Hi Everyone,
So it's been a long time since i posted one of these. So let's go more crazy..
In the past, Image releases have been kinda random. So let's try to
get things on a better schedule...
Maybe 3 times a year? We've been thinking, Early spring for GSOC,
Before School for universities who use our boards, and a mid December
which fits in between..
So... With a plan to have an NEW official image released on April
6th, 2020, let's get started with RC1: (which are up right now..) New
RC every Monday..
Right now i just want to limit images to the Base Console, IoT and IoT
TIDL. (For both Stretch 9.12 and Buster 10.3)
Let's be honest, who really uses the lxqt image? Raise hand???
Issue Tracker: https://github.com/beagleboard/Latest-Images/issues
elinux page with img links: https://elinux.org/Beagleboard:Latest-images-testing
Changes:
usb0/usb1: default ip address (192.168.7.2/192.168.6.2)
For users that like to plug many Beagle's into one PC, you can now
stop fighting usb-gadget, under /etc/default/bb-boot, you can now
update the usb0/usb1 default ip address in one location...
Node-RED : 1.0.4
Can we drop features we would like to be implemented in the April release?
I would like to have kernel 5.4 (or newer) to be functional in the Pocket/BeagleBoneBlack (Wireless)
Reason: I would like to use CAN J1939 directly from Kernel support.
I will keep an eye on the RCs and test them in my domain
Gwen
Please. There is a tracker.
Cool. I need dtbo ovetlays for some of my workshops and a number of out of tree drivers. Really, I need to track them to mainline and create a regression test suite.
Kernels are pretty big. Robert has scripts to load different kernels. Does that work for you?
Great!
No,
Debian 9 ARMHF has no 5.4 version support, starting from the release version the unit does not boot if I enforce the kernel version.
With Debian10 testing version, 10 has 5.4 available in ARMHF, my device fails to mount/boot after upgrading the Kernel.
I will do the exercise with a serial debug connected, to get some info on what is going wrong.
I don’t use the overlays as it never really aligns exactly with the application.
I tend to define the pins in a startup script.
Gwen
Please explain a little more, i don't know specifically what you mean..
No,
In either our Debian 9 or Debian 10 images, just run:
sudo /opt/scripts/tools/update_kernel.sh --ti-channel --lts-5_4
It should boot in the default state.
I don't use the overlays as it never really aligns exactly with the application.
BeagleBone Blue: Users
A bug was just fixed/found in the boot scripts.. It's a simple fix,
but a bad typo on my "hey your not a robotiscape, don't load that
service file cleanup patches, for other boards.."
cd /opt/scripts/
git pull
https://rcn-ee.com/
Console Users, there's a bug in the usb0/usb1 dnsmasq init:
Run:
sudo cp -v /opt/scripts/boot/default/bb-boot /etc/default/
and Reboot..
https://github.com/beagleboard/Latest-Images/issues/5
Hmmm … this may be me (very possible!), but applying the updates above - even with git pull, refreshing from the repository, and the copy command (to be safe), after running the kernel update, I can no longer boot from eMMC. No USB ip address, also the ethernet interface itself doesn’t come up. I can “restore” with the eMMC-flasher microSD build, but that’s back to the older kernel
Any thoughts of how to debug? I don’t have a serial cable (yet), so somewhat flying blind :-(. Thanks!
Which board, what kernel did you try to install?
Sorry! BeagleBone AI, rev A1. Tried upgrading to lts-5.4 (command as above). Make sense?
Is it better to work this here, or put an Issue in to GitHub? Either one is fine with me, just not sure what the preferred answer is.
Thanks!
eMMC is broken in 5.4.x with the AI, haven't had a moment to fix it.
It's a pinmux issue with the new driver.
NP! Just glad I’m not going crazy … LOL!
Would it make sense to addt this to GitHub? No biggie either way, just wondering.
Thanks!
It's fine, it's one of two reasons, why the Summer 2020 snapshot
(which should be released today) is still on v4.19.x
That makes sense, thanks! Perhaps just capture in the release notes (saying not to try lts-5.4 :-)).
Appreciate it!
