KVM support on BBAI64
Is it possible to enable kvm in the kernel?
I running the following version:
$ sudo beagle-version
[sudo] password for debian:
eeprom:[BBONEAI-64-B0-B0007801B00001643522BBBBBB2422]
model:[BeagleBoard.org_BeagleBone_AI-64]
dogtag:[BeagleBoard.org Debian Bullseye Minimal Image 2022-11-01]
bootloader:[/dev/mmcblk0boot0]:[tiboot3.bin]:[U-Boot SPL 2021.01-g8bafcf50 (Nov 10 2022 - 23:19:52 +0000)]
bootloader:[/dev/mmcblk0]:[/boot/firmware/tiboot3.bin]:[U-Boot SPL 2021.01-g8bafcf50 (Nov 10 2022 - 23:19:52 +0000)]
bootloader:[/dev/mmcblk0]:[/boot/firmware/tispl.bin]:[U-Boot SPL 2021.01-g8bafcf50 (Nov 10 2022 - 23:19:52 +0000)]
bootloader:[/dev/mmcblk0]:[/boot/firmware/u-boot.img]:[U-Boot 2021.01-g8bafcf50 (Nov 10 2022 - 23:19:52 +0000)]
UBOOT: Booted Device-Tree:[k3-j721e-beagleboneai64.dts]
kernel:[5.10.145-ti-arm64-r72]
There is no trace of kvm in dmesg. Can it be enabled?
BR,
/j
Sorry, it’s currently disabled. I’ve been trying to get RT to work (which still doesn’t), but with v5.10.x-ti currently, it’s KVM or RT…
git clone -b ti-linux-arm64-5.10.y https://github.com/RobertCNelson/ti-linux-kernel-dev
cd ./ti-linux-kernel-dev
./build_deb.sh
When menuconfig pops up enable virtualization…
Once the linux-image.deb" finish building, just copy it over and install it with ā€œsudo dpkg -i linux-image*.debā€ and reboot…
My first attempt failed as I just enabled Virtualization in the top menu and missed that KVM was found in a sub-menu.
I could then successfully run firecracker on the bbai64 with good results:
root@ubuntu-fc-uvm:~# uname -a
Linux ubuntu-fc-uvm 4.14.174+ #14 SMP Mon Nov 23 20:44:24 UTC 2020 aarch64 aarch64 aarch64 GNU/Linux
root@ubuntu-fc-uvm:~# systemd-analyze
Startup finished in 339ms (kernel) + 1.205s (userspace) = 1.544s
graphical.target reached after 1.109s in userspace
Did i miss any of your tested config’s?
i’m just going to spit ā€˜RT’ out in it’s own custom build…
No, it looks exactly like my .config after enabling virtualization and KVM.
