I am following this guide to install Linaro on my Ubuntu 18.04 machine:
https://www.digikey.com/eewiki/display/linuxonarm/BeagleBone+Black#BeagleBoneBlack-ARMCrossCompiler:GCC
Thanks to Robert’s help, I got Linaro 7.3.1 successfully installed. I am now stuck at building the Linux Kernel. I checked out the long term / real-time branch using:
And proceed to building it:
It failed to build, giving out these status report:
- Detected build host [Ubuntu 18.04.1 LTS]
- host: [x86_64]
- git HEAD commit: [3a7726562a52a27d7712b5eb4cbe4a2f31890ac6]
Installing:
Debian: Getting Started with the BeagleBone Black - Linux Guides - Electronic Component and Engineering Solution Forum - TechForum │ Digi-Key
Thanks to Robert's help, I got Linaro 7.3.1 successfully installed. I am now stuck at building the Linux Kernel. I checked out the long term / real-time branch using:
git checkout origin/am33x-rt-v4.9 -b tmp
./build_kernel.sh
+ Detected build host [Ubuntu 18.04.1 LTS]
+ host: [x86_64]
+ git HEAD commit: [3a7726562a52a27d7712b5eb4cbe4a2f31890ac6]
Installing:
--2018-08-30 15:32:01-- https://releases.linaro.org/components/toolchain/binaries/6.4-2018.05/arm-linux-gnueabihf/gcc-linaro-6.4.1-2018.05-x86_64_arm-linux-gnueabihf.tar.xz
Resolving releases.linaro.org (releases.linaro.org)... 13.228.101.204
Connecting to releases.linaro.org (releases.linaro.org)|13.228.101.204|:443... connected.
ERROR: no certificate subject alternative name matches
requested host name ‘releases.linaro.org’.
To connect to releases.linaro.org insecurely, use `--no-check-certificate'.
--2018-08-30 15:32:01-- https://releases.linaro.org/archive/components/toolchain/binaries/6.4-2018.05/arm-linux-gnueabihf/gcc-linaro-6.4.1-2018.05-x86_64_arm-linux-gnueabihf.tar.xz
So I got a few questions:
1. It installs Linaro 6.4.1 tho I already have 7.3.1. Why does this happen?
How does it know you have 7.3.1 installed?
2. What should I do to get it built?
Read system.sh
I did the first part and get Linaro 7.3.1 instead. Testing with ${CC}gcc succeeded, so I suppose that is the case. Am I doing it wrong?
That was for building u-boot... Currently the kernel build script does
not parse the environment variable CC.. I suppose it "could" with some
patches written, but today NOPE..
So if you want to bypass the pre-choosen compiler you need to open
"system.sh" and see the examples, then correctly add your's..
#ARM GCC CROSS Compiler:
#if CC is not set, a known working linaro based gcc compiler will be
downloaded and utilized.
#CC=<enter full path>/bin/arm-none-eabi-
#CC=<enter full path>/bin/arm-linux-gnueabi-
#CC=<enter full path>/bin/arm-linux-gnueabihf-
It has some error detection, so if you don't properly set the
path/etc, it will just default to the build-in version..
I edited system.sh to have the full link to Linaro 7.3.1. When building the kernel, there is a blue screen coming up. What should I do with it?
