I’m looking for a means to do real-time scheduling on a BeagleBone with the Angstrom distro. Is it possible? I’ve been trying, but failing…
Whenever I try programmatically using pthread_setschedparam, I get “Operation not permitted” errors even when logged in as root.
When I try with the “chrt” command to change a process to use SCHED_FIFO, it reports back that the process is using SCHED_OTHER, effectively ignoring my request.
If real-time is not possible with Angstrom, can anyone recommend a quick path to get there with another distro or add-on to Angstrom?
I have one simple real-time requirement. I need to detect an edge of a GPIO signal and take an action within 1 millisecond of that edge, guaranteed. I’m doing this with user space GPIO calls, blocking a thread waiting on a GPIO edge event. I’m measuring response time by watching another GPIO that I assert when the sleeping thread wakes up. Without real-time scheduling, many edge events are detected and responded to in under 1 ms, but the worst case time is sometimes as long as 20 milliseconds. I could live with 2 or 3 ms, if reliable, but 20 ms is just too slow for my application.
Would a kernel module doing the same job experience better worst-case response times?
I'm looking for a means to do real-time scheduling on a BeagleBone with the Angstrom distro. Is it possible? I've been trying, but failing...
Whenever I try programmatically using pthread_setschedparam, I get "Operation not permitted" errors even when logged in as root.
When I try with the "chrt" command to change a process to use SCHED_FIFO, it reports back that the process is using SCHED_OTHER, effectively ignoring my request.
I have one simple real-time requirement. I need to detect an edge of a GPIO signal and take an action within 1 millisecond of that edge, guaranteed. I'm doing this with user space GPIO calls, blocking a thread waiting on a GPIO edge event. I'm measuring response time by watching another GPIO that I assert when the sleeping thread wakes up. Without real-time scheduling, many edge events are detected and responded to in under 1 ms, but the worst case time is sometimes as long as 20 milliseconds. I could live with 2 or 3 ms, if reliable, but 20 ms is just too slow for my application.
I would imagine this would be no problem for a kernel module, it should even be possible in userspace, how are you blocking your thread? Are you polling an edge triggered interrupt, that's how I would do it.
As for guarantees, well, as Linux isn't realtime without additional patches then you're going to struggle to prove that it will _always_ complete within a certain time frame but with good, solid code and an understanding of exactly which part should be as close to realtime as possible, it is possible to get somewhere near.
polling an edge triggered interrupt, that’s how I would do it.
That’s what I’m doing. I configure the GPIO pin as an edge, open the value file, initialize a file descriptor set, and hang on a poll() call.
