Hi @RobertCNelson,
Okay, it looks like you manually copied BB-CAPE-DISP-CT4-00A0 into common…
Yes, as the LCD was not working we tried to add the overlay manually.
What is your hardware, is it pretty much a BeagleBone Black with that cape pre-installed?
Yes, we have Beaglebone black with BB-CAPE-DISP-CT43 LCD.
If your goal is pre-build a *.dtb will all the custom overlays you need, the ‘fdtoverlay’ tools supports this.
We want to customize the *dtb for our application.
Below is the serial debug msg
[ 0.000000] Linux version 5.15.73-bone-rt-r31 (devika@devika-Latitude-3410) (arm-linux-gnueabi-gcc (GCC) 11.3.0, GNU ld (GNU Binutils) 2.38) #13 PREEMPT_RT Tue Dec 20 10:48:53 IST 2022
[ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=50c5387d
[ 0.000000] OF: fdt: Machine model: TI AM335x BeagleBone Black
[ 0.000000] Memory policy: Data cache writeback
[ 0.000000] efi: UEFI not found.
[ 0.000000] cma: Reserved 48 MiB at 0x9c800000
[ 0.000000] Zone ranges:
[ 0.000000] Normal [mem 0x0000000080000000-0x000000009fefffff]
[ 0.000000] HighMem empty
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x000000009fefffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x000000009fefffff]
[ 0.000000] CPU: All CPU(s) started in SVC mode.
[ 0.000000] AM335X ES2.1 (sgx neon)
[ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 129666
[ 0.000000] Kernel command line: console=ttyO0,115200n8 root=/dev/mmcblk0p1 ro rootfstype=ext4 rootwait 1
[ 0.000000] Unknown kernel command line parameters "1", will be passed to user space.
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:on, heap free:off
[ 0.000000] Memory: 450212K/523264K available (10240K kernel code, 1663K rwdata, 3812K rodata, 1024K init, 362K bss, 23900K reserved, 49152K cma-reserved, 0K highmem)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] ftrace: allocating 46686 entries in 137 pages
[ 0.000000] ftrace: allocated 137 pages with 3 groups
[ 0.000000] trace event string verifier disabled
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU priority boosting: priority 1 delay 500 ms.
[ 0.000000] rcu: RCU_SOFTIRQ processing moved to rcuc kthreads.
[ 0.000000] No expedited grace period (rcu_normal_after_boot).
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Rude variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] IRQ: Found an INTC at 0x(ptrval) (revision 5.0) with 128 interrupts
[ 0.000000] TI gptimer clocksource: always-on /ocp/interconnect@44c00000/segment@200000/target-module@31000
[ 0.000001] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
[ 0.000021] clocksource: dmtimer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.000350] TI gptimer clockevent: 24000000 Hz at /ocp/interconnect@48000000/segment@0/target-module@40000
[ 0.001707] Console: colour dummy device 80x30
[ 0.001742] WARNING: Your 'console=ttyO0' has been replaced by 'ttyS0'
[ 0.001748] This ensures that you still see kernel messages. Please
[ 0.001751] update your kernel commandline.
[ 0.001778] Calibrating delay loop... 995.32 BogoMIPS (lpj=1990656)
[ 0.020420] pid_max: default: 32768 minimum: 301
[ 0.020893] LSM: Security Framework initializing
[ 0.020979] Yama: becoming mindful.
[ 0.021261] AppArmor: AppArmor initialized
[ 0.021272] TOMOYO Linux initialized
[ 0.021500] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.021516] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.023176] CPU: Testing write buffer coherency: ok
[ 0.023242] CPU0: Spectre v2: using BPIALL workaround
[ 0.025077] Setting up static identity map for 0x80100000 - 0x80100054
[ 0.025255] rcu: Hierarchical SRCU implementation.
[ 0.027023] EFI services will not be available.
[ 0.027812] devtmpfs: initialized
[ 0.051884] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[ 0.052352] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.052383] futex hash table entries: 256 (order: 0, 6144 bytes, linear)
[ 0.057615] pinctrl core: initialized pinctrl subsystem
[ 0.059542] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.068247] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.069055] audit: initializing netlink subsys (disabled)
[ 0.070278] thermal_sys: Registered thermal governor 'fair_share'
[ 0.070290] thermal_sys: Registered thermal governor 'bang_bang'
[ 0.070295] thermal_sys: Registered thermal governor 'step_wise'
[ 0.070852] cpuidle: using governor menu
[ 0.076464] audit: type=2000 audit(0.068:1): state=initialized audit_enabled=0 res=1
[ 0.089197] hw-breakpoint: debug architecture 0x4 unsupported.
[ 0.113413] raid6: skip pq benchmark and using algorithm neonx8
[ 0.113430] raid6: using neon recovery algorithm
[ 0.115006] iommu: Default domain type: Translated
[ 0.115018] iommu: DMA domain TLB invalidation policy: strict mode
[ 0.117299] SCSI subsystem initialized
[ 0.117407] libata version 3.00 loaded.
[ 0.117700] usbcore: registered new interface driver usbfs
[ 0.117754] usbcore: registered new interface driver hub
[ 0.117833] usbcore: registered new device driver usb
[ 0.118188] mc: Linux media interface: v0.10
[ 0.118279] pps_core: LinuxPPS API ver. 1 registered
[ 0.118285] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.118306] PTP clock support registered
[ 0.119225] Advanced Linux Sound Architecture Driver Initialized.
[ 0.120301] NetLabel: Initializing
[ 0.120307] NetLabel: domain hash size = 128
[ 0.120312] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[ 0.120850] NetLabel: unlabeled traffic allowed by default
[ 0.121804] clocksource: Switched to clocksource dmtimer
[ 0.241244] VFS: Disk quotas dquot_6.6.0
[ 0.241370] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.242540] AppArmor: AppArmor Filesystem Enabled
[ 0.268605] NET: Registered PF_INET protocol family
[ 0.268853] IP idents hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.270238] tcp_listen_portaddr_hash hash table entries: 256 (order: 0, 5120 bytes, linear)
[ 0.270449] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.270480] TCP established hash table entries: 4096 (order: 2, 16384 bytes, linear)
[ 0.270564] TCP bind hash table entries: 4096 (order: 4, 65536 bytes, linear)
[ 0.270648] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.270925] MPTCP token hash table entries: 512 (order: 1, 12288 bytes, linear)
[ 0.271048] UDP hash table entries: 256 (order: 1, 12288 bytes, linear)
[ 0.271089] UDP-Lite hash table entries: 256 (order: 1, 12288 bytes, linear)
[ 0.271338] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.278463] RPC: Registered named UNIX socket transport module.
[ 0.278477] RPC: Registered udp transport module.
[ 0.278480] RPC: Registered tcp transport module.
[ 0.278484] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.278496] NET: Registered PF_XDP protocol family
[ 1.261140] Initialise system trusted keyrings
[ 1.261545] workingset: timestamp_bits=14 max_order=17 bucket_order=3
[ 1.271617] zbud: loaded
[ 1.275469] NFS: Registering the id_resolver key type
[ 1.275523] Key type id_resolver registered
[ 1.275529] Key type id_legacy registered
[ 1.275690] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 1.275699] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 1.276038] fuse: init (API version 7.34)
[ 1.370272] xor: automatically using best checksumming function neon
[ 1.370291] Key type asymmetric registered
[ 1.370297] Asymmetric key parser 'x509' registered
[ 1.370450] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[ 1.370736] io scheduler mq-deadline registered
[ 1.375203] Serial: 8250/16550 driver, 6 ports, IRQ sharing disabled
[ 1.381389] SPI driver ili9486 has no spi_device_id for waveshare,rpi-lcd-35
[ 1.381404] SPI driver ili9486 has no spi_device_id for ozzmaker,piscreen
[ 1.382340] SPI driver spidev has no spi_device_id for linux,spidev
[ 1.384532] CAN device driver interface
[ 1.385549] usbcore: registered new interface driver uas
[ 1.385619] usbcore: registered new interface driver usb-storage
[ 1.385655] usbcore: registered new interface driver ums-alauda
[ 1.385688] usbcore: registered new interface driver ums-cypress
[ 1.385721] usbcore: registered new interface driver ums-datafab
[ 1.385754] usbcore: registered new interface driver ums_eneub6250
[ 1.385786] usbcore: registered new interface driver ums-freecom
[ 1.386021] usbcore: registered new interface driver ums-isd200
[ 1.386102] usbcore: registered new interface driver ums-jumpshot
[ 1.386139] usbcore: registered new interface driver ums-karma
[ 1.386174] usbcore: registered new interface driver ums-onetouch
[ 1.386225] usbcore: registered new interface driver ums-realtek
[ 1.386260] usbcore: registered new interface driver ums-sddr09
[ 1.386293] usbcore: registered new interface driver ums-sddr55
[ 1.386327] usbcore: registered new interface driver ums-usbat
[ 1.388412] i2c_dev: i2c /dev entries driver
[ 1.388478] Driver for 1-wire Dallas network protocol.
[ 1.389552] softdog: initialized. soft_noboot=0 soft_margin=60 sec soft_panic=0 (nowayout=0)
[ 1.389564] softdog: soft_reboot_cmd=<not set> soft_active_on_boot=0
[ 1.390693] cpuidle: enable-method property 'ti,am3352' found operations
[ 1.391364] sdhci: Secure Digital Host Controller Interface driver
[ 1.391371] sdhci: Copyright(c) Pierre Ossman
[ 1.391524] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.392406] hid: raw HID events driver (C) Jiri Kosina
[ 1.392737] usbcore: registered new interface driver usbhid
[ 1.392745] usbhid: USB HID core driver
[ 1.394655] drop_monitor: Initializing network drop monitor service
[ 1.395907] NET: Registered PF_INET6 protocol family
[ 1.401064] Segment Routing with IPv6
[ 1.401160] In-situ OAM (IOAM) with IPv6
[ 1.401311] mip6: Mobile IPv6
[ 1.401321] NET: Registered PF_PACKET protocol family
[ 1.401345] can: controller area network core
[ 1.401442] NET: Registered PF_CAN protocol family
[ 1.401952] Key type dns_resolver registered
[ 1.401963] mpls_gso: MPLS GSO support
[ 1.402168] ThumbEE CPU extension supported.
[ 1.402188] Registering SWP/SWPB emulation handler
[ 1.402195] omap_voltage_late_init: Voltage driver support not added
[ 1.402471] PM: Cannot get wkup_m3_ipc handle
[ 1.403197] registered taskstats version 1
[ 1.403216] Loading compiled-in X.509 certificates
[ 1.403629] zswap: loaded using pool lzo/zbud
[ 1.404353] Key type ._fscrypt registered
[ 1.404366] Key type .fscrypt registered
[ 1.404371] Key type fscrypt-provisioning registered
[ 1.412488] Btrfs loaded, crc32c=crc32c-generic, zoned=yes, fsverity=yes
[ 1.412651] AppArmor: AppArmor sha1 policy hashing enabled
[ 1.436661] remoteproc remoteproc0: wkup_m3 is available
[ 1.452182] pinctrl-single 44e10800.pinmux: 142 pins, size 568
[ 1.456251] ti-sysc: probe of 44e31000.target-module failed with error -16
[ 1.459603] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[ 1.463652] omap_rtc 44e3e000.rtc: registered as rtc0
[ 1.463703] omap_rtc 44e3e000.rtc: setting system clock to 2000-01-01T00:00:00 UTC (946684800)
[ 1.469386] 48022000.serial: ttyS1 at MMIO 0x48022000 (irq = 25, base_baud = 3000000) is a 8250
[ 1.472867] 48024000.serial: ttyS2 at MMIO 0x48024000 (irq = 26, base_baud = 3000000) is a 8250
[ 1.476395] omap_i2c 4802a000.i2c: bus 1 rev0.11 at 100 kHz
[ 1.481072] ti-sysc: probe of 48040000.target-module failed with error -16
[ 1.492813] OMAP GPIO hardware version 0.1
[ 1.498391] omap-mailbox 480c8000.mailbox: omap mailbox rev 0x400
[ 1.503835] at24 2-0054: supply vcc not found, using dummy regulator
[ 1.526442] at24 2-0054: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 1.526879] at24 2-0055: supply vcc not found, using dummy regulator
[ 1.556559] at24 2-0056: supply vcc not found, using dummy regulator
[ 1.584410] at24 2-0057: supply vcc not found, using dummy regulator
[ 1.614285] omap_i2c 4819c000.i2c: bus 2 rev0.11 at 100 kHz
[ 1.617440] 481a6000.serial: ttyS3 at MMIO 0x481a6000 (irq = 39, base_baud = 3000000) is a 8250
[ 1.620733] 481a8000.serial: ttyS4 at MMIO 0x481a8000 (irq = 40, base_baud = 3000000) is a 8250
[ 1.632197] sdhci-omap 481d8000.mmc: supply vqmmc not found, using dummy regulator
[ 1.650237] omap_rng 48310000.rng: Random Number Generator ver. 20
[ 1.654327] random: crng init done
[ 1.693847] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6, bus freq 1000000
[ 1.695909] davinci_mdio 4a101000.mdio: phy[0]: device 4a101000.mdio:00, driver SMSC LAN8710/LAN8720
[ 1.696335] cpsw-switch 4a100000.switch: initialized cpsw ale version 1.4
[ 1.696350] cpsw-switch 4a100000.switch: ALE Table size 1024
[ 1.696441] cpsw-switch 4a100000.switch: cpts: overflow check period 1250 (jiffies)
[ 1.696456] cpsw-switch 4a100000.switch: CPTS: ref_clk_freq:250000000 calc_mult:2147483648 calc_shift:29 error:0 nsec/sec
[ 1.696555] cpsw-switch 4a100000.switch: Detected MACID = 3c:e4:b0:2b:7c:c6
[ 1.698787] cpsw-switch 4a100000.switch: initialized (regs 0x4a100000, pool size 256) hw_ver:0019010C 1.12 (0)
[ 1.715616] debugfs: Directory '49000000.dma' with parent 'dmaengine' already present!
