Hi sir,
Here is my code for Face detection and its performance in Beagleboard.
#include <opencv2/objdetect/objdetect.hpp>
#include <opencv2/highgui/highgui.hpp>
#include <opencv2/imgproc/imgproc.hpp>
#include "cv.h"
//#include "highgui.h"
#include <iostream>
#include <stdio.h> // A Simple Camera Capture Framework
using namespace std;
using namespace cv;
int isColor = 1;
int frameW = 320;
int frameH = 240;
void detectAndDraw( Mat& img,
CascadeClassifier& cascade, CascadeClassifier&
nestedCascade,
double scale);
String cascadeName =
"../../data/haarcascades/haarcascade_frontalface_alt.xml";
String nestedCascadeName =
"../../data/haarcascades/haarcascade_eye_tree_eyeglasses.xml";
int main(int argc, const char** argv ) {
//CvCapture* capture = 0;
double scale = 1;
//CvCapture* capture = cvCaptureFromCAM(CV_CAP_ANY);
CvCapture* capture = cvCreateCameraCapture(-1);
Mat frame, frameCopy, image;
const String scaleOpt = "--scale=";
size_t scaleOptLen = scaleOpt.length();
const String cascadeOpt = "--cascade=";
size_t cascadeOptLen = cascadeOpt.length();
const String nestedCascadeOpt = "--nested-cascade";
size_t nestedCascadeOptLen = nestedCascadeOpt.length();
String inputName;
CascadeClassifier cascade, nestedCascade;
if( cascadeOpt.compare( 0, cascadeOptLen, argv[1], cascadeOptLen ) ==
0 )
cascadeName.assign( argv[1] + cascadeOptLen );
cout << " from which we have cascadeName= " <<
cascadeName << endl;
cascade.load( cascadeName );
if(!capture){
fprintf(stderr,":-).Cheerrrrrrrrrrrrrrrrrrrrr\n");
return -1;
IplImage *bgr_frame=cvQueryFrame(capture);//Init the video read
//double fps = cvGetCaptureProperty(&capture,CV_CAP_PROP_FPS);
CvSize size = cvSize((int)cvGetCaptureProperty( capture,
CV_CAP_PROP_FRAME_WIDTH),(int)cvGetCaptureProperty( capture,
CV_CAP_PROP_FRAME_HEIGHT) );
//CvVideoWriter *writer =
cvCreateVideoWriter("out.avi",CV_FOURCC('D', 'I', 'V', 'X'),15, size,
isColor);
cvCreateVideoWriter("out.avi",CV_FOURCC('I','Y','U','V'),
15,size,isColor);
//CvVideoWriter *writer = cvCreateVideoWriter("out.avi",CV_FOURCC('U',
'2', '6', '3'),5,size,isColor);
if (writer != NULL)
else fprintf(stderr,":-(\n");
// Create a window in which the captured images will be presented
//cvNamedWindow( "mywindow", CV_WINDOW_AUTOSIZE );
IplImage* logpolar_frame = cvCreateImage(size,IPL_DEPTH_8U,3);
while( (bgr_frame=cvQueryFrame(capture)) != NULL )
cvWriteFrame( writer, bgr_frame );
//cvShowImage( "mywindow", bgr_frame );
//cvFlip( bgr_frame, frameCopy, 0 );
frameCopy = bgr_frame;
detectAndDraw( frameCopy, cascade, nestedCascade, scale);
// Do not release the frame! //If ESC key pressed,
Key=0x10001B under OpenCV 0.9.7(linux version), //remove higher
bits using AND operator
if( (cvWaitKey(10) & 255) == 27 )
break;
cvReleaseVideoWriter( &writer );
//cvReleaseImage( &logpolar_frame );
cvReleaseCapture( &capture );
//cvDestroyWindow( "mywindow" );
return(0);
nestedCascade,
double scale)
int i = 0;
double t = 0;
vector<Rect> faces;
const static Scalar colors[] = { CV_RGB(0,0,255),
CV_RGB(0,128,255),
CV_RGB(0,255,255),
CV_RGB(0,255,0),
CV_RGB(255,128,0),
CV_RGB(255,255,0),
CV_RGB(255,0,0),
CV_RGB(255,0,255)} ;
Mat gray, smallImg( cvRound (img.rows/scale), cvRound(img.cols/
scale), CV_8UC1 );
cvtColor( img, gray, CV_BGR2GRAY );
resize( gray, smallImg, smallImg.size(), 0, 0, INTER_LINEAR );
equalizeHist( smallImg, smallImg );
t = (double)cvGetTickCount();
cascade.detectMultiScale( smallImg, faces,
1.1, 2, 0
