Okay,
This monster of an image named .wic was made, done, and looked over…
What other parts to the beaglebone-ai64 Yocto builds will need to be put on the SD Card to boot it?
P.S. If someone, anyone can decipher this output, please let me know what is going on…
U-Boot SPL 2021.01-gc21ddbdf (Nov 28 2022 - 15:42:44 +0000)
Model: BeagleBoard.org BeagleBone AI-64 R5
EEPROM not available at 0x50, trying to read at 0x51
Board: BBONEAI-64-B0- rev B0
SYSFW ABI: 3.1 (firmware rev 0x0015 '21.9.1--v2021.09a (Terrific Lla')
Trying to boot from MMC1
init_env from device 17 not supported!
Starting ATF on ARM64 core...
NOTICE: BL31: v2.5(release):0588523
NOTICE: BL31: Built : 17:13:47, Feb 16 2023
U-Boot SPL 2021.01-gea96725b (Feb 16 2023 - 17:13:47 +0000)
Model: Texas Instruments K3 J721E SoC
ti_i2c_eeprom_am6_parse_record: Ignoring record id 17
U-Boot 2021.01-gea96725b (Feb 16 2023 - 17:13:47 +0000)
SoC: J721E SR1.1 GP
DRAM: 4 GiB
Flash: 0 Bytes
MMC: sdhci@4f80000: 0, sdhci@4fb0000: 1
Loading Environment from FAT... *** Warning - bad CRC, using default environment
In: serial@2800000
Out: serial@2800000
Err: serial@2800000
am65_cpsw_nuss ethernet@46000000: K3 CPSW: nuss_ver: 0x6BA00101 cpsw_ver: 0x6BA80100 ale_ver: 0x00293904 Ports:1 mdio_freq:1000000
Net: eth0: ethernet@46000000port@1
Press SPACE to abort autoboot in 2 seconds
board_name=[BBONEAI-64-B0-] ...
name_fdt=[k3-j721e-beagleboneai64.dtb] ...
i2c_write: error waiting for data ACK (status=0x116)
pca953x gpio@22: Error reading output register
switch to partitions #0, OK
mmc1 is current device
Scanning mmc 1:1...
libfdt fdt_check_header(): FDT_ERR_BADMAGIC
Scanning disk sdhci@4f80000.blk...
Scanning disk sdhci@4fb0000.blk...
Found 6 disks
No EFI system partition
BootOrder not defined
EFI boot manager: Cannot load any image
Found EFI removable media binary efi/boot/bootaa64.efi
729088 bytes read in 40 ms (17.4 MiB/s)
Booting /efi\boot\bootaa64.efi
Welcome to GRUB!
error: no such device: ((hd0,msdos1)/efi/boot)/EFI/BOOT/grub.cfg.
error: serial port `com0' isn't found.
GNU GRUB version 2.06
│*boot │
Use the ▲ and ▼ keys to select which entry is highlighted.
Press enter to boot the selected OS, `e' to edit the commands
before booting or `c' for a command-line.
The highlighted entry will be executed automatically in 0s.
Booting `boot'
EFI stub: Booting Linux Kernel...
EFI stub: EFI_RNG_PROTOCOL unavailable
EFI stub: ERROR: FIRMWARE BUG: kernel image not aligned on 64k boundary
EFI stub: Using DTB from configuration table
EFI stub: Exiting boot services...