[ 1.715647] edma 49000000.dma: TI EDMA DMA engine driver
[ 1.721638] am335x-phy-driver 47401300.usb-phy: supply vcc not found, using dummy regulator
[ 1.722196] am335x-phy-driver 47401300.usb-phy: dummy supplies not allowed for exclusive requests
[ 1.728526] am335x-phy-driver 47401b00.usb-phy: supply vcc not found, using dummy regulator
[ 1.728817] am335x-phy-driver 47401b00.usb-phy: dummy supplies not allowed for exclusive requests
[ 1.751286] omap-sham 53100000.sham: hw accel on OMAP rev 4.3
[ 1.751518] omap-sham 53100000.sham: will run requests pump with realtime priority
[ 1.754910] omap-aes 53500000.aes: OMAP AES hw accel rev: 3.2
[ 1.755268] omap-aes 53500000.aes: will run requests pump with realtime priority
[ 1.760757] hw perfevents: enabled with armv7_cortex_a8 PMU driver, 5 counters available
[ 1.765974] l3-aon-clkctrl:0000:0: failed to disable
[ 1.766500] pwm-backlight backlight: supply power not found, using dummy regulator
[ 1.770988] PM: Cannot get wkup_m3_ipc handle
[ 1.773569] 44e09000.serial: ttyS0 at MMIO 0x44e09000 (irq = 18, base_baud = 3000000) is a 8250
[ 1.774108] printk: console [ttyS0]: printing thread started
[ 1.774133] printk: console [ttyS0] enabled
[ 1.805121] tps65217-pmic: Failed to locate of_node [id: -1]
[ 1.814183] tps65217-bl: Failed to locate of_node [id: -1]
[ 1.817209] tps65217 0-0024: TPS65217 ID 0xe version 1.2
[ 1.818766] at24 0-0050: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 1.819279] i2c 0-0070: Fixing up cyclic dependency with 4830e000.lcdc
[ 1.819789] pinctrl-single 44e10800.pinmux: pin PIN40 already requested by panel; cannot claim for 0-0070
[ 1.819802] pinctrl-single 44e10800.pinmux: pin-40 (0-0070) status -22
[ 1.819813] pinctrl-single 44e10800.pinmux: could not request pin 40 (PIN40) from group nxp_hdmi_bonelt_pins on device pinctrl-single
[ 1.819824] tda998x 0-0070: Error applying setting, reverse things back
[ 1.819893] omap_i2c 44e0b000.i2c: bus 0 rev0.11 at 400 kHz
[ 1.835177] omap_gpio 44e07000.gpio: Could not set line 6 debounce to 200000 microseconds (-22)
[ 1.835201] sdhci-omap 48060000.mmc: Got CD GPIO
[ 1.835391] sdhci-omap 48060000.mmc: supply vqmmc not found, using dummy regulator
[ 1.837977] remoteproc remoteproc0: powering up wkup_m3
[ 1.838006] remoteproc remoteproc0: Booting fw image am335x-pm-firmware.elf, size 217148
[ 1.838221] remoteproc remoteproc0: remote processor wkup_m3 is now up
[ 1.838278] wkup_m3_ipc 44e11324.wkup_m3_ipc: CM3 Firmware Version = 0x192
[ 1.846023] edt_ft5x06 2-0038: supply vcc not found, using dummy regulator
[ 1.846268] edt_ft5x06 2-0038: supply iovcc not found, using dummy regulator
[ 1.848070] sdhci-omap 481d8000.mmc: supply vqmmc not found, using dummy regulator
[ 1.862570] musb-hdrc musb-hdrc.1: MUSB HDRC host driver
[ 1.862628] musb-hdrc musb-hdrc.1: new USB bus registered, assigned bus number 1
[ 1.862891] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
[ 1.862906] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.862914] usb usb1: Product: MUSB HDRC host driver
[ 1.862920] usb usb1: Manufacturer: Linux 5.15.73-bone-rt-r31 musb-hcd
[ 1.862927] usb usb1: SerialNumber: musb-hdrc.1
[ 1.863812] hub 1-0:1.0: USB hub found
[ 1.864717] hub 1-0:1.0: 1 port detected
[ 1.878246] mmc0: SDHCI controller on 48060000.mmc [48060000.mmc] using External DMA
[ 1.878553] PM: bootloader does not support rtc-only!
[ 1.881666] tps6521x_pwrbutton tps65217-pwrbutton: DMA mask not set
[ 1.882698] input: tps65217_pwr_but as /devices/platform/ocp/44c00000.interconnect/44c00000.interconnect:segment@200000/44e0b000.target-module/44e0b000.i2c/i2c-0/0-0024/tps65217-pwrbutton/input/input0
[ 1.884932] mmc1: SDHCI controller on 481d8000.mmc [481d8000.mmc] using External DMA
[ 1.887819] ### dt-test ### start of unittest - you will see error messages
[ 1.892458] ### dt-test ### EXPECT \ : Duplicate name in testcase-data, renamed to "duplicate-name#1"
[ 1.892840] Duplicate name in testcase-data, renamed to "duplicate-name#1"
[ 1.905048] ### dt-test ### EXPECT / : Duplicate name in testcase-data, renamed to "duplicate-name#1"
[ 1.906171] ### dt-test ### EXPECT \ : OF: /testcase-data/phandle-tests/consumer-a: could not get #phandle-cells-missing for /testcase-data/phandle-tests/provider1
[ 1.906183] OF: /testcase-data/phandle-tests/consumer-a: could not get #phandle-cells-missing for /testcase-data/phandle-tests/provider1
[ 1.906218] ### dt-test ### EXPECT / : OF: /testcase-data/phandle-tests/consumer-a: could not get #phandle-cells-missing for /testcase-data/phandle-tests/provider1
[ 1.906224] ### dt-test ### EXPECT \ : OF: /testcase-data/phandle-tests/consumer-a: could not get #phandle-cells-missing for /testcase-data/phandle-tests/provider1
[ 1.906230] OF: /testcase-data/phandle-tests/consumer-a: could not get #phandle-cells-missing for /testcase-data/phandle-tests/provider1
[ 1.906257] ### dt-test ### EXPECT / : OF: /testcase-data/phandle-tests/consumer-a: could not get #phandle-cells-missing for /testcase-data/phandle-tests/provider1
[ 1.906262] ### dt-test ### EXPECT \ : OF: /testcase-data/phandle-tests/consumer-a: could not find phandle
[ 1.906321] OF: /testcase-data/phandle-tests/consumer-a: could not find phandle 12345678
[ 1.906342] ### dt-test ### EXPECT / : OF: /testcase-data/phandle-tests/consumer-a: could not find phandle
[ 1.906347] ### dt-test ### EXPECT \ : OF: /testcase-data/phandle-tests/consumer-a: could not find phandle
[ 1.906376] OF: /testcase-data/phandle-tests/consumer-a: could not find phandle 12345678
[ 1.906393] ### dt-test ### EXPECT / : OF: /testcase-data/phandle-tests/consumer-a: could not find phandle
[ 1.906398] ### dt-test ### EXPECT \ : OF: /testcase-data/phandle-tests/consumer-a: #phandle-cells = 3 found -1
[ 1.906405] OF: /testcase-data/phandle-tests/consumer-a: #phandle-cells = 3 found 1
[ 1.906423] ### dt-test ### EXPECT / : OF: /testcase-data/phandle-tests/consumer-a: #phandle-cells = 3 found -1
[ 1.906428] ### dt-test ### EXPECT \ : OF: /testcase-data/phandle-tests/consumer-a: #phandle-cells = 3 found -1
[ 1.906434] OF: /testcase-data/phandle-tests/consumer-a: #phandle-cells = 3 found 1
[ 1.906452] ### dt-test ### EXPECT / : OF: /testcase-data/phandle-tests/consumer-a: #phandle-cells = 3 found -1
[ 1.906608] ### dt-test ### EXPECT \ : OF: /testcase-data/phandle-tests/consumer-b: could not get #phandle-missing-cells for /testcase-data/phandle-tests/provider1
[ 1.906622] OF: /testcase-data/phandle-tests/consumer-b: could not get #phandle-missing-cells for /testcase-data/phandle-tests/provider1
[ 1.906651] ### dt-test ### EXPECT / : OF: /testcase-data/phandle-tests/consumer-b: could not get #phandle-missing-cells for /testcase-data/phandle-tests/provider1
[ 1.906656] ### dt-test ### EXPECT \ : OF: /testcase-data/phandle-tests/consumer-b: could not find phandle
[ 1.906691] OF: /testcase-data/phandle-tests/consumer-b: could not find phandle 12345678
[ 1.906711] ### dt-test ### EXPECT / : OF: /testcase-data/phandle-tests/consumer-b: could not find phandle
[ 1.906716] ### dt-test ### EXPECT \ : OF: /testcase-data/phandle-tests/consumer-b: #phandle-cells = 2 found -1
[ 1.906728] OF: /testcase-data/phandle-tests/consumer-b: #phandle-cells = 2 found 1
[ 1.906748] ### dt-test ### EXPECT / : OF: /testcase-data/phandle-tests/consumer-b: #phandle-cells = 2 found -1
[ 1.909679] ### dt-test ### EXPECT \ : platform testcase-data:testcase-device2: IRQ index 0 not found
[ 1.909708] platform testcase-data:testcase-device2: IRQ index 0 not found
[ 1.909721] ### dt-test ### EXPECT / : platform testcase-data:testcase-device2: IRQ index 0 not found
[ 1.918723] mmc0: new high speed SDHC card at address 59b4
[ 1.925064] mmcblk0: mmc0:59b4 29.8 GiB
[ 1.929142] mmcblk0: p1
[ 1.934234] ### dt-test ### EXPECT \ : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data/overlay-node/test-bus/test-unittest0/status
[ 1.934601] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data/overlay-node/test-bus/test-unittest0/status
[ 1.936263] ### dt-test ### EXPECT / : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data/overlay-node/test-bus/test-unittest0/status
[ 1.936275] ### dt-test ### EXPECT \ : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data/overlay-node/test-bus/test-unittest1/status
[ 1.936565] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data/overlay-node/test-bus/test-unittest1/status
[ 1.936975] ### dt-test ### EXPECT / : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data/overlay-node/test-bus/test-unittest1/status
[ 1.936984] ### dt-test ### EXPECT \ : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data/overlay-node/test-bus/test-unittest2/status
[ 1.937283] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data/overlay-node/test-bus/test-unittest2/status
[ 1.942204] ### dt-test ### EXPECT / : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data/overlay-node/test-bus/test-unittest2/status
[ 1.942217] ### dt-test ### EXPECT \ : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data/overlay-node/test-bus/test-unittest3/status
[ 1.942835] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data/overlay-node/test-bus/test-unittest3/status
[ 1.943391] ### dt-test ### EXPECT / : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data/overlay-node/test-bus/test-unittest3/status
[ 1.948549] ### dt-test ### EXPECT \ : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data/overlay-node/test-bus/test-unittest5/status
[ 1.948980] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data/overlay-node/test-bus/test-unittest5/status
[ 1.954172] mmc1: new high speed MMC card at address 0001
[ 1.956671] ### dt-test ### EXPECT / : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data/overlay-node/test-bus/test-unittest5/status
[ 1.956788] ### dt-test ### EXPECT \ : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data/overlay-node/test-bus/test-unittest6/status
[ 1.957134] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data/overlay-node/test-bus/test-unittest6/status
[ 1.959316] mmcblk1: mmc1:0001 M62704 3.56 GiB
[ 1.962240] ### dt-test ### EXPECT / : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data/overlay-node/test-bus/test-unittest6/status
[ 1.962254] ### dt-test ### EXPECT \ : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data/overlay-node/test-bus/test-unittest7/status
[ 1.962769] mmcblk1: p1
[ 1.963945] mmcblk1boot0: mmc1:0001 M62704 2.00 MiB
[ 1.965111] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data/overlay-node/test-bus/test-unittest7/status
[ 1.968597] mmcblk1boot1: mmc1:0001 M62704 2.00 MiB
[ 1.980112] ### dt-test ### EXPECT / : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data/overlay-node/test-bus/test-unittest7/status
[ 1.980987] ### dt-test ### EXPECT \ : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data/overlay-node/test-bus/test-unittest8/status
[ 1.981367] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data/overlay-node/test-bus/test-unittest8/status
[ 1.984469] ### dt-test ### EXPECT / : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data/overlay-node/test-bus/test-unittest8/status
[ 1.984487] ### dt-test ### EXPECT \ : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data/overlay-node/test-bus/test-unittest8/property-foo
[ 1.984845] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data/overlay-node/test-bus/test-unittest8/property-foo
[ 1.985002] ### dt-test ### EXPECT / : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data/overlay-node/test-bus/test-unittest8/property-foo
[ 1.985011] ### dt-test ### EXPECT \ : OF: overlay: node_overlaps_later_cs: #6 overlaps with #7 @/testcase-data/overlay-node/test-bus/test-unittest8
[ 1.985016] ### dt-test ### EXPECT \ : OF: overlay: overlay #6 is not topmost
[ 1.985022] OF: overlay: node_overlaps_later_cs: #6 overlaps with #7 @/testcase-data/overlay-node/test-bus/test-unittest8
[ 1.985050] OF: overlay: overlay #6 is not topmost
[ 1.985055] ### dt-test ### EXPECT / : OF: overlay: overlay #6 is not topmost
[ 1.985059] ### dt-test ### EXPECT / : OF: overlay: node_overlaps_later_cs: #6 overlaps with #7 @/testcase-data/overlay-node/test-bus/test-unittest8
[ 1.988713] mmcblk1rpmb: mmc1:0001 M62704 512 KiB, chardev (242:0)
[ 2.000262] ### dt-test ### EXPECT \ : i2c i2c-1: Added multiplexed i2c bus 2
[ 2.003184] i2c i2c-3: Added multiplexed i2c bus 4
[ 2.010340] ### dt-test ### EXPECT / : i2c i2c-1: Added multiplexed i2c bus 2
[ 2.010349] ### dt-test ### EXPECT \ : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data/overlay-node/test-bus/i2c-test-bus/test-unittest12/status
[ 2.010664] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data/overlay-node/test-bus/i2c-test-bus/test-unittest12/status
[ 2.012051] ### dt-test ### EXPECT / : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data/overlay-node/test-bus/i2c-test-bus/test-unittest12/status
[ 2.012063] ### dt-test ### EXPECT \ : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data/overlay-node/test-bus/i2c-test-bus/test-unittest13/status
[ 2.012295] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data/overlay-node/test-bus/i2c-test-bus/test-unittest13/status
