libusb and Makefiles and Understandings...
#include <iostream>
#include <libusb-1.0/libusb.h>
#include "protocol.h"
using namespace std;
bool deviceMatchesVendorProduct(libusb_device *device, unsigned short idVendor, unsigned short idProduct)
    libusb_device_descriptor desc;
    libusb_get_device_descriptor(device, &desc);
    return idVendor == desc.idVendor && idProduct == desc.idProduct;
void setTarget(int position, int servo)
    const unsigned short vendorId = 0x1ffb;
    unsigned short productIDArray[]={0x0089, 0x008a, 0x008b, 0x008c};
    libusb_context *ctx=0;
    libusb_device **device_list=0;
    libusb_init(&ctx);
    int count=libusb_get_device_list(ctx, &device_list);
    for(int i=0;i<count;i++)
        libusb_device *device=device_list[i];
            for(int Id=0;Id<4;Id++)
                if(deviceMatchesVendorProduct(device, vendorId, productIDArray[Id]))
                    libusb_device_handle *device_handle;
                    libusb_open(device, &device_handle);
                    libusb_control_transfer(device_handle, 0x40, REQUEST_SET_TARGET, position*4, servo, 0, 0, (ushort)5000);
                    libusb_close(device_handle);
                    break;
    libusb_free_device_list(device_list, 0);
    libusb_exit(ctx);
int main()
    while(1)
        int position;
        int servo=0;
        cout << "Enter position: ";
        cin >> position;
        setTarget(position, servo);
    return 0;
:~/Maestro/maestro$ cat protocol.h
/* This C header file that defines the constants needed to communicate with the
   Maestro via USB, USB serial, or TTL serial.
   Most of the information here is also in Usc_protocol.cs.
   This file can be included directly in C/C++ programs or used
   as a reference when writing programs in other languages.
// Serial commands, sent on the virtual serial port or over TTL Serial.
// See the user's guide at http://www.pololu.com/docs/0J40 for more info.
enum uscCommand
    COMMAND_SET_TARGET = 0x84, // 3 data bytes
    COMMAND_SET_SPEED = 0x87, // 3 data bytes
    COMMAND_SET_ACCELERATION = 0x89, // 3 data bytes
    COMMAND_GET_POSITION = 0x90, // 0 data
    COMMAND_GET_MOVING_STATE = 0x93, // 0 data
    COMMAND_GET_ERRORS = 0xA1, // 0 data
    COMMAND_GO_HOME = 0xA2, // 0 data
    COMMAND_STOP_SCRIPT = 0xA4, // 0 data
    COMMAND_RESTART_SCRIPT_AT_SUBROUTINE                = 0xA7, // 1 data bytes
    COMMAND_RESTART_SCRIPT_AT_SUBROUTINE_WITH_PARAMETER = 0xA8, // 3 data bytes
    COMMAND_GET_SCRIPT_STATUS = 0xAE, // 0 data
    COMMAND_MINI_SSC = 0xFF, // (2 data bytes)
// These are the values to put in to bRequest when making a setup packet
// for a control transfer to the Maestro.  See the comments and code in Usc.cs
// for more information about what these requests do and the format of the
// setup packet.
enum uscRequest
    REQUEST_GET_PARAMETER = 0x81,
    REQUEST_SET_PARAMETER = 0x82,
    REQUEST_GET_VARIABLES = 0x83,
    REQUEST_SET_SERVO_VARIABLE = 0x84, // (also clears the serial timeout timer)
    REQUEST_SET_TARGET = 0x85,   // (also clears the serial timeout timer)
    REQUEST_CLEAR_ERRORS = 0x86, // (also clears the serial timeout timer)
    REQUEST_REINITIALIZE = 0x90,
    REQUEST_ERASE_SCRIPT = 0xA0,
    REQUEST_WRITE_SCRIPT = 0xA1,
    REQUEST_SET_SCRIPT_DONE = 0xA2, // value.low.b is 0 for go, 1 for stop, 2 for single-step
    REQUEST_RESTART_SCRIPT_AT_SUBROUTINE = 0xA3,
    REQUEST_RESTART_SCRIPT_AT_SUBROUTINE_WITH_PARAMETER = 0xA4,
    REQUEST_RESTART_SCRIPT = 0xA5,
    REQUEST_START_BOOTLOADER = 0xFF
// These are the bytes used to refer to the different parameters
// in REQUEST_GET_PARAMETER and REQUEST_SET_PARAMETER.  After changing
// any parameter marked as an "Init parameter", you must do REQUEST_REINITIALIZE
// before the new value will be used.
enum uscParameter
    PARAMETER_SERVOS_AVAILABLE                  = 1, // 1 byte - 0-5.  Init parameter.
    PARAMETER_SERVO_PERIOD                      = 2, // 1 byte - instruction cycles allocated to each servo/256, (units of 21.3333 us).  Init parameter.
    PARAMETER_SERIAL_MODE                       = 3, // 1 byte unsigned value.  Valid values are SERIAL_MODE_*.  Init parameter.
    PARAMETER_SERIAL_FIXED_BAUD_RATE            = 4, // 2-byte unsigned value; 0 means autodetect.  Init parameter.
