] at24 2-0055: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 2.079586] at24 2-0056: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 2.086769] at24 2-0057: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 2.094319] eqep 48300180.eqep: ver. 1.0
[ 2.098519] eqep 48300180.eqep: count_mode:0
[ 2.102860] eqep 48300180.eqep: invert_qa:1
[ 2.107090] eqep 48300180.eqep: invert_qb:1
[ 2.111318] eqep 48300180.eqep: invert_qi:0
[ 2.115545] eqep 48300180.eqep: invert_qs:0
[ 2.119771] eqep 48300180.eqep: swap_inputs:0
[ 2.124171] eqep 48300180.eqep: QDECCTL:0x0180
[ 2.128658] eqep 48300180.eqep: QPOSINIT:0x00000000
[ 2.133581] eqep 48300180.eqep: QPOSMAX:0xffffffff
[ 2.138424] eqep 48300180.eqep: QPOSCNT:0x00000000
[ 2.143261] eqep 48300180.eqep: omit_interrupt:0
[ 2.147923] eqep 48300180.eqep: QEINT:0x0800
[ 2.152235] eqep 48300180.eqep: QUPRD:0x05f5e100
[ 2.156895] eqep 48300180.eqep: QEPCTL:0x009e write
[ 2.161818] eqep 48300180.eqep: QEPCTL:0x009e read
[ 2.166669] eqep 48300180.eqep: irq:130, clk_rate:100000000
[ 2.172541] eqep 48302180.eqep: ver. 1.0
[ 2.176645] eqep 48302180.eqep: count_mode:0
[ 2.180975] eqep 48302180.eqep: invert_qa:1
[ 2.185201] eqep 48302180.eqep: invert_qb:1
[ 2.189427] eqep 48302180.eqep: invert_qi:0
[ 2.193655] eqep 48302180.eqep: invert_qs:0
[ 2.197880] eqep 48302180.eqep: swap_inputs:0
[ 2.202279] eqep 48302180.eqep: QDECCTL:0x0180
[ 2.206766] eqep 48302180.eqep: QPOSINIT:0x00000000
[ 2.211687] eqep 48302180.eqep: QPOSMAX:0xffffffff
[ 2.216523] eqep 48302180.eqep: QPOSCNT:0x00000000
[ 2.221359] eqep 48302180.eqep: omit_interrupt:0
[ 2.226020] eqep 48302180.eqep: QEINT:0x0800
[ 2.230332] eqep 48302180.eqep: QUPRD:0x05f5e100
[ 2.234991] eqep 48302180.eqep: QEPCTL:0x009e write
[ 2.239914] eqep 48302180.eqep: QEPCTL:0x009e read
[ 2.244763] eqep 48302180.eqep: irq:132, clk_rate:100000000
[ 2.250593] eqep 48304180.eqep: ver. 1.0
[ 2.254702] eqep 48304180.eqep: count_mode:0
[ 2.259035] eqep 48304180.eqep: invert_qa:1
[ 2.263263] eqep 48304180.eqep: invert_qb:1
[ 2.267489] eqep 48304180.eqep: invert_qi:0
[ 2.271715] eqep 48304180.eqep: invert_qs:0
[ 2.275940] eqep 48304180.eqep: swap_inputs:0
[ 2.280339] eqep 48304180.eqep: QDECCTL:0x0180
[ 2.284826] eqep 48304180.eqep: QPOSINIT:0x00000000
[ 2.289747] eqep 48304180.eqep: QPOSMAX:0xffffffff
[ 2.294582] eqep 48304180.eqep: QPOSCNT:0x00000000
[ 2.299417] eqep 48304180.eqep: omit_interrupt:0
[ 2.304078] eqep 48304180.eqep: QEINT:0x0800
[ 2.308388] eqep 48304180.eqep: QUPRD:0x05f5e100
[ 2.313048] eqep 48304180.eqep: QEPCTL:0x009e write
[ 2.317970] eqep 48304180.eqep: QEPCTL:0x009e read
[ 2.322817] eqep 48304180.eqep: irq:134, clk_rate:100000000
[ 2.404253] libphy: Fixed MDIO Bus: probed
[ 2.409398] CAN device driver interface
[ 2.414782] c_can_platform 481cc000.can: c_can_platform device registered (regs=fa1cc000, irq=41)
[ 2.424916] c_can_platform 481d0000.can: c_can_platform device registered (regs=fa1d0000, irq=42)
