kernel 6.5.4 not loading in Beaglebone black
I am giving drive link below, for all boot files I have tried with
https://drive.google.com/drive/folders/1k8KT-YMqi7zHRn50Ba3hMLw9ZNjg0jTz?usp=drive_link
I have used Dowloaded “bone-debian-9.9-lxqt-armhf-2019-08-03-4gb.img.xz” from
Debian 9.9 2019-08-03 4GB SD LXQT - BeagleBoard
first decompressed it as
unxz bone-debian-9.9-lxqt-armhf-2019-08-03-4gb.img
which gives us “bone-debian-9.9-lxqt-armhf-2019-08-03-4gb.img” file
Right click and opening with “Disk Image Mounter” mounted it into
home/waageesh/rootfs
formatted the SDCard again
Using gParted application created 2 partitions again
partion1 is allocated with 512MB memory with filesystem FAT16 and named as “BOOT”
partion2 is allocated with Rest of the memory with filesystem EXT4 and named as “ROOTFS”
Also, labels “boot, lba” are added to partion1 with right clicking on partion1 and choosing “Manage labels”
Post that, I copied all contents from
/home/waageesh/rootfs(rootfs decompressed from beaglebone black image file)
to
/home/waageesh/ROOTFS(parition created in SDCard, which servers as rootfs for kernel while booting on BBB)
Now that I am ready with bootable SDCard, I have inserted it in microSD slot of BBB board
Already changed booting sequence with S2 button earlier, so booting always starts from SDCard(if available any)
Below is the log for the same
Welcome to minicom 2.8
OPTIONS: I18n
Port /dev/ttyUSB0, 23:31:00
Press CTRL-A Z for help on special keys
56827 bytes read in 7 ms (7.7 MiB/s)
Scanning disk mmc@48060000.blk...
Scanning disk mmc@481d8000.blk...
Found 5 disks
No EFI system partition
BootOrder not defined
EFI boot manager: Cannot load any image
switch to partitions #0, OK
mmc0 is current device
Checking for: /uEnv.txt ...
355 bytes read in 3 ms (115.2 KiB/s)
Loaded environment from /uEnv.txt
Importing environment from mmc ...
Checking if uenvcmd is set ...
Running uenvcmd ...
Booting from microSD ...
10887744 bytes read in 784 ms (13.2 MiB/s)
56827 bytes read in 8 ms (6.8 MiB/s)
## Booting kernel from Legacy Image at 82000000 ...
   Image Name:   Linux-6.5.4
   Created:      2023-10-30   8:33:01 UTC
   Image Type:   ARM Linux Kernel Image (uncompressed)
   Data Size:    10887680 Bytes = 10.4 MiB
   Load Address: 80008000
   Entry Point:  80008000
   Verifying Checksum ... OK
## Flattened Device Tree blob at 88000000
   Loading Kernel Image
   Loading Device Tree to 8ffef000, end 8ffffdfa ... OK
Starting kernel ...
Hi @RobertCNelson ,
I really can’t understand why, could you guide more ?
Running uenvcmd ...
You are using “uenvcmd” in /uEnv.txt… i left this pass in our u-boot builds for end users to do what ‘ever’ they wanted. You are in full control of the boot process…
So since you are in full control, we can not debug what you’ve done.
You need to share your “uEnv.txt” so we can see what you’ve done…
Hi @RobertCNelson
I guess I have already gave link to all files through drive link(BeagleboneBlack_Boot_Files - Google Drive) in previous reply,
but anyway I will uEnv.txt here
uEnv.txt (355 Bytes)
console=ttyS0,115200n8
bootsettings=setenv bootargs console=ttyS0,115200n8 root=/dev/mmcblk0p2 rw rootfstype=ext4 rootwait earlyprintk mem=512M
mmcboot=
echo Booting from microSD ...;
echo loadaddr:${loadaddr}, fdtaddr:${fdtaddr};
setenv autoload no ;
load mmc 0:1 ${loadaddr} uImage ;
load mmc 0:1 ${fdtaddr} am335x-boneblack.dtb ;
run bootsettings ;
bootm ${loadaddr} - ${fdtaddr}
uenvcmd=run mmcboot
i guess i see that, normally i’m on my phone, i’m not going to click a random link when text works fine…
The key line is:
you have console=ttyS0,115200n8 set, so now look at your kernel build, do you have this configured (yes/no)
CONFIG_SERIAL_8250_OMAP=y
CONFIG_SERIAL_8250_OMAP_TTYO_FIXUP=y
earlyprintk doesn’t work that way anymore… since the Board → Device-tree conversion 7-8 years ago, you need to pass the serial address, or make sure the BBB specific kernel config is enabled.
mem=512M why?
Hi @RobertCNelson
Those 2 parameters are configured with “y” in .config file, I have checked it.
waageesh@waageesh-Aspire-A715-75G:~/workspace/ldd/source/linux-6.5.4$ grep -inr "CONFIG_SERIAL_8250_OMAP=y" .config
3109:CONFIG_SERIAL_8250_OMAP=y
waageesh@waageesh-Aspire-A715-75G:~/workspace/ldd/source/linux-6.5.4$ grep -inr "CONFIG_SERIAL_8250_OMAP_TTYO_FIXUP=y" .config
3110:CONFIG_SERIAL_8250_OMAP_TTYO_FIXUP=y
Also, I have modified uEnv.txt file as below
mmcboot=echo Booting from microSD ...; setenv autoload no ; load mmc 0:1 ${loadaddr} uImage ; load mmc 0:1 ${fdtaddr} am335x-boneblack.dtb ; run bootsettings ; bootm ${loadaddr} - ${fdtaddr}
uenvcmd=run mmcboot
Tried rebooting again, still it got stuck saying
Starting kernel…
Below is the log
U-Boot SPL 2022.04-ge0d31da5 (Aug 04 2023 - 18:48:26 +0000)
Trying to boot from MMC2
U-Boot 2022.04-ge0d31da5 (Aug 04 2023 - 18:48:26 +0000)
CPU  : AM335X-GP rev 2.1
Model: TI AM335x BeagleBone Black
DRAM:  512 MiB
Reset Source: Global external warm reset has occurred.
RTC 32KCLK Source: External.
Core:  150 devices, 14 uclasses, devicetree: separate
WDT:   Started wdt@44e35000 with servicing (60s timeout)
MMC:   OMAP SD/MMC: 0, OMAP SD/MMC: 1
Loading Environment from EXT4...
** Unable to use mmc 0:1 for loading the env **
Board: BeagleBone Black
<ethaddr> not set. Validating first E-fuse MAC
BeagleBone Black:
Model: BeagleBone Black Industrial:
BeagleBone Cape EEPROM: no EEPROM at address: 0x54
BeagleBone Cape EEPROM: no EEPROM at address: 0x55
BeagleBone Cape EEPROM: no EEPROM at address: 0x56
BeagleBone Cape EEPROM: no EEPROM at address: 0x57
Net:   eth2: ethernet@4a100000, eth3: usb_ether
Press SPACE to abort autoboot in 0 seconds
board_name=[A335BNLT] ...
board_rev=[EIA0] ...
SD/MMC found on device 0
Couldn't find partition 0:2 0x82000000
Can't set block device
Scanning mmc 0:1...
Found 5 disks
311 bytes read in 2 ms (151.4 KiB/s)
Running uenvcmd ...
10887744 bytes read in 792 ms (13.1 MiB/s)
Starting kernel ...
Yeap it looks fine.
it’s been a long time since i used uImage/bootm, for just try it…
Kernel: make “zImage” target.
Then copy zImage to the same partition as uImage
Then make these changes to uEnv.txt
load mmc 0:1 ${loadaddr} zImage ;
bootz ${loadaddr} - ${fdtaddr}
and see what happens…
Hi @RobertCNelson
I tried with zImage and below uEnv.txt file changes
debian@BeagleBone:~$ cat /media/waageesh/BOOT/uEnv.txt
mmcboot=echo Booting from microSD ...; setenv autoload no ; load mmc 0:1 ${loadaddr} zImage ; load mmc 0:1 ${fdtaddr} am335x-boneblack.dtb ; run bootsettings ; bootz ${loadaddr} - ${fdtaddr}
uenvcmd=run mmcboot
Still kernel is not loading properly
DRAM:  512 MiB
Reset Source: watchdog reset has occurred.
BeagleBone Black:
Scanning mmc 0:1...
Found 5 disks
311 bytes read in 3 ms (100.6 KiB/s)
Running uenvcmd ...
10887680 bytes read in 761 ms (13.6 MiB/s)
Kernel image @ 0x82000000 [ 0x000000 - 0xa62200 ]
Starting kernel ...