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080]
[ 0.000000] Linux version 6.1.46+ (oe-user@oe-host) (aarch64-poky-linux-gcc (GCC) 12.3.0, GNU ld (GNU Binutils) 2.40.0.20230703) #1 SMP PREEMPT_DYNAMIC Tue Oct 17 19:11:40 UTC 2023
[ 0.000000] Machine model: Texas Instruments K3 J721E SoC
[ 0.000000] efi: EFI v2.80 by Das U-Boot
[ 0.000000] efi: RTPROP=0xfcebf040 SMBIOS=0xfcebb000 MEMRESERVE=0xdca80040
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a0000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-memory@a0100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a1000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-memory@a1100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a2000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-memory@a2100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a3000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a3000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a3100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-memory@a3100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a4000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-memory@a4100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a5000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a5000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a5100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-memory@a5100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node c66-dma-memory@a6000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node c66-memory@a6100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node c66-dma-memory@a7000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node c66-memory@a7100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node c71-dma-memory@a8000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a8100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node c71-memory@a8100000, compatible id shared-dma-pool
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal [mem 0x0000000100000000-0x00000008ffffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x000000009e7fffff]
[ 0.000000] node 0: [mem 0x000000009e800000-0x00000000a8ffffff]
[ 0.000000] node 0: [mem 0x00000000a9000000-0x00000000a9ffffff]
[ 0.000000] node 0: [mem 0x00000000aa000000-0x00000000abbfffff]
[ 0.000000] node 0: [mem 0x00000000abc00000-0x00000000fcdfcfff]
[ 0.000000] node 0: [mem 0x00000000fcdfd000-0x00000000fcdfefff]
[ 0.000000] node 0: [mem 0x00000000fcdff000-0x00000000fceb2fff]
[ 0.000000] node 0: [mem 0x00000000fceb3000-0x00000000fceb9fff]
[ 0.000000] node 0: [mem 0x00000000fceba000-0x00000000fcebafff]
[ 0.000000] node 0: [mem 0x00000000fcebb000-0x00000000fcebbfff]
[ 0.000000] node 0: [mem 0x00000000fcebc000-0x00000000fcebdfff]
[ 0.000000] node 0: [mem 0x00000000fcebe000-0x00000000fcec1fff]
[ 0.000000] node 0: [mem 0x00000000fcec2000-0x00000000fcec2fff]
[ 0.000000] node 0: [mem 0x00000000fcec3000-0x00000000fcec7fff]
[ 0.000000] node 0: [mem 0x00000000fcec8000-0x00000000fcec8fff]
[ 0.000000] node 0: [mem 0x00000000fcec9000-0x00000000fcec9fff]
[ 0.000000] node 0: [mem 0x00000000fceca000-0x00000000fcecbfff]
[ 0.000000] node 0: [mem 0x00000000fcecc000-0x00000000fcecdfff]
[ 0.000000] node 0: [mem 0x00000000fcece000-0x00000000fcecefff]
[ 0.000000] node 0: [mem 0x00000000fcecf000-0x00000000fcecffff]
[ 0.000000] node 0: [mem 0x00000000fced0000-0x00000000fced1fff]
[ 0.000000] node 0: [mem 0x00000000fced2000-0x00000000fced2fff]
[ 0.000000] node 0: [mem 0x00000000fced3000-0x00000000ffefffff]
[ 0.000000] node 0: [mem 0x00000000fff00000-0x00000000fff0ffff]
[ 0.000000] node 0: [mem 0x00000000fff10000-0x00000000ffffffff]
[ 0.000000] node 0: [mem 0x0000000880000000-0x00000008ffffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000008ffffffff]
[ 0.000000] cma: Reserved 144 MiB at 0x00000000f3c00000
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.2
[ 0.000000] percpu: Embedded 29 pages/cpu s81768 r8192 d28824 u118784
[ 0.000000] Detected PIPT I-cache on CPU0
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: detected: Spectre-v3a
[ 0.000000] CPU features: detected: Spectre-BHB
[ 0.000000] CPU features: kernel page table isolation forced ON by KASLR
[ 0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[ 0.000000] CPU features: detected: ARM erratum 1742098
[ 0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[ 0.000000] alternatives: applying boot alternatives
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1032192
[ 0.000000] Kernel command line: BOOT_IMAGE=/Image root=PARTUUID=076c4a2a-02 rootwait rootfstype=ext4
[ 0.000000] Unknown kernel command line parameters "BOOT_IMAGE=/Image", will be passed to user space.
