Hi all,
My first post here, did some searches but came up blank.
I’m trying to get D-Link DWA-160 wifi working with linux-4.0 on the old Beagleboard Rev-C
Many version back (do not recall which) this device worked.
I have listed all I can think of that may help, if I missed something please let me know.
Any help will be appreciated,
amf
D-Link
DWA-160
HW Ver B1
FW Ver 2.00
Ralink
driver: rt2870
rt2800lib.ko
RT chipset 2860, rev 0103 detected
07d1:3c11
/etc/wpa_supplicant
ctrl_interface=/var/run/wpa_supplicant
fast_reauth=1
ap_scan=1
eapol_version=1
network={
ssid=“router ssid”
psk=“passwd”
scan_ssid=0
proto=WPA RSN
key_mgmt=WPA-PSK WPA-EAP
pairwise=CCMP TKIP
group=CCMP TKIP
auth_alg=SHARED OPEN
also tried with
key_mgmt=NONE
and the router encryption turned off
/etc/networks/interfaces
auto lo
iface lo inet loopback
auto wlan0
iface wlan0 inet dhcp
last part of kernel booting
Starting network…
[ 3.566223] usb 2-2.3: new high-speed USB device number 3 using ehci-omap
ip: SIOCGIFFLAGS: No such device
[ 3.726135] usb 2-2.3: New USB device found, idVendor=07d1, idProduct=3c11
[ 3.733428] usb 2-2.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 3.741302] usb 2-2.3: Product: 802.11 n WLAN
[ 3.745941] usb 2-2.3: Manufacturer: Ralink
[ 3.750366] usb 2-2.3: SerialNumber: 1.0
ip: can’t find device ‘eth0’
script ran after drivers are loaded
wpa_supplicant -B -iwlan0 -c/etc/wpa_supplicant.conf -Dwext &&
dhcpcd wlan0
output on terminal after running script
Successfully initialized wpa_supplicant
[ 89.307525] ieee80211 phy0: rt2x00lib_request_firmware: Info - Loading firmware file ‘rt2870.bin’
[ 89.334045] ieee80211 phy0: rt2x00lib_request_firmware: Info - Firmware detected - version: 0.29
[ 89.920074] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
ioctl[SIOCSIWPMKSA]: Invalid argument
ioctl[SIOCSIWMODE]: Invalid argument
ioctl[SIOCGIWRANGE]: Invalid argument
ioctl[SIOCGIWMODE]: Invalid argument
ioctl[SIOCSIWAP]: Invalid argument
ioctl[SIOCSIWESSID]: Invalid argument
ioctl[SIOCSIWENCODEEXT]: Invalid argument
wlan0: adding address fe80::af1:9d76:7833:e833
wlan0: waiting for carrier
timed out
dhcpcd exited
# dmesg | tail
[ 14.738891] usbcore: registered new interface driver rtl8192cu
[ 15.126220] usb 2-2.3: reset high-speed USB device number 3 using ehci-omap
[ 15.258361] ieee80211 phy0: rt2x00_set_rt: Info - RT chipset 2860, rev 0103 detected
[ 15.322326] ieee80211 phy0: rt2x00_set_rf: Info - RF chipset 0002 detected
[ 15.377807] ieee80211 phy0: Selected rate control algorithm ‘minstrel_ht’
[ 15.384948] usbcore: registered new interface driver rt2800usb
[ 16.512756] ieee80211 phy0: rt2x00lib_request_firmware: Info - Loading firmware file ‘rt2870.bin’
[ 16.532989] ieee80211 phy0: rt2x00lib_request_firmware: Info - Firmware detected - version: 0.29
[ 17.119445] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 26.714233] random: nonblocking pool is initialized
# dhcpcd --version
dhcpcd 6.8.1
# lsmod
Module Size Used by Not tainted
arc4 1719 2
rt2800usb 15034 0
rt2x00usb 11492 1 rt2800usb
rt2800lib 76924 1 rt2800usb
rt2x00lib 45930 3 rt2800usb,rt2x00usb,rt2800lib
rtl8192cu 98537 0
rtl_usb 14724 1 rtl8192cu
rtl8192c_common 70336 1 rtl8192cu
rtlwifi 104207 3 rtl8192cu,rtl_usb,rtl8192c_common
mac80211 513955 6 rt2x00usb,rt2800lib,rt2x00lib,rtl8192cu,rtl_usb,rtlwifi
cfg80211 428348 3 rt2x00lib,rtlwifi,mac80211