Okay, so no changes… i guess all that’s left… build the kernel with “omap2plus_defconfig” and see any progress, as that will boot…
I tried building kernel 6.5.4 with omap2plus_defconfig and copied newly generated below files
  • linux-6.5.4/arch/arm/boot/uImage
  • linux-6.5.4/arch/arm/boot/dts/ti/omap/am335x-boneblack.dtb
to SDCard BOOT partition.
Rebooted the system, this time it is able to load the kernel from uImage of SDCard.
But now, right after kernel is loaded, serious kernel issue occurred as mmc0: Problem switching card into high-speed mode!
Below is the log for the same:
Debian GNU/Linux 9 beaglebone ttyS0
BeagleBoard.org Debian Image 2019-08-03
Support/FAQ: http://elinux.org/Beagleboard:BeagleBoneBlack_Debian
default username:password is [debian:temppwd]
beaglebone login: [   46.551523] mmc0: Problem switching card into high-speed mode!
[   46.656401] EXT4-fs warning (device mmcblk0p2): ext4_dirblock_csum_verify:404: inode #17911: comm nodejs: No space for directory leaf checksum. Pleas.
[   46.671428] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1689: inode #17911: comm nodejs: checksumming directory block 0
[   46.683040] Aborting journal on device mmcblk0p2-8.
[   46.690292] EXT4-fs error (device mmcblk0p2): ext4_journal_check_start:83: comm rs:main Q:Reg: Detected aborted journal
[   46.710606] EXT4-fs error (device mmcblk0p2): ext4_journal_check_start:83: comm Xorg: Detected aborted journal
[   47.949010] EXT4-fs (mmcblk0p2): Remounting filesystem read-only
[   47.957481] EXT4-fs warning (device mmcblk0p2): ext4_dirblock_csum_verify:404: inode #17911: comm nodejs: No space for directory leaf checksum. Pleas.
[   47.972519] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1689: inode #17911: comm nodejs: checksumming directory block 0
[   47.987451] EXT4-fs warning (device mmcblk0p2): ext4_dirblock_csum_verify:404: inode #17911: comm nodejs: No space for directory leaf checksum. Pleas.
[   48.002468] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1689: inode #17911: comm nodejs: checksumming directory block 0
[   48.017383] EXT4-fs warning (device mmcblk0p2): ext4_dirblock_csum_verify:404: inode #17911: comm nodejs: No space for directory leaf checksum. Pleas.
[   48.032386] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1689: inode #17911: comm nodejs: checksumming directory block 0
[   48.047251] EXT4-fs warning (device mmcblk0p2): ext4_dirblock_csum_verify:404: inode #17911: comm nodejs: No space for directory leaf checksum. Pleas.
[   48.062258] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1689: inode #17911: comm nodejs: checksumming directory block 0
[   58.085962] mmc0: Timeout waiting for hardware interrupt.
[   58.091443] mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
[   58.097914] mmc0: sdhci: Sys addr:  0x00000000 | Version:  0x00003101
[   58.104385] mmc0: sdhci: Blk size:  0x00000200 | Blk cnt:  0x00000010
[   58.110855] mmc0: sdhci: Argument:  0x00258f88 | Trn mode: 0x00000033
[   58.117325] mmc0: sdhci: Present:   0x01f70a06 | Host ctl: 0x00000002
[   58.123795] mmc0: sdhci: Power:     0x0000000f | Blk gap:  0x00000000
[   58.130263] mmc0: sdhci: Wake-up:   0x00000000 | Clock:    0x00000107
[   58.136733] mmc0: sdhci: Timeout:   0x00000009 | Int stat: 0x00000000
[   58.143202] mmc0: sdhci: Int enab:  0x027f000b | Sig enab: 0x027f000b
[   58.149673] mmc0: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[   58.156141] mmc0: sdhci: Caps:      0x07e10080 | Caps_1:   0x00000000
[   58.162610] mmc0: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
[   58.169080] mmc0: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x00000000
[   58.175548] mmc0: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
[   58.182017] mmc0: sdhci: Host ctl2: 0x00000000
[   58.186479] mmc0: sdhci: ============================================
[   59.984391] 8<--- cut here ---
[   59.987715] Unable to handle kernel paging request at virtual address 73736583 when read
[   59.995857] [73736583] *pgd=00000000
[   59.999539] Internal error: Oops: 5 [#1] SMP ARM
[   60.004190] Modules linked in:
[   60.007267] CPU: 0 PID: 1 Comm: systemd Not tainted 6.5.4 #2
[   60.012956] Hardware name: Generic AM33XX (Flattened Device Tree)
[   60.019077] PC is at __kmem_cache_alloc_node+0xbc/0x4dc
[   60.024352] LR is at 0xe0009d40
[   60.027509] pc : [<c02f08d8>]    lr : [<e0009d40>]    psr: a0000013
[   60.033804] sp : e0009d40  ip : c2caf050  fp : 00009d7b
[   60.039051] r10: c0e0e33c  r9 : c1005694  r8 : 00000dc0
[   60.044298] r7 : c1134598  r6 : 73736563  r5 : 00000000  r4 : c1801100
[   60.050855] r3 : 00000020  r2 : df93bb38  r1 : 00009d7a  r0 : 1e9b4000
[   60.057412] Flags: NzCv  IRQs on  FIQs on  Mode SVC_32  ISA ARM  Segment none
[   60.064584] Control: 10c5387d  Table: 82c30019  DAC: 00000051
[   60.070353] Register r0 information: non-paged memory
[   60.075436] Register r1 information: non-paged memory
[   60.080514] Register r2 information: non-slab/vmalloc memory
[   60.086203] Register r3 information: non-paged memory
[   60.091281] Register r4 information: slab kmem_cache start c1801100 pointer offset 0 size 124
[   60.099874] Register r5 information: NULL pointer
[   60.104602] Register r6 information: non-paged memory
[   60.109678] Register r7 information: non-slab/vmalloc memory
[   60.115366] Register r8 information: non-paged memory
[   60.120443] Register r9 information: non-slab/vmalloc memory
[   60.126132] Register r10 information: non-slab/vmalloc memory
[   60.131908] Register r11 information: non-paged memory
[   60.137072] Register r12 information: slab seq_file start c2caf050 pointer offset 0 size 80
[   60.145484] Process systemd (pid: 1, stack limit = 0xacfe6c25)
[   60.151350] Stack: (0xe0009d40 to 0xe000a000)
[   60.155733] 9d40: 00000010 c0325aa0 00000000 00000dc0 00000028 ffffffff 00000010 c36ce400
[   60.163950] 9d60: c33ead68 00000028 c03a6f24 c1801100 00000dc0 c0e0e33c c1891e3c c02a7e88
[   60.172167] 9d80: c03a6f24 c8100900 c33ead68 c0c1d778 c8100900 c36ce400 c33ead68 c105edd4
[   60.180384] 9da0: c8100900 c49f46a0 00000000 c0e0e33c c1891e3c c03a6f24 c1fb3e94 c33ead68
[   60.188600] 9dc0: c03a33a4 c8100900 00000000 c49f46a0 c03a6cac c8100970 00000000 e0009e80
[   60.196818] 9de0: c8100900 c0303c1c 00020000 c107ad0c 00020000 c107ad0c c107ad0c 00020000
[   60.205035] 9e00: c107ad0c 00000000 00000004 e0009f38 00000000 c031b084 e0009f38 c2609680
[   60.213252] 9e20: 00004000 00000000 e0009e84 00000128 005399b4 c08baed0 c18e8000 00000041
[   60.221469] 9e40: c36ce400 00000000 00000000 00000000 00000000 9acd71d3 00000000 ffffff9c
[   60.229685] 9e60: e0009f38 00000001 ffffff9c c01002ec c18e8000 00000005 b6edabfc c031bd0c
[   60.237903] 9e80: c2ccf6d0 c4a1fee0 1d4ef820 0000000c c3670044 00000000 c1bda610 c2518088
[   60.246120] 9ea0: c49f46a0 00000101 00000002 00000000 00000000 000004ac 000002b6 00000000
[   60.254337] 9ec0: 00000000 00000000 e0009ecc 00000000 00000000 00000000 00000000 00000000
[   60.262554] 9ee0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 c3670000
[   60.270770] 9f00: 00000000 00000002 ffffff9c 00000000 000041ed 00000000 c3670000 9acd71d3
[   60.278986] 9f20: 00000039 e0009f68 c3670000 c0305adc 00000000 fffffff7 00020000 00000000
[   60.287203] 9f40: 00000004 00000100 00000001 9acd71d3 00000000 005b2368 00080000 00000008
[   60.295420] 9f60: 00000005 c0305dd0 000a0000 00000000 00000000 00000000 00000000 00000000
[   60.303636] 9f80: 000a0000 00000000 00000000 00000000 00000000 00000000 b6f5fc14 9acd71d3
[   60.311852] 9fa0: 005dc690 c0100080 005dc690 00080000 005b2368 000a0000 000001b6 000001b6
[   60.320070] 9fc0: 005dc690 00080000 00000008 00000005 b6ed0134 b6f67ce8 0054a024 b6edabfc
[   60.328286] 9fe0: 00000000 be8d5724 b6ba78dd b6be3936 20000030 005b2368 00000000 00000000
[   60.336512]  __kmem_cache_alloc_node from kmalloc_trace+0x28/0xb4
[   60.342663]  kmalloc_trace from kernfs_fop_open+0x278/0x308
[   60.348288]  kernfs_fop_open from do_dentry_open+0x1d8/0x544
[   60.353993]  do_dentry_open from path_openat+0xbe0/0x1028
[   60.359430]  path_openat from do_filp_open+0x5c/0xd4
[   60.364426]  do_filp_open from do_sys_openat2+0xb8/0xf0
[   60.369688]  do_sys_openat2 from sys_open+0x74/0xc8
[   60.374601]  sys_open from ret_fast_syscall+0x0/0x58
[   60.379601] Exception stack(0xe0009fa8 to 0xe0009ff0)
[   60.384678] 9fa0:                   005dc690 00080000 005b2368 000a0000 000001b6 000001b6
[   60.392895] 9fc0: 005dc690 00080000 00000008 00000005 b6ed0134 b6f67ce8 0054a024 b6edabfc
[   60.401110] 9fe0: 00000000 be8d5724 b6ba78dd b6be3936
[   60.406192] Code: e3560000 13530000 0a0000b2 e594301c (e796c003)
[   60.412469] ---[ end trace 0000000000000000 ]---
[   60.417187] Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b
[   60.424892] ---[ end Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b ]---
Looks good, it boots up… Now you need to diff your wanted config and omap2plus_defconfig to select what you want and figure out what you misssed… omap2plus_defconfig defaults a lot of options to modules, so you really should install the modules too, or move them to built-in…
Hi @RobertCNelson
To be honest,
I really don’t know what should be inside omap2plus_defconfig .