    PARAMETER_SERIAL_TIMEOUT                    = 6, // 2-byte unsigned value (units of 10ms)
    PARAMETER_SERIAL_ENABLE_CRC                 = 8, // 1 byte boolean value
    PARAMETER_SERIAL_NEVER_SUSPEND              = 9, // 1 byte boolean value
    PARAMETER_SERIAL_DEVICE_NUMBER              = 10, // 1 byte unsigned value, 0-127
    PARAMETER_SERIAL_BAUD_DETECT_TYPE           = 11, // 1 byte - reserved
    PARAMETER_IO_MASK_A                         = 12, // 1 byte - reserved, init parameter
    PARAMETER_OUTPUT_MASK_A                     = 13, // 1 byte - reserved, init parameter
    PARAMETER_IO_MASK_B                         = 14, // 1 byte - reserved, init parameter
    PARAMETER_OUTPUT_MASK_B                     = 15, // 1 byte - reserved, init parameter
    PARAMETER_IO_MASK_C                         = 16, // 1 byte - pins used for I/O instead of servo, init parameter
    PARAMETER_OUTPUT_MASK_C                     = 17, // 1 byte - outputs that are enabled, init parameter
    PARAMETER_IO_MASK_D                         = 18, // 1 byte - reserved, init parameter
    PARAMETER_OUTPUT_MASK_D                     = 19, // 1 byte - reserved, init parameter
    PARAMETER_IO_MASK_E                         = 20, // 1 byte - reserved, init parameter
    PARAMETER_OUTPUT_MASK_E                     = 21, // 1 byte - reserved, init parameter
    PARAMETER_SCRIPT_CRC                        = 22, // 2 byte CRC of script
    PARAMETER_SCRIPT_DONE                       = 24, // 1 byte - if 0, run the bytecode on restart, if 1, stop
    PARAMETER_SERIAL_MINI_SSC_OFFSET            = 25, // 1 byte (0-254)
    PARAMETER_SERVO0_HOME                       = 30, // 2 byte home position (0=off; 1=ignore)
    PARAMETER_SERVO0_MIN                        = 32, // 1 byte min allowed value (x2^6)
    PARAMETER_SERVO0_MAX                        = 33, // 1 byte max allowed value (x2^6)
    PARAMETER_SERVO0_NEUTRAL                    = 34, // 2 byte neutral position
    PARAMETER_SERVO0_RANGE                      = 36, // 1 byte range
    PARAMETER_SERVO0_SPEED                      = 37, // 1 byte (5 mantissa,3 exponent) us per 10ms.  Init parameter.
    PARAMETER_SERVO0_ACCELERATION               = 38, // 1 byte (speed changes that much every 10ms). Init parameter.
    PARAMETER_SERVO1_HOME                       = 39,
    // The pattern continues.  Each servo takes 9 bytes of configuration space.
struct servoSetting
    int position;
    int target;
    unsigned int speed;
    unsigned int acceleration;
/* uscVariables: This struct stores all the variables that can be read via
   REQUEST_GET_VARIABLES.
   There are 12 bytes used per servo setting
struct uscVariables
    // Fix bytecode_asm.asm if you change the order or size of
    // variables in this struct.
    // offset: 0
    unsigned int stackPointer;
    // offset: 1
    unsigned int callStackPointer;
    // offset: 2
     unsigned int errors;
    // offset: 4
     unsigned int programCounter;
    // offset: 6
    int buffer[3]; // protects other RAM from being corrupted by improper instructions
    // offset: 12
    int stack[32];
    // offset: 76
unsigned int callStack[10];
    // offset: 96
    unsigned int scriptDone; // 1 = done; 2 = about to run a single step then be done - placed here to protect against accidental overwriting of Setting
    // offset: 97
    unsigned int buffer2; // protects other RAM from being corrupted by improper instructions
    // offset: 98
    struct servoSetting servoSetting[6];
}; // total length 139 bytes
#define BAUD_DETECT_TYPE_AA 0u
#define BAUD_DETECT_TYPE_FF 1u
// serialMode: Value of PARAMETER_SERIAL_MODE.
enum serialMode
    // On the Command Port, user can send commands and receive responses.
    // TTL port/UART are connected to make a USB-to-serial adapter.
    SERIAL_MODE_USB_DUAL_PORT = 0u,
    // On the Command Port, user can send commands to UMC01 and
    // simultaneously transmit bytes on the UART TX line, and user
    // can receive bytes from the UMC01 and the UART RX line.
    // COM2 does not do anything.
    SERIAL_MODE_USB_CHAINED = 1u,
    // On the UART, user can send commands and receive reponses.
    // Command Port and TTL Port don't do anything.
    SERIAL_MODE_UART_DETECT_BAUD_RATE = 2u,
    SERIAL_MODE_UART_FIXED_BAUD_RATE = 3u,
// There are several different errors.  Each error is represented by a
// different bit number from 0 to 15.
#define ERROR_SERIAL_SIGNAL            0
#define ERROR_SERIAL_OVERRUN           1
#define ERROR_SERIAL_BUFFER_FULL       2
#define ERROR_SERIAL_CRC               3
#define ERROR_SERIAL_PROTOCOL          4
#define ERROR_SERIAL_TIMEOUT           5
#define ERROR_SCRIPT_STACK             6
#define ERROR_SCRIPT_CALL_STACK        7
#define ERROR_SCRIPT_PROGRAM_COUNTER   8
// Local Variables: **
// mode: C **
// c-basic-offset: 4 **
// tab-width: 4 **
// indent-tabs-mode: t **
// end: **
And A-Okay…
I got this to work with the /dev/ttyACM(N) device on the BeagleY-AI but…
  1. The servo listens to one command only.
    a. Can you see why it only listens to one command and then does nothing even the the while loop runs continuously?
  2. So, it tells me, Enter Position:
    b. I enter the position and blamo, no second chances.
Any ideas are welcomed here while I review ideas and come to conclusions.
Update
The source code takes negative numbers. Blah. No wonder I was goofing up…
P.S. That is from the Pololu Forums and I was using it to handle the Maestro Mini 18 from the BeagleY-AI port device /dev/ttyACM(N).