[ 2.012764] ### dt-test ### EXPECT / : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data/overlay-node/test-bus/i2c-test-bus/test-unittest13/status
[ 2.012773] ### dt-test ### EXPECT \ : i2c i2c-1: Added multiplexed i2c bus 3
[ 2.017006] i2c i2c-3: Added multiplexed i2c bus 5
[ 2.017720] ### dt-test ### EXPECT / : i2c i2c-1: Added multiplexed i2c bus 3
[ 2.032240] ### dt-test ### EXPECT \ : gpio-<<int>> (line-B-input): hogged as input
[ 2.032256] ### dt-test ### EXPECT \ : gpio-<<int>> (line-A-input): hogged as input
[ 2.032888] gpio-509 (line-B-input): hogged as input
[ 2.035503] gpio-503 (line-A-input): hogged as input
[ 2.038900] ### dt-test ### EXPECT / : gpio-<<int>> (line-A-input): hogged as input
[ 2.038912] ### dt-test ### EXPECT / : gpio-<<int>> (line-B-input): hogged as input
[ 2.038916] ### dt-test ### EXPECT \ : gpio-<<int>> (line-D-input): hogged as input
[ 2.041527] gpio-501 (line-D-input): hogged as input
[ 2.048538] ### dt-test ### EXPECT / : gpio-<<int>> (line-D-input): hogged as input
[ 2.051992] ### dt-test ### EXPECT \ : gpio-<<int>> (line-C-input): hogged as input
[ 2.052885] gpio-495 (line-C-input): hogged as input
[ 2.052915] ### dt-test ### EXPECT / : gpio-<<int>> (line-C-input): hogged as input
[ 2.060642] ### dt-test ### EXPECT \ : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data-2/substation@100/status
[ 2.060656] ### dt-test ### EXPECT \ : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data-2/fairway-1/status
[ 2.060661] ### dt-test ### EXPECT \ : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data-2/fairway-1/ride@100/track@30/incline-up
[ 2.060666] ### dt-test ### EXPECT \ : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data-2/fairway-1/ride@100/track@40/incline-up
[ 2.060671] ### dt-test ### EXPECT \ : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data-2/lights@40000/status
[ 2.060676] ### dt-test ### EXPECT \ : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data-2/lights@40000/color
[ 2.060680] ### dt-test ### EXPECT \ : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data-2/lights@40000/rate
[ 2.060685] ### dt-test ### EXPECT \ : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /__symbols__/hvac_2
[ 2.060690] ### dt-test ### EXPECT \ : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /__symbols__/ride_200
[ 2.060694] ### dt-test ### EXPECT \ : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /__symbols__/ride_200_left
[ 2.060698] ### dt-test ### EXPECT \ : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /__symbols__/ride_200_right
[ 2.061270] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data-2/substation@100/status
[ 2.061340] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data-2/fairway-1/status
[ 2.061362] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data-2/fairway-1/ride@100/track@30/incline-up
[ 2.061388] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data-2/fairway-1/ride@100/track@40/incline-up
[ 2.061487] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data-2/lights@40000/status
[ 2.061504] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data-2/lights@40000/color
[ 2.061521] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data-2/lights@40000/rate
[ 2.061572] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /__symbols__/hvac_2
[ 2.061607] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /__symbols__/ride_200
[ 2.061640] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /__symbols__/ride_200_left
[ 2.061673] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /__symbols__/ride_200_right
[ 2.075002] ### dt-test ### EXPECT / : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /__symbols__/ride_200_right
[ 2.075012] ### dt-test ### EXPECT / : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /__symbols__/ride_200_left
[ 2.075017] ### dt-test ### EXPECT / : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /__symbols__/ride_200
[ 2.075022] ### dt-test ### EXPECT / : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /__symbols__/hvac_2
[ 2.075026] ### dt-test ### EXPECT / : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data-2/lights@40000/rate
[ 2.075031] ### dt-test ### EXPECT / : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data-2/lights@40000/color
[ 2.075036] ### dt-test ### EXPECT / : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data-2/lights@40000/status
[ 2.075040] ### dt-test ### EXPECT / : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data-2/fairway-1/ride@100/track@40/incline-up
[ 2.075045] ### dt-test ### EXPECT / : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data-2/fairway-1/ride@100/track@30/incline-up
[ 2.075050] ### dt-test ### EXPECT / : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data-2/fairway-1/status
[ 2.075056] ### dt-test ### EXPECT / : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data-2/substation@100/status
[ 2.075061] ### dt-test ### EXPECT \ : OF: overlay: ERROR: multiple fragments add and/or delete node /testcase-data-2/substation@100/motor-1/controller
[ 2.075066] ### dt-test ### EXPECT \ : OF: overlay: ERROR: multiple fragments add, update, and/or delete property /testcase-data-2/substation@100/motor-1/controller/name
[ 2.075457] OF: overlay: ERROR: multiple fragments add and/or delete node /testcase-data-2/substation@100/motor-1/controller
[ 2.075640] OF: overlay: ERROR: multiple fragments add, update, and/or delete property /testcase-data-2/substation@100/motor-1/controller/name
[ 2.075708] ### dt-test ### EXPECT / : OF: overlay: ERROR: multiple fragments add, update, and/or delete property /testcase-data-2/substation@100/motor-1/controller/name
[ 2.075714] ### dt-test ### EXPECT / : OF: overlay: ERROR: multiple fragments add and/or delete node /testcase-data-2/substation@100/motor-1/controller
[ 2.075719] ### dt-test ### EXPECT \ : OF: overlay: ERROR: multiple fragments add and/or delete node /testcase-data-2/substation@100/motor-1/electric
[ 2.075723] ### dt-test ### EXPECT \ : OF: overlay: ERROR: multiple fragments add, update, and/or delete property /testcase-data-2/substation@100/motor-1/electric/rpm_avail
[ 2.075728] ### dt-test ### EXPECT \ : OF: overlay: ERROR: multiple fragments add, update, and/or delete property /testcase-data-2/substation@100/motor-1/electric/name
[ 2.075968] OF: overlay: ERROR: multiple fragments add and/or delete node /testcase-data-2/substation@100/motor-1/electric
[ 2.076053] OF: overlay: ERROR: multiple fragments add, update, and/or delete property /testcase-data-2/substation@100/motor-1/electric/rpm_avail
[ 2.076139] OF: overlay: ERROR: multiple fragments add, update, and/or delete property /testcase-data-2/substation@100/motor-1/electric/name
[ 2.076203] ### dt-test ### EXPECT / : OF: overlay: ERROR: multiple fragments add, update, and/or delete property /testcase-data-2/substation@100/motor-1/electric/name
[ 2.076208] ### dt-test ### EXPECT / : OF: overlay: ERROR: multiple fragments add, update, and/or delete property /testcase-data-2/substation@100/motor-1/electric/rpm_avail
[ 2.076213] ### dt-test ### EXPECT / : OF: overlay: ERROR: multiple fragments add and/or delete node /testcase-data-2/substation@100/motor-1/electric
[ 2.076530] ### dt-test ### end of unittest - 248 passed, 0 failed
[ 2.076874] ALSA device list:
[ 2.076884] No soundcards found.
[ 2.200726] input: generic ft5x06 (51) as /devices/platform/ocp/48000000.interconnect/48000000.interconnect:segment@100000/4819c000.target-module/4819c000.i2c/i2c-2/2-0038/input/input1
[ 2.228569] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
[ 2.228684] VFS: Mounted root (ext4 filesystem) readonly on device 179:1.
[ 2.238164] devtmpfs: mounted
[ 2.253866] Freeing unused kernel image (initmem) memory: 1024K
[ 2.255817] Checked W+X mappings: passed, no W+X pages found
[ 2.255846] Run /sbin/init as init process
[ 2.255851] with arguments:
[ 2.255859] /sbin/init
[ 2.255863] 1
[ 2.255867] with environment:
[ 2.255871] HOME=/
[ 2.255875] TERM=linux
[ 2.287443] Not activating Mandatory Access Control as /sbin/tomoyo-init does not exist.
[ 8.375031] EXT4-fs (mmcblk0p1): re-mounted. Opts: errors=remount-ro. Quota mode: none.
[ 18.801379] pinctrl-single 44e10800.pinmux: pin PIN101 already requested by 2-0038; cannot claim for 48038000.mcasp
[ 18.801404] pinctrl-single 44e10800.pinmux: pin-101 (48038000.mcasp) status -22
[ 18.801418] pinctrl-single 44e10800.pinmux: could not request pin 101 (PIN101) from group mcasp0_pins on device pinctrl-single
[ 18.801430] davinci-mcasp 48038000.mcasp: Error applying setting, reverse things back
[ 28.545996] remoteproc remoteproc1: 4a334000.pru is available
[ 28.582404] remoteproc remoteproc2: 4a338000.pru is available
[ 29.317349] fbcon: Taking over console
[ 30.019402] cpsw-switch 4a100000.switch: starting ndev. mode: dual_mac
[ 30.168067] SMSC LAN8710/LAN8720 4a101000.mdio:00: attached PHY driver (mii_bus:phy_addr=4a101000.mdio:00, irq=POLL)
[ 32.226924] cpsw-switch 4a100000.switch eth0: Link is Up - 100Mbps/Full - flow control off
[ 32.226998] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 0.000354] TI gptimer clockevent: 24000000 Hz at /ocp/interconnect@48000000/segment@0/target-module@40000
[ 0.001711] Console: colour dummy device 80x30
[ 0.001746] WARNING: Your 'console=ttyO0' has been replaced by 'ttyS0'
[ 0.001752] This ensures that you still see kernel messages. Please
[ 0.001756] update your kernel commandline.
[ 0.001783] Calibrating delay loop... 995.32 BogoMIPS (lpj=1990656)
[ 0.020424] pid_max: default: 32768 minimum: 301
[ 0.020894] LSM: Security Framework initializing
[ 0.020981] Yama: becoming mindful.
[ 0.021262] AppArmor: AppArmor initialized
[ 0.021273] TOMOYO Linux initialized
[ 0.021501] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.021518] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.023163] CPU: Testing write buffer coherency: ok
[ 0.023230] CPU0: Spectre v2: using BPIALL workaround
[ 0.025067] Setting up static identity map for 0x80100000 - 0x80100054
[ 0.025246] rcu: Hierarchical SRCU implementation.
[ 0.027015] EFI services will not be available.
[ 0.027802] devtmpfs: initialized
[ 0.051894] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[ 0.052366] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.052454] futex hash table entries: 256 (order: 0, 6144 bytes, linear)
[ 0.057597] pinctrl core: initialized pinctrl subsystem
[ 0.059540] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.068245] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.069051] audit: initializing netlink subsys (disabled)
[ 0.070290] thermal_sys: Registered thermal governor 'fair_share'
[ 0.070300] thermal_sys: Registered thermal governor 'bang_bang'
[ 0.070305] thermal_sys: Registered thermal governor 'step_wise'
[ 0.070859] cpuidle: using governor menu
[ 0.076469] audit: type=2000 audit(0.068:1): state=initialized audit_enabled=0 res=1
[ 0.089236] hw-breakpoint: debug architecture 0x4 unsupported.
[ 0.113486] raid6: skip pq benchmark and using algorithm neonx8
[ 0.113503] raid6: using neon recovery algorithm
[ 0.115072] iommu: Default domain type: Translated
[ 0.115085] iommu: DMA domain TLB invalidation policy: strict mode
[ 0.117395] SCSI subsystem initialized
[ 0.117502] libata version 3.00 loaded.
[ 0.117794] usbcore: registered new interface driver usbfs
[ 0.117847] usbcore: registered new interface driver hub
[ 0.117927] usbcore: registered new device driver usb
[ 0.118281] mc: Linux media interface: v0.10
[ 0.118372] pps_core: LinuxPPS API ver. 1 registered
[ 0.118378] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.118399] PTP clock support registered
[ 0.119320] Advanced Linux Sound Architecture Driver Initialized.
[ 0.120389] NetLabel: Initializing
[ 0.120795] NetLabel: domain hash size = 128
[ 0.120805] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[ 0.120917] NetLabel: unlabeled traffic allowed by default
[ 0.121854] clocksource: Switched to clocksource dmtimer
[ 0.241650] VFS: Disk quotas dquot_6.6.0
[ 0.241777] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.242941] AppArmor: AppArmor Filesystem Enabled
[ 0.272498] NET: Registered PF_INET protocol family
[ 0.272743] IP idents hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.274131] tcp_listen_portaddr_hash hash table entries: 256 (order: 0, 5120 bytes, linear)
[ 0.274342] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.274372] TCP established hash table entries: 4096 (order: 2, 16384 bytes, linear)
[ 0.274457] TCP bind hash table entries: 4096 (order: 4, 65536 bytes, linear)
[ 0.274540] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.274817] MPTCP token hash table entries: 512 (order: 1, 12288 bytes, linear)
[ 0.274938] UDP hash table entries: 256 (order: 1, 12288 bytes, linear)
[ 0.274979] UDP-Lite hash table entries: 256 (order: 1, 12288 bytes, linear)
[ 0.275230] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.282499] RPC: Registered named UNIX socket transport module.
[ 0.282511] RPC: Registered udp transport module.
[ 0.282515] RPC: Registered tcp transport module.
