I have installed Debian on BB xM using NetInstall method described here:
http://elinux.org/BeagleBoardUbuntu#Method_2:_Use_the_NetInstall_method
Everything seams to work fine. Just for the info, here is the output
from uname -a:
Linux t3 3.2.2-x3 #1 SMP Thu Jan 26 18:35:22 UTC 2012 armv7l GNU/Linux
There is no monitor connected to BB and I was using serial console for
the installation:
sudo ./mk_mmc.sh --mmc /dev/mmcblk0 --uboot beagle_xm --serial-mode
After that, I was trying to install gst-dsp by following instructions
on the same page:
http://elinux.org/BeagleBoardUbuntu#DSP
Executing install-DSP.sh works find and after "dsp start" dsp-test
does not report any errors. However, running install-gst-dsp.sh prints
compilation errors and I hope someone can suggest what might be wrong
or provide other tips how to solve it.
The following is what I see when (re)running install-gst-dsp.sh. After
that, if I try to run gst-inspect | grep dsp there is no such plugins
found. I would really appreciate any suggestions.
Andrey.
root@t3:~# ./install-gst-dsp.sh
64 bytes from bk-in-f99.1e100.net (173.194.69.99): icmp_req=1 ttl=50
time=62.2 ms
Reading package lists... Done
Building dependency tree
Reading state information... Done
build-essential is already the newest version.
git-core is already the newest version.
gstreamer-tools is already the newest version.
libgstreamer0.10-dev is already the newest version.
pkg-config is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
CLEAN clean
removed `dsp_bridge.o'
removed `gstdspbase.o'
removed `gstdspbuffer.o'
removed `gstdspdummy.o'
removed `gstdsph263enc.o'
removed `gstdspjpegenc.o'
removed `gstdspmp4venc.o'
removed `gstdspvdec.o'
removed `gstdspvenc.o'
removed `log.o'
removed `plugin.o'
removed `util.o'
removed `dsp_bridge.d'
removed `gstdspbase.d'
removed `gstdspbuffer.d'
removed `gstdspdummy.d'
removed `gstdsph263enc.d'
removed `gstdspjpegenc.d'
removed `gstdspmp4venc.d'
removed `gstdspparse.d'
removed `gstdspvdec.d'
removed `gstdspvenc.d'
removed `log.d'
removed `plugin.d'
removed `util.d'
Already up-to-date.
CC plugin.o
CC gstdspbuffer.o
CC gstdspdummy.o
CC gstdspbase.o
CC gstdspvdec.o
CC gstdspvenc.o
CC gstdsph263enc.o
CC gstdspmp4venc.o
CC gstdspjpegenc.o
CC dsp_bridge.o
CC util.o
CC log.o
CC gstdspparse.o
/tmp/cczYeE5F.s: Assembler messages:
/tmp/cczYeE5F.s:68: Error: selected processor does not support `rev ip,ip'
/tmp/cczYeE5F.s:162: Error: selected processor does not support `rev r3,r3'
/tmp/cczYeE5F.s:560: Error: selected processor does not support `rev r2,r2'
/tmp/cczYeE5F.s:604: Error: selected processor does not support `rev r6,r6'
/tmp/cczYeE5F.s:749: Error: selected processor does not support `rev r1,r1'
/tmp/cczYeE5F.s:819: Error: selected processor does not support `rev r3,r3'
/tmp/cczYeE5F.s:943: Error: selected processor does not support `rev r2,r2'
/tmp/cczYeE5F.s:1000: Error: selected processor does not support `rev sl,sl'
/tmp/cczYeE5F.s:1187: Error: selected processor does not support `rev ip,ip'
/tmp/cczYeE5F.s:1279: Error: selected processor does not support `rev r2,r2'
/tmp/cczYeE5F.s:2153: Error: selected processor does not support `rev r3,r3'
/tmp/cczYeE5F.s:2188: Error: selected processor does not support `rev r7,r7'
/tmp/cczYeE5F.s:2248: Error: selected processor does not support `rev r3,r3'
/tmp/cczYeE5F.s:2320: Error: selected processor does not support `rev r3,r3'
/tmp/cczYeE5F.s:2344: Error: selected processor does not support `rev r7,r7'
/tmp/cczYeE5F.s:2476: Error: selected processor does not support `rev r2,r2'
/tmp/cczYeE5F.s:2512: Error: selected processor does not support `rev r2,r2'
/tmp/cczYeE5F.s:2557: Error: selected processor does not support `rev r3,r3'
/tmp/cczYeE5F.s:2695: Error: selected processor does not support `rev r4,r4'
/tmp/cczYeE5F.s:2804: Error: selected processor does not support `rev r2,r2'
/tmp/cczYeE5F.s:2864: Error: selected processor does not support `rev r2,r2'
/tmp/cczYeE5F.s:2922: Error: selected processor does not support `rev r2,r2'