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.000000] mem auto-init: stack:all(zero), heap alloc:on, heap free:off
[ 0.000000] software IO TLB: area num 2.
[ 0.000000] software IO TLB: mapped [mem 0x00000000efc00000-0x00000000f3c00000] (64MB)
[ 0.000000] Memory: 1780228K/4194304K available (18048K kernel code, 2884K rwdata, 5464K rodata, 6080K init, 1158K bss, 381528K reserved, 147456K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] ftrace: allocating 56039 entries in 219 pages
[ 0.000000] ftrace: allocated 219 pages with 6 groups
[ 0.000000] trace event string verifier disabled
[ 0.000000] Dynamic Preempt: voluntary
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Rude variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 960 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] Root IRQ handler: gic_handle_irq
[ 0.000000] GICv3: GICv3 features: 16 PPIs
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000
[ 0.000000] ITS [mem 0x01820000-0x0182ffff]
[ 0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
[ 0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
[ 0.000000] ITS@0x0000000001820000: allocated 524288 Devices @880800000 (flat, esz 8, psz 64K, shr 0)
[ 0.000000] ITS: using cache flushing for cmd queue
[ 0.000000] GICv3: using LPI property table @0x00000008801f0000
[ 0.000000] GIC: using cache flushing for LPI property table
[ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000880200000
[ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[ 0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0x3ffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
[ 0.000000] sched_clock: 58 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
[ 0.000168] Console: colour dummy device 80x25
[ 0.000638] printk: console [tty0] enabled
[ 0.000665] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
[ 0.000677] pid_max: default: 32768 minimum: 301
[ 0.000792] LSM: Security Framework initializing
[ 0.000837] landlock: Up and running.
[ 0.000843] Yama: becoming mindful.
[ 0.000914] AppArmor: AppArmor initialized
[ 0.000923] TOMOYO Linux initialized
[ 0.000945] LSM support for eBPF active
[ 0.001030] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.001051] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.002244] cblist_init_generic: Setting adjustable number of callback queues.
[ 0.002261] cblist_init_generic: Setting shift to 1 and lim to 1.
[ 0.002330] cblist_init_generic: Setting adjustable number of callback queues.
[ 0.002338] cblist_init_generic: Setting shift to 1 and lim to 1.
[ 0.002395] cblist_init_generic: Setting adjustable number of callback queues.
[ 0.002403] cblist_init_generic: Setting shift to 1 and lim to 1.
[ 0.002535] rcu: Hierarchical SRCU implementation.
[ 0.002542] rcu: Max phase no-delay instances is 1000.
[ 0.003335] Platform MSI: msi-controller@1820000 domain created
[ 0.003488] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created
[ 0.003610] Remapping and enabling EFI services.
[ 0.003926] smp: Bringing up secondary CPUs ...
[ 0.004726] Detected PIPT I-cache on CPU1
[ 0.004795] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
[ 0.004808] GICv3: CPU1: using allocated LPI pending table @0x0000000880210000
[ 0.004841] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
[ 0.004940] smp: Brought up 1 node, 2 CPUs
[ 0.004965] SMP: Total of 2 processors activated.
[ 0.004971] CPU features: detected: 32-bit EL0 Support
[ 0.004976] CPU features: detected: 32-bit EL1 Support
[ 0.004982] CPU features: detected: CRC32 instructions
[ 0.005075] CPU: All CPU(s) started at EL2
[ 0.005092] alternatives: applying system-wide alternatives
[ 0.033647] node 0 deferred pages initialised in 28ms
[ 0.034466] devtmpfs: initialized
[ 0.041369] Registered cp15_barrier emulation handler
[ 0.041399] Registered setend emulation handler
[ 0.041580] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.041603] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
[ 0.043945] pinctrl core: initialized pinctrl subsystem
[ 0.044443] SMBIOS 3.0 present.
