How do I access the PRUs’ shared RAM from within a kernel driver? Is there an equivalent to mmap()?
Can you point me to some tutorials?
–Mark
–Mark
You can probably use it as an attribute.
something like this :
__far attribute((cregister(“PRU_SHAREDMEM”, near))) volatile uint32_t variable_1;
__far attribute((cregister(“PRU_SHAREDMEM”, near))) volatile uint32_t variable_2;
//Somewhere In code
variable_1 = data;
variable_2 = _2_data;
So basically, the compiler allocates memory to these variables somewhere in the shared mem and you have no control over where it gets allocated. So if you wish to share data between the two PRUs, you can probably
define the variable in a common file and then use this exact same variable in the two source codes.
I haven’t actually tried this way. Please let us know if this works.
I do not think so . . .because somehow, you have to "tap into" the kernels
virtual memory pool. *Or* if the peripheral in question is not already
represented in virtual memory. You need to use something like ioremap().
Read the first answer here:
http://unix.stackexchange.com/questions/239205/whats-the-difference-between-ioremap-and-file-operation-mmap
A few search hit's I found yesterday on the subject mention reading LDD3
chapters 9, and 15 . . . but I saw no examples so did not mention anything.
Plus, I have no personal hands on . . . but I do find it an interesting
question.
How do I access the PRUs' shared RAM from within a kernel driver? Is there an
Chapter 15 of LDD3:
The BeagleLogic code probably does what you're wanting to do
(high-speed kernel mode access to the PRU):
990
DMA in my mind almost seems the way to go. But there are several key points
that I'd need to understand to make that determination.But at the moment
I'm imagining all kinds of cool possibilities. . . too bad I do not have
the time to invest into looking into this right now.
DMA is not really necessary, as the PRU can read/write to the ARM
system DRAM and the ARM can read/write to the PRU memories. There are
some ways DMA could improve performance of a high-performance
application using both the ARM and the PRU heavily, but it's not a
clear win in all cases.
However, any kernel-level physical memory access for talking to the
PRU is going to have a lot in common with doing DMA. You need to map
physical addresses into logical memory space, issue fence instruction
to guarantee memory coherency, etc. Basically, the PRU can be
considered a "custom" DMA controller, in that it is something other
than the application processor that is accessing and changing main
memory contents. The usage semantics for talking to the PRU in kernel
space are very similar to using DMA. Just 's/DMA/PRU/g' and you won't
go too far wrong!
Well, what I was thinking, and perhaps this would have more of a home on
the Beagleboard X15. . . Is that, you have a PRU reading data in some
fashion from an external peripheral, at high speeds. Then you want to get
that data out of the PRU shared memory as fast as possible to some external
storage.
With the Beaglebones, you're going to be limited by your fastest block
device, or interface. In the case of the Beaglebone, that would probably be
USB, which as it stands ( stock ) is not really much faster than ethernet.
Real world performance that is.
But on the X15 where you have dual GbE, PCIe, USB3.0, and SATA . . . you
have much faster external "storage". IN this case, you might want a DMA
buffer in kernel space that blasts this data directly onto the storage
peripheral. All the while keeping your CPU load as low as possible, for
other potential duties.
But as I said, I have no practical hands on here, but the theory seems
possible at first glance.
Please do also realize that I left out mmc media on purpose in the context of high speed “permanent” storage. Then the GPMC connected to something could possibly be of use too.
oops ! Sorry. Somehow I just read ‘PRUs’ shared RAM’ and didnt read the ‘within a kernel driver’ part of the main question, and then thought he was asking about PRU’s shared memory usage, to share data between the two PRUs. So the answer was to be able to use shared mem for PRU to PRU communication.
It turns out the answer is in page 250 of Chapter 9 of LDD 3 (https://lwn.net/Kernel/LDD3/).
#include <asm/io.h>
void *ioremap(unsigned long phys_addr, unsigned long size);
void iounmap(void * addr);
unsigned int ioread32(void *addr);
So I used:
#include <asm/io.h>
#define PRU_ADDR 0x4A300000 // Start of PRU memory Page 184 am335x TRM
#define PRU_SHAREDMEM 0x10000 // Offset to shared memory
#define PRU_SHAREDMEM_LEN 0x3000 // Length of shared memory
void *shared_mem;
shared_mem = ioremap(PRU_ADDR+PRU_SHAREDMEM, 0x3000);
and then to read the 0th shared memory:
ioread32(shared_mem+0);
I’ll soon post the simple kernel driver I have working…
–Mark