I am just trying to run beaglebone black board UP and running with specific kernel, so that I can start learning device driver programming on ARM architecture.
I just need a minimal setup of BBB board, to make viable for running kernel without throwing any issues.
So there is no problem with micro SD card, isn’t it ?!!!
If so, how should I proceed now ?
Since you are running Debian, also change the “rw” → “ro”… in /uEnv.txt … then make sure /etc/fstab on the 2nd partition was updated to use the 2nd partition (default is 1st)… but install the kernel modules and retry…
Hi @RobertCNelson
I tried with above changes & still kernel is not booting properly
But Strangely I have one more observation found.
The rootfs built is for kernel version 4.14.108-ti-r113
whereas kernel is built for version 6.5.4
debian@BeagleBone:/media/waageesh/BOOT$ ls -lt
total 5560
-rwxr-xr-x 1 root root     311 Nov  2  2023 uEnv.txt
-rwxr-xr-x 1 root root 5181456 Aug  5 06:44 uImage
-rwxr-xr-x 1 root root   72320 Aug 11  2020 MLO
-rwxr-xr-x 1 root root   56827 Aug 11  2020 am335x-boneblack.dtb
-rwxr-xr-x 1 root root  367496 Aug 11  2020 u-boot.img
debian@BeagleBone:/media/waageesh/BOOT$ cd ../ROOTFS/
debian@BeagleBone:/media/waageesh/ROOTFS$ ls boot/
SOC.sh  System.map-4.14.108-ti-r113  config-4.14.108-ti-r113  dtbs  initrd.img-4.14.108-ti-r113  uEnv.txt  uboot  vmlinuz-4.14.108-ti-r113
ID.txt  bbb-uEnv.txt  bin  boot  dev  etc  home  lib  lost+found  media  mnt  nfs-uEnv.txt  opt  proc  root  run  sbin  srv  sys  tmp  usr  var
Doesn kernel of different version won’t work with rootfs built for different kernel ?
But I am very sure, till 1 week back, I have tried with different kernel images(uImage) with same rootfs which I am showing above.
still shows ‘rw’, for debian or ubuntu, the base tools really want this ‘ro’…
Correct, the ‘rootfs’ has 4.14.108-ti-r113 pre-installed… But like i said the my previous post, you should install the kernel 6.5.4 modules…
Hi @RobertCNelson
Sorry, Now I changed rw → ro in uEnvt.txt file
debian@BeagleBone:~$ lsblk
NAME         MAJ:MIN RM  SIZE RO TYPE MOUNTPOINT
mmcblk1      179:0    0  3.5G  0 disk
`-mmcblk1p1  179:1    0  3.5G  0 part /
mmcblk1boot0 179:256  0    2M  1 disk
mmcblk1boot1 179:512  0    2M  1 disk
mmcblk0      179:768  0  7.5G  0 disk
|-mmcblk0p1  179:769  0  512M  0 part
`-mmcblk0p2  179:770  0    7G  0 part
debian@BeagleBone:~$ sudo mount /dev/mmcblk0p1 /media/waageesh/BOOT/
bootsettings=setenv bootargs console=ttyS0,115200n8 root=/dev/mmcblk0p2 ro rootfstype=ext4 rootwait
uenvcmd=run mmcboot
Installed new kernel modules(6.5.4) in SDCard/ROOTFS partition
debian@BeagleBone:/media/waageesh/ROOTFS/lib/modules$ ls
4.14.108-ti-r113  6.5.4
debian@BeagleBone:/media/waageesh/ROOTFS/lib/modules$ ls 6.5.4/kernel/
arch/    crypto/  drivers/ fs/      lib/     mm/      net/     sound/
debian@BeagleBone:/media/waageesh/ROOTFS/lib/modules$ ls 6.5.4/kernel/drivers/
ata/        clk/        crypto/     gpu/        iio/        media/      mtd/        power/      rtc/        video/
block/      connector/  dma/        hid/        input/      memory/     net/        pwm/        soc/        w1/
bluetooth/  counter/    extcon/     hsi/        leds/       mfd/        pci/        regulator/  spi/        watchdog/
char/       cpufreq/    gpio/       hwmon/      mailbox/    misc/       phy/        remoteproc/ usb/
Below is the log when rebooted the board
/W�.+˩H�Core:  150 devices, 14 uclasses, devicetree: separate
BeagleBone Black:
Scanning mmc 0:1...
70087 bytes read in 10 ms (6.7 MiB/s)
Found 5 disks
Running uenvcmd ...
5181600 bytes read in 377 ms (13.1 MiB/s)
70087 bytes read in 9 ms (7.4 MiB/s)
   Created:      2023-11-02  20:01:29 UTC
   Data Size:    5181536 Bytes = 4.9 MiB
   Loading Device Tree to 8ffeb000, end 8ffff1c6 ... OK
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 6.5.4 (waageesh@waageesh-Aspire-A715-75G) (arm-linux-gnueabihf-gcc (GCC) 14.0.0 20230605 (experimental) [master revision c73
[    0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c5387d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] OF: fdt: Machine model: TI AM335x BeagleBone Black
[    0.000000] Memory policy: Data cache writeback
[    0.000000] cma: Reserved 16 MiB at 0x9e800000
[    0.000000] Zone ranges:
[    0.000000]   Normal   [mem 0x0000000080000000-0x000000009fdfffff]
[    0.000000]   HighMem  empty
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000080000000-0x000000009fdfffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x000000009fdfffff]
[    0.000000] CPU: All CPU(s) started in SVC mode.
[    0.000000] AM335X ES2.1 (sgx neon)
[    0.000000] percpu: Embedded 16 pages/cpu s35604 r8192 d21740 u65536
[    0.000000] Kernel command line: console=ttyS0,115200n8 root=/dev/mmcblk0p2 ro rootfstype=ext4 rootwait
[    0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes, linear)
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 129412
[    0.000000] mem auto-init: stack:all(zero), heap alloc:off, heap free:off
[    0.000000] Memory: 483724K/522240K available (11264K kernel code, 1102K rwdata, 2508K rodata, 1024K init, 281K bss, 22132K reserved, 16384K cma-rese)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[    0.000000] trace event string verifier disabled
[    0.000000] rcu: Hierarchical RCU implementation.
