I am having trouble connecting to the MSS with a Segger J-Link (via JTAG).
I have a FlashPro5 and I am able to successfully read device info with FPExpress when hooked up via the TC-2050 cable
I am aware that the TC-2050/JTAG pinout is for a FlashPro, and will not work with a J-Link without an adapter, so I created one.
FlashPro5 pinout:
Segger J-Link EDU mini pinout:
Adapter:
(I have verified this adapter by going pin for pin from my FlashPro5 to the adapter Arm JTAG header, then connecting the TC-2050 cable from Microsemi header to the board, and successfully read the device info via FPExpress once again)
Even with the adapter, I am unable to connect or even detect the MPFS when using JLinkExe
When connected to MPFS:
I have the same question. I only have Jlink and use a adapter and it did not work.
Anyway what device do you select upon Jlink Connect? I tried unspecified RISC-V and also tried Codasip RISC-V devices, all are not working. In my case, TDO is constantly low. The Jlink Console looks like this:
Connecting to target via JTAG
ConfigTargetSettings() start
ConfigTargetSettings() end - Took 19us
TotalIRLen = ?, IRPrint = 0x..000000000000000000000000
Failed to identify target. Resetting via Reset pin and trying again.
ConfigTargetSettings() end - Took 6us
Cannot connect to target.
Has anyone successfully connected this device to Jlink?
I’d suggest double-checking your J-link software version and make sure it’s up to date. Sometimes, just updating the tools can resolve connectivity issues.
