However, I'd like to compile a kernel-module or two, so I need the linux
headers for the kernel used in these images.
Would it be possible to somehow provide a tgz containing the headers? In
openembedded they're usually located at:
$OE_HOME/tmp/staging/armv7a-angstrom-linux-gnueabi/usr/include/linux/
I've tried to use the headers from my local OpenEmbedded installation
but for some reason I always get the following error in the kernel log:
testmodulek: disagrees about version of symbol struct_module
Fun fact: my self-compiled kernel has the same version as the one
provided with narcissus, but it still does not work (It should,
shouldn't it?)
If I use my own kernel my module loads, but in this case all other
modules won't load anymore.
you are going to need a cross compile toolchain, I use codesourcery
( free to download) and mkimage(apt-getable)
then type:
ARCH=arm make CROSS_COMPILE=/path/to/the/tool/chain/bins/
toolchain distclean
toolchain omap3_beagle_defconfig
toolchain menuconfig /*here you activate everything you want*/
toolchain uImage modules
you are going to get a uImage in the folder arch/arm/boot
now do ARCH=arm make CROSS_COMPILE=/path/to/the/tool/chain/
bins/toolchain
INSTALL_MOD_PATH=/path/to/your/card files
partition modules_install
sorry, hadn't read everything, this error is due to difference in the
kernel version you are using and the kernel you are using to compile
the module....there is a way to force module to load by erasing the
mod_info section but I never did it...
I couldn't open the narcissus sd.img...how did you do it?
