Do applications using the libpruio library have to be compiled natively?
Can anyone here point to a guide to cross compile a Qt app using the libpruio library?
As a beginner, I need help getting getting started with this!
Thanks!
Thanks!
AFAIK there is no such a guide.
I’m not a cross-compiling expert. But it should be possible to install libpruio in the cross-compiler environment. The compiler needs the header files in the include directory and the linker needs the binary in the lib directory.
Anyway, since libpruio is a hardware driver for AM335x CPU the testing have to be done natively.
Regards