/tmp/cczYeE5F.s:2985: Error: selected processor does not support `rev r3,r3'
/tmp/cczYeE5F.s:3085: Error: selected processor does not support `rev r2,r2'
/tmp/cczYeE5F.s:3155: Error: selected processor does not support `rev r1,r1'
/tmp/cczYeE5F.s:3265: Error: selected processor does not support `rev r4,r4'
/tmp/cczYeE5F.s:3311: Error: selected processor does not support `rev r4,r4'
/tmp/cczYeE5F.s:3357: Error: selected processor does not support `rev r2,r2'
/tmp/cczYeE5F.s:3447: Error: selected processor does not support `rev r3,r3'
/tmp/cczYeE5F.s:3655: Error: selected processor does not support `rev r2,r2'
/tmp/cczYeE5F.s:3709: Error: selected processor does not support `rev r2,r2'
make: *** [gstdspparse.o] Error 1
CC gstdspparse.o
/tmp/cctMbiby.s: Assembler messages:
/tmp/cctMbiby.s:68: Error: selected processor does not support `rev ip,ip'
/tmp/cctMbiby.s:162: Error: selected processor does not support `rev r3,r3'
/tmp/cctMbiby.s:560: Error: selected processor does not support `rev r2,r2'
/tmp/cctMbiby.s:604: Error: selected processor does not support `rev r6,r6'
/tmp/cctMbiby.s:749: Error: selected processor does not support `rev r1,r1'
/tmp/cctMbiby.s:819: Error: selected processor does not support `rev r3,r3'
/tmp/cctMbiby.s:943: Error: selected processor does not support `rev r2,r2'
/tmp/cctMbiby.s:1000: Error: selected processor does not support `rev sl,sl'
/tmp/cctMbiby.s:1187: Error: selected processor does not support `rev ip,ip'
/tmp/cctMbiby.s:1279: Error: selected processor does not support `rev r2,r2'
/tmp/cctMbiby.s:2153: Error: selected processor does not support `rev r3,r3'
/tmp/cctMbiby.s:2188: Error: selected processor does not support `rev r7,r7'
/tmp/cctMbiby.s:2248: Error: selected processor does not support `rev r3,r3'
/tmp/cctMbiby.s:2320: Error: selected processor does not support `rev r3,r3'
/tmp/cctMbiby.s:2344: Error: selected processor does not support `rev r7,r7'
/tmp/cctMbiby.s:2476: Error: selected processor does not support `rev r2,r2'
/tmp/cctMbiby.s:2512: Error: selected processor does not support `rev r2,r2'
/tmp/cctMbiby.s:2557: Error: selected processor does not support `rev r3,r3'
/tmp/cctMbiby.s:2695: Error: selected processor does not support `rev r4,r4'
/tmp/cctMbiby.s:2804: Error: selected processor does not support `rev r2,r2'
/tmp/cctMbiby.s:2864: Error: selected processor does not support `rev r2,r2'
/tmp/cctMbiby.s:2922: Error: selected processor does not support `rev r2,r2'
/tmp/cctMbiby.s:2985: Error: selected processor does not support `rev r3,r3'
/tmp/cctMbiby.s:3085: Error: selected processor does not support `rev r2,r2'
/tmp/cctMbiby.s:3155: Error: selected processor does not support `rev r1,r1'
/tmp/cctMbiby.s:3265: Error: selected processor does not support `rev r4,r4'
/tmp/cctMbiby.s:3311: Error: selected processor does not support `rev r4,r4'
/tmp/cctMbiby.s:3357: Error: selected processor does not support `rev r2,r2'
/tmp/cctMbiby.s:3447: Error: selected processor does not support `rev r3,r3'
/tmp/cctMbiby.s:3655: Error: selected processor does not support `rev r2,r2'
/tmp/cctMbiby.s:3709: Error: selected processor does not support `rev r2,r2'
CLEAN clean
removed `libgstomapfb.so'
removed `log.o'
removed `omapfb.o'
removed `log.d'
removed `omapfb.d'
Already up-to-date.
CC omapfb.o
CC log.o
LINK libgstomapfb.so
install -m 755 -D libgstomapfb.so //usr/lib/gstreamer-0.10/libgstomapfb.so
CLEAN clean
Already on 'master'
Already up-to-date.
error: branch 'firmware-tmp' not found.
Branch firmware-tmp set up to track remote branch firmware from origin.
Switched to a new branch 'firmware-tmp'
`firmware/test.dll64P' -> `/lib/dsp/test.dll64P'
Switched to branch 'master'
Deleted branch firmware-tmp (was b3e097c).
CC dsp_load.o
CC dsp_bridge.o
LINK dsp-load
CC dsp_probe.o
CC log.o
LINK dsp-probe
CC dsp_test.o
LINK dsp-test
CC dsp_exec.o
LINK dsp-exec
install -m 755 dsp-load -D /usr/bin/dsp-load
install -m 755 dsp-probe -D /usr/bin/dsp-probe
install -m 755 dsp-test -D /usr/bin/dsp-test
install -m 755 dsp-exec -D /usr/bin/dsp-exec
root@t3:~# gst-inspect | grep dsp
