Finally I fixed the board and had the chance to test the Atin u-
boot.bin with usb :))
kapare@vostro:~/beagleboard/sd$ ls /dev/ttyAC*
/dev/ttyACM0
dmesg | tail
[35388.720987] cdc_acm: This device cannot do calls on its own. It is
no modem.
[35388.721957] cdc_acm 7-3:1.0: ttyACM0: USB ACM device
and start minicom /dev/ttyACM0
The problem was that last cylinder of first partition was set to 50
and not to 51, hey!
Command (m for help): [n]
Command action
e extended
p primary partition (1-4)
[p]
Partition number (1-4): [1]
First cylinder (1-245, default 1): [(press Enter)]
Using default value 1
Last cylinder or +size or +sizeM or +sizeK (1-245, default 245): [+50]
-----------script used----------
#!/bin/sh
# Environment variables
SD_PATH="/dev/mmcblk0"
SD_P1_PATH="/dev/mmcblk0p1"
SD_P2_PATH="/dev/mmcblk0p2"
# SD validation.
SD_INSERT="SD insert test: "
if [ -e $SD_PATH ]
then
echo "--> ${SD_INSERT} OK"
else
echo "--> ${SD_INSERT} FAILED"
echo "--> SD not inserted!"
exit $?
fi
# Mount validation for p1.
MOUNT_P1="SD P1 mount test: "
if [ -n "`mount | grep /dev/mmcblk0p1`" ]
then
echo "--> ${MOUNT_P1} FAILED"
echo "--> sudo umount ${SD_P1_PATH}"
sudo umount $SD_P1_PATH
else
echo "--> ${MOUNT_P1} OK"
fi
MOUNT_P2="SD P2 mount test: "
if [ -n "`mount | grep /dev/mmcblk0p2`" ]
then
echo "--> ${MOUNT_P2} FAILED"
echo "--> sudo umount ${SD_P2_PATH}"
sudo umount $SD_P2_PATH
else
echo "--> ${MOUNT_P2} OK"
fi
# Disk /dev/mmcblk0: 1977 MB, 1977614336 bytes
# 1977614336/255/63/512 = 240.431248055 = FLOOR = 240
# Create partition backup: sfdisk -H 255 -S 63 -C 240 --d /dev/mmcblk0
sd-beagleboard-partition.out
# Create partition
# echo "--> Create SD partition: sfdisk -H 255 -S 63 -C 240 --force /
dev/mmcblk0 < sd-beagleboard-partition.out"
# sfdisk -H 255 -S 63 -C 240 --force /dev/mmcblk0 < sd-beagleboard-
partition.out
fdiskCommands()
echo d
echo 1
echo d
echo 2
echo n
echo p
echo 1
echo
echo 51
echo t
echo c
echo a
echo 1
echo n
echo p
echo 2
echo
echo
echo t
echo 2
echo 83
echo w
echo "--> Create partitions on SD card."
fdiskCommands | fdisk -C 240 -H 255 -S 63 /dev/mmcblk0
# Format the partitions
echo "--> Format SD P1 into FAT32: sudo mkfs.msdos -F 32 /dev/
mmcblk0p1 -n boot"
sudo mkfs.msdos -F 32 /dev/mmcblk0p1 -n boot
echo "--> Format SD P2 into ext3: sudo mkfs.ext3 -L rootfs /dev/
mmcblk0p2"
sudo mkfs.ext3 -L rootfs /dev/mmcblk0p2
# Mount newly formated partition:
echo "--> Mount newly formated partition"
sudo mount /dev/mmcblk0p1 /mnt/boot
sudo mount /dev/mmcblk0p2 /mnt/rootfs
# IMPORTANT TO DO THIS BEFORE ANY OTHER FILES ARE COPIED:
# Copy the MLO file that you downloaded to the Beagle_Boot partition.
# The MLO file must be the first file copied to the partition after re-
formatting.
echo "--> Copy MLO to boot partition."
sudo cp /home/kapare/beagleboard/sd/boot/MLO_restore /mnt/boot/MLO
echo "--> Copy u-boot to boot partition."
# sudo cp /home/kapare/beagleboard/sd/boot/u-boot.bin_autoflash /mnt/
boot/u-boot.bin
sudo cp /home/kapare/beagleboard/sd/boot/musb_gadget-u-boot.bin /mnt/
boot/u-boot.bin
echo "--> umount partitions."
sync
sudo umount /dev/mmcblk0p1 /dev/mmcblk0p2