[ 0.044455] DMI: /, BIOS 2021.01-gea96725b 02/16/2023
[ 0.044852] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.045751] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
[ 0.045945] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.046207] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.046251] audit: initializing netlink subsys (disabled)
[ 0.046431] audit: type=2000 audit(0.044:1): state=initialized audit_enabled=0 res=1
[ 0.046741] thermal_sys: Registered thermal governor 'fair_share'
[ 0.046746] thermal_sys: Registered thermal governor 'bang_bang'
[ 0.046753] thermal_sys: Registered thermal governor 'step_wise'
[ 0.046758] thermal_sys: Registered thermal governor 'user_space'
[ 0.046764] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.046914] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.046960] ASID allocator initialised with 32768 entries
[ 0.062098] KASLR enabled
[ 0.066707] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.066724] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
[ 0.066730] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
[ 0.066735] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
[ 0.066741] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.066746] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
[ 0.066752] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
[ 0.066757] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
[ 0.067668] raid6: skipped pq benchmark and selected neonx8
[ 0.067681] raid6: using neon recovery algorithm
[ 0.068278] k3-chipinfo 43000014.chipid: Family:J721E rev:SR2.0 JTAGID[0x1bb6402f] Detected
[ 0.069388] iommu: Default domain type: Translated
[ 0.069400] iommu: DMA domain TLB invalidation policy: strict mode
[ 0.069712] SCSI subsystem initialized
[ 0.069937] usbcore: registered new interface driver usbfs
[ 0.069966] usbcore: registered new interface driver hub
[ 0.069984] usbcore: registered new device driver usb
[ 0.070297] pps_core: LinuxPPS API ver. 1 registered
[ 0.070303] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.070314] PTP clock support registered
[ 0.070488] Registered efivars operations
[ 0.071207] NetLabel: Initializing
[ 0.071216] NetLabel: domain hash size = 128
[ 0.071221] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[ 0.071254] NetLabel: unlabeled traffic allowed by default
[ 0.071435] vgaarb: loaded
[ 0.391602] clocksource: Switched to clocksource arch_sys_counter
[ 0.392020] VFS: Disk quotas dquot_6.6.0
[ 0.392063] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.392185] FS-Cache: Loaded
[ 0.392537] CacheFiles: Loaded
[ 0.392936] AppArmor: AppArmor Filesystem Enabled
[ 0.397043] NET: Registered PF_INET protocol family
[ 0.397242] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.399106] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
[ 0.399194] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.399252] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.399527] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes, linear)
[ 0.400563] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.400848] MPTCP token hash table entries: 4096 (order: 4, 98304 bytes, linear)
[ 0.400981] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
[ 0.401043] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
[ 0.401217] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.402542] RPC: Registered named UNIX socket transport module.
[ 0.402558] RPC: Registered udp transport module.
[ 0.402563] RPC: Registered tcp transport module.