[ 0.282519] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.282530] NET: Registered PF_XDP protocol family
[ 1.261733] Initialise system trusted keyrings
[ 1.262186] workingset: timestamp_bits=14 max_order=17 bucket_order=3
[ 1.272202] zbud: loaded
[ 1.276056] NFS: Registering the id_resolver key type
[ 1.276137] Key type id_resolver registered
[ 1.276143] Key type id_legacy registered
[ 1.276308] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 1.276317] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 1.276659] fuse: init (API version 7.34)
[ 1.369351] xor: automatically using best checksumming function neon
[ 1.369371] Key type asymmetric registered
[ 1.369378] Asymmetric key parser 'x509' registered
[ 1.369532] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[ 1.369824] io scheduler mq-deadline registered
[ 1.374329] Serial: 8250/16550 driver, 6 ports, IRQ sharing disabled
[ 1.380530] SPI driver ili9486 has no spi_device_id for waveshare,rpi-lcd-35
[ 1.380544] SPI driver ili9486 has no spi_device_id for ozzmaker,piscreen
[ 1.381312] SPI driver spidev has no spi_device_id for linux,spidev
[ 1.383665] CAN device driver interface
[ 1.384696] usbcore: registered new interface driver uas
[ 1.384761] usbcore: registered new interface driver usb-storage
[ 1.384798] usbcore: registered new interface driver ums-alauda
[ 1.384832] usbcore: registered new interface driver ums-cypress
[ 1.384865] usbcore: registered new interface driver ums-datafab
[ 1.384897] usbcore: registered new interface driver ums_eneub6250
[ 1.384929] usbcore: registered new interface driver ums-freecom
[ 1.384962] usbcore: registered new interface driver ums-isd200
[ 1.385033] usbcore: registered new interface driver ums-jumpshot
[ 1.385069] usbcore: registered new interface driver ums-karma
[ 1.385103] usbcore: registered new interface driver ums-onetouch
[ 1.385151] usbcore: registered new interface driver ums-realtek
[ 1.385184] usbcore: registered new interface driver ums-sddr09
[ 1.385219] usbcore: registered new interface driver ums-sddr55
[ 1.385252] usbcore: registered new interface driver ums-usbat
[ 1.387550] i2c_dev: i2c /dev entries driver
[ 1.387617] Driver for 1-wire Dallas network protocol.
[ 1.388683] softdog: initialized. soft_noboot=0 soft_margin=60 sec soft_panic=0 (nowayout=0)
[ 1.388695] softdog: soft_reboot_cmd=<not set> soft_active_on_boot=0
[ 1.389659] cpuidle: enable-method property 'ti,am3352' found operations
[ 1.390527] sdhci: Secure Digital Host Controller Interface driver
[ 1.390535] sdhci: Copyright(c) Pierre Ossman
[ 1.390688] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.391582] hid: raw HID events driver (C) Jiri Kosina
[ 1.391918] usbcore: registered new interface driver usbhid
[ 1.391924] usbhid: USB HID core driver
[ 1.393650] drop_monitor: Initializing network drop monitor service
[ 1.395096] NET: Registered PF_INET6 protocol family
[ 1.400255] Segment Routing with IPv6
[ 1.400353] In-situ OAM (IOAM) with IPv6
[ 1.400506] mip6: Mobile IPv6
[ 1.400517] NET: Registered PF_PACKET protocol family
[ 1.400542] can: controller area network core
[ 1.400642] NET: Registered PF_CAN protocol family
[ 1.401005] Key type dns_resolver registered
[ 1.401014] mpls_gso: MPLS GSO support
[ 1.401219] ThumbEE CPU extension supported.
[ 1.401236] Registering SWP/SWPB emulation handler
[ 1.401244] omap_voltage_late_init: Voltage driver support not added
[ 1.401513] PM: Cannot get wkup_m3_ipc handle
[ 1.402507] registered taskstats version 1
[ 1.402528] Loading compiled-in X.509 certificates
[ 1.402939] zswap: loaded using pool lzo/zbud
[ 1.403668] Key type ._fscrypt registered
[ 1.403679] Key type .fscrypt registered
[ 1.403683] Key type fscrypt-provisioning registered
[ 1.411752] Btrfs loaded, crc32c=crc32c-generic, zoned=yes, fsverity=yes
[ 1.411930] AppArmor: AppArmor sha1 policy hashing enabled
[ 1.435953] remoteproc remoteproc0: wkup_m3 is available
[ 1.451510] pinctrl-single 44e10800.pinmux: 142 pins, size 568
[ 1.455537] ti-sysc: probe of 44e31000.target-module failed with error -16
[ 1.458897] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[ 1.462946] omap_rtc 44e3e000.rtc: registered as rtc0
[ 1.462994] omap_rtc 44e3e000.rtc: setting system clock to 2000-01-01T00:00:00 UTC (946684800)
[ 1.468738] 48022000.serial: ttyS1 at MMIO 0x48022000 (irq = 25, base_baud = 3000000) is a 8250
[ 1.472221] 48024000.serial: ttyS2 at MMIO 0x48024000 (irq = 26, base_baud = 3000000) is a 8250
[ 1.475789] omap_i2c 4802a000.i2c: bus 1 rev0.11 at 100 kHz
[ 1.480433] ti-sysc: probe of 48040000.target-module failed with error -16
[ 1.492179] OMAP GPIO hardware version 0.1
[ 1.497687] omap-mailbox 480c8000.mailbox: omap mailbox rev 0x400
[ 1.503165] at24 2-0054: supply vcc not found, using dummy regulator
[ 1.526488] at24 2-0054: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 1.526921] at24 2-0055: supply vcc not found, using dummy regulator
[ 1.556603] at24 2-0056: supply vcc not found, using dummy regulator
[ 1.584463] at24 2-0057: supply vcc not found, using dummy regulator
[ 1.614332] omap_i2c 4819c000.i2c: bus 2 rev0.11 at 100 kHz
[ 1.617474] 481a6000.serial: ttyS3 at MMIO 0x481a6000 (irq = 39, base_baud = 3000000) is a 8250
[ 1.620732] 481a8000.serial: ttyS4 at MMIO 0x481a8000 (irq = 40, base_baud = 3000000) is a 8250
[ 1.632329] sdhci-omap 481d8000.mmc: supply vqmmc not found, using dummy regulator
[ 1.650288] omap_rng 48310000.rng: Random Number Generator ver. 20
[ 1.654374] random: crng init done
[ 1.693898] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6, bus freq 1000000
[ 1.695960] davinci_mdio 4a101000.mdio: phy[0]: device 4a101000.mdio:00, driver SMSC LAN8710/LAN8720
[ 1.696384] cpsw-switch 4a100000.switch: initialized cpsw ale version 1.4
[ 1.696397] cpsw-switch 4a100000.switch: ALE Table size 1024
[ 1.696491] cpsw-switch 4a100000.switch: cpts: overflow check period 1250 (jiffies)
[ 1.696504] cpsw-switch 4a100000.switch: CPTS: ref_clk_freq:250000000 calc_mult:2147483648 calc_shift:29 error:0 nsec/sec
[ 1.696605] cpsw-switch 4a100000.switch: Detected MACID = 3c:e4:b0:2b:7c:c6
[ 1.698847] cpsw-switch 4a100000.switch: initialized (regs 0x4a100000, pool size 256) hw_ver:0019010C 1.12 (0)
[ 1.715651] debugfs: Directory '49000000.dma' with parent 'dmaengine' already present!
[ 1.715681] edma 49000000.dma: TI EDMA DMA engine driver
[ 1.721621] am335x-phy-driver 47401300.usb-phy: supply vcc not found, using dummy regulator
[ 1.722163] am335x-phy-driver 47401300.usb-phy: dummy supplies not allowed for exclusive requests
[ 1.728562] am335x-phy-driver 47401b00.usb-phy: supply vcc not found, using dummy regulator
[ 1.728851] am335x-phy-driver 47401b00.usb-phy: dummy supplies not allowed for exclusive requests
[ 1.751364] omap-sham 53100000.sham: hw accel on OMAP rev 4.3
[ 1.751594] omap-sham 53100000.sham: will run requests pump with realtime priority
[ 1.755013] omap-aes 53500000.aes: OMAP AES hw accel rev: 3.2
[ 1.755377] omap-aes 53500000.aes: will run requests pump with realtime priority
[ 1.760828] hw perfevents: enabled with armv7_cortex_a8 PMU driver, 5 counters available
[ 1.766045] l3-aon-clkctrl:0000:0: failed to disable
[ 1.766567] pwm-backlight backlight: supply power not found, using dummy regulator
[ 1.771075] PM: Cannot get wkup_m3_ipc handle
[ 1.773655] 44e09000.serial: ttyS0 at MMIO 0x44e09000 (irq = 18, base_baud = 3000000) is a 8250
[ 1.774205] printk: console [ttyS0]: printing thread started
[ 1.774231] printk: console [ttyS0] enabled
[ 1.802017] tps65217-pmic: Failed to locate of_node [id: -1]
[ 1.811125] tps65217-bl: Failed to locate of_node [id: -1]
[ 1.814161] tps65217 0-0024: TPS65217 ID 0xe version 1.2
[ 1.815672] at24 0-0050: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 1.816016] i2c 0-0070: Fixing up cyclic dependency with 4830e000.lcdc
[ 1.816519] pinctrl-single 44e10800.pinmux: pin PIN40 already requested by panel; cannot claim for 0-0070
[ 1.816533] pinctrl-single 44e10800.pinmux: pin-40 (0-0070) status -22
[ 1.816544] pinctrl-single 44e10800.pinmux: could not request pin 40 (PIN40) from group nxp_hdmi_bonelt_pins on device pinctrl-single
[ 1.816555] tda998x 0-0070: Error applying setting, reverse things back
[ 1.816624] omap_i2c 44e0b000.i2c: bus 0 rev0.11 at 400 kHz
[ 1.838868] omap_gpio 44e07000.gpio: Could not set line 6 debounce to 200000 microseconds (-22)
[ 1.838892] sdhci-omap 48060000.mmc: Got CD GPIO
[ 1.839083] sdhci-omap 48060000.mmc: supply vqmmc not found, using dummy regulator
[ 1.842049] remoteproc remoteproc0: powering up wkup_m3
[ 1.842079] remoteproc remoteproc0: Booting fw image am335x-pm-firmware.elf, size 217148
[ 1.842298] remoteproc remoteproc0: remote processor wkup_m3 is now up
[ 1.842357] wkup_m3_ipc 44e11324.wkup_m3_ipc: CM3 Firmware Version = 0x192
[ 1.843418] edt_ft5x06 2-0038: supply vcc not found, using dummy regulator
[ 1.843653] edt_ft5x06 2-0038: supply iovcc not found, using dummy regulator
[ 1.847280] sdhci-omap 481d8000.mmc: supply vqmmc not found, using dummy regulator
[ 1.860316] musb-hdrc musb-hdrc.1: MUSB HDRC host driver
[ 1.860373] musb-hdrc musb-hdrc.1: new USB bus registered, assigned bus number 1
[ 1.860646] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
[ 1.860661] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.860669] usb usb1: Product: MUSB HDRC host driver
[ 1.860676] usb usb1: Manufacturer: Linux 5.15.73-bone-rt-r31 musb-hcd
[ 1.860682] usb usb1: SerialNumber: musb-hdrc.1
[ 1.861837] hub 1-0:1.0: USB hub found
[ 1.862091] hub 1-0:1.0: 1 port detected
[ 1.872377] PM: bootloader does not support rtc-only!
