System starts with
0.000000] Kernel command line: console=ttyO0,115200n8 root=UUID=250d80ed-1acd-4cc5-906f-2af2805ff23d ro rootfstype=ext4 rootwait fixrtc
even if there is nothing defined in uEnv.txt
Permanently or just once in a while?
See u-boot.cfg in u-boot repo for the default configuration otherwise explore the u-boot console.
Hi all.
System starts with
Yes, cmdline is in uEnv.txt, but even when it’s empty/hashed, kernel still gets Kernel command line: console=ttyO0,115200n8 root=UUID=250d80ed-1acd-4cc5-906f-2af2805ff23d ro rootfstype=ext4 rootwait fixrtc,
I assume it is in uboot.cfg?, thanks you both
Ok, probably it is not needed anymore. What is defined in uEnv.txt is just added to the end of kernel comand (cmdline=console=ttyS0,115200n8).
Doesn’t look as pretty as it could look, but works.
