Inline assembly on Beaglebone.
I have been trying to run inline assembly on Beaglebone black. I used example from this tutorial and my code is here
void main(void) { asm("mov r0,r0"); }
But when I run with gcc
gcc helloworld.c -o helloworld
gcc returns:
Error: too many memory references for mov'
My gcc version is:
GCC: gcc (Debian 4.6.3-14) 4.6.3
You are trying to use ARM machine language. If you run this on a PC with
the x86 GCC you get the error you reported. You need to either use ARM
cross-compiler on the PC or compile it on the ARM platform (beaglebone).
Why are you moving R0 to R0?
its a simple nop
