Anyone can share the latest image for beagole board xM rec C1 ?
I want to setup it to download media into external hard disk
Monthy snapshots with directions here:
http://elinux.org/BeagleBoardDebian#Debian_.28jessie.29
Sorry, i don't really test the xM anymore, other then basic boot tests..
Sorry, i don’t really test the xM anymore, other then basic boot tests…
I created a simple console disk image at http://debian.beagleboard.org/images/beaglexm-debian-8.3-console-2016-02-11-2gb.img.xz.
If I get positive feedback, I will link from BeagleBoard.org/latest-images. I have not tested it myself yet.
Looks good, except i flashed it to a broken microsd card:
xzcat beaglexm-debian-8.3-console-2016-02-11-2gb.img.xz | sudo dd of=/dev/sde
U-Boot SPL 2016.01-00001-gc0bfce8 (Jan 25 2016 - 20:14:03)
Trying to boot from MMC
SPL: Please implement spl_start_uboot() for your board
SPL: Direct Linux boot not active!
reading u-boot.img
reading u-boot.img
U-Boot 2016.01-00001-gc0bfce8 (Jan 25 2016 - 20:14:03 -0600), Build:
jenkins-github_Bootloader-Builder-325
OMAP36XX/37XX-GP ES1.2, CPU-OPP2, L3-200MHz, Max CPU Clock 1 Ghz
I2C: ready
DRAM: 512 MiB
NAND: 0 MiB
MMC: OMAP SD/MMC: 0
Beagle xM Rev C
No EEPROM on expansion board
OMAP die ID: 1701000e016830c49ff8000034680022Net: usb_ether
Error: usb_ether address not set.
switch to partitions #0, OK
mmc0 is current device
SD/MMC found on device 0
Checking for: /uEnv.txt ...
Checking for: /boot/uEnv.txt ...
260 bytes read in 46 ms (4.9 KiB/s)
Checking if uname_r is set in /boot/uEnv.txt...
Running uname_boot ...
loading /boot/vmlinuz-4.4.1-armv7-x5 ...
5793392 bytes read in 555 ms (10 MiB/s)
loading /boot/dtbs/4.4.1-armv7-x5/omap3-beagle-xm.dtb ...
108305 bytes read in 243 ms (434.6 KiB/s)
loading /boot/initrd.img-4.4.1-armv7-x5 ...
9777413 bytes read in 896 ms (10.4 MiB/s)
debug: [console=ttyO2,115200n8 root=/dev/mmcblk0p2 ro rootfstype=ext4
rootwait coherent_pool=1M quiet] ...
debug: [bootz 0x82000000 0x88080000:953105 0x88000000] ...
Kernel image @ 0x82000000 [ 0x000000 - 0x586670 ]
## Flattened Device Tree blob at 88000000
Loading Ramdisk to 8f6ac000, end 8ffff105 ... OK
Loading Device Tree to 8f68e000, end 8f6ab710 ... OK
Starting kernel ...
[ 0.851165] platform 48058000.ssi-controller: Cannot lookup hwmod 'ssi'
[ 0.855285] of_amba_device_create(): amba_device_add() failed (-19)
for /etb@5401b000
[ 0.855438] of_amba_device_create(): amba_device_add() failed (-19)
for /etm@54010000
[ 4.842193] tfp410 encoder@0: failed to parse PD gpio
[ 4.842742] connector-dvi connector@0: failed to find video source
[ 4.897338] Error: Driver 'tfp410' is already registered, aborting...
[ 5.025207] ehci-omap 48064800.ehci: Can't get PHY device for port 1: -517
[ 5.148040] omap2_set_init_voltage: unable to find boot up OPP for
vdd_mpu_iva
[ 5.155700] omap2_set_init_voltage: unable to set vdd_mpu_iva
[ 5.161834] omap2_set_init_voltage: unable to find boot up OPP for vdd_core
[ 5.169128] omap2_set_init_voltage: unable to set vdd_core
Loading, please wait...
[ 7.181335] mmc0: card never left busy state
[ 7.185821] mmc0: error -110 whilst initialising SD card
Gave up waiting for root device. Common problems:
- Boot args (cat /proc/cmdline)
- Check rootdelay= (did the system wait long enough?)
