Can someone please explain to me the image_copy codec engine example
(besides the obvious copying images!).
The example reads frames from the supplied in.dat file, encodes them
then decodes them again to reproduce the input file. Am I correct in
saying in.dat is an image in byte array/binary format, it then encodes
it to a JPEG, then decodes it to its original format?
My aim for this is to decode JPEG images into a byte array to apply
image processing algorithms.
Also do you think using the codec engine the best way to approach this
problem?
Any help is much appreciated.
Stuart