[    0.000000] rcu:     RCU event tracing is enabled.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=2 to nr_cpu_ids=1.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=1
[    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[    0.000000] IRQ: Found an INTC at 0x(ptrval) (revision 5.0) with 128 interrupts
[    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[    0.000000] TI gptimer clocksource: always-on /ocp/interconnect@44c00000/segment@200000/target-module@31000
[    0.000002] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
[    0.000026] clocksource: dmtimer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[    0.000489] TI gptimer clockevent: 24000000 Hz at /ocp/interconnect@48000000/segment@0/target-module@40000
[    0.001923] Console: colour dummy device 80x30
[    0.002002] Calibrating delay loop... 996.14 BogoMIPS (lpj=4980736)
[    0.090536] CPU: Testing write buffer coherency: ok
[    0.090633] CPU0: Spectre v2: using BPIALL workaround
[    0.090646] pid_max: default: 32768 minimum: 301
[    0.090780] LSM: initializing lsm=capability,integrity
[    0.090949] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.090969] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.092409] CPU0: thread -1, cpu 0, socket -1, mpidr 0
[    0.093864] Setting up static identity map for 0x80100000 - 0x80100078
[    0.094146] rcu: Hierarchical SRCU implementation.
[    0.094157] rcu:     Max phase no-delay instances is 1000.
[    0.094877] smp: Bringing up secondary CPUs ...
[    0.094924] smp: Brought up 1 node, 1 CPU
[    0.094937] SMP: Total of 1 processors activated (996.14 BogoMIPS).
[    0.094946] CPU: All CPU(s) started in SVC mode.
[    0.095741] devtmpfs: initialized
[    0.110491] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[    0.111009] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.111047] futex hash table entries: 256 (order: 2, 16384 bytes, linear)
[    0.112317] pinctrl core: initialized pinctrl subsystem
[    0.114775] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.117299] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.117899] audit: initializing netlink subsys (disabled)
[    0.119190] thermal_sys: Registered thermal governor 'fair_share'
[    0.119209] thermal_sys: Registered thermal governor 'step_wise'
[    0.119215] thermal_sys: Registered thermal governor 'user_space'
[    0.119345] cpuidle: using governor menu
[    0.138939] No ATAGs?
[    0.138964] hw-breakpoint: debug architecture 0x4 unsupported.
[    0.141650] audit: type=2000 audit(0.110:1): state=initialized audit_enabled=0 res=1
[    0.141950] kprobes: kprobe jump-optimization is enabled. All kprobes are optimized if possible.
[    0.810385] iommu: Default domain type: Translated
[    0.810405] iommu: DMA domain TLB invalidation policy: strict mode
[    0.811902] SCSI subsystem initialized
[    0.813634] pps_core: LinuxPPS API ver. 1 registered
[    0.813645] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.813671] PTP clock support registered
[    0.815474] vgaarb: loaded
[    0.815782] clocksource: Switched to clocksource dmtimer
[    0.816372] VFS: Disk quotas dquot_6.6.0
[    0.816428] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    0.881075] NET: Registered PF_INET protocol family
[    0.881417] IP idents hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.882786] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 4096 bytes, linear)
[    0.882823] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.882842] TCP established hash table entries: 4096 (order: 2, 16384 bytes, linear)
[    0.882884] TCP bind hash table entries: 4096 (order: 4, 65536 bytes, linear)
[    0.882984] TCP: Hash tables configured (established 4096 bind 4096)
[    0.883111] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
[    0.883143] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
[    0.883320] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.884542] RPC: Registered named UNIX socket transport module.
[    0.884563] RPC: Registered udp transport module.
[    0.884569] RPC: Registered tcp transport module.
[    0.884574] RPC: Registered tcp-with-tls transport module.
[    0.884579] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.884604] PCI: CLS 0 bytes, default 64
[    0.886306] Initialise system trusted keyrings
[    0.887163] workingset: timestamp_bits=14 max_order=17 bucket_order=3
[    0.888337] NFS: Registering the id_resolver key type
[    0.888400] Key type id_resolver registered
[    0.888408] Key type id_legacy registered
[    0.888454] jffs2: version 2.2. (NAND) (SUMMARY)  © 2001-2006 Red Hat, Inc.
[    0.888844] Key type asymmetric registered
[    0.888859] Asymmetric key parser 'x509' registered
[    0.888927] io scheduler mq-deadline registered
[    0.888939] io scheduler kyber registered
[    0.889004] io scheduler bfq registered
[    0.892831] Serial: 8250/16550 driver, 6 ports, IRQ sharing enabled
[    0.910974] brd: module loaded
[    0.919072] loop: module loaded
[    0.919995] mtdoops: mtd device (mtddev=name/number) must be supplied
[    0.922661] i2c_dev: i2c /dev entries driver
[    0.923485] cpuidle: enable-method property 'ti,am3352' found operations
[    0.923915] sdhci: Secure Digital Host Controller Interface driver
[    0.923926] sdhci: Copyright(c) Pierre Ossman
[    0.924095] sdhci-pltfm: SDHCI platform and OF driver helper
[    0.924354] ledtrig-cpu: registered to indicate activity on CPUs
[    0.925135] Initializing XFRM netlink socket
[    0.925281] NET: Registered PF_INET6 protocol family
[    0.927214] Segment Routing with IPv6
[    0.927291] In-situ OAM (IOAM) with IPv6
[    0.927407] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[    0.928316] NET: Registered PF_PACKET protocol family
[    0.928347] NET: Registered PF_KEY protocol family
[    0.928473] Key type dns_resolver registered
[    0.928682] ThumbEE CPU extension supported.
[    0.928702] Registering SWP/SWPB emulation handler
[    0.929143] omap_voltage_late_init: Voltage driver support not added
[    0.929479] SmartReflex Class3 initialized
[    0.937135] Loading compiled-in X.509 certificates
[    0.978429] platform 44e10800.pinmux: Fixed dependency cycle(s) with /ocp/interconnect@44c00000/segment@200000/target-module@10000/scm@0/pinmux@800/cs
[    0.978974] pinctrl-single 44e10800.pinmux: 142 pins, size 568
[    0.983515] ti-sysc: probe of 44e31000.target-module failed with error -16
[    0.998077] ti-sysc: probe of 48040000.target-module failed with error -16
[    1.010472] OMAP GPIO hardware version 0.1
[    1.023320] omap_i2c 4819c000.i2c: bus 2 rev0.11 at 100 kHz
[    1.051795] sdhci-omap 481d8000.mmc: supply pbias not found, using dummy regulator
[    1.052240] sdhci-omap 481d8000.mmc: supply vqmmc not found, using dummy regulator
[    1.105796] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6, bus freq 1000000
[    1.127700] davinci_mdio 4a101000.mdio: phy[0]: device 4a101000.mdio:00, driver SMSC LAN8710/LAN8720
[    1.128149] cpsw-switch 4a100000.switch: initialized cpsw ale version 1.4
[    1.128167] cpsw-switch 4a100000.switch: ALE Table size 1024
[    1.128438] cpsw-switch 4a100000.switch: cpts: overflow check period 500 (jiffies)
[    1.128459] cpsw-switch 4a100000.switch: CPTS: ref_clk_freq:250000000 calc_mult:2147483648 calc_shift:29 error:0 nsec/sec
[    1.128550] cpsw-switch 4a100000.switch: Detected MACID = e4:15:f6:f5:d0:69
[    1.130329] cpsw-switch 4a100000.switch: initialized (regs 0x4a100000, pool size 256) hw_ver:0019010C 1.12 (0)
[    1.140942] debugfs: Directory '49000000.dma' with parent 'dmaengine' already present!
[    1.140985] edma 49000000.dma: TI EDMA DMA engine driver
[    1.160546] hw perfevents: enabled with armv7_cortex_a8 PMU driver, 5 counters available
[    1.167680] l3-aon-clkctrl:0000:0: failed to disable
[    1.170131] printk: console [ttyS0] disabled
[    1.170952] 44e09000.serial: ttyS0 at MMIO 0x44e09000 (irq = 34, base_baud = 3000000) is a 8250
[    1.171031] printk: console [ttyS0] enabled
[    2.126677] tps65217-pmic: Failed to locate of_node [id: -1]
[    2.132704] tps65217-bl: Failed to locate of_node [id: -1]
[    2.143508] tps65217 0-0024: TPS65217 ID 0xe version 1.2
[    2.149682] i2c 0-0070: Fixed dependency cycle(s) with /ocp/interconnect@48000000/segment@300000/target-module@e000/lcdc@0/port/endpoint@0
[    2.162469] omap_i2c 44e0b000.i2c: bus 0 rev0.11 at 400 kHz
[    2.170951] omap_gpio 44e07000.gpio: Could not set line 6 debounce to 200000 microseconds (-22)
[    2.179859] sdhci-omap 48060000.mmc: Got CD GPIO
[    2.184821] sdhci-omap 48060000.mmc: supply pbias not found, using dummy regulator
[    2.195227] sdhci-omap 48060000.mmc: supply vqmmc not found, using dummy regulator
[    2.205914] clk: Disabling unused clocks
[    2.211243] sdhci-omap 481d8000.mmc: supply pbias not found, using dummy regulator
[    2.219932] sdhci-omap 481d8000.mmc: supply vqmmc not found, using dummy regulator
[    2.255838] mmc1: SDHCI controller on 481d8000.mmc [481d8000.mmc] using External DMA
[    2.264681] mmc0: SDHCI controller on 48060000.mmc [48060000.mmc] using External DMA
[    2.273516] Waiting for root device /dev/mmcblk0p2...
