Kernel update to 4.4.15-ti-r35 failure
When updating the TI kernel from 4.4.14-ti-r34 to 4.4.15-ti-r35 on Debian 8.5, the kernel failed to
boot cleanly. On connecting a console, the boot process failed in initramfs when trying to mount the
real boot partition (the eMMC). The mount command from initramfs was complaining about invalid
parameters. Any idea about what is causing this? Edited uEnv.txt to refer to the older kernel and
re-booted ok, so was fixable.
Cheers Steve.
Hi Steve,
Hi Steve,
Mainline u-boot seems to use a ‘blkid’ command to set the UUID. Does that work for X15?
FYI, it seems to have also broken WL1835 wifi over SDIO (mmc2).
I’ll be looking for the build!
Hi Steve,
Sigh, yeah it's broken on my bbb too...
with r34, i was chasing why the uuid=<> option was failing to find the
microSD card on the x15, i fixed that and pushed as r35..
Mainline u-boot seems to use a 'blkid' command to set the UUID. Does that
work for X15?
Debian Jessie era tools (sfdisk (util-linux 2.25.x) and mkfs.ext4
(e2fsprogs 1.42.12)) don't set the PARTUUID bit unless you force GPT which
breaks other things..
e2fsprogrs 1.43, can be backported to jessie, but you still need util-linux
2.27 (which needs a few more things backported) *( i initially went down
this path yesterday, before giving up. :wink: )
Then with r35, i noticed the eMMC on x15 had regressed (while the microSD
was working), which i fixed in r36, by pulling the patch from 4.5.x to hard
code microSD=mmc0, eMMC=mmc1...
and now the bbb is broken.. blah...
r37 is being built right now, so everything should be good again..
So, i'll revert back to r34, but leave the 4.5.x hardcode in place for
the x15. :wink:
I'll be looking for the build!
Hi Steve,
OK, that wasn’t the issue. ti-rt-r36 still fails with WL1835.
Useful debug output:
Jul 19 15:12:08 beaglebone kernel: omap_hsmmc 47810000.mmc: card claims to support voltages below defined range
Jul 19 15:12:08 beaglebone kernel: mmc2: error -16 whilst initialising SDIO card
Hi Steve,
Is -r37 on the way or do I need to look at this as a potential device tree issue related to the new kernel and start hacking the tree again?
OK, that wasn't the issue. ti-rt-r36 still fails with WL1835.
SDIO card
Most of the r37 builds are done, still waiting on a few "rt" builds, this
will work right now in wheezy/jessie/stretch/sid
sudo apt-get update ; sudo apt-get install linux-image-4.4.15-ti-r37
That did the trick! WL1835 is working out-of-the-box.
Working for me :slight_smile:
Thanks.