[ 1.872921] tps6521x_pwrbutton tps65217-pwrbutton: DMA mask not set
[ 1.880517] mmc0: SDHCI controller on 48060000.mmc [48060000.mmc] using External DMA
[ 1.880979] input: tps65217_pwr_but as /devices/platform/ocp/44c00000.interconnect/44c00000.interconnect:segment@200000/44e0b000.target-module/44e0b000.i2c/i2c-0/0-0024/tps65217-pwrbutton/input/input0
[ 1.882573] mmc1: SDHCI controller on 481d8000.mmc [481d8000.mmc] using External DMA
[ 1.885557] ### dt-test ### start of unittest - you will see error messages
[ 1.887468] ### dt-test ### EXPECT \ : Duplicate name in testcase-data, renamed to "duplicate-name#1"
[ 1.887796] Duplicate name in testcase-data, renamed to "duplicate-name#1"
[ 1.895808] ### dt-test ### EXPECT / : Duplicate name in testcase-data, renamed to "duplicate-name#1"
[ 1.897104] ### dt-test ### EXPECT \ : OF: /testcase-data/phandle-tests/consumer-a: could not get #phandle-cells-missing for /testcase-data/phandle-tests/provider1
[ 1.897118] OF: /testcase-data/phandle-tests/consumer-a: could not get #phandle-cells-missing for /testcase-data/phandle-tests/provider1
[ 1.897151] ### dt-test ### EXPECT / : OF: /testcase-data/phandle-tests/consumer-a: could not get #phandle-cells-missing for /testcase-data/phandle-tests/provider1
[ 1.897157] ### dt-test ### EXPECT \ : OF: /testcase-data/phandle-tests/consumer-a: could not get #phandle-cells-missing for /testcase-data/phandle-tests/provider1
[ 1.897162] OF: /testcase-data/phandle-tests/consumer-a: could not get #phandle-cells-missing for /testcase-data/phandle-tests/provider1
[ 1.897189] ### dt-test ### EXPECT / : OF: /testcase-data/phandle-tests/consumer-a: could not get #phandle-cells-missing for /testcase-data/phandle-tests/provider1
[ 1.897194] ### dt-test ### EXPECT \ : OF: /testcase-data/phandle-tests/consumer-a: could not find phandle
[ 1.897255] OF: /testcase-data/phandle-tests/consumer-a: could not find phandle 12345678
[ 1.897278] ### dt-test ### EXPECT / : OF: /testcase-data/phandle-tests/consumer-a: could not find phandle
[ 1.897283] ### dt-test ### EXPECT \ : OF: /testcase-data/phandle-tests/consumer-a: could not find phandle
[ 1.897313] OF: /testcase-data/phandle-tests/consumer-a: could not find phandle 12345678
[ 1.897330] ### dt-test ### EXPECT / : OF: /testcase-data/phandle-tests/consumer-a: could not find phandle
[ 1.897335] ### dt-test ### EXPECT \ : OF: /testcase-data/phandle-tests/consumer-a: #phandle-cells = 3 found -1
[ 1.897341] OF: /testcase-data/phandle-tests/consumer-a: #phandle-cells = 3 found 1
[ 1.897360] ### dt-test ### EXPECT / : OF: /testcase-data/phandle-tests/consumer-a: #phandle-cells = 3 found -1
[ 1.897365] ### dt-test ### EXPECT \ : OF: /testcase-data/phandle-tests/consumer-a: #phandle-cells = 3 found -1
[ 1.897370] OF: /testcase-data/phandle-tests/consumer-a: #phandle-cells = 3 found 1
[ 1.897388] ### dt-test ### EXPECT / : OF: /testcase-data/phandle-tests/consumer-a: #phandle-cells = 3 found -1
[ 1.897545] ### dt-test ### EXPECT \ : OF: /testcase-data/phandle-tests/consumer-b: could not get #phandle-missing-cells for /testcase-data/phandle-tests/provider1
[ 1.897558] OF: /testcase-data/phandle-tests/consumer-b: could not get #phandle-missing-cells for /testcase-data/phandle-tests/provider1
[ 1.897587] ### dt-test ### EXPECT / : OF: /testcase-data/phandle-tests/consumer-b: could not get #phandle-missing-cells for /testcase-data/phandle-tests/provider1
[ 1.897593] ### dt-test ### EXPECT \ : OF: /testcase-data/phandle-tests/consumer-b: could not find phandle
[ 1.897627] OF: /testcase-data/phandle-tests/consumer-b: could not find phandle 12345678
[ 1.897647] ### dt-test ### EXPECT / : OF: /testcase-data/phandle-tests/consumer-b: could not find phandle
[ 1.897651] ### dt-test ### EXPECT \ : OF: /testcase-data/phandle-tests/consumer-b: #phandle-cells = 2 found -1
[ 1.897663] OF: /testcase-data/phandle-tests/consumer-b: #phandle-cells = 2 found 1
[ 1.897682] ### dt-test ### EXPECT / : OF: /testcase-data/phandle-tests/consumer-b: #phandle-cells = 2 found -1
[ 1.900192] ### dt-test ### EXPECT \ : platform testcase-data:testcase-device2: IRQ index 0 not found
[ 1.900218] platform testcase-data:testcase-device2: IRQ index 0 not found
[ 1.900228] ### dt-test ### EXPECT / : platform testcase-data:testcase-device2: IRQ index 0 not found
[ 1.919905] mmc0: new high speed SDHC card at address 59b4
[ 1.922188] ### dt-test ### EXPECT \ : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data/overlay-node/test-bus/test-unittest0/status
[ 1.922564] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data/overlay-node/test-bus/test-unittest0/status
[ 1.926922] mmcblk0: mmc0:59b4 29.8 GiB
[ 1.930234] ### dt-test ### EXPECT / : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data/overlay-node/test-bus/test-unittest0/status
[ 1.930249] ### dt-test ### EXPECT \ : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data/overlay-node/test-bus/test-unittest1/status
[ 1.930834] mmcblk0: p1
[ 1.932408] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data/overlay-node/test-bus/test-unittest1/status
[ 1.932919] ### dt-test ### EXPECT / : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data/overlay-node/test-bus/test-unittest1/status
[ 1.932929] ### dt-test ### EXPECT \ : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data/overlay-node/test-bus/test-unittest2/status
[ 1.933335] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data/overlay-node/test-bus/test-unittest2/status
[ 1.939152] ### dt-test ### EXPECT / : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data/overlay-node/test-bus/test-unittest2/status
[ 1.939167] ### dt-test ### EXPECT \ : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data/overlay-node/test-bus/test-unittest3/status
[ 1.939560] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data/overlay-node/test-bus/test-unittest3/status
[ 1.940245] ### dt-test ### EXPECT / : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data/overlay-node/test-bus/test-unittest3/status
[ 1.947109] ### dt-test ### EXPECT \ : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data/overlay-node/test-bus/test-unittest5/status
[ 1.947864] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data/overlay-node/test-bus/test-unittest5/status
[ 1.950237] mmc1: new high speed MMC card at address 0001
[ 1.951198] ### dt-test ### EXPECT / : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data/overlay-node/test-bus/test-unittest5/status
[ 1.951320] ### dt-test ### EXPECT \ : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data/overlay-node/test-bus/test-unittest6/status
[ 1.951667] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data/overlay-node/test-bus/test-unittest6/status
[ 1.962027] mmcblk1: mmc1:0001 M62704 3.56 GiB
[ 1.964895] ### dt-test ### EXPECT / : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data/overlay-node/test-bus/test-unittest6/status
[ 1.964908] ### dt-test ### EXPECT \ : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data/overlay-node/test-bus/test-unittest7/status
[ 1.965424] mmcblk1: p1
[ 1.966662] mmcblk1boot0: mmc1:0001 M62704 2.00 MiB
[ 1.967830] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data/overlay-node/test-bus/test-unittest7/status
[ 1.969563] ### dt-test ### EXPECT / : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data/overlay-node/test-bus/test-unittest7/status
[ 1.970499] ### dt-test ### EXPECT \ : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data/overlay-node/test-bus/test-unittest8/status
[ 1.970853] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data/overlay-node/test-bus/test-unittest8/status
[ 1.974125] mmcblk1boot1: mmc1:0001 M62704 2.00 MiB
[ 1.975283] ### dt-test ### EXPECT / : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data/overlay-node/test-bus/test-unittest8/status
[ 1.975296] ### dt-test ### EXPECT \ : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data/overlay-node/test-bus/test-unittest8/property-foo
[ 1.975664] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data/overlay-node/test-bus/test-unittest8/property-foo
[ 1.975726] ### dt-test ### EXPECT / : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data/overlay-node/test-bus/test-unittest8/property-foo
[ 1.975733] ### dt-test ### EXPECT \ : OF: overlay: node_overlaps_later_cs: #6 overlaps with #7 @/testcase-data/overlay-node/test-bus/test-unittest8
[ 1.975738] ### dt-test ### EXPECT \ : OF: overlay: overlay #6 is not topmost
[ 1.975743] OF: overlay: node_overlaps_later_cs: #6 overlaps with #7 @/testcase-data/overlay-node/test-bus/test-unittest8
[ 1.975769] OF: overlay: overlay #6 is not topmost
[ 1.975773] ### dt-test ### EXPECT / : OF: overlay: overlay #6 is not topmost
[ 1.975777] ### dt-test ### EXPECT / : OF: overlay: node_overlaps_later_cs: #6 overlaps with #7 @/testcase-data/overlay-node/test-bus/test-unittest8
[ 1.979335] mmcblk1rpmb: mmc1:0001 M62704 512 KiB, chardev (242:0)
[ 1.997282] ### dt-test ### EXPECT \ : i2c i2c-1: Added multiplexed i2c bus 2
[ 2.002068] i2c i2c-3: Added multiplexed i2c bus 4
[ 2.002800] ### dt-test ### EXPECT / : i2c i2c-1: Added multiplexed i2c bus 2
[ 2.002810] ### dt-test ### EXPECT \ : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data/overlay-node/test-bus/i2c-test-bus/test-unittest12/status
[ 2.003122] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data/overlay-node/test-bus/i2c-test-bus/test-unittest12/status
[ 2.004478] ### dt-test ### EXPECT / : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data/overlay-node/test-bus/i2c-test-bus/test-unittest12/status
[ 2.004491] ### dt-test ### EXPECT \ : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data/overlay-node/test-bus/i2c-test-bus/test-unittest13/status
[ 2.004723] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data/overlay-node/test-bus/i2c-test-bus/test-unittest13/status
[ 2.005183] ### dt-test ### EXPECT / : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data/overlay-node/test-bus/i2c-test-bus/test-unittest13/status
[ 2.005193] ### dt-test ### EXPECT \ : i2c i2c-1: Added multiplexed i2c bus 3
[ 2.013339] i2c i2c-3: Added multiplexed i2c bus 5
[ 2.014258] ### dt-test ### EXPECT / : i2c i2c-1: Added multiplexed i2c bus 3
[ 2.028256] ### dt-test ### EXPECT \ : gpio-<<int>> (line-B-input): hogged as input
[ 2.028271] ### dt-test ### EXPECT \ : gpio-<<int>> (line-A-input): hogged as input
[ 2.028906] gpio-509 (line-B-input): hogged as input
[ 2.034657] gpio-503 (line-A-input): hogged as input
[ 2.035783] ### dt-test ### EXPECT / : gpio-<<int>> (line-A-input): hogged as input
[ 2.035792] ### dt-test ### EXPECT / : gpio-<<int>> (line-B-input): hogged as input
[ 2.035797] ### dt-test ### EXPECT \ : gpio-<<int>> (line-D-input): hogged as input
[ 2.038637] gpio-501 (line-D-input): hogged as input
[ 2.042954] ### dt-test ### EXPECT / : gpio-<<int>> (line-D-input): hogged as input
[ 2.051059] ### dt-test ### EXPECT \ : gpio-<<int>> (line-C-input): hogged as input
[ 2.051943] gpio-495 (line-C-input): hogged as input
[ 2.051969] ### dt-test ### EXPECT / : gpio-<<int>> (line-C-input): hogged as input
[ 2.055642] ### dt-test ### EXPECT \ : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data-2/substation@100/status
[ 2.055653] ### dt-test ### EXPECT \ : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data-2/fairway-1/status
[ 2.055658] ### dt-test ### EXPECT \ : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data-2/fairway-1/ride@100/track@30/incline-up
[ 2.055663] ### dt-test ### EXPECT \ : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data-2/fairway-1/ride@100/track@40/incline-up
[ 2.055668] ### dt-test ### EXPECT \ : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data-2/lights@40000/status
[ 2.055673] ### dt-test ### EXPECT \ : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data-2/lights@40000/color
[ 2.055678] ### dt-test ### EXPECT \ : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data-2/lights@40000/rate
[ 2.055682] ### dt-test ### EXPECT \ : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /__symbols__/hvac_2
[ 2.055687] ### dt-test ### EXPECT \ : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /__symbols__/ride_200
[ 2.055691] ### dt-test ### EXPECT \ : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /__symbols__/ride_200_left
[ 2.055696] ### dt-test ### EXPECT \ : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /__symbols__/ride_200_right
[ 2.056262] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data-2/substation@100/status
[ 2.056331] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data-2/fairway-1/status
[ 2.056353] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data-2/fairway-1/ride@100/track@30/incline-up
[ 2.056379] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data-2/fairway-1/ride@100/track@40/incline-up
[ 2.056478] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data-2/lights@40000/status
[ 2.056495] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data-2/lights@40000/color
[ 2.056512] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data-2/lights@40000/rate
[ 2.056561] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /__symbols__/hvac_2
[ 2.056596] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /__symbols__/ride_200
[ 2.056629] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /__symbols__/ride_200_left
[ 2.056663] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /__symbols__/ride_200_right
[ 2.067578] ### dt-test ### EXPECT / : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /__symbols__/ride_200_right
[ 2.067589] ### dt-test ### EXPECT / : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /__symbols__/ride_200_left
[ 2.067593] ### dt-test ### EXPECT / : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /__symbols__/ride_200
[ 2.067598] ### dt-test ### EXPECT / : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /__symbols__/hvac_2
[ 2.067602] ### dt-test ### EXPECT / : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data-2/lights@40000/rate
[ 2.067607] ### dt-test ### EXPECT / : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data-2/lights@40000/color
[ 2.067612] ### dt-test ### EXPECT / : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data-2/lights@40000/status
[ 2.067616] ### dt-test ### EXPECT / : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data-2/fairway-1/ride@100/track@40/incline-up
[ 2.067621] ### dt-test ### EXPECT / : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data-2/fairway-1/ride@100/track@30/incline-up
[ 2.067626] ### dt-test ### EXPECT / : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data-2/fairway-1/status
[ 2.067631] ### dt-test ### EXPECT / : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data-2/substation@100/status
[ 2.067637] ### dt-test ### EXPECT \ : OF: overlay: ERROR: multiple fragments add and/or delete node /testcase-data-2/substation@100/motor-1/controller
[ 2.067642] ### dt-test ### EXPECT \ : OF: overlay: ERROR: multiple fragments add, update, and/or delete property /testcase-data-2/substation@100/motor-1/controller/name
[ 2.068021] OF: overlay: ERROR: multiple fragments add and/or delete node /testcase-data-2/substation@100/motor-1/controller
[ 2.068205] OF: overlay: ERROR: multiple fragments add, update, and/or delete property /testcase-data-2/substation@100/motor-1/controller/name
[ 2.068273] ### dt-test ### EXPECT / : OF: overlay: ERROR: multiple fragments add, update, and/or delete property /testcase-data-2/substation@100/motor-1/controller/name
[ 2.068280] ### dt-test ### EXPECT / : OF: overlay: ERROR: multiple fragments add and/or delete node /testcase-data-2/substation@100/motor-1/controller
[ 2.068285] ### dt-test ### EXPECT \ : OF: overlay: ERROR: multiple fragments add and/or delete node /testcase-data-2/substation@100/motor-1/electric
[ 2.068289] ### dt-test ### EXPECT \ : OF: overlay: ERROR: multiple fragments add, update, and/or delete property /testcase-data-2/substation@100/motor-1/electric/rpm_avail
[ 2.068294] ### dt-test ### EXPECT \ : OF: overlay: ERROR: multiple fragments add, update, and/or delete property /testcase-data-2/substation@100/motor-1/electric/name
[ 2.068534] OF: overlay: ERROR: multiple fragments add and/or delete node /testcase-data-2/substation@100/motor-1/electric
[ 2.068618] OF: overlay: ERROR: multiple fragments add, update, and/or delete property /testcase-data-2/substation@100/motor-1/electric/rpm_avail
[ 2.068703] OF: overlay: ERROR: multiple fragments add, update, and/or delete property /testcase-data-2/substation@100/motor-1/electric/name
[ 2.068767] ### dt-test ### EXPECT / : OF: overlay: ERROR: multiple fragments add, update, and/or delete property /testcase-data-2/substation@100/motor-1/electric/name
[ 2.068772] ### dt-test ### EXPECT / : OF: overlay: ERROR: multiple fragments add, update, and/or delete property /testcase-data-2/substation@100/motor-1/electric/rpm_avail
[ 2.068777] ### dt-test ### EXPECT / : OF: overlay: ERROR: multiple fragments add and/or delete node /testcase-data-2/substation@100/motor-1/electric
[ 2.069096] ### dt-test ### end of unittest - 248 passed, 0 failed
[ 2.069452] ALSA device list:
[ 2.069463] No soundcards found.