[    2.312068] mmc0: new high speed SDHC card at address 0001
[    2.318804] mmcblk0: mmc0:0001  7.50 GiB
[    2.325996]  mmcblk0: p1 p2
[    2.333125] mmc1: new high speed MMC card at address 0001
[    2.339823] mmcblk1: mmc1:0001 M62704 3.53 GiB
[    2.347080]  mmcblk1: p1
[    2.350731] mmcblk1boot0: mmc1:0001 M62704 2.00 MiB
[    2.357767] mmcblk1boot1: mmc1:0001 M62704 2.00 MiB
[    2.364448] mmcblk1rpmb: mmc1:0001 M62704 512 KiB, chardev (250:0)
[    2.375477] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
[    2.382978] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
[   11.056610] EXT4-fs (mmcblk0p2): recovery complete
[   12.291018] EXT4-fs (mmcblk0p2): mounted filesystem 0ae028b1-c046-4a45-9621-55960ec1b68a ro with ordered data mode. Quota mode: none.
[   12.303303] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[   12.316035] devtmpfs: mounted
[   12.320383] Freeing unused kernel image (initmem) memory: 1024K
[   12.327154] Run /sbin/init as init process
[   12.894243] systemd[1]: System time before build time, advancing clock.
[   15.345800] random: crng init done
[   15.406798] systemd[1]: systemd 232 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTL)
[   15.425951] systemd[1]: Detected architecture arm.
Welcome to Debian GNU/Linux 9 (stretch)!
[   15.477322] systemd[1]: Set hostname to <beaglebone>.
[   16.213385] systemd[1]: Listening on udev Kernel Socket.
[  OK  ] Listening on udev Kernel Socket.
[   16.247317] systemd[1]: Created slice User and Session Slice.
[  OK  ] Created slice User and Session Slice.
[   16.286577] systemd[1]: Listening on Journal Socket (/dev/log).
[  OK  ] Listening on Journal Socket (/dev/log).
[   16.326557] systemd[1]: Listening on Journal Socket.
[  OK  ] Listening on Journal Socket.
[   16.367428] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[  OK  ] Set up automount Arbitrary Executab…rmats File System Automount Point.
[   16.406812] systemd[1]: Listening on Journal Audit Socket.
[  OK  ] Listening on Journal Audit Socket.
[   16.446403] systemd[1]: Listening on fsck to fsckd communication Socket.
[  OK  ] Listening on fsck to fsckd communication Socket.
[  OK  ] Listening on /dev/initctl Compatibility Named Pipe.
[  OK  ] Listening on udev Control Socket.
[  OK  ] Started Forward Password Requests to Wall Directory Watch.
[  OK  ] Listening on Syslog Socket.
[  OK  ] Created slice System Slice.
[  OK  ] Created slice system-getty.slice.
         Starting Set the console keyboard layout...
         Starting Journal Service...
         Mounting /sys/kernel/debug...
         Starting Create list of required st…ce nodes for the current kernel...
         Starting Load Kernel Modules...
[  OK  ] Reached target Slices.
[  OK  ] Created slice system-serial\x2dgetty.slice.
         Mounting POSIX Message Queue File System...
         Starting File System Check on Root Device...
[  OK  ] Started Dispatch Password Requests to Console Directory Watch.
[  OK  ] Reached target Encrypted Volumes.
[  OK  ] Reached target Paths.
[  OK  ] Reached target Swap.
[  OK  ] Reached target Remote File Systems.
[  OK  ] Mounted POSIX Message Queue File System.
[  OK  ] Mounted /sys/kernel/debug.
[  OK  ] Started Create list of required sta…vice nodes for the current kernel.
[FAILED] Failed to start Load Kernel Modules.
See 'systemctl status systemd-modules-load.service' for details.
[DEPEND] Dependency failed for robotcontrol.
[  OK  ] Started File System Check Daemon to report status.
         Mounting Configuration File System...
         Starting Apply Kernel Variables...
         Starting Create Static Device Nodes in /dev...
[  OK  ] Mounted Configuration File System.
[  OK  ] Started File System Check on Root Device.
         Starting Remount Root and Kernel File Systems...
[  OK  ] Started Apply Kernel Variables.
[  OK  ] Started Journal Service.
[  OK  ] Started Create Static Device Nodes in /dev.
         Starting udev Kernel Device Manager...
[   17.945428] EXT4-fs (mmcblk0p2): re-mounted 0ae028b1-c046-4a45-9621-55960ec1b68a r/w. Quota mode: none.
[  OK  ] Started Remount Root and Kernel File Systems.
         Starting Load/Save Random Seed...
         Starting Flush Journal to Persistent Storage...
         Starting udev Coldplug all Devices...
[  OK  ] Started Load/Save Random Seed.
[   18.326871] systemd-journald[79]: Received request to flush runtime journal from PID 1
[  OK  ] Started Flush Journal to Persistent Storage.
[  OK  ] Started udev Kernel Device Manager.
[  OK  ] Started Set the console keyboard layout.
[  OK  ] Reached target Local File Systems (Pre).
[  OK  ] Reached target Local File Systems.
         Starting Raise network interfaces...
         Starting Set console font and keymap...
         Starting Create Volatile Files and Directories...
[  OK  ] Started Set console font and keymap.
[  OK  ] Started Create Volatile Files and Directories.
         Starting Network Time Synchronization...
         Starting Update UTMP about System Boot/Shutdown...
[  OK  ] Started Entropy daemon using the HAVEGE algorithm.
[  OK  ] Started Update UTMP about System Boot/Shutdown.
[  OK  ] Started Network Time Synchronization.
[  OK  ] Reached target System Time Synchronized.
[  OK  ] Started Raise network interfaces.
[  OK  ] Started udev Coldplug all Devices.
[  OK  ] Reached target System Initialization.
[  OK  ] Listening on D-Bus System Message Bus Socket.
[  OK  ] Started Daily Cleanup of Temporary Directories.
[  OK  ] Reached target Timers.
[  OK  ] Listening on node-red.socket.
[  OK  ] Listening on bonescript.socket.
[   21.842335] remoteproc remoteproc0: wkup_m3 is available
[  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[  OK  ] Listening on cloud9.socket.
[  OK  ] Reached target Sockets.
[  OK  ] Reached target Basic System.
         Starting LSB: Load kernel modules needed to enable cpufreq scaling...
         Starting LSB: Start daemon at boot time...
[  OK  ] Started D-Bus System Message Bus.
