I have soldered a 15 ohm power resistor between SYS_5V (P9.8) and DGND (P9.2). This increases SYS_5V load by 333mA. After three days of test I can confirm that random reboot frequency have not changed so it seems that the current load is not the problem.
Follow your finding on the unexpected TPS65217C behavior, I patched the tps65217 driver with irq handling. The 3.2 kernel does not handle nNMI/PMIC_INT interrupt; the 3.8 kernel does. I placed printk in the interrupt handler and got the same result as yours. The PMIC_INT was issued every 2 seconds which is caused by the USBI flag in the TPS65217C interrupt register.
[ 217.095367] tps65217_irq: USB power status change
[ 217.259338] tps65217_irq: USB power status change
[ 219.096801] tps65217_irq: USB power status change
[ 219.256103] tps65217_irq: USB power status change
[ 221.094177] tps65217_irq: USB power status change
[ 221.262084] tps65217_irq: USB power status change
[ 223.095611] tps65217_irq: USB power status change
[ 223.259033] tps65217_irq: USB power status change
[ 225.097045] tps65217_irq: USB power status change
[ 225.255859] tps65217_irq: USB power status change
[ 227.094024] tps65217_irq: USB power status change
[ 227.262908] tps65217_irq: USB power status change
[ 229.095489] tps65217_irq: USB power status change
I paste part of the log above. The actual timing of USBI status change is at a inteval of 0.16, 1.84 seconds interval. I lowered the CPU frequency from 1G to 300MHz. I don’t observe any change in this timing.
I also loaded an Angstrom (3.8 kernel) on the BBB. By inspecting the interrupts (cat /proc/interrupts), it seems that 3.8 kernel does NOT have the same behavior. I will be checking the PMIC configuration difference between 3.2 and 3.8 kernel.
Also, if USB is connected to the mini USB connector. This behavior is going away.
By the way when I connected 5vdc directly to the additional ldo ic I have grounded Vusb as well and the board worked without any reboot issue during 1 week. Probably I was in a wrong direction thinking that it was totally depending on the current overload at tps65217. One of the ideas was about the USB grounding and I combined all solutions at once
Will test only grounded Vusb to check your hypothesis
This appears to be related to USB OTG. The VBUS, ID, and D+ pins on USB0 are all generating 0.5 Hz signals. The signal on VBUS that the TPS65217C is detecting may be OTG probing.
This may not be the cause of the random reboots, but it’s worth some examination.
I can confirm that the pulsing detected by PMIC on USB_DC signal is the probing from USB-OTG.
After I disabled the USB-OTG in the kernel, the system has never rebooted. Btw I also re-loaded Angstrom image (3.8 kernel) and Andrew’s Android image (with 3.8 kernel). I did not observe USB-OTG probing pulses on the VBus. I believe in the 3.8 kernel, the USB-OTG has not been implemented/enabled. That might be reason why it seems that 3.8 kernel doesn’t have the random reboot behavior.
In case anyone wants to test it out, here is the change in the source code (NOTE: ignore the line and column numbers; just search for the struct “static struct omap_musb_board_data musb_board_data” ):
As of late, the BBB actually powers down completely (power LED is off). And pressing the power button, reset button, even BOOT button does nothing. Hell, even unplugging and plugging back in the power doesn’t do anything. If I wait several minutes I can get the thing to power on…for about 50seconds then it goes dead again.
Appears that it is, as others suggested, a physical issue…crap.
Please request an RMA so we can look at it. Make sure it is in the failed state and that you let the RMA team know how to get it in that state and recover.
Hi
any news on this issue ? I have the same problem with my beagle xm, with linux not running anything and it still reboots after 1 to 5 minutes
If there is anything electric to do to make this work (add a capacity in front of the 5V power supply, …) I can do it, I have lots of electronic tools at work
Btw, I am logged in through tty and I see
Broadcast message from root@arm
(unknown) at 11:40 ...
The system is going down for reboot NOW!
[ 143.036193] Restarting system.
so somehow it might not be a complete physical problem, the system knows about it (Linux version 3.7.10-x9 on Ubuntu 12.10 and beagleboard xm)
I RMA-ed it using the Beagle Board website. Took about 20 days, round trip, to get the board back. I doubt even if I had the skills to replace circuit chips, I’d would have been able to find it…I have no idea how they diagnose issues for their boards.
But you may have another issue. As mine eventually stopped booting back up after the randomly rebooting for several days. Might be harder for them to find the issue. As they told me to leave the board in a “failed state” and ship it to them. But if your’s is rebooting, then it will never be in a ‘failed state’.
Hi Robert,
Do you know more detail about the time jump issue in uboot? for example, fix commit number, or some words used for the commit?
I am interested to find out what exactly the fixes are, but there are too many commits in uboot and I need some thing to search with.
Strange … I checked the commit and found it had been included within the v2013.04 uboot release … but my BB board is still experienced with this time jump issue one/two times per day. Could there be anything else?
Regards.
Damien
