I’m trying to install 6LBR on BBB following the instruction from here http://processors.wiki.ti.com/index.php/Cc26xx_sw_examples
and here https://github.com/cetic/6lbr/wiki/BeagleBone-Software-Configuration with no luck
There are multiple build errors.
Was anyone able to do it? If yes what is the trick?
I installed the latest Debian image on SD from here http://beagleboard.org/latest-images
Jan
I'm trying to install 6LBR on BBB following the instruction from here
Platform simplelink · contiki-ng/contiki-ng Wiki · GitHub
and here
BeagleBone Software Configuration · cetic/6lbr Wiki · GitHub with no
luck
Remember, we aren't looking over your shoulder, you need to tell us
what "errors" your seeing...
Latest Software Images - BeagleBoard
Thanks Robert,
The problem was with missing dependencies.
If anyone wants to use BBB as edge router for 6LoWPAN (running 6LBR), the proper installation instructions are
here https://github.com/cetic/6lbr/wiki/Other-Linux-Software-Configuration under “Installation from sources”
Jan