[   22.273027] wkup_m3_ipc 44e11324.wkup_m3_ipc: IPC Request for A8->M3 Channel failed! -517
[   22.297715] at24 2-0054: supply vcc not found, using dummy regulator
[   22.419452] omap_rtc 44e3e000.rtc: registered as rtc0
[   22.424632] omap_rtc 44e3e000.rtc: setting system clock to 2000-01-01T00:00:00 UTC (946684800)
[   22.435148] wkup_m3_ipc 44e11324.wkup_m3_ipc: IPC Request for A8->M3 Channel failed! -517
[   22.497738] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[   22.508066] at24 2-0055: supply vcc not found, using dummy regulator
[   22.594427] wkup_m3_ipc 44e11324.wkup_m3_ipc: IPC Request for A8->M3 Channel failed! -517
[   22.677783] tps6521x_pwrbutton tps65217-pwrbutton: DMA mask not set
[   22.696498] at24 2-0056: supply vcc not found, using dummy regulator
[   22.815361] input: tps65217_pwrbutton as /devices/platform/ocp/44c00000.interconnect/44c00000.interconnect:segment@200000/44e0b000.target-module/44e00
[   22.835009] wkup_m3_ipc 44e11324.wkup_m3_ipc: IPC Request for A8->M3 Channel failed! -517
[   22.849080] at24 2-0057: supply vcc not found, using dummy regulator
[   22.937773] am335x-phy-driver 47401300.usb-phy: dummy supplies not allowed for exclusive requests
[   22.972965] at24 0-0050: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[   22.981149] wkup_m3_ipc 44e11324.wkup_m3_ipc: IPC Request for A8->M3 Channel failed! -517
[   23.053713] usbcore: registered new interface driver usbfs
[   23.059498] usbcore: registered new interface driver hub
[   23.064941] usbcore: registered new device driver usb
[   23.073353] am335x-phy-driver 47401b00.usb-phy: dummy supplies not allowed for exclusive requests
[   23.088276] wkup_m3_ipc 44e11324.wkup_m3_ipc: IPC Request for A8->M3 Channel failed! -517
[   23.190672] tda998x 0-0070: found TDA19988
[   23.220894] wkup_m3_ipc 44e11324.wkup_m3_ipc: IPC Request for A8->M3 Channel failed! -517
[   23.378164] wkup_m3_ipc 44e11324.wkup_m3_ipc: IPC Request for A8->M3 Channel failed! -517
[   23.539483] wkup_m3_ipc 44e11324.wkup_m3_ipc: IPC Request for A8->M3 Channel failed! -517
[   23.654148] wkup_m3_ipc 44e11324.wkup_m3_ipc: IPC Request for A8->M3 Channel failed! -517
[   23.666861] musb-hdrc musb-hdrc.1: MUSB HDRC host driver
[   23.672263] musb-hdrc musb-hdrc.1: new USB bus registered, assigned bus number 1
[   23.804646] omap-mailbox 480c8000.mailbox: omap mailbox rev 0x400
         Starting Connection service...
         Starting BBAI brcmfmac tether Service...
         Starting System Logging Service...
[   24.171704] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.05
[   24.180294] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   24.187661] usb usb1: Product: MUSB HDRC host driver
[   24.192657] usb usb1: Manufacturer: Linux 6.5.4 musb-hcd
[   24.198034] usb usb1: SerialNumber: musb-hdrc.1
         Starting Generic Board Startup...
         Starting rc_battery_monitor...
         Starting LSB: Start busybox udhcpd at boot time...
         Starting BB WL18xx wlan0 Service...
[  OK  ] Started Regular background program processing daemon.
[   24.930729] hub 1-0:1.0: USB hub found
[   25.046788] hub 1-0:1.0: 1 port detected
[  OK  ] Started Deferred execution scheduler.
[  OK  ] Started Bonescript autorun.
[   25.426342] omap_rng 48310000.rng: Random Number Generator ver. 20
         Starting Login Service...
[   25.657318] remoteproc remoteproc0: powering up wkup_m3
         Starting Avahi mDNS/DNS-SD Stack...
[   25.742663] tilcdc 4830e000.lcdc: bound 0-0070 (ops tda998x_audio_codec_init [tda998x])
[   25.851143] remoteproc remoteproc0: Direct firmware load for am335x-pm-firmware.elf failed with error -2
[   25.860961] remoteproc remoteproc0: request_firmware failed: -2
[   25.867006] wkup_m3_ipc 44e11324.wkup_m3_ipc: rproc_boot failed
[  OK  ] Started System Logging Service.
[   26.074537] [drm] Initialized tilcdc 1.0.0 20121205 for 4830e000.lcdc on minor 0
[   26.315953] tilcdc 4830e000.lcdc: [drm] Cannot find any crtc or sizes
[   26.324081] tilcdc 4830e000.lcdc: [drm] Cannot find any crtc or sizes
[  OK  ] Started rc_battery_monitor.
[  OK  ] Started BBAI brcmfmac tether Service.
[  OK  ] Started BB WL18xx wlan0 Service.
[   26.691094] PM: Cannot get wkup_m3_ipc handle
[   26.837560] omap-sham 53100000.sham: hw accel on OMAP rev 4.3
[   26.858790] omap-aes 53500000.aes: OMAP AES hw accel rev: 3.2
[   27.002714] omap-sham 53100000.sham: will run requests pump with realtime priority
[   27.011559] PM: Cannot get wkup_m3_ipc handle
[  OK  ] Found device /dev/ttyS0.
[   27.062611] omap-aes 53500000.aes: will run requests pump with realtime priority
[   27.071323] PM: Cannot get wkup_m3_ipc handle
[   28.294990] cpsw-switch 4a100000.switch: starting ndev. mode: dual_mac
[   28.627447] SMSC LAN8710/LAN8720 4a101000.mdio:00: attached PHY driver (mii_bus:phy_addr=4a101000.mdio:00, irq=POLL)
[  OK  ] Started LSB: Start daemon at boot time.
[  OK  ] Started LSB: Start busybox udhcpd at boot time.
[   30.463666] PM: Cannot get wkup_m3_ipc handle
[   30.649846] PM: Cannot get wkup_m3_ipc handle
[  OK  ] Started LSB: Load kernel modules needed to enable cpufreq scaling.
[  OK  ] Started Connection service.
[  OK  ] Started Avahi mDNS/DNS-SD Stack.
[  OK  ] Started Login Service.
         Starting Hostname Service...
         Starting WPA supplicant...
[  OK  ] Reached target Sound Card.
         Starting LSB: set CPUFreq kernel parameters...
[  OK  ] Started WPA supplicant.
[  OK  ] Reached target Network.
         Starting A high performance web server and a reverse proxy server...
         Starting Permit User Sessions...
[  OK  ] Reached target Network is Online.
         Starting LSB: Advanced IEEE 802.11 management daemon...
[  OK  ] Started LSB: set CPUFreq kernel parameters.
[  OK  ] Started LSB: Advanced IEEE 802.11 management daemon.
[  OK  ] Started Permit User Sessions.
[  OK  ] Started Hostname Service.
         Starting Light Display Manager...
[  OK  ] Started Getty on tty1.
[  OK  ] Started Serial Getty on ttyS0.
[  OK  ] Reached target Login Prompts.
[  OK  ] Started Light Display Manager.
[  OK  ] Started A high performance web server and a reverse proxy server.
[  OK  ] Stopped Light Display Manager.
beaglebone login: debian
[   44.181054] EXT4-fs error (device mmcblk0p2): ext4_find_extent:936: inode #168539: comm dpkg-query: pblk 1323005 bad header/extent: invalid magic - m)
[   44.199443] Aborting journal on device mmcblk0p2-8.
[   44.207430] EXT4-fs error (device mmcblk0p2): ext4_journal_check_start:83: comm rs:main Q:Reg: Detected aborted journal
[   44.227921] EXT4-fs error (device mmcblk0p2): ext4_journal_check_start:83: comm lightdm: Detected aborted journal
[   44.322540] EXT4-fs error (device mmcblk0p2): ext4_journal_check_start:83: comm Xorg: Detected aborted journal
[   54.245777] mmc0: Timeout waiting for hardware interrupt.
[   54.251254] mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
[   54.257723] mmc0: sdhci: Sys addr:  0x00000000 | Version:  0x00003101
[   54.264194] mmc0: sdhci: Blk size:  0x00000200 | Blk cnt:  0x00000028
[   54.270665] mmc0: sdhci: Argument:  0x00942ef0 | Trn mode: 0x00000033
[   54.277136] mmc0: sdhci: Present:   0x01f70a06 | Host ctl: 0x00000002
[   54.283605] mmc0: sdhci: Power:     0x0000000f | Blk gap:  0x00000000
[   54.290075] mmc0: sdhci: Wake-up:   0x00000000 | Clock:    0x00000087
[   54.296543] mmc0: sdhci: Timeout:   0x0000000a | Int stat: 0x00000000
[   54.303013] mmc0: sdhci: Int enab:  0x027f000b | Sig enab: 0x027f000b
[   54.309483] mmc0: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[   54.315951] mmc0: sdhci: Caps:      0x07e10080 | Caps_1:   0x00000000
[   54.322420] mmc0: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
[   54.328889] mmc0: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x00000000
[   54.335359] mmc0: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
[   54.341828] mmc0: sdhci: Host ctl2: 0x00000000
[   54.346291] mmc0: sdhci: ============================================
[   54.408885] EXT4-fs warning (device mmcblk0p2): ext4_dirblock_csum_verify:404: inode #17911: comm nodejs: No space for directory leaf checksum. Pleas.
