JTAG Dongles for CCS?
Hi Folks,
My first posting (and 1st project with the OMAP part).
We've designed a product using the BB schematics as the
basis, and 1st boards don't work. (surprise, surprise).
Anyhow, I'd like to hook up a JTAG dongle & see what is
really happening, but was quite shocked by the prices of the
'suggested' dongles that TI recommends.
I've got a mini N-link here that I've used on other ARM based
parts... would there be any patches / add-ons that might allow
me to use this for debugging?
Or other possible low<er> cost options.
Tim
Hi Tim,
You could go for at XDS100v2 (79$) together with CCSv4 - I just got one, but
haven't yet had time to try it out, but it's supposed to work :slight_smile:
You can get it from:
http://www.ti-estore.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=TMD
SEMU100v2U-14T
Best regards - Good luck and welcome to the OMAP world :slight_smile:
  Søren
Greetings:
I recently purchased a Rev C4 board with the TI 14-pin JTAG connector. TI does not recommend the 14-pin JTAG connection for new designs, and the OMAP processor has trace capability not available with the 14-pin connector.
So, does the -xM design still have the TI 14-pin JTAG connector?
Regards:
Mike Nelson
http://michaeltnelson.com
They don’t? On the latest couple of TI Reference designs I have seen the 14 pin header still exists…
That being said changing to a connector (and getting some cheap HW) supporting SDTI as well as JTAG would be great J
Beagle XM still uses the original 14 pin header…
Best regards
Søren
Thanks Soren,
I got one yesterday from our TI guy. I'll be checking it out
Thanks!!
Tim
Hi Tim,
Great - Please let us know of any results - Great or Bad :slight_smile:
Thanks in advance
  Søren
Hi Soren,
Looks like the 'free' one I got was a V1. Won't do the OMAP parts.
Guess I'll just have to !buy! one! :slight_smile:
Tim
Hello all,
I successfully managed to use a Blackhawk USB100V2 with CCS 4.1.2 Platinium
together with a Beagleboard v4.
I have used the dsplink 1.6.2 readwrite example sources, create a project with CCS 4 (quit painfull
to get it compiled). Then I followed the description here
http://processors.wiki.ti.com/index.php/Debugging_the_DSP_side_of_a_DSPLink_application_on_OMAP_using_CCS
to step through the dsp code.
So, at least for me the USB100V2 is working. Great!
Some time ago I have bought a USB560+ clone, but for this device
and CCS 3.3 I had no luck to get it running with the Beagleboard DSP!
Regards
Martin