[ 0.402569] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.402580] NET: Registered PF_XDP protocol family
[ 0.402593] PCI: CLS 0 bytes, default 64
[ 0.408038] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.408528] kvm [1]: IPA Size Limit: 44 bits
[ 0.409130] kvm [1]: GICv3: no GICV resource entry
[ 0.409139] kvm [1]: disabling GICv2 emulation
[ 0.409158] kvm [1]: GIC system register CPU interface enabled
[ 0.409230] kvm [1]: vgic interrupt IRQ9
[ 0.409289] kvm [1]: Hyp mode initialized successfully
[ 0.463312] Initialise system trusted keyrings
[ 0.463558] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[ 0.466775] zbud: loaded
[ 0.468477] NFS: Registering the id_resolver key type
[ 0.468517] Key type id_resolver registered
[ 0.468523] Key type id_legacy registered
[ 0.468575] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.468584] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 0.468693] fuse: init (API version 7.37)
[ 0.489549] NET: Registered PF_ALG protocol family
[ 0.489579] xor: measuring software checksum speed
[ 0.490674] 8regs : 9081 MB/sec
[ 0.491695] 32regs : 9723 MB/sec
[ 0.493201] arm64_neon : 6573 MB/sec
[ 0.493205] xor: using function: 32regs (9723 MB/sec)
[ 0.493217] Key type asymmetric registered
[ 0.493224] Asymmetric key parser 'x509' registered
[ 0.494025] alg: self-tests for CTR-KDF (hmac(sha256)) passed
[ 0.494115] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[ 0.494216] io scheduler mq-deadline registered
[ 0.496545] pinctrl-single 4301c000.pinctrl: 94 pins, size 376
[ 0.496888] pinctrl-single 11c000.pinctrl: 173 pins, size 692
[ 0.500977] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
[ 0.503309] arm-smmu-v3 36600000.iommu: ias 48-bit, oas 48-bit (features 0x00001faf)
[ 0.503922] arm-smmu-v3 36600000.iommu: allocated 65536 entries for cmdq
[ 0.504187] arm-smmu-v3 36600000.iommu: allocated 32768 entries for evtq
[ 0.505175] arm-smmu-v3 36600000.iommu: msi_domain absent - falling back to wired irqs
[ 0.506854] SPI driver tps6594 has no spi_device_id for ti,tps6594-q1
[ 0.506867] SPI driver tps6594 has no spi_device_id for ti,tps6593-q1
[ 0.506873] SPI driver tps6594 has no spi_device_id for ti,lp8764-q1
[ 0.507257] megasas: 07.719.03.00-rc1
[ 0.510466] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[ 0.510486] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 0.510518] sky2: driver version 1.30
[ 0.511224] VFIO - User Level meta-driver version: 0.3
[ 0.513005] i2c_dev: i2c /dev entries driver
[ 0.513206] Driver for 1-wire Dallas network protocol.
[ 0.514392] sdhci: Secure Digital Host Controller Interface driver
[ 0.514398] sdhci: Copyright(c) Pierre Ossman
[ 0.514613] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.515574] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.515957] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[ 0.516066] omap_timer 40400000.timer: error -ENXIO: IRQ index 0 not found
[ 0.516191] hid: raw HID events driver (C) Jiri Kosina
[ 0.516410] usbcore: registered new interface driver usbhid
[ 0.516418] usbhid: USB HID core driver
[ 0.517351] optee: probing for conduit method.
[ 0.517373] optee: revision 3.12 (cac3fef2)
[ 0.517635] optee: initialized driver
[ 0.518698] NET: Registered PF_INET6 protocol family
[ 0.520162] Segment Routing with IPv6
[ 0.520208] In-situ OAM (IOAM) with IPv6
[ 0.520264] mip6: Mobile IPv6
[ 0.520280] NET: Registered PF_PACKET protocol family
[ 0.520412] Key type dns_resolver registered
[ 0.520420] mpls_gso: MPLS GSO support
[ 0.520802] registered taskstats version 1
[ 0.520824] Loading compiled-in X.509 certificates
[ 0.521247] zswap: loaded using pool lzo/zbud
[ 0.521604] Key type .fscrypt registered
[ 0.521612] Key type fscrypt-provisioning registered
[ 0.522982] Btrfs loaded, crc32c=crc32c-generic, zoned=yes, fsverity=yes
[ 0.523220] Key type encrypted registered
[ 0.523233] AppArmor: AppArmor sha1 policy hashing enabled
[ 0.523298] ima: secureboot mode disabled
[ 0.523311] ima: No TPM chip found, activating TPM-bypass!
