Hi, everyone! I try connect PS3 joystick to BBB. Automatically it doesn’t work. joydev module built-in kernel. I try manual connect http://ubuntuforums.org/showthread.php?t=338457 , but failed. How I can connect usb joystick to BBB?
I don’t know if this will help but I got my xbox 360 wired controller to work with the BBB (and even ROS Hydro) running Ubuntu 13.04
http://andrewdai.co/xbox-controller-ros.html
What OS version are you on?
I have the same system Ubuntu 13.04 and ROS Hydro too
I tried connect PS3 joystick used xboxdrv. But it doesn’t worked, although it should be as in manual.
Which kernel version do you have? uname -r
Could you show me this file /proc/config.gz? I just want to confirm it.
3.8.13-bone28
Thanks for answer, but I found solver. I connected joystick via bluetooth. http://answers.ros.org/question/102676/ps3joy-slow-output/?answer=134786#post-id-134786
