I am designing an expansion board for the XM, I found several errors
in the manual "BeagleBoard-xM System Reference Manual Revision A3".
The external connector tables are miss-labeled in some places (.ex
table 26 is marked as P13 and should be P17.) In section "8.3.3 DC
Source Control" the signal "nUSB_POWER" is referenced. This signal
cannot be found in any of the connector tables. The schematic
indicates it's located on LCD expansion connector P13 pin 12. However,
the description in table 25 indicates this pin is not connected.
Figure 51 shows a signal "nUSB_DC_EN" on pin 25 of the main expansion
header. However, this signal is labeled "REGEN" in table 25 and on the
schematic. 1) Does anyone know if these discrepancies have been fixed
in any documentation? 2) Can I believe the schematic for P13 pin 12
being "nUSB_POWER"? 3) Does "nUSB_DC_EN" exist on the expansion
connector pin 25 and is its function the same as "nUSB_POWER"?
Tom
