I am currently getting some BBB PCBs manufactured. I have used the gerber data and BoM supplied but the PCB manufacturer is reporting an issue with the specified connectors not fitting because the PCB hole size is too small to take the pins.
The connector specified is: SSHS-123-D-02-GT-LF which has recommended hole size of 0.040 (1.2mm)
The PCB manufacturer is telling that the hole size in the drill file is: T04 Holesize 4. = 30.000000 Tolerance = +3.000000/-3.000000 PLATED MILS Quantity = 96
The data I have sent to them is from the file: Beaglebone_blackrevB4_MFG.zip
I am unsure what has happened here. Obviously these boards can be manufactured with the data.
I’d be grateful of any input and also if anyone can specify a connector that will fit holes of that size?
We don’t have any issues. We do look for a tight fit to prevent moving during the soldering process. We have used these same connectors for a very long time now without issue.
I can now confirm that my PCB supplier has now successfully fitted connectors P8, P8 and I have taken delivery of my first-off sample.
Gerald, are you able to point me to some instructions on how I get my “virgin” beagleboardblack up and running?
I have tried using an SD card with a known good android image but this does not work, the error I get from hyperterminal is:
U-Boot SPL 2011.09 (Nov 27 2013 - 10:43:10)
Chipsee AM335x EVM Board
Incorrect magic number in EEPROM
read_eeprom() failure. continuing with ddr3
OMAP SD/MMC: 0
mmc_send_cmd: timedout waiting for cmddis!
** Can’t read from device 0 **
spl: fat register err - -1
ERROR ### Please RESET the board
I’m not surprised that it doesn’t yet work because there must be some programming/setup to be done on the board itself before it will operate and this hasn’t yet been done.
That should be fine.. Here's the init script i use to flash the eMMC,
notice how it programs the eeprom first before calling the eMMC
flasher script at the bottom.. So in the end it'll fail, but the
eeprom will be programmed with the beaglebone black eeprom..
