After updating OE, linux kernel version is changed to 2.6.37 from
2.6.32 (from linux-omap-psp_2.6.32.bb to linx-omap_2.6.37) in terms of
angstrom-2010.x.conf. By building console-image, I got u-boot and
uImage. Here
are two problems,
1. u-boot doesn't work on C4 except orange screen (it has much smaller
size than built out
side of OE using codesourcery).
2. use previous u-boot built out side of OE, but the uImage hangs on
Loading u-boot.bin from
mmc
U-Boot 2010.06-00704-gcd67422-dirty (Aug 22 2010 - 13:38:03)
OMAP3530-GP ES3.1, CPU-OPP2 L3-165MHz
I2C: ready
DRAM: 256 MiB
NAND: 256 MiB
In: serial
Out: serial
Err: serial
Board revision C4
Die ID #1978000400000000040365fa1700e01a
OMAP3 beagleboard.org # AT S7=45 S0=0 L1 V1 X4 &c1 E1 Q0
syntax error
OMAP3 beagleboard.org # boot
mmc1 is available
reading uImage.bin
2850272 bytes read
## Booting kernel from Legacy Image at 80300000 ...
Image Name: Angstrom/2.6.37/beagleboard
Data Size: 2850208 Bytes = 2.7 MiB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum ... OK
Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
I have tried to build 2.6.37 before updating OE, I got the same
problem. Did I miss something or
change version to 2.6.32 from angstrom-2010.x.conf?