[ 2.489690] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6, bus freq 1000000
[ 2.497450] davinci_mdio 4a101000.mdio: detected phy mask fffffffe
[ 2.504670] MDIO: davinci_mdio: dt: updated phy_id[0] from phy_mask[fffffffe]
[ 2.526422] libphy: 4a101000.mdio: probed
[ 2.530713] davinci_mdio 4a101000.mdio: phy[0]: device 4a101000.mdio:00, driver SMSC LAN8710/LAN8720
[ 2.541275] cpsw 4a100000.ethernet: Detected MACID = 00:35:ff:90:27:1e
[ 2.548164] cpsw 4a100000.ethernet: initialized cpsw ale version 1.4
[ 2.554655] cpsw 4a100000.ethernet: ALE Table size 1024
[ 2.560025] cpsw 4a100000.ethernet: cpts: overflow check period 1250 (jiffies)
[ 2.571282] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 2.577973] ehci-platform: EHCI generic platform driver
[ 2.583731] ehci-omap: OMAP-EHCI Host Controller driver
[ 2.590147] usbcore: registered new interface driver usb-storage
[ 2.599638] am335x-phy-driver 47401300.usb-phy: 47401300.usb-phy supply vcc not found, using dummy regulator
[ 2.613029] am335x-phy-driver 47401b00.usb-phy: 47401b00.usb-phy supply vcc not found, using dummy regulator
[ 2.627706] musb-hdrc musb-hdrc.1: MUSB HDRC host driver
[ 2.633142] musb-hdrc musb-hdrc.1: new USB bus registered, assigned bus number 1
[ 2.640943] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.647816] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.655097] usb usb1: Product: MUSB HDRC host driver
[ 2.660108] usb usb1: Manufacturer: Linux 4.14.71-ti-r80 musb-hcd
[ 2.666251] usb usb1: SerialNumber: musb-hdrc.1
[ 2.671865] hub 1-0:1.0: USB hub found
[ 2.675870] hub 1-0:1.0: 1 port detected
[ 2.692434] omap_rtc 44e3e000.rtc: registered as rtc0
[ 2.699252] i2c /dev entries driver
[ 2.704171] Driver for 1-wire Dallas network protocol.
[ 2.713084] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[ 2.720796] softdog: initialized. soft_noboot=0 soft_margin=60 sec soft_panic=0 (nowayout=0)
[ 2.731183] cpuidle: enable-method property ‘ti,am3352’ found operations
[ 2.739055] sdhci: Secure Digital Host Controller Interface driver
[ 2.745355] sdhci: Copyright(c) Pierre Ossman
[ 2.750999] omap_hsmmc 48060000.mmc: Got CD GPIO
[ 2.796131] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.810423] ledtrig-cpu: registered to indicate activity on CPUs
[ 2.817192] omap-aes 53500000.aes: OMAP AES hw accel rev: 3.2
[ 2.823328] omap-aes 53500000.aes: will run requests pump with realtime priority
[ 2.833494] omap-sham 53100000.sham: hw accel on OMAP rev 4.3
[ 2.843849] hidraw: raw HID events driver (C) Jiri Kosina
[ 2.850703] usbcore: registered new interface driver usbhid
[ 2.856633] usbhid: USB HID core driver
[ 2.861116] remoteproc remoteproc0: wkup_m3 is available
[ 2.868497] mmc0: host does not support reading read-only switch, assuming write-enable
[ 2.882340] wireguard: WireGuard 0.0.20180925 loaded. See www.wireguard.com for information.
[ 2.882347] wireguard: Copyright (C) 2015-2018 Jason A. Donenfeld Jason@zx2c4.com. All Rights Reserved.