[ 0.523327] ima: Allocated hash algorithm: sha256
[ 0.523355] ima: No architecture policies found
[ 0.523408] evm: Initialising EVM extended attributes:
[ 0.523414] evm: security.selinux
[ 0.523419] evm: security.SMACK64 (disabled)
[ 0.523424] evm: security.SMACK64EXEC (disabled)
[ 0.523428] evm: security.SMACK64TRANSMUTE (disabled)
[ 0.523433] evm: security.SMACK64MMAP (disabled)
[ 0.523437] evm: security.apparmor
[ 0.523441] evm: security.ima
[ 0.523445] evm: security.capability
[ 0.523449] evm: HMAC attrs: 0x1
[ 0.532378] ti-sci 44083000.dmsc: ABI: 3.1 (firmware rev 0x0015 '21.9.1--v2021.09a (Terrific Lla')
[ 0.574856] omap_i2c 40b00000.i2c: bus 1 rev0.12 at 100 kHz
[ 0.575404] omap_i2c 40b10000.i2c: bus 2 rev0.12 at 100 kHz
[ 0.575949] omap_i2c 42120000.i2c: bus 0 rev0.12 at 100 kHz
[ 0.576677] pca953x 3-0020: supply vcc not found, using dummy regulator
[ 0.576759] pca953x 3-0020: using no AI
[ 0.599648] pca953x 3-0020: failed writing register
[ 0.599728] pca953x: probe of 3-0020 failed with error -121
[ 0.599974] pca953x 3-0022: supply vcc not found, using dummy regulator
[ 0.600046] pca953x 3-0022: using AI
[ 0.600114] pca953x 3-0022: failed writing register
[ 0.600176] pca953x: probe of 3-0022 failed with error -121
[ 0.600266] omap_i2c 2000000.i2c: bus 3 rev0.12 at 400 kHz
[ 0.601027] omap_i2c 2010000.i2c: bus 4 rev0.12 at 400 kHz
[ 0.601617] omap_i2c 2020000.i2c: bus 5 rev0.12 at 100 kHz
[ 0.602265] pca953x 6-0020: supply vcc not found, using dummy regulator
[ 0.602339] pca953x 6-0020: using no AI
[ 0.623649] pca953x 6-0020: failed writing register
[ 0.623751] pca953x: probe of 6-0020 failed with error -121
[ 0.624106] omap_i2c 2030000.i2c: bus 6 rev0.12 at 400 kHz
[ 0.624826] omap_i2c 2040000.i2c: bus 7 rev0.12 at 100 kHz
[ 0.625343] omap_i2c 2050000.i2c: bus 8 rev0.12 at 100 kHz
[ 0.625972] pca953x 9-0020: supply vcc not found, using dummy regulator
[ 0.626049] pca953x 9-0020: using no AI
[ 0.647652] pca953x 9-0020: failed writing register
[ 0.647753] pca953x: probe of 9-0020 failed with error -121
[ 0.647871] omap_i2c 2060000.i2c: bus 9 rev0.12 at 400 kHz
[ 0.648161] ti-sci-intr bus@100000:bus@28380000:interrupt-controller2: Interrupt Router 137 domain created
[ 0.648302] ti-sci-intr bus@100000:interrupt-controller0: Interrupt Router 131 domain created
[ 0.648435] ti-sci-intr bus@100000:main-navss:interrupt-controller1: Interrupt Router 213 domain created
[ 0.648653] ti-sci-inta 33d00000.interrupt-controller: Interrupt Aggregator domain 209 created
[ 0.657115] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:235
[ 0.657139] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
[ 0.657146] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66346100, num_proxies:64
[ 0.659407] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[440,150] sci-dev-id:211
[ 0.659427] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
[ 0.659433] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66346100, num_proxies:64
[ 0.660098] 40a00000.serial: ttyS1 at MMIO 0x40a00000 (irq = 198, base_baud = 6000000) is a 8250
[ 0.660749] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 199, base_baud = 3000000) is a 8250
[ 2.820899] printk: console [ttyS2] enabled
