Launching a .sh script @start BBB Augstrom
So i have a Beagle Bone Black linked to an HDMI screen via HDMI (it works) and a ssh access via USB.
I have a basic network script to lauch when the beagle bone power on. The script is working fine when started “manually” via ssh.
Followed this tuto http://mattrichardson.com/BeagleBone-System-Services/ but when the bbb reboot the script isn’t launched at all.
*root@beaglebone:/lib/systemd/*system# ls -la | grep monService.service
-rwxrwxrwx 1 root root 242 Jan 1 06:33 monService.service
root@beaglebone:/lib/systemd/system# cat monService.service
[Unit]
Description=blabla
[Service]
WorkingDirectory=/home/root/
ExecStart=/monScript.sh
RemainAfterExit=yes
[Install]
WantedBy=multi-user.target
status when started :
monService.service - blabla
Loaded: loaded (/lib/systemd/system/monService.service; enabled)
Active: active (exited) (Result: exit-code) since Sat 2000-01-01 06:35:59 CET; 28min ago
Main PID: 132 (code=exited, status=203/EXEC)
CGroup: name=systemd:/system/monService.service
Jan 01 06:40:01 beaglebone systemd[1]: Started blabla
Jan 01 06:40:16 beaglebone systemd[1]: Started blabla
Any help would be nice !
I found this link helpful when making services:
http://kezhong.wordpress.com/2011/11/19/creating-my-own-systemd-service-files-on-fedora-16x86_64/
It's possibly an order of operations thing. You can have the service run
last with Type=idle in the Service section.
tks for help Alfredo.
That didn’t work though.
Try
ExecStart=/bin/sh monScript.sh
aslo use
Type=idle
to prevent starting the scrip[t to early
thank you. I find out that the script was launched too early and the commands inside where erased by auto-login.
tks for help again
