I am using the 3.8.13-bone24 kernel (in Ubuntu) and trying to add keyboard emulation using hid.c. According to other forums, I need to add the structs found @https://www.kernel.org/doc/Documentation/usb/gadget_hid.txt to hid.c, compile the modules, then insert the module using insmod or modprobe. I’ve done this (cross compiled on a x64 Mint15 host) ,but the problem I am having is that both insmod and modprobe error out with something like ‘error inserting module … no such device’ . I’ve ensured that the vermagic matches the kernel and have tried following several different examples of how to get this working. Unfortunately, I don’t think I have enough 'kernel knowledge" to pull together exactly what I need to do.
So, the basic question is: What are the steps to take to emulate a keyboard using the BeagleBone Black? I’m not locked into any particular OS or kernel version, I just need the Bone to act as a keyboard (although Ubuntu is preferred, simply due to familiarity). So, if any of you know how to do this in any other OS or kernel version, please do share.
