How much trouble can I get myself into by trying to teach myself how
to write a boot.scr file through trial and error?
I have done some Google-ing, so I have some guidance, but I am not
100% sure as to what everything in the file means or where certain
binary addresses and args come from.
Could I end up doing major damage to my board or SD card if my
boot.scr file is written wrong?
Thank you!
This is what I have come up with:
if fatload mmc 0 0x80200000 uImage
then
setenv bootargs ' console= ttyS2,115200n8 ${optargs} mpurate=720
buddy=zippy2 vram=12M omapfb.mode=dvi:1024x768MR-16@60
omapdss.def_disp=dvi root=/dev/mmcblk0p2 rw rootfstype=ext3 rootwait'
echo ***** stand-alone demo *****
fi
bootm 0x80200000
I got 0x80200000 from "loadaddr=0x80200000" of my printenv
I made my bootargs by following the output format I received from
printenv
The worst thing that could happen is that you erase the NAND, but you're loading things from SD card anyway.
Have a look at http://gitorious.org/angstrom/openembedded/trees/org.openembedded.dev/recipes/angstrom/angstrom-uboot-scripts to see some examples of bootscripts.
regards,
Koen
That can be much shorter:
setenv dvimode ''1024x768MR-16@60"
run loaduimage
run mmcboot
See [1] for a 720p example that also sets up ram for the overlays.
regards,
Koen
http://gitorious.org/angstrom/openembedded/blobs/org.openembedded.dev/recipes/angstrom/angstrom-uboot-scripts/720p.cmd
Perfect! I got it. Thank you for your help!
I used the format:
setenv dvimode 1024x768MR-16@60
run loaduimage
run mmcboot
And followed the instructions from http://beagleintern.blogspot.com/