[ 2.825841] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 200, base_baud = 3000000) is a 8250
[ 2.835066] 2820000.serial: ttyS4 at MMIO 0x2820000 (irq = 201, base_baud = 3000000) is a 8250
[ 2.844279] 2840000.serial: ttyS6 at MMIO 0x2840000 (irq = 202, base_baud = 3000000) is a 8250
[ 2.853689] davinci_mdio 46000000.ethernet:mdio@f00: Configuring MDIO in manual mode
[ 2.861442] davinci_mdio: probe of 46000000.ethernet:mdio@f00 failed with error -22
[ 2.869168] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000
[ 2.881989] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
[ 2.889201] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
[ 2.895650] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:0
[ 2.906207] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010a, freq:200000000, add_val:4 pps:0
[ 2.915400] mmc0: CQHCI version 5.10
[ 2.915712] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vdd-hba-supply regulator, assuming enabled
[ 2.929506] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vcc-supply regulator, assuming enabled
[ 2.939667] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq-supply regulator, assuming enabled
[ 2.949911] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq2-supply regulator, assuming enabled
[ 2.955608] mmc0: SDHCI controller on 4f80000.sdhci [4f80000.sdhci] using ADMA 64-bit
[ 2.969070] scsi host0: ufshcd
[ 2.981307] pca953x 4-0020: supply vcc not found, using dummy regulator
[ 2.988021] pca953x 4-0020: using no AI
[ 3.015650] pca953x 4-0020: failed writing register
[ 3.020633] pca953x: probe of 4-0020 failed with error -121
[ 3.026278] mmc0: Command Queue Engine enabled
[ 3.030733] mmc0: new HS200 MMC card at address 0001
[ 3.030789] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc7100
[ 3.036162] mmcblk0: mmc0:0001 TB2916 14.6 GiB
[ 3.046813] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc7100
[ 3.048203] mmcblk0: p1 p2
[ 3.056223] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fc7100
[ 3.056537] mmcblk0boot0: mmc0:0001 TB2916 4.00 MiB
[ 3.067794] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fc7100
[ 3.068476] mmcblk0boot1: mmc0:0001 TB2916 4.00 MiB
[ 3.079347] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fc7100
[ 3.080023] mmcblk0rpmb: mmc0:0001 TB2916 4.00 MiB, chardev (237:0)
[ 3.095573] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: 8)
[ 3.107186] ti-udma 31150000.dma-controller: Channels: 122 (tchan: 61, rchan: 61, gp-rflow: 16)
[ 3.120200] davinci_mdio 46000000.ethernet:mdio@f00: Configuring MDIO in manual mode
[ 3.127964] davinci_mdio: probe of 46000000.ethernet:mdio@f00 failed with error -22
[ 3.135702] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000
[ 3.148537] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
[ 3.155751] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
[ 3.162193] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:0
[ 3.172755] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
[ 3.184525] debugfs: Directory 'pd:242' with parent 'pm_genpd' already present!
[ 3.191946] debugfs: Directory 'pd:241' with parent 'pm_genpd' already present!
[ 3.199267] debugfs: Directory 'pd:240' with parent 'pm_genpd' already present!
[ 3.206595] debugfs: Directory 'pd:239' with parent 'pm_genpd' already present!
