JumboImage Booting and TSC
Yes you are right.
I mean Super Jumbo AIOS.
I did create a boot.scr but on the Touchbook with mkimage.
I was not sure what to copy and what to leave out from the script,
there was also no uImage like on the demo-image only a uImage2.
It seems to work, only the screen resolution does not work.
It could be the Display that refuses to adapte to the settings.
But I will check your binaries
Are you referring to the Super Jumbo from Always Innovating? Please be
more precise in your naming :wink:
Regarding the screen resolution, the default of the SuperJumbo is:
1024x768. If you want to change it, you need to add a boot.scr at the
top of the first partition. Read this:
http://www.alwaysinnovating.com/wiki/index.php/Beagleboard#Creating_a_
custom_boot.scr
Here you have a script for 720p resolution:
http://git.alwaysinnovating.com/cgit.cgi/ai.openembedded.dev/tree/aios
/postprocess/usr/bin/ai/reset/create-boot-scr.sh
The corresponding binaries is here:
/postprocess/usr/bin/ai/reset/boot.scr
I try in AIOS.
The Touchscreen gets recognizid and the pointer follows the movement,
just the wrong direction.
Where are the calibration settings stored?
Do you use fdi?
When I start ximput_calibratior the values are displayd but not
stored.
Rico Naef