[ 2.199585] input: generic ft5x06 (51) as /devices/platform/ocp/48000000.interconnect/48000000.interconnect:segment@100000/4819c000.target-module/4819c000.i2c/i2c-2/2-0038/input/input1
[ 2.211943] EXT4-fs (mmcblk0p1): INFO: recovery required on readonly filesystem
[ 2.211964] EXT4-fs (mmcblk0p1): write access will be enabled during recovery
[ 5.820542] EXT4-fs (mmcblk0p1): recovery complete
[ 5.886307] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
[ 5.886456] VFS: Mounted root (ext4 filesystem) readonly on device 179:1.
[ 5.897277] devtmpfs: mounted
[ 5.913598] Freeing unused kernel image (initmem) memory: 1024K
[ 5.915566] Checked W+X mappings: passed, no W+X pages found
[ 5.915594] Run /sbin/init as init process
[ 5.915601] with arguments:
[ 5.915608] /sbin/init
[ 5.915612] 1
[ 5.915617] with environment:
[ 5.915620] HOME=/
[ 5.915624] TERM=linux
[ 5.926059] Not activating Mandatory Access Control as /sbin/tomoyo-init does not exist.
[ 10.058176] EXT4-fs (mmcblk0p1): re-mounted. Opts: errors=remount-ro. Quota mode: none.
[ 17.615691] pinctrl-single 44e10800.pinmux: pin PIN101 already requested by 2-0038; cannot claim for 48038000.mcasp
[ 17.615716] pinctrl-single 44e10800.pinmux: pin-101 (48038000.mcasp) status -22
[ 17.615729] pinctrl-single 44e10800.pinmux: could not request pin 101 (PIN101) from group mcasp0_pins on device pinctrl-single
[ 17.615742] davinci-mcasp 48038000.mcasp: Error applying setting, reverse things back
[ 20.423103] remoteproc remoteproc1: 4a334000.pru is available
[ 20.438784] remoteproc remoteproc2: 4a338000.pru is available
[ 59.216666] cpsw-switch 4a100000.switch: starting ndev. mode: dual_mac
[ 59.251438] fbcon: Taking over console
[ 59.328013] SMSC LAN8710/LAN8720 4a101000.mdio:00: attached PHY driver (mii_bus:phy_addr=4a101000.mdio:00, irq=POLL)
[ 0.000000] Linux version 5.15.73-bone-rt-r31 (devika@devika-Latitude-3410) (arm-linux-gnueabi-gcc (GCC) 11.3.0, GNU ld (GNU Binutils) 2.38) #13 PREEMPT_RT Tue Dec 20 10:48:53 IST 2022
[ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=50c5387d
[ 0.000000] OF: fdt: Machine model: TI AM335x BeagleBone Black
[ 0.000000] Memory policy: Data cache writeback
[ 0.000000] efi: UEFI not found.
[ 0.000000] cma: Reserved 48 MiB at 0x9c800000
[ 0.000000] Zone ranges:
[ 0.000000] Normal [mem 0x0000000080000000-0x000000009fefffff]
[ 0.000000] HighMem empty
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x000000009fefffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x000000009fefffff]
[ 0.000000] CPU: All CPU(s) started in SVC mode.
[ 0.000000] AM335X ES2.1 (sgx neon)
[ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 129666
[ 0.000000] Kernel command line: console=ttyO0,115200n8 root=/dev/mmcblk0p1 ro rootfstype=ext4 rootwait 1
[ 0.000000] Unknown kernel command line parameters "1", will be passed to user space.
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:on, heap free:off
[ 0.000000] Memory: 450212K/523264K available (10240K kernel code, 1663K rwdata, 3812K rodata, 1024K init, 362K bss, 23900K reserved, 49152K cma-reserved, 0K highmem)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] ftrace: allocating 46686 entries in 137 pages
[ 0.000000] ftrace: allocated 137 pages with 3 groups
[ 0.000000] trace event string verifier disabled
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU priority boosting: priority 1 delay 500 ms.
[ 0.000000] rcu: RCU_SOFTIRQ processing moved to rcuc kthreads.
[ 0.000000] No expedited grace period (rcu_normal_after_boot).
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Rude variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] IRQ: Found an INTC at 0x(ptrval) (revision 5.0) with 128 interrupts
[ 0.000000] TI gptimer clocksource: always-on /ocp/interconnect@44c00000/segment@200000/target-module@31000
[ 0.000001] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
[ 0.000020] clocksource: dmtimer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.000351] TI gptimer clockevent: 24000000 Hz at /ocp/interconnect@48000000/segment@0/target-module@40000
[ 0.001713] Console: colour dummy device 80x30
[ 0.001747] WARNING: Your 'console=ttyO0' has been replaced by 'ttyS0'
[ 0.001753] This ensures that you still see kernel messages. Please
[ 0.001785] Calibrating delay loop... 995.32 BogoMIPS (lpj=1990656)
[ 0.020421] pid_max: default: 32768 minimum: 301
[ 0.020893] LSM: Security Framework initializing
[ 0.020982] Yama: becoming mindful.
[ 0.021263] AppArmor: AppArmor initialized
[ 0.021274] TOMOYO Linux initialized
[ 0.021498] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.021515] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.023174] CPU: Testing write buffer coherency: ok
[ 0.023239] CPU0: Spectre v2: using BPIALL workaround
[ 0.027019] EFI services will not be available.
[ 0.027795] devtmpfs: initialized
[ 0.051891] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[ 0.052365] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.052453] futex hash table entries: 256 (order: 0, 6144 bytes, linear)
[ 0.057679] pinctrl core: initialized pinctrl subsystem
[ 0.059615] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.068336] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.069141] audit: initializing netlink subsys (disabled)
[ 0.070381] thermal_sys: Registered thermal governor 'fair_share'
[ 0.070393] thermal_sys: Registered thermal governor 'bang_bang'
[ 0.070398] thermal_sys: Registered thermal governor 'step_wise'
[ 0.070952] cpuidle: using governor menu
[ 0.076460] audit: type=2000 audit(0.068:1): state=initialized audit_enabled=0 res=1
[ 0.089282] hw-breakpoint: debug architecture 0x4 unsupported.
[ 0.113546] raid6: skip pq benchmark and using algorithm neonx8
[ 0.113563] raid6: using neon recovery algorithm
[ 0.115146] iommu: Default domain type: Translated
[ 0.115157] iommu: DMA domain TLB invalidation policy: strict mode
[ 0.117487] SCSI subsystem initialized
[ 0.117599] libata version 3.00 loaded.
[ 0.117885] usbcore: registered new interface driver usbfs
[ 0.117940] usbcore: registered new interface driver hub
[ 0.118018] usbcore: registered new device driver usb
[ 0.118370] mc: Linux media interface: v0.10
[ 0.118464] pps_core: LinuxPPS API ver. 1 registered
[ 0.118470] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.118492] PTP clock support registered
[ 0.119418] Advanced Linux Sound Architecture Driver Initialized.
[ 0.120920] NetLabel: Initializing
[ 0.120929] NetLabel: domain hash size = 128
[ 0.120936] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[ 0.121030] NetLabel: unlabeled traffic allowed by default
[ 0.121969] clocksource: Switched to clocksource dmtimer
[ 0.241333] VFS: Disk quotas dquot_6.6.0
[ 0.241462] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.242631] AppArmor: AppArmor Filesystem Enabled
[ 0.268757] NET: Registered PF_INET protocol family
[ 0.269003] IP idents hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.270395] tcp_listen_portaddr_hash hash table entries: 256 (order: 0, 5120 bytes, linear)
[ 0.270607] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.270637] TCP established hash table entries: 4096 (order: 2, 16384 bytes, linear)
[ 0.270722] TCP bind hash table entries: 4096 (order: 4, 65536 bytes, linear)
[ 0.270806] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.271086] MPTCP token hash table entries: 512 (order: 1, 12288 bytes, linear)
[ 0.271208] UDP hash table entries: 256 (order: 1, 12288 bytes, linear)
[ 0.271250] UDP-Lite hash table entries: 256 (order: 1, 12288 bytes, linear)
[ 0.271505] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.278647] RPC: Registered named UNIX socket transport module.
[ 0.278659] RPC: Registered udp transport module.
[ 0.278663] RPC: Registered tcp transport module.
[ 0.278667] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.278678] NET: Registered PF_XDP protocol family
[ 1.261219] Initialise system trusted keyrings
[ 1.261617] workingset: timestamp_bits=14 max_order=17 bucket_order=3
[ 1.271686] zbud: loaded
[ 1.275538] NFS: Registering the id_resolver key type
[ 1.275611] Key type id_resolver registered
[ 1.275617] Key type id_legacy registered
[ 1.275778] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 1.275786] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 1.276136] fuse: init (API version 7.34)
[ 1.368259] xor: automatically using best checksumming function neon
[ 1.368278] Key type asymmetric registered
[ 1.368284] Asymmetric key parser 'x509' registered
[ 1.368433] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[ 1.368715] io scheduler mq-deadline registered
[ 1.373194] Serial: 8250/16550 driver, 6 ports, IRQ sharing disabled
[ 1.379597] SPI driver ili9486 has no spi_device_id for waveshare,rpi-lcd-35
[ 1.379612] SPI driver ili9486 has no spi_device_id for ozzmaker,piscreen
[ 1.380383] SPI driver spidev has no spi_device_id for linux,spidev
[ 1.382812] CAN device driver interface
[ 1.383824] usbcore: registered new interface driver uas
[ 1.383896] usbcore: registered new interface driver usb-storage
[ 1.383931] usbcore: registered new interface driver ums-alauda
[ 1.383964] usbcore: registered new interface driver ums-cypress
[ 1.383997] usbcore: registered new interface driver ums-datafab
[ 1.384029] usbcore: registered new interface driver ums_eneub6250
[ 1.384061] usbcore: registered new interface driver ums-freecom
[ 1.384094] usbcore: registered new interface driver ums-isd200
[ 1.384161] usbcore: registered new interface driver ums-jumpshot
[ 1.384200] usbcore: registered new interface driver ums-karma
[ 1.384235] usbcore: registered new interface driver ums-onetouch
[ 1.384284] usbcore: registered new interface driver ums-realtek
[ 1.384317] usbcore: registered new interface driver ums-sddr09
[ 1.384351] usbcore: registered new interface driver ums-sddr55
[ 1.384384] usbcore: registered new interface driver ums-usbat
[ 1.386653] i2c_dev: i2c /dev entries driver
[ 1.386722] Driver for 1-wire Dallas network protocol.
[ 1.387774] softdog: initialized. soft_noboot=0 soft_margin=60 sec soft_panic=0 (nowayout=0)
[ 1.387785] softdog: soft_reboot_cmd=<not set> soft_active_on_boot=0
[ 1.388748] cpuidle: enable-method property 'ti,am3352' found operations
[ 1.389414] sdhci: Secure Digital Host Controller Interface driver
[ 1.389420] sdhci: Copyright(c) Pierre Ossman
[ 1.389571] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.390673] hid: raw HID events driver (C) Jiri Kosina
[ 1.391014] usbcore: registered new interface driver usbhid
[ 1.391021] usbhid: USB HID core driver
[ 1.392763] drop_monitor: Initializing network drop monitor service
[ 1.394240] NET: Registered PF_INET6 protocol family
[ 1.399379] Segment Routing with IPv6
[ 1.399474] In-situ OAM (IOAM) with IPv6
[ 1.399627] mip6: Mobile IPv6
[ 1.399638] NET: Registered PF_PACKET protocol family
[ 1.399660] can: controller area network core
[ 1.399763] NET: Registered PF_CAN protocol family
[ 1.400146] Key type dns_resolver registered
[ 1.400156] mpls_gso: MPLS GSO support
[ 1.400361] ThumbEE CPU extension supported.
