Hello there,
I have installed latest console version of Debian from eLinux.org . Its uses kernel version 4.1.9:
Linux beaglebone 4.1.9-ti-r20 #1 SMP PREEMPT Fri Oct 2 05:35:56 UTC 2015 armv7l GNU/Linux
I was trying to load BB-UART5 overlay but I failed. I also dont see any overlays loaded I thought I would, like eMMC:
root@beaglebone:/sys/devices/platform/bone_capemgr# cat slots 0: PF---- -1 1: PF---- -1 2: PF---- -1 3: PF---- -1
When I tried to load the tree i got:
[ 3013.532495] bone_capemgr bone_capemgr: part_number 'BB-UART5', version 'N/A' [ 3013.532543] bone_capemgr bone_capemgr: slot #4: override [ 3013.532561] bone_capemgr bone_capemgr: Using override eeprom data at slot 4 [ 3013.532579] bone_capemgr bone_capemgr: slot #4: 'Override Board Name,00A0,Override Manuf,BB-UART5' [ 3013.533110] __of_adjust_tree_phandle_references: Could not find target property 'fixup' @/__local_fixups__ [ 3013.548518] bone_capemgr bone_capemgr: slot #4: Failed to resolve tree
And I have compiled the tds before and put the dtbo in /lib/firmware/
Has anything changed in the new kernel regarding dts loading and general usage?
I would apreciate all help regarding this topic!
Am not sure: Did you compile dts with the patched version of dtc?
Andreas
I used dtc in version 1.4.0 i believe.
To make overlays build properly, you need a special version of dtc
found at [1] further details see [2]
[1] https://github.com/pantoniou/dtc
[2] https://github.com/beagleboard/bb.org-overlays
Andreas
I will try this out, thank you.
W dniu 2015-10-12 o 11:58, 'Andreas Müller' via BeagleBoard pisze:
Im sorry but I cant find any source on how to install the dtc compiller after I have downloaed it from http://devicetree.org/Device_Tree_Compiler
I think I managed to do everything, thank you.
There is still one thing that differs from version 3.8 kernel- I dont see either hdmi/emmc was disabled or not by looking at the slots. How can I check that?
I am also getting the same error with 4.1.9-ti-r20, what exactly did you do to fix it?
Guys, please read the readme.md and /boot/uEnv.txt for examples on how
to disable the "hdmi/emmc"..
https://github.com/beagleboard/bb.org-overlays/blob/master/readme.md
under: "BBB compatibility issues"
There are also other combinations listed in /boot/uEnv.txt
Hi, I have followed this link: beagleboard/bb.org-overlays It doesnt say it in there, but after the steps with update_kernel.sh, you have to clone the directory and go into it for the next steps.
Thanks Robert,
I am simply trying to enable UART4 which I didn’t think needed anything disabling though?
Lee
in /boot/uEnv.txt
cape_enable=bone_capemgr.enable_partno=BB-UART4
and reboot.
(this is assuming /lib/firmware/BB-UART4-00A0.dtbo is installed)
Thanks Robert,
BB-UART4-00A0.dtbo is present in /lib/firmware. I’ve not had an issue before but this is a freshly flashed Jessie BBB.
dmesg shows the following which is the same error as per the first post when echoing into the slots.
[ 4.968908] __of_adjust_tree_phandle_references: Could not find target property ‘fixup’ @/local_f
ixups
[ 4.979738] bone_capemgr bone_capemgr: slot #4: Failed to resolve tree
[ 4.987236] bone_capemgr bone_capemgr: loader: failed to load slot-4 BB-UART4:00A0 (prio 0)
That means you have the wrong dtc compiler..
You need to re-do step 2 & 3:
(i just updated the readme.md to make it more useful... (i think..))
Thanks Robert,
I’ve just reflashed it again with the latest Jessie image and will run through those steps.
One thing not 100% clear in the steps is the best location to get the latest (patched) DTC, there are many differing sources it seems!
Lee
I moved the "./dtc-overlay.sh" script right after the "check dtc" in
step 2... I'm hoping it should be more obvious to run it..
Robert,
Yes that is much better thank you. Working well now
Thank you very much,
Lee
tteague
October 19, 2015, 1:42am
18
Robert, I have the same question about the source of DTC 1.4.1-gXYZXYZXYZ - I installed the device-tree-overlay package into a new build (Linux beaglebone 4.1.10-bone-rt-r16 #1 Sun Oct 4 09:05:14 UTC 2015 armv7l GNU/Linux) and checked the version of dtc. It was v1.4.0. I tried running ./dtc_overlay.sh, but the version didn’t change. So, I cloned the git repository of the source at devicetree.org , did a make and make install. The version is still 1.4.0. The only reference Google has to the string in your readme (DTC 1.4.1-gXYZXYZXYZ) points to your readme.
Thank you
Tim
It's installed too:
/usr/local/bin/
https://github.com/beagleboard/bb.org-overlays/blob/master/dtc-overlay.sh#L56
If it doesn't work, your PATH is mangled..
