First of all, I am new to linux and the beagleboard so please excuse
me if my questions are less than scholarly.
I am having a few issues that I am attempting to resolve right now so
that I can get up and running on a project that I am doing. First off:
I am using minicom from ubuntu 10.10 to interact with the BB.
I have used the angstrom-distro .org how to video to get angstrom
running. (I think this video will not work for the xm but I am not
sue)
I have used this tutorial also:
http://treyweaver.blogspot.com/2010/10/installing-angstrom-on-beagleboard-xm.html
The original angstrom image that came with the XM works flawlessly.
I have also used two angstrom images. One heavier from angstrom-
dist.org and one that was created by narcissus.
Card formatting seems to be what it is supposed to be. A 100Mb fat32
partition with the rest being ext2 or ext3 by cylinders.
1) My first problem is that I can't get my own SD card images to boot
on start up. The original angstrom image works great and if I
interrupt the boot process and switch the SD cards to my angstrom
image, it works.
When it is not working, all I see in minicom are some garbage
character when I reset the board. Clearly, I am having an issue with
getting it to boot and not the image I have.
Minicom garbage:
Welcome to minicom 2.4
OPTIONS: I18n
Compiled on Jun 3 2010, 13:48:00.
Port /dev/ttyUSB0
Press CTRL-A Z for help on special
keys
60
I have tried copying the boot files from the included angstrom image
to my card. Same issue. I know I need the correct files inside my boot
partition but I can't seem to get it right.
Is there some formatting of the OMAP that I have to do to get it to
work correctly? At the end of the video tutorial I did, one is
requested to mess around with those setting which I did do but they
might not apply to the xm. When I did use that tutorial, the boot
process did not give me garbage but instead went looking for non-
existant NAND memory. Can I change that boot process to make it work?
This was by far as close as I got to making it work.
Basically, I am open to try anything.
My second problem is probably much more trivial. When I use opkg
install <pkg>, it installs the pkg to my ram no matter what I do.
Obviously, I would like for it to install to my SD card so I have some
disk space to work with and more importantly, so it is not volatile. I
have tried messing around with commands but I can't figure it out.
Any help would be greatly appreciated!
Thank you,
Eric