[ 1.400378] Registering SWP/SWPB emulation handler
[ 1.400385] omap_voltage_late_init: Voltage driver support not added
[ 1.400657] PM: Cannot get wkup_m3_ipc handle
[ 1.401372] registered taskstats version 1
[ 1.401392] Loading compiled-in X.509 certificates
[ 1.401797] zswap: loaded using pool lzo/zbud
[ 1.402777] Key type ._fscrypt registered
[ 1.402791] Key type .fscrypt registered
[ 1.402795] Key type fscrypt-provisioning registered
[ 1.410903] Btrfs loaded, crc32c=crc32c-generic, zoned=yes, fsverity=yes
[ 1.411069] AppArmor: AppArmor sha1 policy hashing enabled
[ 1.435050] remoteproc remoteproc0: wkup_m3 is available
[ 1.450517] pinctrl-single 44e10800.pinmux: 142 pins, size 568
[ 1.454584] ti-sysc: probe of 44e31000.target-module failed with error -16
[ 1.457755] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[ 1.460236] omap_rtc 44e3e000.rtc: already running
[ 1.461874] omap_rtc 44e3e000.rtc: registered as rtc0
[ 1.461919] omap_rtc 44e3e000.rtc: setting system clock to 2000-01-01T00:05:15 UTC (946685115)
[ 1.467767] 48022000.serial: ttyS1 at MMIO 0x48022000 (irq = 25, base_baud = 3000000) is a 8250
[ 1.471236] 48024000.serial: ttyS2 at MMIO 0x48024000 (irq = 26, base_baud = 3000000) is a 8250
[ 1.474775] omap_i2c 4802a000.i2c: bus 1 rev0.11 at 100 kHz
[ 1.479467] ti-sysc: probe of 48040000.target-module failed with error -16
[ 1.491330] OMAP GPIO hardware version 0.1
[ 1.496833] omap-mailbox 480c8000.mailbox: omap mailbox rev 0x400
[ 1.502350] at24 2-0054: supply vcc not found, using dummy regulator
[ 1.526600] at24 2-0054: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 1.527037] at24 2-0055: supply vcc not found, using dummy regulator
[ 1.556716] at24 2-0056: supply vcc not found, using dummy regulator
[ 1.584584] at24 2-0057: supply vcc not found, using dummy regulator
[ 1.614426] omap_i2c 4819c000.i2c: bus 2 rev0.11 at 100 kHz
[ 1.617567] 481a6000.serial: ttyS3 at MMIO 0x481a6000 (irq = 39, base_baud = 3000000) is a 8250
[ 1.620841] 481a8000.serial: ttyS4 at MMIO 0x481a8000 (irq = 40, base_baud = 3000000) is a 8250
[ 1.632356] sdhci-omap 481d8000.mmc: supply vqmmc not found, using dummy regulator
[ 1.650321] omap_rng 48310000.rng: Random Number Generator ver. 20
[ 1.654451] random: crng init done
[ 1.694011] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6, bus freq 1000000
[ 1.696063] davinci_mdio 4a101000.mdio: phy[0]: device 4a101000.mdio:00, driver SMSC LAN8710/LAN8720
[ 1.696490] cpsw-switch 4a100000.switch: initialized cpsw ale version 1.4
[ 1.696504] cpsw-switch 4a100000.switch: ALE Table size 1024
[ 1.696599] cpsw-switch 4a100000.switch: cpts: overflow check period 1250 (jiffies)
[ 1.696611] cpsw-switch 4a100000.switch: CPTS: ref_clk_freq:250000000 calc_mult:2147483648 calc_shift:29 error:0 nsec/sec
[ 1.696720] cpsw-switch 4a100000.switch: Detected MACID = 3c:e4:b0:2b:7c:c6
[ 1.698980] cpsw-switch 4a100000.switch: initialized (regs 0x4a100000, pool size 256) hw_ver:0019010C 1.12 (0)
[ 1.715827] debugfs: Directory '49000000.dma' with parent 'dmaengine' already present!
[ 1.715859] edma 49000000.dma: TI EDMA DMA engine driver
[ 1.721833] am335x-phy-driver 47401300.usb-phy: supply vcc not found, using dummy regulator
[ 1.722387] am335x-phy-driver 47401300.usb-phy: dummy supplies not allowed for exclusive requests
[ 1.728680] am335x-phy-driver 47401b00.usb-phy: supply vcc not found, using dummy regulator
[ 1.728964] am335x-phy-driver 47401b00.usb-phy: dummy supplies not allowed for exclusive requests
[ 1.751452] omap-sham 53100000.sham: hw accel on OMAP rev 4.3
[ 1.751649] omap-sham 53100000.sham: will run requests pump with realtime priority
[ 1.755047] omap-aes 53500000.aes: OMAP AES hw accel rev: 3.2
[ 1.755443] omap-aes 53500000.aes: will run requests pump with realtime priority
[ 1.760908] hw perfevents: enabled with armv7_cortex_a8 PMU driver, 5 counters available
[ 1.766122] l3-aon-clkctrl:0000:0: failed to disable
[ 1.766655] pwm-backlight backlight: supply power not found, using dummy regulator
[ 1.771173] PM: Cannot get wkup_m3_ipc handle
[ 1.773779] 44e09000.serial: ttyS0 at MMIO 0x44e09000 (irq = 18, base_baud = 3000000) is a 8250
[ 1.774321] printk: console [ttyS0]: printing thread started
[ 1.774345] printk: console [ttyS0] enabled
[ 1.802145] tps65217-pmic: Failed to locate of_node [id: -1]
[ 1.811195] tps65217-bl: Failed to locate of_node [id: -1]
[ 1.814228] tps65217 0-0024: TPS65217 ID 0xe version 1.2
[ 1.815730] at24 0-0050: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 1.816089] i2c 0-0070: Fixing up cyclic dependency with 4830e000.lcdc
[ 1.816596] pinctrl-single 44e10800.pinmux: pin PIN40 already requested by panel; cannot claim for 0-0070
[ 1.816610] pinctrl-single 44e10800.pinmux: pin-40 (0-0070) status -22
[ 1.816621] pinctrl-single 44e10800.pinmux: could not request pin 40 (PIN40) from group nxp_hdmi_bonelt_pins on device pinctrl-single
[ 1.816633] tda998x 0-0070: Error applying setting, reverse things back
[ 1.816698] omap_i2c 44e0b000.i2c: bus 0 rev0.11 at 400 kHz
[ 1.835284] omap_gpio 44e07000.gpio: Could not set line 6 debounce to 200000 microseconds (-22)
[ 1.835309] sdhci-omap 48060000.mmc: Got CD GPIO
[ 1.835497] sdhci-omap 48060000.mmc: supply vqmmc not found, using dummy regulator
[ 1.838140] remoteproc remoteproc0: powering up wkup_m3
[ 1.838166] remoteproc remoteproc0: Booting fw image am335x-pm-firmware.elf, size 217148
[ 1.838381] remoteproc remoteproc0: remote processor wkup_m3 is now up
[ 1.838441] wkup_m3_ipc 44e11324.wkup_m3_ipc: CM3 Firmware Version = 0x192
[ 1.842612] edt_ft5x06 2-0038: supply vcc not found, using dummy regulator
[ 1.842855] edt_ft5x06 2-0038: supply iovcc not found, using dummy regulator
[ 1.844569] sdhci-omap 481d8000.mmc: supply vqmmc not found, using dummy regulator
[ 1.862403] musb-hdrc musb-hdrc.1: MUSB HDRC host driver
[ 1.862462] musb-hdrc musb-hdrc.1: new USB bus registered, assigned bus number 1
[ 1.862737] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
[ 1.862753] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.862761] usb usb1: Product: MUSB HDRC host driver
[ 1.862768] usb usb1: Manufacturer: Linux 5.15.73-bone-rt-r31 musb-hcd
[ 1.862775] usb usb1: SerialNumber: musb-hdrc.1
[ 1.863634] hub 1-0:1.0: USB hub found
[ 1.863705] hub 1-0:1.0: 1 port detected
[ 1.875547] PM: bootloader does not support rtc-only!
[ 1.876100] tps6521x_pwrbutton tps65217-pwrbutton: DMA mask not set
[ 1.882787] mmc1: SDHCI controller on 481d8000.mmc [481d8000.mmc] using External DMA
[ 1.883328] mmc0: SDHCI controller on 48060000.mmc [48060000.mmc] using External DMA
[ 1.884475] input: tps65217_pwr_but as /devices/platform/ocp/44c00000.interconnect/44c00000.interconnect:segment@200000/44e0b000.target-module/44e0b000.i2c/i2c-0/0-0024/tps65217-pwrbutton/input/input0
[ 1.888582] ### dt-test ### start of unittest - you will see error messages
[ 1.892283] ### dt-test ### EXPECT \ : Duplicate name in testcase-data, renamed to "duplicate-name#1"
[ 1.893036] Duplicate name in testcase-data, renamed to "duplicate-name#1"
[ 1.899295] ### dt-test ### EXPECT / : Duplicate name in testcase-data, renamed to "duplicate-name#1"
[ 1.900363] ### dt-test ### EXPECT \ : OF: /testcase-data/phandle-tests/consumer-a: could not get #phandle-cells-missing for /testcase-data/phandle-tests/provider1
[ 1.900374] OF: /testcase-data/phandle-tests/consumer-a: could not get #phandle-cells-missing for /testcase-data/phandle-tests/provider1
[ 1.900408] ### dt-test ### EXPECT / : OF: /testcase-data/phandle-tests/consumer-a: could not get #phandle-cells-missing for /testcase-data/phandle-tests/provider1
[ 1.900414] ### dt-test ### EXPECT \ : OF: /testcase-data/phandle-tests/consumer-a: could not get #phandle-cells-missing for /testcase-data/phandle-tests/provider1
[ 1.900420] OF: /testcase-data/phandle-tests/consumer-a: could not get #phandle-cells-missing for /testcase-data/phandle-tests/provider1
[ 1.900447] ### dt-test ### EXPECT / : OF: /testcase-data/phandle-tests/consumer-a: could not get #phandle-cells-missing for /testcase-data/phandle-tests/provider1
[ 1.900452] ### dt-test ### EXPECT \ : OF: /testcase-data/phandle-tests/consumer-a: could not find phandle
[ 1.900507] OF: /testcase-data/phandle-tests/consumer-a: could not find phandle 12345678
[ 1.900527] ### dt-test ### EXPECT / : OF: /testcase-data/phandle-tests/consumer-a: could not find phandle
[ 1.900532] ### dt-test ### EXPECT \ : OF: /testcase-data/phandle-tests/consumer-a: could not find phandle
[ 1.900561] OF: /testcase-data/phandle-tests/consumer-a: could not find phandle 12345678
[ 1.900580] ### dt-test ### EXPECT / : OF: /testcase-data/phandle-tests/consumer-a: could not find phandle
[ 1.900584] ### dt-test ### EXPECT \ : OF: /testcase-data/phandle-tests/consumer-a: #phandle-cells = 3 found -1
[ 1.900591] OF: /testcase-data/phandle-tests/consumer-a: #phandle-cells = 3 found 1
[ 1.900609] ### dt-test ### EXPECT / : OF: /testcase-data/phandle-tests/consumer-a: #phandle-cells = 3 found -1
[ 1.900614] ### dt-test ### EXPECT \ : OF: /testcase-data/phandle-tests/consumer-a: #phandle-cells = 3 found -1
[ 1.900620] OF: /testcase-data/phandle-tests/consumer-a: #phandle-cells = 3 found 1
[ 1.900637] ### dt-test ### EXPECT / : OF: /testcase-data/phandle-tests/consumer-a: #phandle-cells = 3 found -1
[ 1.900795] ### dt-test ### EXPECT \ : OF: /testcase-data/phandle-tests/consumer-b: could not get #phandle-missing-cells for /testcase-data/phandle-tests/provider1
[ 1.900808] OF: /testcase-data/phandle-tests/consumer-b: could not get #phandle-missing-cells for /testcase-data/phandle-tests/provider1
[ 1.900837] ### dt-test ### EXPECT / : OF: /testcase-data/phandle-tests/consumer-b: could not get #phandle-missing-cells for /testcase-data/phandle-tests/provider1
[ 1.900843] ### dt-test ### EXPECT \ : OF: /testcase-data/phandle-tests/consumer-b: could not find phandle
[ 1.900879] OF: /testcase-data/phandle-tests/consumer-b: could not find phandle 12345678
[ 1.900898] ### dt-test ### EXPECT / : OF: /testcase-data/phandle-tests/consumer-b: could not find phandle
[ 1.900902] ### dt-test ### EXPECT \ : OF: /testcase-data/phandle-tests/consumer-b: #phandle-cells = 2 found -1
[ 1.900915] OF: /testcase-data/phandle-tests/consumer-b: #phandle-cells = 2 found 1
[ 1.900934] ### dt-test ### EXPECT / : OF: /testcase-data/phandle-tests/consumer-b: #phandle-cells = 2 found -1
[ 1.910651] ### dt-test ### EXPECT \ : platform testcase-data:testcase-device2: IRQ index 0 not found
[ 1.910681] platform testcase-data:testcase-device2: IRQ index 0 not found
[ 1.910694] ### dt-test ### EXPECT / : platform testcase-data:testcase-device2: IRQ index 0 not found
[ 1.918608] mmc0: new high speed SDHC card at address 59b4
[ 1.925077] mmcblk0: mmc0:59b4 29.8 GiB
[ 1.928616] mmcblk0: p1
[ 1.932724] ### dt-test ### EXPECT \ : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data/overlay-node/test-bus/test-unittest0/status
[ 1.933092] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data/overlay-node/test-bus/test-unittest0/status
[ 1.942134] ### dt-test ### EXPECT / : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data/overlay-node/test-bus/test-unittest0/status
[ 1.942149] ### dt-test ### EXPECT \ : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data/overlay-node/test-bus/test-unittest1/status
[ 1.942597] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data/overlay-node/test-bus/test-unittest1/status
[ 1.943226] ### dt-test ### EXPECT / : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data/overlay-node/test-bus/test-unittest1/status
[ 1.943238] ### dt-test ### EXPECT \ : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data/overlay-node/test-bus/test-unittest2/status
[ 1.943712] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data/overlay-node/test-bus/test-unittest2/status
[ 1.946052] ### dt-test ### EXPECT / : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data/overlay-node/test-bus/test-unittest2/status
[ 1.946068] ### dt-test ### EXPECT \ : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data/overlay-node/test-bus/test-unittest3/status
[ 1.946670] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data/overlay-node/test-bus/test-unittest3/status
[ 1.947137] ### dt-test ### EXPECT / : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data/overlay-node/test-bus/test-unittest3/status
[ 1.947800] mmc1: new high speed MMC card at address 0001
[ 1.950462] ### dt-test ### EXPECT \ : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data/overlay-node/test-bus/test-unittest5/status
[ 1.950883] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data/overlay-node/test-bus/test-unittest5/status
[ 1.953026] mmcblk1: mmc1:0001 M62704 3.56 GiB
[ 1.956346] mmcblk1: p1
[ 1.957477] mmcblk1boot0: mmc1:0001 M62704 2.00 MiB
[ 1.963534] ### dt-test ### EXPECT / : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data/overlay-node/test-bus/test-unittest5/status
[ 1.963650] ### dt-test ### EXPECT \ : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data/overlay-node/test-bus/test-unittest6/status
[ 1.964033] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data/overlay-node/test-bus/test-unittest6/status
[ 1.967471] mmcblk1boot1: mmc1:0001 M62704 2.00 MiB
[ 1.968614] ### dt-test ### EXPECT / : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data/overlay-node/test-bus/test-unittest6/status
