Now I've tried it with the Knoppix live DVD and a new card.
/dev/sdb1 is a USB flash memory stick
/dev/sdc1 is the FAT32 partition with the boot files
/dev/sdc2 is the ext3 partition where I would like to untar the
Angstrom demo image to.
Here are the results:
knoppix@Knoppix:~$ sudo mkdir -p /tmp/disk1
knoppix@Knoppix:~$ sudo mount /dev/sdc2 /tmp/disk1
knoppix@Knoppix:~$ mount
rootfs on / type rootfs (rw)
/proc on /proc type proc (rw)
/sys on /sys type sysfs (rw)
/dev/hda on /cdrom type iso9660 (ro)
/dev/cloop on /KNOPPIX type iso9660 (ro)
/dev/cloop2 on /KNOPPIX2 type iso9660 (ro)
/ramdisk on /ramdisk type tmpfs (rw)
/UNIONFS on /UNIONFS type aufs (rw,xino=/ramdisk/.aufs.xino,br:/
ramdisk=rw:/KNOPPIX=rr:/KNOPPIX2=rr)
/proc/bus/usb on /proc/bus/usb type usbfs (rw)
/dev/pts on /dev/pts type devpts (rw)
/dev/sdb1 on /media/sdb1 type vfat
(ro,nosuid,nodev,uid=1000,gid=1000,fmask=0000,dmask=0000,codepage=cp437,iocharset=iso8859-1,shortname=winnt)
/dev/sdc2 on /ramdisk/tmp/disk1 type ext3 (rw,data=ordered)
knoppix@Knoppix:~$ sudo su
root@Knoppix:/ramdisk/home/knoppix# tar xpjf /media/sdb1/Angstrom-
Beagleboard-demo-image-glibc-ipk-2008.1-test-20080920-
beagleboard.rootfs.tar.bz2 -C /tmp/disk1/
And now come all the error lines. The last lines are:
tar: ./usr/lib/firefox-devel-3.1a2/sdk: Cannot change ownership to uid
0, gid 0: Read-only file system
tar: ./usr/lib/firefox-devel-3.1a2/sdk: Cannot change mode to rwxr-xr-
x: Read-only file system
tar: ./usr/lib/firefox-devel-3.1a2: Cannot utime: Read-only file
system
tar: ./usr/lib/firefox-devel-3.1a2: Cannot change ownership to uid 0,
tar: ./usr/lib/firefox-devel-3.1a2: Cannot change mode to rwxr-xr-x:
tar: ./usr/lib/X11: Cannot utime: Read-only file system
tar: ./usr/lib/X11: Cannot change ownership to uid 0, gid 0: Read-only
file system
tar: ./usr/lib/X11: Cannot change mode to rwxr-xr-x: Read-only file
system
tar: ./usr/lib: Cannot utime: Read-only file system
tar: ./usr/lib: Cannot change ownership to uid 0, gid 0: Read-only
file system
tar: ./usr/lib: Cannot change mode to rwxr-xr-x: Read-only file system
tar: ./usr: Cannot utime: Read-only file system
tar: ./usr: Cannot change ownership to uid 0, gid 0: Read-only file
system
tar: ./usr: Cannot change mode to rwxr-xr-x: Read-only file system
tar: .: Cannot utime: Read-only file system
tar: .: Cannot change ownership to uid 0, gid 0: Read-only file system
tar: .: Cannot change mode to rwxr-xr-x: Read-only file system
tar: Error exit delayed from previous errors
root@Knoppix:/ramdisk/home/knoppix# mount
/dev/sdc2 on /ramdisk/tmp/disk1 type ext3 (ro,data=ordered)
It shows that "rw" is changed into "ro".
Only 2 folders named "dev" and "usr" have been untarred to sdc2.
Mark
