I was trying to run LINKSYS Wireless-G USB Network Adapter with RangeBooster Model No. WUSB54GR on beagle board with ubuntu installed on it.
I get the following error:
ub_port_status failed (err = -32)
To access official Ubuntu documentation, please visit:or -110
hub_port_status failed (err = -32)
Cannot enable port 2. Maybe the USB cable is bad?
[ 606.181976] ehci-omap ehci-omap.0: port 2 reset error -110
[ 606.197509] hub 1-0:1.0: hub_port_status failed (err = -32)
[ 606.907531] usb 1-2: device not accepting address 6, error -71
[ 606.923767] hub 1-0:1.0: unable to enumerate USB device on port 2
How can i fix this problem
I was initially running LINKSYS Wireless-G USB Network Adapter Model No WUSB54G ver.4 and it ran fine.
Any help would be greatly appreciated
Like the error says... I'd try a different port on your hub and check
your cables. It doesn't like something about your setup... I've
found some kernels where more sensitive to this... Which are you
using.. 'uname -a'
Hi. First I would find out which chipset it uses. Since you already
uses a similar item before chances are the chipset is the same. I
usually do a lsusb on my linux pc and then google the ID.
Also - you should make sure that you power off the board completely
and try again. I have sometimes experienced that the reset button on
the board is not sufficient to remove problems.
Tallak
cmpe reg wrote:
I guess the kernel image is v2.6.31.6-x6.0/linux-image-2.6.31.6-x6.0_1.0karmic_armel.deb
loacated at:
http://rcn-ee.net/deb/kernel/beagle/karmic/v2.6.31.6-x6.0/linux-image-2.6.31.6-x6.0_1.0karmic_armel.deb
I checked the cables and they work fine with the other wifi adapter mentioned in the original post. So i guess the cables are good enough.
How should i try a different port on the hub.
Regards
I'm guessing it's just a single port hub, normally, i'd just move it
to one of the other ones and see if the error continues... I've had a
couple mostec ethernet devices report that same error shortly before
they never worked again on any arm/x86/etc machine...
What does lsusb return?
I would try a newer kernel. Such as:
http://www.rcn-ee.net/deb/kernel/beagle/karmic/v2.6.32.11-x12/
Hi
lsusb returns the following:
[ 248.628021] ehci-omap ehci-omap.0: port 2 reset error -110
[ 248.643951] hub 1-0:1.0: hub_port_status failed (err = -32)
[ 248.870208] ehci-omap ehci-omap.0: port 2 reset error -110
[ 248.885772] hub 1-0:1.0: hub_port_status failed (err = -32)
[ 249.112426] ehci-omap ehci-omap.0: port 2 reset error -110
[ 249.127838] hub 1-0:1.0: hub_port_status failed (err = -32)
[ 249.354644] ehci-omap ehci-omap.0: port 2 reset error -110
[ 249.370239] hub 1-0:1.0: hub_port_status failed (err = -32)
[ 249.596801] ehci-omap ehci-omap.0: port 2 reset error -110
[ 249.612213] hub 1-0:1.0: hub_port_status failed (err = -32)
[ 249.627716] hub 1-0:1.0: Cannot enable port 2. Maybe the USB cable is bad?
[ 249.706146] ehci-omap ehci-omap.0: port 2 reset error -110
[ 249.721557] hub 1-0:1.0: hub_port_status failed (err = -32)
[ 249.948364] ehci-omap ehci-omap.0: port 2 reset error -110
[ 249.963775] hub 1-0:1.0: hub_port_status failed (err = -32)
[ 250.190551] ehci-omap ehci-omap.0: port 2 reset error -110
[ 250.205932] hub 1-0:1.0: hub_port_status failed (err = -32)
[ 250.432739] ehci-omap ehci-omap.0: port 2 reset error -110
[ 250.448150] hub 1-0:1.0: hub_port_status failed (err = -32)
[ 250.674865] ehci-omap ehci-omap.0: port 2 reset error -110
[ 250.690246] hub 1-0:1.0: hub_port_status failed (err = -32)
[ 250.705810] hub 1-0:1.0: Cannot enable port 2. Maybe the USB cable is bad?
[ 250.784240] ehci-omap ehci-omap.0: port 2 reset error -110
[ 250.799774] hub 1-0:1.0: hub_port_status failed (err = -32)
[ 251.026458] ehci-omap ehci-omap.0: port 2 reset error -110
[ 251.041900] hub 1-0:1.0: hub_port_status failed (err = -32)
[ 251.268676] ehci-omap ehci-omap.0: port 2 reset error -110
[ 251.284057] hub 1-0:1.0: hub_port_status failed (err = -32)
[ 251.510864] ehci-omap ehci-omap.0: port 2 reset error -110
[ 251.526275] hub 1-0:1.0: hub_port_status failed (err = -32)
[ 251.753021] ehci-omap ehci-omap.0: port 2 reset error -110
[ 251.768432] hub 1-0:1.0: hub_port_status failed (err = -32)
[ 251.783935] hub 1-0:1.0: Cannot enable port 2. Maybe the USB cable is bad?
[ 251.862396] ehci-omap ehci-omap.0: port 2 reset error -110
[ 251.877838] hub 1-0:1.0: hub_port_status failed (err = -32)
[ 252.104614] ehci-omap ehci-omap.0: port 2 reset error -110
[ 252.119995] hub 1-0:1.0: hub_port_status failed (err = -32)
[ 252.346801] ehci-omap ehci-omap.0: port 2 reset error -110
[ 252.362182] hub 1-0:1.0: hub_port_status failed (err = -32)
[ 252.589019] ehci-omap ehci-omap.0: port 2 reset error -110
[ 252.604400] hub 1-0:1.0: hub_port_status failed (err = -32)
[ 252.831176] ehci-omap ehci-omap.0: port 2 reset error -110
[ 252.846649] hub 1-0:1.0: hub_port_status failed (err = -32)
[ 252.862243] hub 1-0:1.0: Cannot enable port 2. Maybe the USB cable is bad?
[ 252.880218] hub 1-0:1.0: unable to enumerate USB device on port 2
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Should i try the new kernel you suggested?
Should i try the new kernel?
Hi
Hi
Hi
Hi
Please don’t spam the list - I already have enough email as it is.
I am extremely sorry for the spam.
It was unintended.
The mailer deamon kept sending the message back from a recipient and my system kept sending it to the entire list again and again.
Thanks for the feed back.
