I have been trying to install Ubuntu on my Beagle board recently with
little success. I used the netinstall method found at http://elinux.org/BeagleBoardUbuntu#NetInstall_Method . This method
takes forever to complete, I chose to install Ubuntu netbook when
given the option. After everything completed it reboots and goes to an
orange screen and just sits there. I have xM-B and am powering with
USB hooked up to my desktop.
little success. I used the netinstall method found at BeagleBoardUbuntu - eLinux.org . This method
given the option.
Yeap, it will, there's atleast 700Mb of packages it'll need to
download and then install..
Little weird, can you share a serial boot log?
That setup is not supported on the xM.. Plug in a 5volt DC adapter,
the issue you see above can be explained by the kernel crashing due to
lack of power..
Once you add a 5volt DC adapter and it still fail's i'll need that boot log..
