On Tue, 25 Jun 2019 10:23:10 -0700 (PDT),
chicagobob123@gmail.com declaimed the
following:
This is something that I thought I would find easily. I have a 12c backpack
that connects to a 16x2 LCD panel. https://www.adafruit.com/product/292
I thought for sure I could download Python code to use it but I guess not.
I installed this from adafruit
pip3 install adafruit-circuitpython-charlcd
That package is primarily to be used with their version of
"circuitpython" which runs on microcontroller boards (Adafruit Metro M4,
for example) that don't have an operating system.
Supported boards are at
However... The circuitpython documentation has a section on using it on
a Raspberry-Pi... Using an interface package to translate the CircuitPython
hardware I/O to Linux compatible operations.
You will probably have to follow that and edit the needed files to map the
I/O to the Beagle equivalent. (Actually, it looks like Beaglebone Black and
Pocket Beagle definitions were added April 2, so you might get away with
just installing that library)