[   54.423939] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1689: inode #17911: comm nodejs: checksumming directory block 0
[   54.440789] EXT4-fs error (device mmcblk0p2): ext4_journal_check_start:83: comm systemd: Detected aborted journal
[   54.451633] EXT4-fs (mmcblk0p2): Remounting filesystem read-only
[   54.459437] EXT4-fs warning (device mmcblk0p2): dx_probe:820: inode #168539: lblock 0: comm dpkg-query: error -117 reading directory block
[   54.551244] EXT4-fs warning (device mmcblk0p2): ext4_dirblock_csum_verify:404: inode #17911: comm nodejs: No space for directory leaf checksum. Pleas.
[   54.566374] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1689: inode #17911: comm nodejs: checksumming directory block 0
[   54.626548] EXT4-fs warning (device mmcblk0p2): ext4_dirblock_csum_verify:404: inode #17911: comm nodejs: No space for directory leaf checksum. Pleas.
[   54.641591] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1689: inode #17911: comm nodejs: checksumming directory block 0
[   54.676379] EXT4-fs warning (device mmcblk0p2): ext4_dirblock_csum_verify:404: inode #17911: comm nodejs: No space for directory leaf checksum. Pleas.
[   54.691382] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1689: inode #17911: comm nodejs: checksumming directory block 0
[  OK  ] Stopped Serial Getty on ttyS0.
[   54.750742] EXT4-fs warning (device mmcblk0p2): ext4_dirblock_csum_verify:404: inode #17911: comm nodejs: No space for directory leaf checksum. Pleas.
[   54.765856] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1689: inode #17911: comm nodejs: checksumming directory block 0
[   56.210598] mmc0: Problem switching card into high-speed mode!
beaglebone login: [   66.405774] mmc0: Timeout waiting for hardware interrupt.
[   66.411254] mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
[   66.417725] mmc0: sdhci: Sys addr:  0x00000000 | Version:  0x00003101
[   66.424195] mmc0: sdhci: Blk size:  0x00000200 | Blk cnt:  0x00000020
[   66.430666] mmc0: sdhci: Argument:  0x0094cbd0 | Trn mode: 0x00000033
[   66.437135] mmc0: sdhci: Present:   0x01f70a06 | Host ctl: 0x00000002
[   66.443605] mmc0: sdhci: Power:     0x0000000f | Blk gap:  0x00000000
[   66.450074] mmc0: sdhci: Wake-up:   0x00000000 | Clock:    0x00000107
[   66.456545] mmc0: sdhci: Timeout:   0x00000009 | Int stat: 0x00000000
[   66.463013] mmc0: sdhci: Int enab:  0x027f000b | Sig enab: 0x027f000b
[   66.469483] mmc0: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[   66.475952] mmc0: sdhci: Caps:      0x07e10080 | Caps_1:   0x00000000
[   66.482421] mmc0: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
[   66.488890] mmc0: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x00000000
[   66.495359] mmc0: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
[   66.501828] mmc0: sdhci: Host ctl2: 0x00000000
[   66.506291] mmc0: sdhci: ============================================
debian
[   85.605771] mmc0: Timeout waiting for hardware interrupt.
[   85.611254] mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
[   85.617723] mmc0: sdhci: Sys addr:  0x00000000 | Version:  0x00003101
[   85.624195] mmc0: sdhci: Blk size:  0x00000200 | Blk cnt:  0x00000020
[   85.630664] mmc0: sdhci: Argument:  0x0094cbd0 | Trn mode: 0x00000033
[   85.637134] mmc0: sdhci: Present:   0x01f70a06 | Host ctl: 0x00000002
[   85.643604] mmc0: sdhci: Power:     0x0000000f | Blk gap:  0x00000000
[   85.650073] mmc0: sdhci: Wake-up:   0x00000000 | Clock:    0x00000107
[   85.656542] mmc0: sdhci: Timeout:   0x00000009 | Int stat: 0x00000000
[   85.663011] mmc0: sdhci: Int enab:  0x027f000b | Sig enab: 0x027f000b
[   85.669481] mmc0: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[   85.675949] mmc0: sdhci: Caps:      0x07e10080 | Caps_1:   0x00000000
[   85.682417] mmc0: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
[   85.688887] mmc0: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x00000000
[   85.695356] mmc0: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
[   85.701826] mmc0: sdhci: Host ctl2: 0x00000000
[   85.706287] mmc0: sdhci: ============================================
[   85.814680] mmc0: Problem switching card into high-speed mode!
[FAILED] Failed to start Generic Board Startup.
See 'systemctl status generic-board-startup.service' for details.
         Starting BB WL18xx Bluetooth Service...
[FAILED] Failed to start BB WL18xx Bluetooth Service.
See 'systemctl status bb-wl18xx-bluetooth.service' for details.
[  OK  ] Reached target Multi-User System.
[  OK  ] Reached target Graphical Interface.
         Starting Update UTMP about System Runlevel Changes...
[FAILED] Failed to start Update UTMP about System Runlevel Changes.
See 'systemctl status systemd-update-utmp-runlevel.service' for details.
beaglebone login: [  116.487535] 8<--- cut here ---
[  116.490656] Unable to handle kernel paging request at virtual address 2d333150 when read
[  116.498950] [2d333150] *pgd=00000000
[  116.502568] Internal error: Oops: 5 [#1] SMP ARM
[  116.507215] Modules linked in: snd_soc_hdmi_codec evdev iptable_nat nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 snd_soc_simple_card iptable_man4
[  116.574207] CPU: 0 PID: 555 Comm: (sh) Not tainted 6.5.4 #1
[  116.579811] Hardware name: Generic AM33XX (Flattened Device Tree)
[  116.585932] PC is at __kmem_cache_alloc_node+0xbc/0x4dc
[  116.591207] LR is at 0xe047dd08
[  116.594365] pc : [<c02f08d8>]    lr : [<e047dd08>]    psr: a0010013
[  116.600660] sp : e047dd08  ip : c110c390  fp : 0000cc52
[  116.605908] r10: c105edb0  r9 : c1005694  r8 : 00000dc0
[  116.611155] r7 : c1134598  r6 : 2d333130  r5 : 00000000  r4 : c1801100
[  116.617711] r3 : 00000020  r2 : df93bb38  r1 : 0000cc51  r0 : 1e9b4000
[  116.624269] Flags: NzCv  IRQs on  FIQs on  Mode SVC_32  ISA ARM  Segment none
[  116.631440] Control: 10c5387d  Table: 837c8019  DAC: 00000051
[  116.637209] Register r0 information: non-paged memory
[  116.642291] Register r1 information: non-paged memory
[  116.647369] Register r2 information: non-slab/vmalloc memory
[  116.653061] Register r3 information: non-paged memory
[  116.658137] Register r4 information: slab kmem_cache start c1801100 pointer offset 0 size 124
[  116.666732] Register r5 information: NULL pointer
[  116.671460] Register r6 information: non-paged memory
[  116.676536] Register r7 information: non-slab/vmalloc memory
[  116.682226] Register r8 information: non-paged memory
[  116.687303] Register r9 information: non-slab/vmalloc memory
[  116.692991] Register r10 information: non-slab/vmalloc memory
[  116.698766] Register r11 information: non-paged memory
[  116.703929] Register r12 information: non-slab/vmalloc memory
[  116.709704] Process (sh) (pid: 555, stack limit = 0x2e6ae69d)
[  116.715483] Stack: (0xe047dd08 to 0xe047e000)
[  116.719867] dd00:                   df93bb38 00000018 00000000 00000dc0 00000018 ffffffff
[  116.728085] dd20: c25720d8 e047dda0 00000005 00000018 c01f6cf8 c1801100 00000dc0 c105edb0
[  116.736301] dd40: c112a29c c02a7e88 c01f6cf8 c1801280 00000dc0 c105edb0 c112a29c e047dda0
[  116.744518] dd60: 00000005 0000000a c0e0e33c 00000020 00000103 c105edb0 c112a29c c01f6cf8
[  116.752735] dd80: 00000000 c5afa200 c36c6800 c5afa000 00000020 c01f9d3c 00000000 c2c00000
