In my project the serial connection is for an application-specific
use, so I cannot take the u-boot output from that port. I'd like to
redirect such log messages to the dvi-d port in order to see logs with
a dvi-d screen. Is it possibile? Otherwise, is there any other method
to acquire log messages without using the serial port?
Thanks in advance,
Daniele
Thanks in advance,
u-boot does not output to DVI. you cansetup a framebuffer console
for the kernel to get logs on the DVI.
but you can also use another serial port on the omap3, the BB
exposes it on the expansion connector, it's 1.8V so
just add a level shifter...
