KwikByte KBOC BB_2
I am looking for someone who what successfully booted a KwikByte KBOC
BB_2 developers board.
I just can't get my board to display anything on to the serial
terminal connection. I even tested my RS232 to USB connection by
shorting the RX and TX pin without the board and I can echo text back
on to the terminal as expected.
When I connect it to the Kwikbyte board I get nothing.
Any help would be greatly appreciated.
Neel
I haven't used it directly, but according to:
http://www.kwikbyte.com/KBOC/BB2/docs/KBOC_BB2_USER.pdf
Your going to need a Level Converter for the 3.3V signaling...
They recommend, TTL-232R-3V3
What are you using?
I was using a different RS232 to USB cable that didn't work. The
TTL-232R-3V3 worked. Now I have to figure out how to get the omapfb to
display at a different resolution since it is not working on my LCD.