[ 2.883186] NET: Registered protocol family 10
[ 2.903067] Segment Routing with IPv6
[ 2.903161] mip6: Mobile IPv6
[ 2.903179] NET: Registered protocol family 17
[ 2.903196] can: controller area network core (rev 20170425 abi 9)
[ 2.903281] NET: Registered protocol family 29
[ 2.903411] Key type dns_resolver registered
[ 2.903416] mpls_gso: MPLS GSO support
[ 2.903650] omap_voltage_late_init: Voltage driver support not added
[ 2.904243] PM: Cannot get wkup_m3_ipc handle
[ 2.904441] ThumbEE CPU extension supported.
[ 2.904467] Registering SWP/SWPB emulation handler
[ 2.905669] registered taskstats version 1
[ 2.905801] zswap: loaded using pool lzo/zbud
[ 2.912773] Btrfs loaded, crc32c=crc32c-generic
[ 2.912868] ima: No TPM chip found, activating TPM-bypass! (rc=-19)
[ 2.912890] ima: Allocated hash algorithm: sha256
[ 2.996482] mmc0: new high speed SDHC card at address 21fb
[ 3.004525] mmcblk0: mmc0:21fb APPSD 15.0 GiB
[ 3.010696] mmcblk0: p1
[ 3.040102] input: tps65217_pwr_but as /devices/platform/ocp/44e0b000.i2c/i2c-0/0-0024/tps65217-pwrbutton/input/input0
[ 3.051555] tps65217 0-0024: TPS65217 ID 0xe version 1.2
[ 3.057460] at24 0-0050: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 3.064548] omap_i2c 44e0b000.i2c: bus 0 rev0.11 at 400 kHz
[ 3.071915] remoteproc remoteproc0: powering up wkup_m3
[ 3.081537] remoteproc remoteproc0: Booting fw image am335x-pm-firmware.elf, size 217168
[ 3.091774] PM: Cannot get wkup_m3_ipc handle
[ 3.096559] remoteproc remoteproc0: remote processor wkup_m3 is now up
[ 3.096581] wkup_m3_ipc 44e11324.wkup_m3_ipc: CM3 Firmware Version = 0x193
[ 3.111733] omap_rtc 44e3e000.rtc: setting system clock to 2000-01-01 00:00:01 UTC (946684801)
[ 3.120719] of_cfs_init
[ 3.123421] of_cfs_init: OK
[ 3.127698] ALSA device list:
[ 3.130804] No soundcards found.
[ 3.138936] Freeing unused kernel memory: 1024K
Loading, please wait…
[ 3.601535] random: systemd-udevd: uninitialized urandom read (16 bytes read)
[ 3.614709] random: systemd-udevd: uninitialized urandom read (16 bytes read)
[ 3.627684] random: udevadm: uninitialized urandom read (16 bytes read)
Begin: Loading essential drivers … done.
Begin: Running /scripts/init-premount … done.
Begin: Mounting root file system … Begin: Running /scripts/local-top … done.
Begin: Running /scripts/local-premount … Scanning for Btrfs filesystems
done.
[ 31.907656] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
done.
Begin: Running /scripts/local-bottom … done.
Begin: Running /scripts/init-bottom … done.
[ 32.072106] EXT4-fs error (device mmcblk0p1): ext4_lookup:1586: inode #2: comm mount: deleted inode referenced: 655362
[ 32.230544] EXT4-fs error (device mmcblk0p1): ext4_lookup:1586: inode #400456: comm run-init: deleted inode referenced: 525501
Target filesystem doesn’t have requested /o[ 32.256086] EXT4-fs error (device mmcblk0p1): ext4_lookup:1586: inode #2: comm run-init: deleted inode 5
[ 32.327720] EXT4-fs error (device mmcblk0p1): ext4_lookup:1586: inode #2: comm run-init: deleted inode referenced: 786433
run-init: /bin/init: Structure needs cleaning[ 32.346270] EXT4-fs error (device mmcblk0p1): ext4_lookup:1586: inode #2: comm run-init: deleted inod3
Enter ‘help’ for a list of built-in commands.
