I’m running ubuntu on the Beaglebone A5. I’m using jack to capture sound from a custom-made soundcard connected to the beaglebone. Until very recently jack was running just fine, however, suddenly I can’t start the jack server anymore as it crashes with a ‘Bus error’.
Only a few hours ago I was able to start a jack server with:
jackd -d alsa -p 256 -n 4 -C hw:0 -r 48000 -i 8
Then I just installed g++ and libjack-dev packages in order to compile a simple jack client. Since then starting a jack server gives me:
ubuntu@arm:~$ jackd -v -d alsa -p 256 -n 4 -C hw:0 -r 48000 -i 8
jackd 0.121.0
Copyright 2001-2009 Paul Davis, Stephane Letz, Jack O’Quinn, Torben Hohn and others.
jackd comes with ABSOLUTELY NO WARRANTY
This is free software, and you are welcome to redistribute it
under certain conditions; see the file COPYING for details
getting driver descriptor from /usr/lib/arm-linux-gnueabi/jack/jack_oss.so
getting driver descriptor from /usr/lib/arm-linux-gnueabi/jack/jack_net.so
getting driver descriptor from /usr/lib/arm-linux-gnueabi/jack/jack_alsa.so
getting driver descriptor from /usr/lib/arm-linux-gnueabi/jack/jack_dummy.so
JACK compiled with System V SHM support.
server `default’ registered
loading driver …
registered builtin port type 32 bit float mono audio
registered builtin port type 8 bit raw midi
clock source = system clock via clock_gettime
start poll on 3 fd’s
new client: alsa_pcm, id = 1 type 1 @ 0x17340 fd = -1
apparent rate = 48000
creating alsa driver … -|hw:0|256|4|48000|8|0|nomon|swmeter|-|32bit
control device hw:0
configuring for 48000Hz, period = 256 frames (5.3 ms), buffer = 4 periods
ALSA: final selected sample format for capture: 32bit integer little-endian
ALSA: use 16 periods for capture
new buffer size 256
resizing port buffer segment for type 0, one buffer = 1024 bytes
resizing port buffer segment for type 1, one buffer = 1024 bytes
registered port system:capture_1, offset = 1024
registered port system:capture_2, offset = 2048
registered port system:capture_3, offset = 3072
registered port system:capture_4, offset = 4096
registered port system:capture_5, offset = 5120
registered port system:capture_6, offset = 6144
registered port system:capture_7, offset = 7168
registered port system:capture_8, offset = 8192
++ jack_sort_graph
++ jack_rechain_graph():
– jack_rechain_graph()
– jack_sort_graph
830 waiting for signals
Bus error
It doesn’t seem to be a problem with ALSA as I’m able to record via ALSA. When trying to start jackd the kernel gives me two kind of nebulous messages:
[ 1870.399810] Alignment trap: not handling instruction edc76a06 at [<401375ca>]
[ 1870.407562] Unhandled fault: alignment exception (0x801) at 0x400ea1e6
I really would appreciate any kind of suggestion or hint on this!
Chris