- Check root= (did the system wait for the right device?)
- Missing modules (cat /proc/modules; ls /dev)
ALERT! /dev/mmcblk0p2 does not exist. Dropping to a shell!
(initramfs)
"mmc0: error -110 whilst initialising SD card" this a bad microSD card..
This time with a good microsd card:
monitor alive via edid:
debian@arm:~$ cat /sys/class/drm/card0-DVI-D-1/edid | parse-edid
Checksum Correct
Section "Monitor"
Identifier "DELL 1707FP"
ModelName "DELL 1707FP"
VendorName "DEL"
# Monitor Manufactured week 48 of 2006
# EDID version 1.3
# Digital Display
DisplaySize 340 270
Gamma 2.20
Option "DPMS" "true"
Horizsync 30-81
VertRefresh 56-76
# Maximum pixel clock is 140MHz
#Not giving standard mode: 1152x864, 75Hz
#Not giving standard mode: 1280x1024, 60Hz
Modeline "Mode 0" +hsync +vsync
EndSection
usb:
debian@arm:~$ lsusb
Bus 002 Device 005: ID 046d:c52b Logitech, Inc. Unifying Receiver
Bus 002 Device 004: ID 0424:2504 Standard Microsystems Corp. USB 2.0 Hub
Bus 002 Device 003: ID 0424:ec00 Standard Microsystems Corp.
SMSC9512/9514 Fast Ethernet Adapter
Bus 002 Device 002: ID 0424:9514 Standard Microsystems Corp.
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
ethernet:
debian@arm:~$ sudo ifconfig -a
eth0 Link encap:Ethernet HWaddr 3a:76:00:fb:79:d2
inet addr:192.168.0.142 Bcast:192.168.0.255 Mask:255.255.255.0
inet6 addr: fe80::3876:ff:fefb:79d2/64 Scope:Link
UP BROADCAST RUNNING MULTICAST DYNAMIC MTU:1500 Metric:1
RX packets:29 errors:0 dropped:0 overruns:0 frame:0
TX packets:61 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:3164 (3.0 KiB) TX bytes:10140 (9.9 KiB)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:160 errors:0 dropped:0 overruns:0 frame:0
TX packets:160 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:12960 (12.6 KiB) TX bytes:12960 (12.6 KiB)
usb0 Link encap:Ethernet HWaddr 9a:b9:4c:c7:09:ef
BROADCAST MULTICAST MTU:1500 Metric:1
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
debian@arm:~$ cpufreq-info
cpufrequtils 008: cpufreq-info (C) Dominik Brodowski 2004-2009
Report errors and bugs to cpufreq@vger.kernel.org, please.
analyzing CPU 0:
driver: cpufreq-dt
CPUs which run at the same hardware frequency: 0
CPUs which need to have their frequency coordinated by software: 0
maximum transition latency: 300 us.
hardware limits: 300 MHz - 800 MHz
available frequency steps: 300 MHz, 600 MHz, 800 MHz
available cpufreq governors: conservative, ondemand, userspace,
powersave, performance
current policy: frequency should be within 300 MHz and 800 MHz.
The governor "ondemand" may decide which speed to use
within this range.
current CPU frequency is 300 MHz.
cpufreq stats: 300 MHz:82.59%, 600 MHz:2.69%, 800 MHz:14.72% (41)
Sorry no 1Ghz, no one is really working on opp stuff for omap3's
anymore on mainline... (and our local hack doesn't work anymore..)
BeagleBoardDebian - eLinux.org
http://debian.beagleboard.org/images/beaglexm-debian-8.3-console-2016-02-11-2gb.img.xz.If I get positive feedback, I will link from BeagleBoard.org/latest-images.
I have not tested it myself yet.This time with a good microsd card:
This is good. It was built without a microSD card (script only). There is a bmap for it in the same path. I will push to latest-images and look at additions as requested.
I think the bmap will fail...
When last i tried bmap vs dd for pre-omap4 bootrom's, they were
failing to boot u-boot..
I'm tempted to dd /dev/random into the first MB before craeting the
first fat partition.. (just haven't tried this yet)..
As i think the bootrom get's stuck on something the bmap ignored..
