I am trying to use LibGPIOd and gpiod.h in a file. Well, it works as expected, i.e. even better than before today when I tried w/ a newer image.
Anyway…
- Fixes
a. libgpiod doesnot
cause the pin to stay on/1/high when the file ends and has finished running. - Errors
a. libgpiod does stay in charge of the file which causes other uses to the gpio unavailable.
b. For instance, not using gpiod.h in a file descriptor like in normal sysfs entries as fd cannot be used once a file w/ gpiod.h has been used.
P.S. Is this something that has changed or is it just me? The concern I am having is that the lack of control once my program runs and then fails causes a gpio to halt or stay in a low state until reboot.
