I am a new user to the Beagle board and have just got the Angstrom
distribution up and running on the board. I would like to profile my
ARM applications (using OProfile). Can anyone tell me if the Angstrom
distribution (I have downloaded the latest release) comes with
oprofile, and if so, what I need to do to install it.
If the Angstrom build does not come with oprofile, do I download it
from sourceforge.net? If so, can anyone tell me what the build options
need to be set to for Angstrom/Beagle board combination.
Thanks in advance,
Phil
Did you try opcontrol at command prompt ? I think oprofile is built by default.
Otherwise if you have network access on the beagleboard - try opkg update;opkg install oprofile
When I tried last using 2.6.29 omap kernels - oprofile looked to be broken. But 2.6.28 was working well.
Pratheesh
opkg install oprofile should work if you are connected to the internet
(you may need to opkg update first)
Philip
