I am trying to use d D-Link USB Ethernet with Debian 8.7 running on BBB.
The device describes itself as: “D-Link DUB-1312 USB 3.0 to Gigabit Ethernet Adapter”.
The lsusb output is:
“Bus 001 Device 002: ID 2001:4a00 D-Link Corp.”
The driver for this device is ax88179_178a which is loaded into the kernel as a module.
The driver finds the device:
[ 21.274812] ax88179_178a 1-1:1.0 eth1: register ‘ax88179_178a’ at usb-musb-hdrc.1.auto-1, D-Link DUB-1312 USB 3.0 to Gigabit Ethernet Adapter, e4:6f:13:f3:df:43
[ 21.280951] usbcore: registered new interface driver ax88179_178a
[ 21.791100] omap-sham 53100000.sham: hw accel on OMAP rev 4.3
[ 21.836014] omap-aes 53500000.aes: OMAP AES hw accel rev: 3.2
[ 23.920271] asoc-simple-card sound: i2s-hifi <-> 48038000.mcasp mapping ok
[ 24.088282] ax88179_178a 1-1:1.0 enxe46f13f3df43: renamed from eth1
If I manually bring enxe46f13f3df43 up, then I can configure it and get a working connection to the internet.
I wanted to automatically bring up the device to use DHCP but when I added:
auto enxe46f13f3df43
iface enxe46f13f3df43 inet dhcp
to /etc/network/interfaces the interface was not brought up automatically (even after reboot)
I tried to statically configured the device with:
iface enxe46f13f3df43 inet static
address 192.168.1.100
network 255.255.255.0
gateway 192.168.1.1
but the interface also did not come up automatically in this case. It would come up correctly configured if I manually ran ifup enxe46f13f3df43.
I also tried to change the interface name to eth1 using /etc/udev/rules.d/71-local-rules
Auto generated by RootStock-NG: setup_sdcard.sh
udevadm info -q all -p /sys/class/net/eth0 --attribute-walk
BeagleBone: net device ()
SUBSYSTEM==“net”, ACTION==“add”, KERNELS==“enxe46f13f3df43”, ATTR{dev_id}==“0x0”, ATTR{type}==“1”, NAME=“eth1”
I also tried to use the systemd.link feature by creating a file called /etc/systemd/network/10-local.link with these contents:
[Match]
Driver=ax88179_178a
[Link]
Name=eth1
So, there are two problems here:
the interface is not being configured automatically
I can’t rename the interface with either udevd or systemd.link configuration
Can anyone help me understand why this isn’t working as expected?
