For a project I’ve been working on, I’ve converted a BeagleBone Black wireless board to a different form factor, removing any components of the system I didn’t need. Once I tried to print and populate the board, I found that several components such as the SD card reader and importantly, the HDMI controller have been discontinued permanently. Does Beaglebone still manufacture these boards, and if so. How?
Hi @Crazycolbster , yeap, the BeagleBone Black Wireless needs a new PCB design… We found a new microSD cage, that was used in Rev C3 of the base BeagleBone Black… GitHub - beagleboard/beaglebone-black: Design and Document files for the BeagleBone Black from BeagleBoard.org
Yeap, the HDMI encoder went EOL, we did a last time buy, so we should be good for awhile. We are looking at options. Sadly the best HDMI option SIL9022A needs patches for our oldest of old images…
edit sil9021a → sil9022a
That’s unfortunate, but good to know. Thanks!
As a side question, I couldn’t find anything when I googled “SIL9021A”. Do you by chance know where I could find a datasheet for that?
Sorry it helps i type the correct part… Updated…
and linux driver…
if you don’t need audio, the other options is:
TFP410 (video only)
Speaking of discontinued or hard to get.
Anyone have comments on how well this might work? I have several beagles that are back in their kennel, barking a lot and very bored.
John
RobertCNelson
March 25
and linux driver…
TFP410 (video only)
I’ve personally backed that project, i was kinda expecting more users would do the same.
Hello Sir,
@RobertCNelson , does this put a damper on already mfg. boards that one may own or find out in userland?
P.S. I am asking b/c I found my board(s), the BBBW, are working well and they do not have any faults so far due to ideas in this post.
I’m confused… Are you asking if an EOL part will cause breakage on existing finished boards in the hands of users and current shipping images?
@RobertCNelson , yes sir. I know the parts are obsolete now but does this control any aspect to already, “existing finished” boards in my hands?
Hi @silver2row , i’m really confused on what you want me to do…
The NXP HDMI encoder went EOL, they stopped making them…
You have a board with the part that works today, it worked yesterday, it’ll work tomorrow…
What “exactly” are you asking me to do?
At some point, “new” boards will show up with a replacement HDMI encoder, that’s it… Future boards will ‘eventually’ need a replacement HDMI encoder. Your board that works today, will not magically stop working because we needed to replace part… (that would be very bad)…
Hello @RobertCNelson ,
Nothing sir. I do not expect you to do anything. I was just wondering.
Any update to this topic? We just tried to place an order and found out that it (and two previous orders) aren’t being filled due to the redesign in progress. We can apparently re-order if we place a minimum order of 1000 boards as a custom build.
Anyone got any updates on this topic? As of now I can only see 60 of these in stock online.
I need to know whether I need to update an old design with a plug-in replacement (if anyone can recommend any that would be great) or whether the BBBW has just been refreshed ans is being manufactured.
Does anyone have an update on this? In Digikey it says that is discontinued.
