Hey, I have tried booting linux image in the eMMC through u-boot but it always drops to busybox shell. As suggested by the busybox shell I double checked the PARTUUID using blkid it’s a match so why can’t it load the rfs?
My emmc has a single partition debian image. U-boot lies in the first partiition of my sd card(boot by pressing s2 switch.Here are my logs,uEnv.txt.
Standalone beaglebone boots just fine that is without my u-boot and sd card not inserted it boots fine from the emmc(which means emmc image is good) just when I try uboot from sd card this happensEnter code here
uEnv.txt
ipaddr=192.168.7.2
serverip=192.168.7.1
console=ttyO0,115200n8
finduuid=part uuid mmc 1:1 uuid
netargs=setenv bootargs console=ttyO0,115200n8 root=UUID=aa9109fe-2099-47e0-b8a5-e1a3f87848b0 rootwait rw rootfstype=ext4 rootwait coherent_pool=1M net.ifnames=0 quiet
loadaddr=0x82000000
ftdaddr=0x88000000
initramaddr=0x88080000
initrdsize=452040
netboot=echo Booting from emmc …; setenv autoload no ;echo moving zimage from emmc to DRAM…;load mmc 1:1 ${loadaddr} /boot/vmlinuz-4.14.71-ti-r80;echo moving dtb from emmc to DRAM… ; load mmc 1:1 ${fdtaddr} /boot/dtbs/4.14.71-ti-r80/am335x-boneblack-uboot-univ.dtb ; echo moving initrd from emmc to DRAM…;load mmc 1:1 ${initramaddr} /boot/initrd.img-4.14.71-ti-r80;echo running netargs …; run netargs ; echo bootzzzz…;bootz ${loadaddr} ${initramaddr}:${initrdsize} ${ftdaddr}
uenvcmd=echo running netboot…;run netboot
Starting kernel …
[ 0.002066] timer_probe: no matching timers found
[ 1.132460] wkup_m3_ipc 44e11324.wkup_m3_ipc: could not get rproc handle
[ 1.444765] omap_voltage_late_init: Voltage driver support not added
[ 1.452379] PM: Cannot get wkup_m3_ipc handle
Gave up waiting for root file system device. Common problems:
Boot args (cat /proc/cmdline)
Check rootdelay= (did the system wait long enough?)
Missing modules (cat /proc/modules; ls /dev)
ALERT! PARTUUID=8fb410a9-01 does not exist. Dropping to a shell!
/dev/mmcblk1p1: LABEL=“rootfs” UUID=“aa9109fe-2099-47e0-b8a5-e1a3f87848b0” TYPE=“ext4” PARTUUID=“8fb410a9-01”