[ 1.968624] ### dt-test ### EXPECT \ : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data/overlay-node/test-bus/test-unittest7/status
[ 1.968997] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data/overlay-node/test-bus/test-unittest7/status
[ 1.975736] ### dt-test ### EXPECT / : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data/overlay-node/test-bus/test-unittest7/status
[ 1.976611] ### dt-test ### EXPECT \ : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data/overlay-node/test-bus/test-unittest8/status
[ 1.976973] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data/overlay-node/test-bus/test-unittest8/status
[ 1.978633] mmcblk1rpmb: mmc1:0001 M62704 512 KiB, chardev (242:0)
[ 1.979388] ### dt-test ### EXPECT / : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data/overlay-node/test-bus/test-unittest8/status
[ 1.979401] ### dt-test ### EXPECT \ : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data/overlay-node/test-bus/test-unittest8/property-foo
[ 1.979737] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data/overlay-node/test-bus/test-unittest8/property-foo
[ 1.979793] ### dt-test ### EXPECT / : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data/overlay-node/test-bus/test-unittest8/property-foo
[ 1.979800] ### dt-test ### EXPECT \ : OF: overlay: node_overlaps_later_cs: #6 overlaps with #7 @/testcase-data/overlay-node/test-bus/test-unittest8
[ 1.979805] ### dt-test ### EXPECT \ : OF: overlay: overlay #6 is not topmost
[ 1.979811] OF: overlay: node_overlaps_later_cs: #6 overlaps with #7 @/testcase-data/overlay-node/test-bus/test-unittest8
[ 1.979835] OF: overlay: overlay #6 is not topmost
[ 1.979840] ### dt-test ### EXPECT / : OF: overlay: overlay #6 is not topmost
[ 1.979843] ### dt-test ### EXPECT / : OF: overlay: node_overlaps_later_cs: #6 overlaps with #7 @/testcase-data/overlay-node/test-bus/test-unittest8
[ 2.002847] ### dt-test ### EXPECT \ : i2c i2c-1: Added multiplexed i2c bus 2
[ 2.004601] i2c i2c-3: Added multiplexed i2c bus 4
[ 2.005284] ### dt-test ### EXPECT / : i2c i2c-1: Added multiplexed i2c bus 2
[ 2.005293] ### dt-test ### EXPECT \ : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data/overlay-node/test-bus/i2c-test-bus/test-unittest12/status
[ 2.005606] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data/overlay-node/test-bus/i2c-test-bus/test-unittest12/status
[ 2.011031] ### dt-test ### EXPECT / : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data/overlay-node/test-bus/i2c-test-bus/test-unittest12/status
[ 2.011045] ### dt-test ### EXPECT \ : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data/overlay-node/test-bus/i2c-test-bus/test-unittest13/status
[ 2.011293] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data/overlay-node/test-bus/i2c-test-bus/test-unittest13/status
[ 2.011756] ### dt-test ### EXPECT / : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data/overlay-node/test-bus/i2c-test-bus/test-unittest13/status
[ 2.011766] ### dt-test ### EXPECT \ : i2c i2c-1: Added multiplexed i2c bus 3
[ 2.018219] i2c i2c-3: Added multiplexed i2c bus 5
[ 2.018980] ### dt-test ### EXPECT / : i2c i2c-1: Added multiplexed i2c bus 3
[ 2.034500] ### dt-test ### EXPECT \ : gpio-<<int>> (line-B-input): hogged as input
[ 2.034515] ### dt-test ### EXPECT \ : gpio-<<int>> (line-A-input): hogged as input
[ 2.035164] gpio-509 (line-B-input): hogged as input
[ 2.036568] gpio-503 (line-A-input): hogged as input
[ 2.038223] ### dt-test ### EXPECT / : gpio-<<int>> (line-A-input): hogged as input
[ 2.038232] ### dt-test ### EXPECT / : gpio-<<int>> (line-B-input): hogged as input
[ 2.038237] ### dt-test ### EXPECT \ : gpio-<<int>> (line-D-input): hogged as input
[ 2.040864] gpio-501 (line-D-input): hogged as input
[ 2.049438] ### dt-test ### EXPECT / : gpio-<<int>> (line-D-input): hogged as input
[ 2.052896] ### dt-test ### EXPECT \ : gpio-<<int>> (line-C-input): hogged as input
[ 2.053780] gpio-495 (line-C-input): hogged as input
[ 2.053809] ### dt-test ### EXPECT / : gpio-<<int>> (line-C-input): hogged as input
[ 2.057633] ### dt-test ### EXPECT \ : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data-2/substation@100/status
[ 2.057646] ### dt-test ### EXPECT \ : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data-2/fairway-1/status
[ 2.057651] ### dt-test ### EXPECT \ : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data-2/fairway-1/ride@100/track@30/incline-up
[ 2.057656] ### dt-test ### EXPECT \ : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data-2/fairway-1/ride@100/track@40/incline-up
[ 2.057661] ### dt-test ### EXPECT \ : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data-2/lights@40000/status
[ 2.057666] ### dt-test ### EXPECT \ : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data-2/lights@40000/color
[ 2.057671] ### dt-test ### EXPECT \ : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data-2/lights@40000/rate
[ 2.057676] ### dt-test ### EXPECT \ : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /__symbols__/hvac_2
[ 2.057680] ### dt-test ### EXPECT \ : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /__symbols__/ride_200
[ 2.057684] ### dt-test ### EXPECT \ : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /__symbols__/ride_200_left
[ 2.057689] ### dt-test ### EXPECT \ : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /__symbols__/ride_200_right
[ 2.062356] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data-2/substation@100/status
[ 2.062418] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data-2/fairway-1/status
[ 2.062457] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data-2/fairway-1/ride@100/track@30/incline-up
[ 2.062485] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data-2/fairway-1/ride@100/track@40/incline-up
[ 2.062583] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data-2/lights@40000/status
[ 2.062602] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data-2/lights@40000/color
[ 2.062618] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data-2/lights@40000/rate
[ 2.062674] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /__symbols__/hvac_2
[ 2.062710] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /__symbols__/ride_200
[ 2.062744] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /__symbols__/ride_200_left
[ 2.062777] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /__symbols__/ride_200_right
[ 2.065952] ### dt-test ### EXPECT / : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /__symbols__/ride_200_right
[ 2.075997] ### dt-test ### EXPECT / : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /__symbols__/ride_200_left
[ 2.076004] ### dt-test ### EXPECT / : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /__symbols__/ride_200
[ 2.076009] ### dt-test ### EXPECT / : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /__symbols__/hvac_2
[ 2.076013] ### dt-test ### EXPECT / : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data-2/lights@40000/rate
[ 2.076018] ### dt-test ### EXPECT / : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data-2/lights@40000/color
[ 2.076023] ### dt-test ### EXPECT / : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data-2/lights@40000/status
[ 2.076027] ### dt-test ### EXPECT / : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data-2/fairway-1/ride@100/track@40/incline-up
[ 2.076032] ### dt-test ### EXPECT / : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data-2/fairway-1/ride@100/track@30/incline-up
[ 2.076037] ### dt-test ### EXPECT / : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data-2/fairway-1/status
[ 2.076042] ### dt-test ### EXPECT / : OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data-2/substation@100/status
[ 2.076047] ### dt-test ### EXPECT \ : OF: overlay: ERROR: multiple fragments add and/or delete node /testcase-data-2/substation@100/motor-1/controller
[ 2.076052] ### dt-test ### EXPECT \ : OF: overlay: ERROR: multiple fragments add, update, and/or delete property /testcase-data-2/substation@100/motor-1/controller/name
[ 2.076442] OF: overlay: ERROR: multiple fragments add and/or delete node /testcase-data-2/substation@100/motor-1/controller
[ 2.076625] OF: overlay: ERROR: multiple fragments add, update, and/or delete property /testcase-data-2/substation@100/motor-1/controller/name
[ 2.076695] ### dt-test ### EXPECT / : OF: overlay: ERROR: multiple fragments add, update, and/or delete property /testcase-data-2/substation@100/motor-1/controller/name
[ 2.076701] ### dt-test ### EXPECT / : OF: overlay: ERROR: multiple fragments add and/or delete node /testcase-data-2/substation@100/motor-1/controller
[ 2.076706] ### dt-test ### EXPECT \ : OF: overlay: ERROR: multiple fragments add and/or delete node /testcase-data-2/substation@100/motor-1/electric
[ 2.076710] ### dt-test ### EXPECT \ : OF: overlay: ERROR: multiple fragments add, update, and/or delete property /testcase-data-2/substation@100/motor-1/electric/rpm_avail
[ 2.076715] ### dt-test ### EXPECT \ : OF: overlay: ERROR: multiple fragments add, update, and/or delete property /testcase-data-2/substation@100/motor-1/electric/name
[ 2.076957] OF: overlay: ERROR: multiple fragments add and/or delete node /testcase-data-2/substation@100/motor-1/electric
[ 2.077042] OF: overlay: ERROR: multiple fragments add, update, and/or delete property /testcase-data-2/substation@100/motor-1/electric/rpm_avail
[ 2.077127] OF: overlay: ERROR: multiple fragments add, update, and/or delete property /testcase-data-2/substation@100/motor-1/electric/name
[ 2.077191] ### dt-test ### EXPECT / : OF: overlay: ERROR: multiple fragments add, update, and/or delete property /testcase-data-2/substation@100/motor-1/electric/name
[ 2.077197] ### dt-test ### EXPECT / : OF: overlay: ERROR: multiple fragments add, update, and/or delete property /testcase-data-2/substation@100/motor-1/electric/rpm_avail
[ 2.077202] ### dt-test ### EXPECT / : OF: overlay: ERROR: multiple fragments add and/or delete node /testcase-data-2/substation@100/motor-1/electric
[ 2.077518] ### dt-test ### end of unittest - 248 passed, 0 failed
[ 2.077862] ALSA device list:
[ 2.077872] No soundcards found.
[ 2.201766] input: generic ft5x06 (51) as /devices/platform/ocp/48000000.interconnect/48000000.interconnect:segment@100000/4819c000.target-module/4819c000.i2c/i2c-2/2-0038/input/input1
[ 2.214146] EXT4-fs (mmcblk0p1): INFO: recovery required on readonly filesystem
[ 2.214167] EXT4-fs (mmcblk0p1): write access will be enabled during recovery
[ 3.587715] EXT4-fs (mmcblk0p1): recovery complete
[ 3.666951] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
[ 3.667067] VFS: Mounted root (ext4 filesystem) readonly on device 179:1.
[ 3.677141] devtmpfs: mounted
[ 3.689500] Freeing unused kernel image (initmem) memory: 1024K
[ 3.691478] Checked W+X mappings: passed, no W+X pages found
[ 3.691508] Run /sbin/init as init process
[ 3.691513] with arguments:
[ 3.691520] /sbin/init
[ 3.691525] 1
[ 3.691529] with environment:
[ 3.691533] HOME=/
[ 3.691536] TERM=linux
[ 3.725518] Not activating Mandatory Access Control as /sbin/tomoyo-init does not exist.
[ 8.906400] EXT4-fs (mmcblk0p1): re-mounted. Opts: errors=remount-ro. Quota mode: none.
[ 22.178796] pinctrl-single 44e10800.pinmux: pin PIN101 already requested by 2-0038; cannot claim for 48038000.mcasp
[ 22.178821] pinctrl-single 44e10800.pinmux: pin-101 (48038000.mcasp) status -22
[ 22.178835] pinctrl-single 44e10800.pinmux: could not request pin 101 (PIN101) from group mcasp0_pins on device pinctrl-single
[ 22.178848] davinci-mcasp 48038000.mcasp: Error applying setting, reverse things back
[ 25.838174] remoteproc remoteproc1: 4a334000.pru is available
[ 25.841955] remoteproc remoteproc2: 4a338000.pru is available
[ 111.845196] fbcon: Taking over console
[ 112.167909] cpsw-switch 4a100000.switch: starting ndev. mode: dual_mac
[ 112.272173] SMSC LAN8710/LAN8720 4a101000.mdio:00: attached PHY driver (mii_bus:phy_addr=4a101000.mdio:00, irq=POLL)
[ 133.318222] usb 1-1: new high-speed USB device number 2 using musb-hdrc
[ 133.541357] usb 1-1: New USB device found, idVendor=03f0, idProduct=7d40, bcdDevice= 1.00
[ 133.541388] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 133.541397] usb 1-1: Product: HP v236w
[ 133.541404] usb 1-1: Manufacturer: HP
[ 133.541411] usb 1-1: SerialNumber: 7F0018CB26DF4923
[ 133.551901] usb-storage 1-1:1.0: USB Mass Storage device detected
[ 133.569315] scsi host0: usb-storage 1-1:1.0
[ 136.980906] scsi 0:0:0:0: Direct-Access hp HP v236w DL17 PQ: 0 ANSI: 4
[ 137.003212] sd 0:0:0:0: [sda] 30322688 512-byte logical blocks: (15.5 GB/14.5 GiB)
[ 137.004068] sd 0:0:0:0: [sda] Write Protect is off
[ 137.004087] sd 0:0:0:0: [sda] Mode Sense: 23 00 00 00
[ 137.004907] sd 0:0:0:0: [sda] No Caching mode page found
[ 137.004921] sd 0:0:0:0: [sda] Assuming drive cache: write through
[ 137.016465] sda: sda1
[ 137.020538] sd 0:0:0:0: [sda] Attached SCSI removable disk
[ 137.106269] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 202.994889] usb 1-1: USB disconnect, device number 2
LCD is working with the default image, however, when we customize the LCD is not working. We have tested the other peripherals (I2C/UART/ADC etc) which are working when we customize the *.dtb file.
Sreekanth