[ 3.215048] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[ 3.383278] cdns-ufshcd 4e84000.ufs: link startup failed 1
[ 3.388775] cdns-ufshcd 4e84000.ufs: UFS Host state=0
[ 3.393819] cdns-ufshcd 4e84000.ufs: outstanding reqs=0x0 tasks=0x0
[ 3.400074] cdns-ufshcd 4e84000.ufs: saved_err=0x0, saved_uic_err=0x0
[ 3.406503] cdns-ufshcd 4e84000.ufs: Device power mode=1, UIC link state=0
[ 3.413365] cdns-ufshcd 4e84000.ufs: PM in progress=0, sys. suspended=0
[ 3.419966] cdns-ufshcd 4e84000.ufs: Auto BKOPS=0, Host self-block=0
[ 3.426307] cdns-ufshcd 4e84000.ufs: Clk gate=1
[ 3.430828] cdns-ufshcd 4e84000.ufs: last_hibern8_exit_tstamp at 0 us, hibern8_exit_cnt=0
[ 3.438991] cdns-ufshcd 4e84000.ufs: last intr at 3383268 us, last intr status=0x404
[ 3.446720] cdns-ufshcd 4e84000.ufs: error handling flags=0x0, req. abort count=0
[ 3.454192] cdns-ufshcd 4e84000.ufs: hba->ufs_version=0x210, Host capabilities=0x1587031f, caps=0x0
[ 3.463223] cdns-ufshcd 4e84000.ufs: quirks=0x0, dev. quirks=0x0
[ 3.469218] cdns-ufshcd 4e84000.ufs: clk: core_clk, rate: 250000000
[ 3.475473] cdns-ufshcd 4e84000.ufs: clk: phy_clk, rate: 19200000
[ 3.481555] cdns-ufshcd 4e84000.ufs: clk: ref_clk, rate: 19200000
[ 3.487651] host_regs: 00000000: 1587031f 00000000 00000210 00000000
[ 3.493997] host_regs: 00000010: 00000000 00000000 00000000 00000000
[ 3.500339] host_regs: 00000020: 00000000 00000470 00000000 00000000
[ 3.506680] host_regs: 00000030: 00000008 00000001 00000000 00000000
[ 3.513024] host_regs: 00000040: 00000000 00000000 00000000 00000000
[ 3.519365] host_regs: 00000050: 00000000 00000000 00000000 00000000
[ 3.525705] host_regs: 00000060: 00000000 00000000 00000000 00000000
[ 3.532047] host_regs: 00000070: 00000000 00000000 00000000 00000000
[ 3.538390] host_regs: 00000080: 00000000 00000000 00000000 00000000
[ 3.544730] host_regs: 00000090: 00000016 00000000 00000001 00000000
[ 3.551071] cdns-ufshcd 4e84000.ufs: No record of pa_err
[ 3.556372] cdns-ufshcd 4e84000.ufs: No record of dl_err
[ 3.561674] cdns-ufshcd 4e84000.ufs: No record of nl_err
[ 3.566976] cdns-ufshcd 4e84000.ufs: No record of tl_err
[ 3.572279] cdns-ufshcd 4e84000.ufs: No record of dme_err
[ 3.577666] cdns-ufshcd 4e84000.ufs: No record of auto_hibern8_err
[ 3.583834] cdns-ufshcd 4e84000.ufs: No record of fatal_err
[ 3.589394] cdns-ufshcd 4e84000.ufs: link_startup_fail[0] = 0x1 at 3383275 us
[ 3.596518] cdns-ufshcd 4e84000.ufs: link_startup_fail: total cnt=1
[ 3.602774] cdns-ufshcd 4e84000.ufs: No record of resume_fail
[ 3.608508] cdns-ufshcd 4e84000.ufs: No record of suspend_fail
[ 3.614330] cdns-ufshcd 4e84000.ufs: No record of dev_reset
[ 3.619890] cdns-ufshcd 4e84000.ufs: No record of host_reset
[ 3.625539] cdns-ufshcd 4e84000.ufs: No record of task_abort
[ 3.631519] Waiting for root device PARTUUID=076c4a2a-02...
[ 13.284149] platform 2900000.pcie: deferred probe pending
[ 13.289557] platform 2910000.pcie: deferred probe pending
[ 13.294946] platform 2920000.pcie: deferred probe pending
[ 13.300334] platform fixedregulator-sd: deferred probe pending
[ 13.306155] platform 4fb0000.sdhci: deferred probe pending
I am slowly getting the hang of it. The builds are working but my cables and connections may be a bit dated…
Anyway…thank you for reading. I am using mickledore for now and things are booting into an issue, then a initramfs, and then finally a Yocto distro.
Phew.