(initramfs) chmod
BusyBox v1.22.1 (Debian 1:1.22.0-19+b3) multi-call binary.
Usage: chmod [-Rcvf] MODE[,MODE]… FILE…
Each MODE is one or more of the letters ugoa, one of the
symbols ±= and one or more of the letters rwxst
    -R      Recurse
    -c      List changed files
    -v      List all files
    -f      Hide errors
(initramfs) chmod 777 /bin/init
chmod: /bin/init: No such file or directory
(initramfs) cd /bin
(initramfs) ls
[ fgrep mount sync
[[ find mt tac
ar fold mv tail
ash free nc tar
awk fstype netstat taskset
basename ftpget nfsmount tee
btrfs ftpput nslookup telnet
btrfs-zero-log getopt nuke test
bunzip2 grep od tftp
busybox groups openvt time
bzcat gunzip patch timeout
bzip2 gzip pidof top
cal halt ping touch
cat head ping6 tr
chgrp hexdump pivot_root traceroute
chmod hostid poweroff traceroute6
chown hostname printf true
chroot id ps tty
chvt ionice pwd udevadm
clear ipcalc readlink umount
cmp ipconfig realpath uname
cp kill reboot uncompress
cpio killall renice unexpand
cryptroot-unlock kmod reset uniq
cttyhack last resume unix2dos
cut less rev unlzma
date ln rm unlzop
dc loadkeys rmdir unxz
dd logger rpm unzip
deallocvt login rpm2cpio uptime
df logname run-init usleep
diff losetup run-parts uudecode
dirname ls sed uuencode
dmesg lzcat seq vi
dnsdomainname lzma setkeycodes watch
dos2unix lzop setsid wc
du lzopcat sh wget
dumpkmap md5sum sha1sum which
dumpleases microcom sha256sum who
echo minips sha512sum whoami
egrep mkdir sleep xargs
env mkfifo sort xz
expand mknod stat xzcat
expr mktemp strings yes
false more stty zcat
(initramfs)
(initramfs) cd ../etc/
(initramfs) [ 114.109607] random: crng init done
[ 114.113051] random: 7 urandom warning(s) missed due to ratelimiting
(initramfs) ls -l init
ls: init: No such file or directory
(initramfs) pwd
/etc
(initramfs) ls ini*
ls: ini*: No such file or directory
(initramfs) ls
boottime.kmap.gz ld.so.conf motd
fstab ld.so.conf.d mtab
ld.so.cache modprobe.d udev
(initramfs)
(initramfs) chmod 777 init
chmod: init: No such file or directory
(initramfs) exit
Usage: exec run-init [-d caps] [-c consoledev] [-n] /real-root /sbin/init [args]
[ 192.193768] Kernel panic - not syncing: Attempted to kill init! exitcode=0x00000100
[ 192.193768]
[ 192.202974] CPU: 0 PID: 1 Comm: run-init Not tainted 4.14.71-ti-r80 #1
[ 192.209532] Hardware name: Generic AM33XX (Flattened Device Tree)
[ 192.215704] [] (unwind_backtrace) from [] (show_stack+0x20/0x24)
[ 192.223496] [] (show_stack) from [] (dump_stack+0x80/0x94)
[ 192.230773] [] (dump_stack) from [] (panic+0x100/0x284)
[ 192.237778] [] (panic) from [] (complete_and_exit+0x0/0x2c)
[ 192.245127] [] (complete_and_exit) from [] (do_group_exit+0x0/0xd0)
[ 192.253194] —[ end Kernel panic - not syncing: Attempted to kill init! exitcode=0x00000100
[ 192.253194]
I am not able to see the contents at development laptop also.
Better if u can suggest workable from Latest Software Images - BeagleBoard and flashing process, i m using dd as balena is giving issue too..
Regards.
Ankur
so can you stop at u-boot. i believe that you can delete emmc from u-boot.
don’t recall off hand what the commands are. but i’m sure a google will get you that info.
