Interconnecting two Beagle Bone Blacks
Hi
I’m trying to connect two beagle bones, such that they can communicate using TCP.
My first attempt is to use the USB cable by plugin the USB-cable into USB port one one machine and the MicroUSB port on the other.
The machine with the main USB port does not add the interface for the USB as it normally would on any other linux machine.
Here is the ifconfig
root@beaglebone:~# ifconfig
eth0 Link encap:Ethernet HWaddr 1c:ba:8c:a7:ac:26
UP BROADCAST MULTICAST MTU:1500 Metric:1
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
Interrupt:40
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:63312 errors:0 dropped:0 overruns:0 frame:0
TX packets:63312 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:5546794 (5.2 MiB) TX bytes:5546794 (5.2 MiB)
usb0 Link encap:Ethernet HWaddr 96:9f:43:e9:77:c6
inet addr:192.168.7.2 Bcast:192.168.7.3 Mask:255.255.255.252
inet6 addr: fe80::949f:43ff:fee9:77c6/64 Scope:Link
RX packets:7244 errors:0 dropped:0 overruns:0 frame:0
TX packets:6820 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:377882 (369.0 KiB) TX bytes:906342 (885.0 KiB)
I run debian on both BBBs.
I’m not 100% that the driver for that exists in ArmHF. What’s dmesg say after you plug it in?
At any rate why not a crossover cable? or through your home router?
Or a cheap switch, such as:
What’s the reason for wanting to use usb instead of the eth0 ports?