[  116.760952] dda0: c347d988 c34ed108 c10611d8 c1116a40 c10266f8 c1142670 c180d000 c2f1ca00
[  116.769169] ddc0: c18b2000 c18b2080 c18b2100 6c427dcb e047ddd0 c112a29c e047de28 e047dd6c
[  116.777386] dde0: 00000001 c1109f89 c112a2a4 c5afa200 c5afa2bc c01face8 00002991 c112a29c
[  116.785602] de00: c5ad0000 00000001 c36c6800 00000001 00000000 00000000 00000000 c01fbb24
[  116.793820] de20: 00000000 6c427dcb c5afa2bc c5afa2bc e047de30 e047de30 e047de38 e047de38
[  116.802036] de40: e047de40 e047de40 00000000 00000000 e047de38 00000000 00000000 00000000
[  116.810252] de60: 00000001 6c427dcb 00000000 c2f1c580 c5ad0000 c36c6800 00000004 00000001
[  116.818469] de80: 00000000 00000000 00000000 c0201cec 01000004 6c427dcb bead3590 00000000
[  116.826685] dea0: 00000000 c2f1c580 c2f1c590 e047df30 00000004 c0201d80 00000000 00000000
[  116.834903] dec0: 00000001 c2f1c580 c2f1c590 c36028c0 00000004 c03a6bc0 00000000 00000000
[  116.843120] dee0: 00000000 00000000 c32439c0 e047df80 005a8b90 c0c1d788 bead3590 c030866c
[  116.851337] df00: 00000000 00000000 00201000 00000000 01000005 00000001 00000004 005a8b90
[  116.859554] df20: 00000000 00000000 00000001 00000000 c32439c0 00000000 00000000 00000000
[  116.867770] df40: 00000000 00000000 00000000 00004004 00000000 00000000 00000004 6c427dcb
[  116.875986] df60: c32439c0 c32439c0 00000000 00000000 c01002ec c5ad0000 00000004 c0308994
[  116.884203] df80: 00000000 00000000 00000000 6c427dcb 00000003 00000004 005a8b90 006085d0
[  116.892420] dfa0: 00000004 c0100080 00000004 005a8b90 00000003 005a8b90 00000004 00000000
[  116.900637] dfc0: 00000004 005a8b90 006085d0 00000004 005a8b90 00000004 fffffffe bead3590
[  116.908854] dfe0: 00000000 bead3478 00000000 b6be6d12 00010030 00000003 00000000 00000000
[  116.917079]  __kmem_cache_alloc_node from kmalloc_trace+0x28/0xb4
[  116.923232]  kmalloc_trace from allocate_cgrp_cset_links+0x30/0xc0
[  116.929467]  allocate_cgrp_cset_links from find_css_set+0x2b8/0x5e8
[  116.935783]  find_css_set from cgroup_migrate_prepare_dst+0x3c/0x1ec
[  116.942180]  cgroup_migrate_prepare_dst from cgroup_attach_task+0xf0/0x210
[  116.949095]  cgroup_attach_task from __cgroup1_procs_write+0x128/0x17c
[  116.955668]  __cgroup1_procs_write from cgroup1_procs_write+0x1c/0x24
[  116.962148]  cgroup1_procs_write from kernfs_fop_write_iter+0xfc/0x1e8
[  116.968732]  kernfs_fop_write_iter from vfs_write+0x1d4/0x38c
[  116.974531]  vfs_write from ksys_write+0x70/0xfc
[  116.979185]  ksys_write from ret_fast_syscall+0x0/0x58
[  116.984360] Exception stack(0xe047dfa8 to 0xe047dff0)
[  116.989438] dfa0:                   00000004 005a8b90 00000003 005a8b90 00000004 00000000
[  116.997655] dfc0: 00000004 005a8b90 006085d0 00000004 005a8b90 00000004 fffffffe bead3590
[  117.005870] dfe0: 00000000 bead3478 00000000 b6be6d12
[  117.010951] Code: e3560000 13530000 0a0000b2 e594301c (e796c003)
[  117.017205] ---[ end trace 0000000000000000 ]---
[  403.045819] 8<--- cut here ---
[  403.048935] Unable to handle kernel paging request at virtual address 2d333150 when read
[  403.057130] [2d333150] *pgd=00000000
[  403.060746] Internal error: Oops: 5 [#2] SMP ARM
[  403.065390] Modules linked in: snd_soc_hdmi_codec evdev iptable_nat nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 snd_soc_simple_card iptable_man4
[  403.132385] CPU: 0 PID: 50 Comm: kworker/0:17 Tainted: G      D            6.5.4 #1
[  403.140082] Hardware name: Generic AM33XX (Flattened Device Tree)
[  403.146210] Workqueue:  0x0 (events)
[  403.149823] PC is at __kmem_cache_alloc_node+0xbc/0x4dc
[  403.155093] LR is at 0xe03e9e58
[  403.158249] pc : [<c02f08d8>]    lr : [<e03e9e58>]    psr: a0010013
[  403.164543] sp : e03e9e58  ip : e03e9f28  fp : 0000cc52
[  403.169791] r10: 00000000  r9 : c1005694  r8 : 00000cc0
[  403.175038] r7 : c1134598  r6 : 2d333130  r5 : 00000000  r4 : c1801100
[  403.181595] r3 : 00000020  r2 : df93bb38  r1 : 0000cc51  r0 : 1e9b4000
[  403.188153] Flags: NzCv  IRQs on  FIQs on  Mode SVC_32  ISA ARM  Segment none
[  403.195324] Control: 10c5387d  Table: 82ebc019  DAC: 00000051
[  403.201093] Register r0 information: non-paged memory
[  403.206175] Register r1 information: non-paged memory
[  403.211252] Register r2 information: non-slab/vmalloc memory
[  403.216944] Register r3 information: non-paged memory
[  403.222021] Register r4 information: slab kmem_cache start c1801100 pointer offset 0 size 124
[  403.230614] Register r5 information: NULL pointer
[  403.235343] Register r6 information: non-paged memory
[  403.240420] Register r7 information: non-slab/vmalloc memory
[  403.246109] Register r8 information: non-paged memory
[  403.251185] Register r9 information: non-slab/vmalloc memory
[  403.256872] Register r10 information: NULL pointer
[  403.261687] Register r11 information: non-paged memory
[  403.266851] Register r12 information: 2-page vmalloc region starting at 0xe03e8000 allocated at kernel_clone+0xa4/0x3ac
[  403.277713] Process kworker/0:17 (pid: 50, stack limit = 0x2dc970a1)
[  403.284101] Stack: (0xe03e9e58 to 0xe03ea000)
[  403.288480] 9e40:                                                       ffffffff 00000000
[  403.296697] 9e60: 00000000 00000cc0 00000020 ffffffff 00000000 df938800 00000000 00000020
[  403.304914] 9e80: c015b888 c1801100 00000cc0 00000000 00000000 c02a7e88 c015b888 ffff0a00
[  403.313131] 9ea0: 00000dc0 c0d73fdb ffffff04 df938800 00000000 c2f1c780 c0d73fe8 c0156bd0
[  403.321348] 9ec0: c1003d40 00000000 00000000 c015b888 00000000 00000000 e03e9ed8 e03e9ed8
[  403.329565] 9ee0: ffff0a00 6c427dcb df938800 c2f1c780 00000000 df938988 c1fd0000 df938820
[  403.337781] 9f00: df93885c c015b9d4 e03e9f28 c0aee730 e03e9f28 6c427dcb df93885c df938800
[  403.345998] 9f20: c01539f8 c0d73fe8 e03e9f34 c0d7f5c8 00002843 00303a30 00000000 00000000
[  403.354214] 9f40: 00000000 6c427dcb df938800 c1ff4b80 df938800 df938820 df938800 c0156ee4
[  403.362432] 9f60: c1ff4b80 00000000 e03e5ed0 c1ff5a40 c1ff5dc0 c0156bd0 c1ff4b80 c1fd0000
[  403.370649] 9f80: e03e5ed0 00000000 00000000 c015d3e8 c1ff5a40 c015d310 00000000 00000000
[  403.378865] 9fa0: 00000000 00000000 00000000 c0100174 00000000 00000000 00000000 00000000
[  403.387082] 9fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[  403.395298] 9fe0: 00000000 00000000 00000000 00000000 00000013 00000000 00000000 00000000
[  403.403520]  __kmem_cache_alloc_node from kmalloc_trace+0x28/0xb4
[  403.409668]  kmalloc_trace from __kthread_create_on_node+0x54/0x170
[  403.415995]  __kthread_create_on_node from kthread_create_on_node+0x30/0x60
[  403.423008]  kthread_create_on_node from create_worker+0xb8/0x254
[  403.429144]  create_worker from worker_thread+0x314/0x504
[  403.434578]  worker_thread from kthread+0xd8/0xf8
[  403.439315]  kthread from ret_from_fork+0x14/0x20
[  403.444048] Exception stack(0xe03e9fb0 to 0xe03e9ff8)
[  403.449125] 9fa0:                                     00000000 00000000 00000000 00000000
[  403.457341] 9fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[  403.465556] 9fe0: 00000000 00000000 00000000 00000000 00000013 00000000
[  403.472207] Code: e3560000 13530000 0a0000b2 e594301c (e796c003)
[  403.478435] ---[ end trace 0000000000000000 ]---
Hi @RobertCNelson
I am waiting for your suggestion, anything else I should try ?
